Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimImageGeometry Class Reference
Container class that holds both 2D transform and 3D projection information for an image Only one instance of this is alive per image. More...
#include <ossimImageGeometry.h>
Inheritance diagram for ossimImageGeometry:
ossimObject ossimReferenced
Public Types
typedef std::vector< ossim_float64DeltaParamList
 ossimImageGeometry ()
 Default constructor defaults to unity transform with no projection. More...
virtual ~ossimImageGeometry ()
 ossimImageGeometry (const ossimImageGeometry &copy_this)
 Copy constructor – performs a deep copy. More...
 ossimImageGeometry (ossim2dTo2dTransform *transform, ossimProjection *projection)
 Constructs with projection and transform objects available for referencing. More...
bool open (const ossimFilename &image)
 Shortcut way of getting to an image's geometry when access to pixels is not needed. More...
void rnToRn (const ossimDpt &inRnPt, ossim_uint32 inResolutionLevel, ossim_uint32 outResolutionLevel, ossimDpt &outRnPt) const
 rnToRn is a utility method that takes a rn resolution image point and maps it to the another rn resolution image point. More...
void rnToFull (const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimDpt &fullPt) const
 rnToFull is a utility method that takes a rn resolution image point and maps it to the full image point. More...
void fullToRn (const ossimDpt &fullPt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
 fullToRn is a utility method that takes a full image point and maps it to a rn resolution image point. More...
void rnToWorld (const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimGpt &wpt) const
 rnToWorld is a utility method that takes a rn resolution image point and maps it to the world point. More...
void worldToRn (const ossimGpt &wpt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
 worldToRn is a utility method that takes a world point allows one to transform all the way back to an rn point. More...
bool localToWorld (const ossimDpt &local_pt, ossimGpt &world_pt) const
 Exposes the 3D projection from image to world coordinates. More...
bool localToWorld (const ossimDrect &local_rect, ossimGrect &world_rect) const
bool localToWorld (const ossimDpt &local_pt, const double &h_ellipsoid, ossimGpt &world_pt) const
 Exposes the 3D projection from image to world coordinates given a constant height above ellipsoid. More...
bool worldToLocal (const ossimGpt &world_pt, ossimDpt &local_pt) const
 Exposes the 3D world-to-local image coordinate reverse projection. More...
bool worldToLocal (const ossimGrect &world_rect, ossimDrect &local_rect) const
void setTransform (ossim2dTo2dTransform *transform)
 Sets the transform to be used for local-to-full-image coordinate transformation. More...
void setProjection (ossimProjection *projection)
 Sets the projection to be used for local-to-world coordinate transformation. More...
const ossim2dTo2dTransformgetTransform () const
 Access methods for transform (may be NULL pointer). More...
const ossimProjectiongetProjection () const
 Access methods for projection (may be NULL pointer). More...
bool isMapProjected () const
 Returns true if underlying projection is derived from ossimMapProjection. More...
const ossimMapProjectiongetAsMapProjection () const
bool hasProjection () const
 Returns TRUE if valid projection defined. More...
bool hasTransform () const
 Returns TRUE if valid transform defined. More...
bool isAffectedByElevation () const
 Returns TRUE if this geometry is sensitive to elevation. More...
ossimDpt getMetersPerPixel () const
 Returns the GSD associated with this image in the active projection. More...
void getMetersPerPixel (ossimDpt &gsd) const
 Get the ground sample distance(GSD) associated with this image in the active projection. More...
ossimDpt getDegreesPerPixel () const
 Returns the resolution of this image in degrees/pixel. More...
void getDegreesPerPixel (ossimDpt &dpp) const
 Get the resolution of this image in degrees/pixel. More...
bool getCornerGpts (ossimGpt &ul, ossimGpt &ur, ossimGpt &lr, ossimGpt &ll) const
 Assigns the ossimGpts with the ground coordinates of the four corresponding image corner points. More...
void getTiePoint (ossimGpt &tie, bool edge) const
 Get the latitude, longitude of the tie point. More...
void getTiePoint (ossimDpt &tie, bool edge) const
 Get the easting, northing of the tie point. More...
std::ostream & print (std::ostream &out) const
 Prints contents to output stream. More...
bool operator== (const ossimImageGeometry &compare_this) const
 Returns TRUE if argument geometry has exactly the same instances for transform and m_projection. More...
const ossimImageGeometryoperator= (const ossimImageGeometry &copy_this)
 Replaces any existing transform and projection with those in the copy_this object. More...
ossimDpt decimationFactor (ossim_uint32 r_index) const
 Returns the decimation factor from R0 for the resolution level specified. More...
void decimationFactor (ossim_uint32 r_index, ossimDpt &result) const
 Method to get the decimation factor for a given resolution level. More...
void decimationFactors (std::vector< ossimDpt > &decimations) const
 Gets array of all decimation levels. More...
void setDiscreteDecimation (const std::vector< ossimDpt > &decimation_list)
 Sets the decimation scheme to a discrete list of decimation factors. More...
ossim_uint32 getNumberOfDecimations () const
void setImageSize (const ossimIpt &size)
const ossimIptgetImageSize () const
bool getCrossesDateline () const
void getImageEdgePoints (std::vector< ossimDpt > &result, ossim_uint32 partitions=25) const
void calculatePolyBounds (ossimPolyArea2d &result, ossim_uint32 partitions=25) const
 This is the first stage implementation. More...
void getBoundingRect (ossimIrect &bounding_rect) const
 Get the bounding rect of (0, 0) to (imageSize.x-1, imageSize.y-1). More...
void getBoundingRect (ossimDrect &bounding_rect) const
void getBoundingGroundRect (ossimGrect &bounding_grect) const
 Creates a new instance of ossimImageGeometry with the same transform and projection. More...
 Attempts to initialize a transform and a projection given the KWL. More...
 Saves the transform (if any) and projection (if any) states to the KWL. More...
void setTargetRrds (ossim_uint32 rrds)
 Set m_targetRrds data member. More...
ossim_uint32 getTargetRrds () const
void applyScale (const ossimDpt &scale, bool recenterTiePoint)
 Changes the GSD and image size to reflect the scale provided. More...
virtual ossimAdjustableParameterInterfacegetAdjustableParameterInterface ()
virtual const ossimAdjustableParameterInterfacegetAdjustableParameterInterface () const
bool computeImageToGroundPartialsWRTAdjParam (ossimDpt &result, const ossimGpt &gpt, ossim_uint32 idx, ossim_float64 paramDelta=1.0)
bool computeImageToGroundPartialsWRTAdjParams (NEWMAT::Matrix &result, const ossimGpt &gpt, ossim_float64 paramDelta=1.0)
bool computeImageToGroundPartialsWRTAdjParams (NEWMAT::Matrix &result, const ossimGpt &gpt, const DeltaParamList &deltas)
bool computeGroundToImagePartials (NEWMAT::Matrix &result, const ossimGpt &gpt, const ossimDpt3d &deltaLlh)
bool computeGroundToImagePartials (NEWMAT::Matrix &result, const ossimGpt &gpt)
ossim_float64 upIsUpAngle (const ossimDpt &) const
ossim_float64 upIsUpAngle () const
ossim_float64 northUpAngle () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
void undecimatePoint (const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimDpt &outPt) const
 Method to back out decimation of a point. More...
void decimatePoint (const ossimDpt &inPt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
 Method to apply decimation of a point. More...
virtual ~ossimReferenced ()
ossimRefPtr< ossim2dTo2dTransformm_transform
 Maintains local_image-to-full_image transformation. More...
ossimRefPtr< ossimProjectionm_projection
 Maintains full_image-to-world_space transformation. More...
std::vector< ossimDptm_decimationFactors
 List of decimation factors for R-levels. More...
ossimIpt m_imageSize
ossim_uint32 m_targetRrds
 Target rrds for localToWorld and worldToLocal methods. More...
Detailed Description
This is the object that is returned from a call to ossimImageSource::getImageGeometry()
All images in OSSIM have at least a 2D transformation from local (relative to start of file) to full-image coordinates. Often this transform is an identity transform (does nothing). In some cases however, the first pixel in the file does not correspond to the upper-left pixel of the original, full image. Since the image's sensor model may only apply to full-image pixel coordinates, it is necessary to reference the latter when making computing ground point location. Also the local image could be a reduced resolution level of the full image. So the image could be a decimated sub image of the full image.
Additionally, images typically are accompanied by some form of metadata that defines the mapping from 2D image coordinates to 3D world coordinates. This mapping may be in the form of a map projection for orthorectified images, or a perspective projection such as a sensor model.
This object class maintains both 2D transform and 3D projection information for the associated image. This object will typically be created and "owned" by the image handler object. Therefore, only one copy per image will exist at a time.
Notes: 1) Shifts are relative to "full image space". So if you have a sub image from r2 the shift given to the transform should be relative to "full image space". 2) A decimation of 1.0 is the full image. This may or may not be r0 as r0 can be decimated.
Definition at line 65 of file ossimImageGeometry.h.
Member Typedef Documentation
◆ DeltaParamList
Definition at line 68 of file ossimImageGeometry.h.
◆ ossimImageGeometry() [1/3]
ossimImageGeometry::ossimImageGeometry ( )
Definition at line 31 of file ossimImageGeometry.cpp.
References m_imageSize, and ossimIpt::makeNan().
32 :
33 m_transform (0),
34 m_projection(0),
36 m_imageSize(),
37 m_targetRrds(0)
38 {
40 }
ossimRefPtr< ossim2dTo2dTransform > m_transform
void makeNan()
Definition: ossimIpt.h:56
ossimRefPtr< ossimProjection > m_projection
std::vector< ossimDpt > m_decimationFactors
◆ ~ossimImageGeometry()
ossimImageGeometry::~ossimImageGeometry ( )
virtual
Definition at line 79 of file ossimImageGeometry.cpp.
80 {
81  // Nothing to do
82 }
◆ ossimImageGeometry() [2/3]
ossimImageGeometry::ossimImageGeometry ( const ossimImageGeometry copy_this)
This is needed when an imageSource in the chain needs to modify the image geometry at that point in the chain. The image geometry to the left of that imageSource must remain unchanged. This constructor permits that imageSource to maintain its own geometry based on the input geometry. All chained objects to the right would see this alternate geometry. See ossimScaleFilter for an example of this case.
Definition at line 49 of file ossimImageGeometry.cpp.
50 :
51 ossimObject(copy_this),
55 m_imageSize(copy_this.m_imageSize),
56 m_targetRrds(copy_this.m_targetRrds)
57 {
58 }
virtual ossimObject * dup() const =0
bool valid() const
Definition: ossimRefPtr.h:75
Definition: ossimObject.cpp:29
◆ ossimImageGeometry() [3/3]
ossimImageGeometry::ossimImageGeometry ( ossim2dTo2dTransform transform,
ossimProjection proj
Either pointer can be NULL – the associated mapping would be identity.
Definition at line 64 of file ossimImageGeometry.cpp.
65 :
66 ossimObject(),
67 m_transform(transform),
68 m_projection(proj),
70 m_imageSize(),
71 m_targetRrds(0)
72 {
74 }
void makeNan()
Member Function Documentation
◆ applyScale()
void ossimImageGeometry::applyScale ( const ossimDpt scale,
Parameters
scaleThe scale to be applied in x and y directions
recenterTiePointIf true the will adjust the tie point by shifting the original tie to the upper left corner, applying scale, then shifting back by half of either the new theDeltaLat/lon or theMetersPerPixel depending on if underlying projection isGeographic.
Definition at line 1285 of file ossimImageGeometry.cpp.
References ossimMapProjection::applyScale(), ossimRefPtr< T >::get(), m_imageSize, m_projection, ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
1286 {
1287  if ((scale.x != 0.0) && (scale.y != 0.0))
1288  {
1289  ossimMapProjection* map_Proj = dynamic_cast<ossimMapProjection*>(m_projection.get());
1290  if ( map_Proj )
1291  {
1292  m_imageSize.x = ossim::round<ossim_int32>(m_imageSize.x / scale.x);
1293  m_imageSize.y = ossim::round<ossim_int32>(m_imageSize.y / scale.y);
1294  map_Proj->applyScale(scale, recenterTiePoint);
1295  }
1296  }
1297 }
double y
Definition: ossimDpt.h:165
virtual void applyScale(const ossimDpt &scale, bool recenterTiePoint)
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: the...
ossim_int32 y
Definition: ossimIpt.h:142
double x
Definition: ossimDpt.h:164
ossim_int32 x
Definition: ossimIpt.h:141
◆ calculatePolyBounds()
void ossimImageGeometry::calculatePolyBounds ( ossimPolyArea2d result,
ossim_uint32  partitions = 25
) const
It will determine if it crosses the dateline and do a special multi polygon for the ossimPolyArea2d result. For each edge of the image we walk "partitions" number of points. If we cross a dateline we calculate the crossing lat by using the parametric form of the equation. For example, if we are crossing from positive to negative that means we are going through the 180 degree lon location and we will need to solve for the paramtetric parameter t and plug back into the parametric equation to solve for the latitude. Basic form: start + (end-start)*t = 180. If we are coming from negative to positive then we solve basic form: start + (end-start)*t = -180. Where deltaPoint is (end-start)
              ossim_float64 t = ((180-start.x)/deltaPoint.x);
              ossim_float64 lat = (start.y+deltaPoint.y*t);
If we do not cross the dateline then if the image is affected by elevation (i.e. a sensor model) then we use the partitions parameter to calculate that number of partitions to sample along each edge.
if The geometry is not affected by elevation then we just use the corner points and ignore the partitions parameter
Parameters
polyholds the resulting polygon. This could be a MultiPolygon depending on the geometry
partitionsThese are the number of steps you want when walking the border.
Definition at line 1146 of file ossimImageGeometry.cpp.
References ossimPolyArea2d::add(), ossimPolyArea2d::clear(), ossimPolygon::clear(), ossimPolygon::clipToRect(), ossim_hdf5::crossesDateline(), getBoundingRect(), getCrossesDateline(), getImageEdgePoints(), ossimDrect::hasNans(), ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossimPolyArea2d::isValid(), localToWorld(), ossimGpt::lond(), ossimDrect::midPoint(), ossimPolyArea2d::setToBufferedShape(), and ossim::sgn().
1147 {
1148  std::vector<ossimDpt> points;
1149  std::vector<ossimGpt> gPoints;
1150  std::vector<ossimPolygon> polyList;
1151  ossimDrect imageRect;
1152  ossimGpt cg;
1153  ossimDrect worldRect(ossimDpt(-180,-90),
1154  ossimDpt(-180,90),
1155  ossimDpt(180,90),
1156  ossimDpt(180,-90));
1157  getBoundingRect(imageRect);
1158  // bool affectedByElevation = isAffectedByElevation();
1160  result.clear();
1161  if(imageRect.hasNans())
1162  {
1163  // error out
1164  return;
1165  }
1166  localToWorld(imageRect.midPoint(), cg);
1167  if(cg.isLatNan() || cg.isLonNan())
1168  {
1169  return;
1170  }
1171  ossim_int32 sgn = static_cast<ossim_int32>(
1172  ossim::sgn(cg.lond()));
1173
1174  getImageEdgePoints(points, partitions);
1175  if(points.empty())
1176  {
1177  return;
1178  }
1179
1180  if(crossesDateline)
1181  {
1182  for(std::vector<ossimDpt>::const_iterator iter=points.begin();
1183  iter != points.end();
1184  ++iter)
1185  {
1186  ossimGpt testGpt;
1187  localToWorld(*iter, testGpt);
1188
1189  if(!testGpt.isLatNan()&&!testGpt.isLonNan())
1190  {
1191  bool needToShift =( (std::fabs(testGpt.lond()-cg.lond()) > 180.0)||
1192  (std::fabs(testGpt.lond()>180.0)) );
1193  if(needToShift)
1194  {
1195  testGpt.lond(testGpt.lond()+sgn*360);
1196  }
1197  gPoints.push_back(testGpt);
1198  }
1199  }
1200  // now clip the ground list to the full ground rect
1201  //
1202  ossimPolygon tempPoly(gPoints);
1203  tempPoly.clipToRect(polyList, worldRect);
1204  for(std::vector<ossimPolygon>::const_iterator iter = polyList.begin();
1205  iter!=polyList.end();++iter)
1206  {
1207  result.add(ossimPolyArea2d(*iter));
1208  }
1209  // now shift gpoints to the other side
1210  //
1211  for(std::vector<ossimGpt>::iterator iter = gPoints.begin();
1212  iter != gPoints.end();
1213  ++iter)
1214  {
1215  (*iter).lond((*iter).lond()+(-sgn*360));
1216  }
1217  tempPoly = gPoints;
1218  polyList.clear();
1219  tempPoly.clipToRect(polyList, worldRect);
1220  for(std::vector<ossimPolygon>::const_iterator iter = polyList.begin();
1221  iter!=polyList.end();++iter)
1222  {
1223  result.add(ossimPolyArea2d(*iter));
1224  }
1225  }
1226  else
1227  {
1228  for(std::vector<ossimDpt>::const_iterator iter=points.begin();
1229  iter != points.end();++iter)
1230  {
1231  ossimGpt testGpt;
1232  localToWorld(*iter, testGpt);
1233
1234  if(!testGpt.isLatNan()&&!testGpt.isLonNan())
1235  {
1236  gPoints.push_back(testGpt);
1237  }
1238  }
1239  result.add(ossimPolygon(gPoints));
1240  }
1241  if(!result.isValid()) result.setToBufferedShape();
1242 }
T sgn(T x)
Definition: ossimCommon.h:339
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
bool isLonNan() const
Definition: ossimGpt.h:140
bool isValid(bool displayValidationError=false) const
void getBoundingRect(ossimIrect &bounding_rect) const
bool isLatNan() const
Definition: ossimGpt.h:139
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
bool hasNans() const
Definition: ossimDrect.h:396
void add(const ossimPolyArea2d &rhs)
ossimDpt midPoint() const
Definition: ossimDrect.h:817
ossimPolyArea2d & setToBufferedShape(double distance=FLT_EPSILON)
bool crossesDateline(H5::DataSet &dataset, const ossimIrect &validRect)
Checks for dateline cross.
int ossim_int32
void getImageEdgePoints(std::vector< ossimDpt > &result, ossim_uint32 partitions=25) const
◆ computeGroundToImagePartials() [1/2]
bool ossimImageGeometry::computeGroundToImagePartials ( NEWMAT::Matrix &  result,
const ossimGpt gpt,
const ossimDpt3d deltaLlh
Definition at line 1400 of file ossimImageGeometry.cpp.
References ossimGpt::datum(), DEG_PER_RAD, getProjection(), ossimGpt::height(), ossim::isnan(), ossimGpt::latd(), ossimGpt::lond(), worldToLocal(), ossimDpt3d::x, ossimDpt::x, ossimDpt3d::y, ossimDpt::y, and ossimDpt3d::z.
Referenced by computeGroundToImagePartials(), and ossimPointObservation::getObjSpacePartials().
1403 {
1404  if(!getProjection()) return false;
1405  ossimDpt p1;
1406  ossimDpt p2;
1407
1408  ossimDpt deltaWithRespectToLon;
1409  ossimDpt deltaWithRespectToLat;
1410  ossimDpt deltaWithRespectToH;
1411  ossim_float64 h = ossim::isnan(gpt.height())?0.0:gpt.height();
1412
1413  // do the change in lon first for the dx, dy
1414  //
1415  worldToLocal(ossimGpt(gpt.latd(), gpt.lond()+deltaLlh.x, h, gpt.datum()), p1);
1416  worldToLocal(ossimGpt(gpt.latd(), gpt.lond()-deltaLlh.x, h, gpt.datum()), p2);
1417
1418  double den = 0.5/deltaLlh.x; // this is the same as dividing by 2*delta
1419  deltaWithRespectToLon = (p2-p1)*den;
1420
1421
1422  // do the change in lat for the dx, dy
1423  //
1424  worldToLocal(ossimGpt(gpt.latd()+deltaLlh.y, gpt.lond(), h, gpt.datum()), p1);
1425  worldToLocal(ossimGpt(gpt.latd()-deltaLlh.y, gpt.lond(), h, gpt.datum()), p2);
1426
1427  den = 0.5/deltaLlh.y; // this is the same as dividing by 2*delta
1428  deltaWithRespectToLat = (p2-p1)*den;
1429
1430
1431  // do the change in height first for the dx, dy
1432  //
1433  worldToLocal(ossimGpt(gpt.latd(), gpt.lond(), h+deltaLlh.z, gpt.datum()), p1);
1434  worldToLocal(ossimGpt(gpt.latd(), gpt.lond(), h-deltaLlh.z, gpt.datum()), p2);
1435
1436  den = 0.5/deltaLlh.z; // this is the same as dividing by 2*delta
1437  deltaWithRespectToH = (p2-p1)*den;
1438
1439
1440  result = NEWMAT::Matrix(3,2);
1441
1442  // set the matrix
1443  //
1444  result[1][0] = deltaWithRespectToLon.x*DEG_PER_RAD;
1445  result[1][1] = deltaWithRespectToLon.y*DEG_PER_RAD;
1446  result[0][0] = deltaWithRespectToLat.x*DEG_PER_RAD;
1447  result[0][1] = deltaWithRespectToLat.y*DEG_PER_RAD;
1448  result[2][0] = deltaWithRespectToH.x;
1449  result[2][1] = deltaWithRespectToH.y;
1450
1451
1452  return true;
1453 }
double lond() const
#define DEG_PER_RAD
double y
double latd() const
Definition: ossimGpt.h:87
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
double ossim_float64
double z
Definition: ossimDpt3d.h:145
double height() const
Definition: ossimGpt.h:107
double x
double x
Definition: ossimDpt3d.h:143
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
double y
Definition: ossimDpt3d.h:144
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ computeGroundToImagePartials() [2/2]
const ossimGpt gpt
Definition at line 1455 of file ossimImageGeometry.cpp.
References computeGroundToImagePartials(), FLT_EPSILON, getMetersPerPixel(), ossimDpt::length(), and ossimGpt::metersPerDegree().
1457 {
1458  ossimDpt mpp = getMetersPerPixel();
1459  ossimGpt originPoint;
1460  ossim_float64 len = mpp.length();
1461
1462  if(len > FLT_EPSILON)
1463  {
1464  ossim_float64 delta = originPoint.metersPerDegree().length();
1465
1466  delta = len/delta;
1467
1468  return computeGroundToImagePartials(result,
1469  gpt,
1470  ossimDpt3d(delta,
1471  delta,
1472  len));
1473  }
1474
1475  return false;
1476 }
bool computeGroundToImagePartials(NEWMAT::Matrix &result, const ossimGpt &gpt, const ossimDpt3d &deltaLlh)
double length() const
Definition: ossimDpt.h:81
#define FLT_EPSILON
ossimDpt getMetersPerPixel() const
ossimDpt metersPerDegree() const
Definition: ossimGpt.cpp:498
◆ computeImageToGroundPartialsWRTAdjParam()
bool ossimImageGeometry::computeImageToGroundPartialsWRTAdjParam ( ossimDpt result,
const ossimGpt gpt,
ossim_uint32  idx,
ossim_float64  paramDelta = 1.0
Definition at line 1310 of file ossimImageGeometry.cpp.
References getAdjustableParameterInterface(), ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), ossimAdjustableParameterInterface::getParameterCenter(), ossimDpt::hasNans(), ossimAdjustableParameterInterface::setParameterCenter(), and worldToLocal().
Referenced by computeImageToGroundPartialsWRTAdjParams().
1314 {
1315  double den = 0.5/paramDelta; // this is the same as dividing by 2*delta
1316
1317  result = ossimDpt(0.0,0.0);
1319
1320  if(!adjustableParamInterface) return false;
1321  if(idx >= adjustableParamInterface->getNumberOfAdjustableParameters()) return false;
1322
1323  ossimDpt p1, p2;
1324  // double middle = adjustableParamInterface->getAdjustableParameter(idx);
1325  double middle = adjustableParamInterface->getParameterCenter(idx);
1326
1327  //set parm to high value
1328  // adjustableParamInterface->setAdjustableParameter(idx, middle + paramDelta, true);
1329  adjustableParamInterface->setParameterCenter(idx, middle + paramDelta, true);
1330  worldToLocal(gpt, p1);
1331
1332  //set parm to low value and gte difference
1333  // adjustableParamInterface->setAdjustableParameter(idx, middle - paramDelta, true);
1334  adjustableParamInterface->setParameterCenter(idx, middle - paramDelta, true);
1335  worldToLocal(gpt, p2);
1336
1337  //get partial derivative
1338  result = (p2-p1)*den;
1339
1340  //reset param
1341  // adjustableParamInterface->setAdjustableParameter(idx, middle, true);
1342  adjustableParamInterface->setParameterCenter(idx, middle, true);
1343
1344  return !result.hasNans();
1345 }
virtual ossimAdjustableParameterInterface * getAdjustableParameterInterface()
Definition: ossimDpt.h:67
void setParameterCenter(ossim_uint32 idx, double center, bool notify=false)
◆ computeImageToGroundPartialsWRTAdjParams() [1/2]
bool ossimImageGeometry::computeImageToGroundPartialsWRTAdjParams ( NEWMAT::Matrix &  result,
const ossimGpt gpt,
Definition at line 1347 of file ossimImageGeometry.cpp.
References computeImageToGroundPartialsWRTAdjParam(), getAdjustableParameterInterface(), ossimAdjustableParameterInterface::getNumberOfAdjustableParameters(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimPointObservation::getParameterPartials().
1350 {
1352
1353  ossim_uint32 nAdjustables = adjustableParamInterface->getNumberOfAdjustableParameters();
1354
1355  ossim_uint32 idx = 0;
1356
1357  result = NEWMAT::Matrix(nAdjustables, 2);
1358  for(;idx < nAdjustables; ++idx)
1359  {
1360  ossimDpt paramResResult;
1362  gpt,
1363  idx,
1364  paramDelta);
1365  result[idx][0] = paramResResult.x;
1366  result[idx][1] = paramResResult.y;
1367  }
1368
1369  return true;
1370 }
bool computeImageToGroundPartialsWRTAdjParam(ossimDpt &result, const ossimGpt &gpt, ossim_uint32 idx, ossim_float64 paramDelta=1.0)
double y
unsigned int ossim_uint32
double x
◆ computeImageToGroundPartialsWRTAdjParams() [2/2]
const ossimGpt gpt,
const DeltaParamList deltas
Definition at line 1372 of file ossimImageGeometry.cpp.
1375 {
1376
1378
1379  ossim_uint32 nAdjustables = adjustableParamInterface->getNumberOfAdjustableParameters();
1380
1381  if(nAdjustables != deltas.size()) return false;
1382  ossim_uint32 idx = 0;
1383
1384  result = NEWMAT::Matrix(nAdjustables, 2);
1385  for(;idx < nAdjustables; ++idx)
1386  {
1387  ossimDpt paramResResult;
1389  gpt,
1390  idx,
1391  deltas[idx]);
1392  // ROWxCOL
1393  result[idx][0] = paramResResult.x;
1394  result[idx][1] = paramResResult.y;
1395  }
1396
1397  return true;
1398 }
double y
double x
◆ decimatePoint()
void ossimImageGeometry::decimatePoint ( const ossimDpt inPt,
ossimDpt rnPt
) const
protected
Parameters
inPtIs a point with no decimation.
resolutionLevelIs the resolution of the point rnPt.
rnPtIs the result of the transform
Definition at line 948 of file ossimImageGeometry.cpp.
References decimationFactor(), ossimDpt::hasNans(), ossimDpt::makeNan(), ossimDpt::x, and ossimDpt::y.
Referenced by fullToRn(), and rnToRn().
951 {
952
953  // Apply the decimation.
954  ossimDpt decimation = decimationFactor(resolutionLevel);
955
956  //---
957  // If no nans and one or both of the factors is not 1.0 decimation should
958  // be applied.
959  //---
960  if ( (decimation.x != 1.0) || (decimation.y != 1.0) )
961  {
962  if ( !decimation.hasNans() && !inPt.hasNans() )
963  {
964  rnPt.x = inPt.x * decimation.x;
965  rnPt.y = inPt.y * decimation.y;
966  }
967  else
968  {
969  rnPt.makeNan();
970  }
971  }
972  else
973  {
974  rnPt = inPt; // No decimation.
975  }
976 }
double y
double x
void makeNan()
Definition: ossimDpt.h:65
ossimDpt decimationFactor(ossim_uint32 r_index) const
◆ decimationFactor() [1/2]
ossimDpt ossimImageGeometry::decimationFactor ( ossim_uint32  r_index) const
For r_index=0, the decimation factor is by definition 1.0. For the non-discrete case, r_index=1 returns a decimation of 0.5. If the vector of discrete decimation factors (m_decimationFactors) is empty, the factor will be computed as f=1/2^n
Definition at line 489 of file ossimImageGeometry.cpp.
References m_decimationFactors, and size.
Referenced by decimatePoint(), ossimMrSidReader::getDecimationFactor(), ossimMrSidReader::getTile(), ossimImageViewProjectionTransform::imageToView(), operator==(), undecimatePoint(), and ossimImageViewProjectionTransform::viewToImage().
490 {
492  if (size)
493  {
494  if (r_index < size)
495  {
496  return m_decimationFactors[r_index];
497  }
498
499  // Return the last defined decimation if the index requested exceeds list size:
500  return m_decimationFactors[size-1];
501  }
502
503  // Compute the decimation factor:
504  ossim_float64 factor = 1.0/(ossim_float64)(1 << r_index);
505
506  return ossimDpt(factor, factor);
507 }
yy_size_t size
◆ decimationFactor() [2/2]
void ossimImageGeometry::decimationFactor ( ossim_uint32  r_index,
ossimDpt result
) const
If the array of decimations is not initialized by owner, the default is: r_index=0 is by definition 1.0. r_index=n Where n is some level the factor will be computed as f=1/2^n.
Parameters
resLevelReduced resolution set for requested decimation.
resultossimDpt to initialize with requested decimation.
Definition at line 509 of file ossimImageGeometry.cpp.
References m_decimationFactors, ossimDpt::x, and ossimDpt::y.
511 {
512  const ossim_uint32 SIZE = (ossim_uint32)m_decimationFactors.size();
513  if (SIZE)
514  {
515  if (r_index < SIZE)
516  {
517  result = m_decimationFactors[r_index];
518  }
519  else
520  {
521  //---
522  // Return the last defined decimation if the index requested
523  // exceeds list size:
524  //---
525  result = m_decimationFactors[SIZE-1];
526  }
527  }
528  else
529  {
530  // Compute the decimation factor:
531  ossim_float64 factor = 1.0/(ossim_float64)(1 << r_index);
532  result.x = factor;
533  result.y = factor;
534  }
535 }
double y
double x
◆ decimationFactors()
void ossimImageGeometry::decimationFactors ( std::vector< ossimDpt > &  decimations) const
Parameters
decimationsArray to initialiaze.
Definition at line 537 of file ossimImageGeometry.cpp.
References m_decimationFactors.
Referenced by ossimMrSidReader::getDecimationFactors().
539 {
540  decimations = m_decimationFactors;
541 }
◆ dup()
virtual ossimObject* ossimImageGeometry::dup ( ) const
inlinevirtual
Overrides base-class version requiring loadState() and saveState() (not implemented yet)
Definition at line 378 of file ossimImageGeometry.h.
Referenced by ossimEquationUtil::initInputSources().
378 { return new ossimImageGeometry(*this); }
◆ fullToRn()
void ossimImageGeometry::fullToRn ( const ossimDpt fullPt,
ossimDpt rnPt
) const
Parameters
fullPtIs a point in full image space.
resolutionLevelIs the resolution of the point rnPt. A value of 0 is the local image.
fullPtIs the result of the transform
Definition at line 135 of file ossimImageGeometry.cpp.
References decimatePoint(), ossim2dTo2dTransform::inverse(), m_transform, and ossimRefPtr< T >::valid().
Referenced by ossimImageViewProjectionTransform::imageToView(), ossimImageViewProjectionTransform::viewToImage(), and worldToLocal().
138 {
139  // Apply shift/rotation.
140  ossimDpt localPt;
141  if (m_transform.valid())
142  {
143  m_transform->inverse(fullPt, localPt);
144  }
145  else
146  {
147  localPt = fullPt; // No transform (shift/rotation)
148  }
149
150  // Apply the decimation.
151  decimatePoint(localPt, resolutionLevel, rnPt);
152 }
bool valid() const
virtual void inverse(const ossimDpt &input, ossimDpt &output) const
void decimatePoint(const ossimDpt &inPt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
◆ getAdjustableParameterInterface() [1/2]
ossimAdjustableParameterInterface * ossimImageGeometry::getAdjustableParameterInterface ( )
virtual
◆ getAdjustableParameterInterface() [2/2]
const ossimAdjustableParameterInterface * ossimImageGeometry::getAdjustableParameterInterface ( ) const
virtual
Definition at line 1304 of file ossimImageGeometry.cpp.
References getProjection().
1305 {
1306  return dynamic_cast<const ossimAdjustableParameterInterface*>(getProjection());
1307
1308 }
◆ getAsMapProjection() [1/2]
const ossimMapProjection* ossimImageGeometry::getAsMapProjection ( ) const
inline
◆ getAsMapProjection() [2/2]
inline
Returns
ossimMapProjection* or NULL if projection not set or not derived from ossimMapProjection.
Definition at line 186 of file ossimImageGeometry.h.
187  { return dynamic_cast<ossimMapProjection*>( m_projection.get() ); }
◆ getBoundingGroundRect()
void ossimImageGeometry::getBoundingGroundRect ( ossimGrect bounding_grect) const
Definition at line 1275 of file ossimImageGeometry.cpp.
References getCornerGpts(), ossimGpt::lat, ossimGpt::lon, ossimGrect::lr(), and ossimGrect::ul().
Referenced by getTiePoint(), and ossimChipProcTool::setAoiToInputs().
1276 {
1277  ossimGpt ul, ur, lr, ll;
1278  getCornerGpts(ul, ur, lr, ll);
1279  bounding_grect.ul().lat = ul.lat > ur.lat ? ul.lat : ur.lat;
1280  bounding_grect.ul().lon = ul.lon < ll.lon ? ul.lon : ll.lon;
1281  bounding_grect.lr().lat = ll.lat < lr.lat ? ll.lat : lr.lat;
1282  bounding_grect.lr().lon = ur.lon > lr.lon ? ur.lon : lr.lon;
1283 }
bool getCornerGpts(ossimGpt &ul, ossimGpt &ur, ossimGpt &lr, ossimGpt &ll) const
Assigns the ossimGpts with the ground coordinates of the four corresponding image corner points...
ossim_float64 lon
Definition: ossimGpt.h:266
const ossimGpt & ul() const
Definition: ossimGrect.h:252
ossim_float64 lat
Definition: ossimGpt.h:265
const ossimGpt & lr() const
Definition: ossimGrect.h:269
◆ getBoundingRect() [1/2]
void ossimImageGeometry::getBoundingRect ( ossimIrect bounding_rect) const
Relies on image size being initialized.
Parameters
bounding_rectInitialized by this method. Will do a ossimIrect::makeNan() if the image size is not initialized.
Definition at line 1245 of file ossimImageGeometry.cpp.
References ossimIpt::hasNans(), m_imageSize, ossimIrect::makeNan(), ossimIrect::set_lrx(), ossimIrect::set_lry(), ossimIrect::set_ulx(), ossimIrect::set_uly(), ossimIpt::x, and ossimIpt::y.
Referenced by calculatePolyBounds(), ATP::AtpGenerator::constructChain(), ossimPotraceTool::convertToBitmap(), ossimInfo::getCenterGround(), getCrossesDateline(), ossimInfo::getImageBounds(), getImageEdgePoints(), ossimInfo::getImg2grd(), ossimRangeDomeTileSource::getTile(), ossimImageViewProjectionTransform::getViewSegments(), ossimImageRenderer::initializeBoundingRects(), northUpAngle(), ossimPotraceTool::transformLineStrings(), and upIsUpAngle().
1246 {
1247  if (m_imageSize.hasNans())
1248  {
1249  bounding_rect.makeNan();
1250  }
1251  else
1252  {
1253  bounding_rect.set_ulx(0);
1254  bounding_rect.set_uly(0);
1255  bounding_rect.set_lrx(m_imageSize.x-1);
1256  bounding_rect.set_lry(m_imageSize.y-1);
1257  }
1258 }
void set_uly(ossim_int32 y)
Definition: ossimIrect.h:666
void set_lrx(ossim_int32 x)
Definition: ossimIrect.h:693
void set_lry(ossim_int32 y)
Definition: ossimIrect.h:702
ossim_int32 y
void makeNan()
Definition: ossimIrect.h:329
ossim_int32 x
Definition: ossimIpt.h:58
void set_ulx(ossim_int32 x)
Definition: ossimIrect.h:657
◆ getBoundingRect() [2/2]
void ossimImageGeometry::getBoundingRect ( ossimDrect bounding_rect) const
Definition at line 1260 of file ossimImageGeometry.cpp.
References ossimIpt::hasNans(), m_imageSize, ossimDrect::makeNan(), ossimDrect::set_lrx(), ossimDrect::set_lry(), ossimDrect::set_ulx(), ossimDrect::set_uly(), ossimIpt::x, and ossimIpt::y.
1261 {
1262  if (m_imageSize.hasNans())
1263  {
1264  bounding_rect.makeNan();
1265  }
1266  else
1267  {
1268  bounding_rect.set_ulx(0);
1269  bounding_rect.set_uly(0);
1270  bounding_rect.set_lrx(m_imageSize.x-1);
1271  bounding_rect.set_lry(m_imageSize.y-1);
1272  }
1273 }
void set_uly(ossim_float64 y)
Definition: ossimDrect.h:718
void makeNan()
Definition: ossimDrect.h:388
void set_ulx(ossim_float64 x)
Definition: ossimDrect.h:709
void set_lry(ossim_float64 y)
Definition: ossimDrect.h:754
ossim_int32 y
ossim_int32 x
void set_lrx(ossim_float64 x)
Definition: ossimDrect.h:745
◆ getCornerGpts()
bool ossimImageGeometry::getCornerGpts ( ossimGpt ul,
ossimGpt ur,
ossimGpt lr,
ossimGpt ll
) const
Returns the ossimGpts for the four image corner points.
Returns true if points are valid.
Definition at line 714 of file ossimImageGeometry.cpp.
References localToWorld(), m_imageSize, status, ossimIpt::x, and ossimIpt::y.
Referenced by getBoundingGroundRect(), ossimTiledElevationDatabase::getBoundingRect(), ossimImageElevationHandler::open(), and ossimNitfWriterBase::writeGeometry().
716 {
717  ossimDpt iul (0,0);
718  ossimDpt iur (m_imageSize.x-1, 0);
719  ossimDpt ilr (m_imageSize.x-1, m_imageSize.y-1);
720  ossimDpt ill (0, m_imageSize.y-1);
721
722  bool status = true;
723
724  status &= localToWorld(iul, gul);
725  status &= localToWorld(iur, gur);
726  status &= localToWorld(ilr, glr);
727  status &= localToWorld(ill, gll);
728
729  return status;
730 }
return status
ossim_int32 y
ossim_int32 x
◆ getCrossesDateline()
bool ossimImageGeometry::getCrossesDateline ( ) const
Definition at line 1027 of file ossimImageGeometry.cpp.
References ossimGpt::changeDatum(), ossimGpt::datum(), getBoundingRect(), ossimGpt::isLonNan(), ossimIrect::ll(), localToWorld(), ossimGpt::lond(), ossimIrect::lr(), ossimIrect::midPoint(), ossimIrect::ul(), and ossimIrect::ur().
Referenced by calculatePolyBounds(), ossimImageRenderer::initializeBoundingRects(), ossimImageViewProjectionTransform::initializeDatelineCrossing(), and ossimImageViewProjectionTransform::initializeViewSize().
1028 {
1029  bool result = false;
1030  ossimIrect rect;
1031  ossimGpt ul;
1032  ossimGpt ur;
1033  ossimGpt lr;
1034  ossimGpt ll;
1035  ossimGpt center;
1036  ossimGpt wgs84;
1037
1038  getBoundingRect(rect);
1039
1040  localToWorld(rect.ul(), ul);
1041  localToWorld(rect.ur(), ur);
1042  localToWorld(rect.lr(), lr);
1043  localToWorld(rect.ll(), ll);
1044  localToWorld(rect.midPoint(), center);
1045
1046  if(ul.isLonNan()||ur.isLonNan()||lr.isLonNan()||ll.isLonNan()||center.isLonNan())
1047  {
1048  return result;
1049  }
1050  else
1051  {
1052  ul.changeDatum(wgs84.datum());
1053  ur.changeDatum(wgs84.datum());
1054  lr.changeDatum(wgs84.datum());
1055  ll.changeDatum(wgs84.datum());
1056  center.changeDatum(wgs84.datum());
1057  result = ( (fabs(center.lond()-ul.lond()) > 180.0) ||
1058  (fabs(center.lond()-ur.lond()) > 180.0) ||
1059  (fabs(center.lond()-lr.lond()) > 180.0) ||
1060  (fabs(center.lond()-ll.lond()) > 180.0) ||
1061  (fabs(ul.lond()) > 180.0) ||
1062  (fabs(ur.lond()) > 180.0) ||
1063  (fabs(lr.lond()) > 180.0) ||
1064  (fabs(ll.lond()) > 180.0)
1065
1066  );
1067  }
1068
1069  return result;
1070 }
double lond() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
const ossimIpt & ll() const
Definition: ossimIrect.h:277
void changeDatum(const ossimDatum *datum)
This will actually perform a shift.
Definition: ossimGpt.cpp:316
datum().
ossimIpt midPoint() const
Definition: ossimIrect.h:750
const ossimIpt & lr() const
Definition: ossimIrect.h:276
const ossimIpt & ur() const
Definition: ossimIrect.h:275
◆ getDegreesPerPixel() [1/2]
ossimDpt ossimImageGeometry::getDegreesPerPixel ( ) const
Note that this only makes sense if there is a projection associated with the image. Returns NaNs if no projection defined.
Definition at line 389 of file ossimImageGeometry.cpp.
Referenced by ossimChipProcTool::computeAdjustedViewFromGrect(), ossimGmlSupportData::getGeoOrigin(), ossimGpkgWriter::getGsd(), ossimLasReader::getImageGeometry(), and ossimPdfWriter::getLgiDictCtm().
390 {
391  ossimDpt dpp;
392  getDegreesPerPixel(dpp);
393  return dpp;
394 }
ossimDpt getDegreesPerPixel() const
◆ getDegreesPerPixel() [2/2]
void ossimImageGeometry::getDegreesPerPixel ( ossimDpt dpp) const
Degrees/pixel is taken from projection if there is no transform set; else, taken from three localToWorld calls (one pixel apart) at the image center. If the projection or the image size(if needed) is not set the point will be set to NaNs.
Parameters
dppPoint to intialize with degrees/pixel.
Note
This only makes sense if there is a projection associated with the image.
Result should be checked for NaNs after call.
Definition at line 401 of file ossimImageGeometry.cpp.
References ossimRefPtr< T >::get(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimIpt::hasNans(), ossimGpt::height(), ossimDpt::lat, ossimGpt::lat, localToWorld(), ossimDpt::lon, ossimGpt::lon, m_imageSize, m_projection, m_transform, ossimDpt::makeNan(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
402 {
403  const ossimMapProjection *map_proj = dynamic_cast<const ossimMapProjection *>(m_projection.get());
404  if (map_proj && !m_transform.valid())
405  {
406  // No transform present, so simply query the projection for resolution:
407  dpp = map_proj->getDecimalDegreesPerPixel();
408  }
409  else if (m_projection.valid() && (m_imageSize.hasNans() == false))
410  {
411  // A transform is involved, so need to use localToWorld call below:
412  ossimDpt pL0 (m_imageSize/2);
413  ossimDpt pLx (pL0.x+1, pL0.y);
414  ossimDpt pLy (pL0.x, pL0.y+1);
415  ossimGpt g0, gx, gy;
416
417  localToWorld(pL0, g0);
418  localToWorld(pLx, g0.height(), gx);
419  localToWorld(pLy, g0.height(), gy);
420
421  // Compute horizontal distance for one pixel:
422  double dlatx = std::fabs(g0.lat - gx.lat);
423  double dlaty = std::fabs(g0.lat - gy.lat);
424  double dlonx = std::fabs(g0.lon - gx.lon);
425  double dlony = std::fabs(g0.lon - gy.lon);
426  dpp.lat = sqrt(dlatx*dlatx + dlaty*dlaty);
427  dpp.lon = sqrt(dlonx*dlonx + dlony*dlony);
428  }
429  else
430  {
431  // This object is not fully initialized:
432  dpp.makeNan();
433  }
434 }
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
bool valid() const
double lat
ossim_float64 lon
double lon
ossim_float64 lat
void makeNan()
◆ getImageEdgePoints()
void ossimImageGeometry::getImageEdgePoints ( std::vector< ossimDpt > &  result,
) const
Definition at line 1072 of file ossimImageGeometry.cpp.
References ossimDrect::expand(), getBoundingRect(), ossimDrect::hasNans(), ossimDrect::ll(), ossimDrect::lr(), ossimDrect::ul(), ossimDrect::ur(), ossimDpt::x, and ossimDpt::y.
Referenced by calculatePolyBounds(), and ossimImageViewProjectionTransform::getViewSegments().
1073 {
1074
1075  ossimDrect imageRect;
1076  getBoundingRect(imageRect);
1077  if(imageRect.hasNans())
1078  {
1079  // error out
1080  return;
1081  }
1082
1083  // Make edge to edge.
1084  imageRect.expand( ossimDpt(0.5, 0.5) );
1085
1086  result.clear();
1087  // First get the image points we will be transforming
1088  if(partitions > 2)
1089  {
1090  ossimDpt uli = imageRect.ul();
1091  ossimDpt uri = imageRect.ur();
1092  ossimDpt lri = imageRect.lr();
1093  ossimDpt lli = imageRect.ll();
1094
1095  ossim_float32 stepSize = partitions;
1096  ossimDpt deltaUpper = (uri-uli)*(1.0/stepSize);
1097  ossimDpt deltaRight = (lri-uri)*(1.0/stepSize);
1098  ossimDpt deltaLower = (lli-lri)*(1.0/stepSize);
1099  ossimDpt deltaLeft = (uli-lli)*(1.0/stepSize);
1100
1101  ossimDpt p;
1102  ossim_int32 idx = 0;
1103  ossimDpt initialPoint= uli;
1104  for(idx = 0; idx < stepSize;++idx)
1105  {
1106  result.push_back(initialPoint);
1107  initialPoint.x+=deltaUpper.x;
1108  initialPoint.y+=deltaUpper.y;
1109  }
1110  initialPoint= uri;
1111  for(idx = 0; idx < stepSize;++idx)
1112  {
1113  result.push_back(initialPoint);
1114  initialPoint.x+=deltaRight.x;
1115  initialPoint.y+=deltaRight.y;
1116  }
1117
1118  initialPoint= lri;
1119  for(idx = 0; idx < stepSize;++idx)
1120  {
1121  result.push_back(initialPoint);
1122  initialPoint.x+=deltaLower.x;
1123  initialPoint.y+=deltaLower.y;
1124  }
1125
1126  initialPoint= lli;
1127  for(idx = 0; idx < stepSize;++idx)
1128  {
1129  result.push_back(initialPoint);
1130  initialPoint.x+=deltaLeft.x;
1131  initialPoint.y+=deltaLeft.y;
1132  }
1133  }
1134  else // If not enough partitions then we will just use the corners
1135  {
1136  result.resize(4);
1137
1138  result[0] = imageRect.ul();
1139  result[1] = imageRect.ur();
1140  result[2] = imageRect.lr();
1141  result[3] = imageRect.ll();
1142  }
1143
1144 }
float ossim_float32
const ossimDpt & ul() const
Definition: ossimDrect.h:339
double y
const ossimDrect & expand(const ossimDpt &padding)
Definition: ossimDrect.cpp:493
const ossimDpt & ur() const
Definition: ossimDrect.h:340
double x
const ossimDpt & ll() const
Definition: ossimDrect.h:342
const ossimDpt & lr() const
Definition: ossimDrect.h:341
int ossim_int32
◆ getImageSize()
const ossimIpt& ossimImageGeometry::getImageSize ( ) const
inline
◆ getMetersPerPixel() [1/2]
ossimDpt ossimImageGeometry::getMetersPerPixel ( ) const
Returns GSD in meters in x- and y-directions.
This may not be the same as the member projection's stated resolution since a transform may be involved.
Definition at line 343 of file ossimImageGeometry.cpp.
Referenced by computeGroundToImagePartials(), ATP::AtpGenerator::constructChain(), ossimGpkgWriter::getGsd(), ossimLasReader::getImageGeometry(), ossimInfo::getImageGeometryInfo(), ossimGmlSupportData::getMapOrigin(), ossimGeoAnnotationEllipseObject::getWidthHeightInPixels(), ossimSFIMFusion::initialize(), ossimImageToPlaneNormalFilter::initialize(), ossimTilingRect::initializeBase(), ossimImageRenderer::initializeBoundingRects(), ossimEquationUtil::initInputSources(), ossimImageElevationHandler::open(), saveState(), and ossimGeneralRasterElevHandler::setFilename().
344 {
345  ossimDpt gsd;
346  getMetersPerPixel(gsd);
347  return gsd;
348 }
◆ getMetersPerPixel() [2/2]
void ossimImageGeometry::getMetersPerPixel ( ossimDpt gsd) const
Computes GSD in meters in x- and y-directions.
GSD is taken from projection if there is no transform set; else, taken from three localToWorld calls (one pixel apart) at the image center. If the projection or the image size(if needed) is not set the point will be set to NaNs.
Parameters
gsdPoint to intialize with GSD.
Note
Definition at line 354 of file ossimImageGeometry.cpp.
References ossimGpt::distanceTo(), ossimProjection::getMetersPerPixel(), ossimIpt::hasNans(), ossimGpt::height(), localToWorld(), m_imageSize, m_projection, m_transform, ossimDpt::makeNan(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
355 {
356  if (m_projection.valid() && !m_transform.valid())
357  {
358  // No transform present, so simply query the projection for GSD:
360  }
361  else if (m_projection.valid() && (m_imageSize.hasNans() == false))
362  {
363  // A transform is involved, so need to use localToWorld call below:
364  ossimDpt pL0 (m_imageSize/2);
365  ossimDpt pLx (pL0.x+1, pL0.y);
366  ossimDpt pLy (pL0.x, pL0.y+1);
367  ossimGpt g0, gx, gy;
368
369  localToWorld(pL0, g0);
370  localToWorld(pLx, g0.height(), gx);
371  localToWorld(pLy, g0.height(), gy);
372
373  // Compute horizontal distance for one pixel:
374  gsd.x = g0.distanceTo(gx);
375  gsd.y = g0.distanceTo(gy);
376  }
377  else
378  {
379  // This object is not fully initialized:
380  gsd.makeNan();
381  }
382 }
bool valid() const
double y
double distanceTo(const ossimGpt &arg_gpt) const
METHOD: distanceTo(ossimGpt) Computes straight-line distance in meters between this and arg gpt: ...
Definition: ossimGpt.cpp:431
virtual ossimDpt getMetersPerPixel() const =0
double x
void makeNan()
◆ getNumberOfDecimations()
ossim_uint32 ossimImageGeometry::getNumberOfDecimations ( ) const
inline
Returns
The number of decimation factors
Definition at line 322 of file ossimImageGeometry.h.
Referenced by ossimMrSidReader::getDecimationFactors(), and ossimImageHandler::initImageParameters().
323  {
324  return (ossim_uint32)m_decimationFactors.size();
325  }
◆ getProjection() [1/2]
const ossimProjection* ossimImageGeometry::getProjection ( ) const
inline
Definition at line 165 of file ossimImageGeometry.h.
Referenced by ossimCoarseGridModel::buildGrid(), ossimGeoPdfReader::computeBoundingRect(), computeGroundToImagePartials(), ossimElevRemapper::elevRemap(), ossimHdf5Tool::execute(), ossimSubImageTool::execute(), ossimKakaduJpipImageGeometryFactory::extendGeometry(), ossimImageGeometryFactory::extendGeometry(), getAdjustableParameterInterface(), ossimPdfWriter::getEpsgCode(), ossimERSTileSource::getImageGeometry(), ossimKakaduJpipHandler::getImageGeometry(), ossimGeneralRasterTileSource::getImageGeometry(), ossimUsgsDemTileSource::getImageGeometry(), ossimOpjJp2Reader::getImageGeometry(), ossimJpegTileSource::getImageGeometry(), ossimMG4LidarReader::getImageGeometry(), ossimGeoPdfReader::getImageGeometry(), ossimMrSidReader::getImageGeometry(), ossimH5ImageHandler::getImageGeometry(), ossimLasReader::getImageGeometry(), ossimKakaduJp2Reader::getImageGeometry(), ossimGpkgReader::getImageGeometry(), ossimImageViewProjectionTransform::getImageToViewBounds(), ossimImageViewProjectionTransform::getInputMetersPerPixel(), ossimPdfWriter::getLgiDictCtm(), ossimChipperUtil::getMapProjection(), ossimImageViewProjectionTransform::getOutputMetersPerPixel(), ATP::AtpGenerator::getValidVertices(), ossimGeoAnnotationEllipseObject::getWidthHeightInPixels(), ossimChipperUtil::hasSensorModelInput(), ossimImageViewProjectionTransform::imageToView(), ossimLasReader::init(), ossimElevRemapper::initialize(), ossimImageProjectionModel::initialize(), ossimViewshedTool::initializeProjectionGsd(), ossimChipProcTool::initializeProjectionGsd(), ossimTiledElevationDatabase::initializeReferenceProjection(), ossimImageViewProjectionTransform::initializeViewSize(), ossimViewshedTool::initProcessingChain(), ossimMapCompositionSource::inputMapProjection(), ossimGdalOgrVectorAnnotation::loadExternalGeometryFile(), ossimGdalOgrVectorAnnotation::loadLineString(), ossimGdalOgrVectorAnnotation::loadMultiLineString(), ossimGdalOgrVectorAnnotation::loadMultiPoint(), ossimGdalOgrVectorAnnotation::loadMultiPolygon(), ossimGdalOgrVectorAnnotation::loadPoint(), ossimGdalOgrVectorAnnotation::loadPolygon(), ossimChipProcTool::newIdentityProjection(), ossimGeoidImage::open(), ossimVpfAnnotationSource::ossimVpfAnnotationSource(), ossimTilingPoly::parseShpFile(), ossimPointCloudImageHandler::setGSD(), ossimRpcSolver::solveCoefficients(), ossimOrthoImageMosaic::updateGeometry(), ossimRLevelFilter::updateGeometry(), ossimScaleFilter::updateGeometry(), ossimGdalOgrVectorAnnotation::verifyViewParams(), ossimImageViewProjectionTransform::viewToImage(), ossimERSFileWriter::writeFile(), ossimEnviHeaderFileWriter::writeFile(), ossimFgdcFileWriter::writeFile(), ossimNitfWriterBase::writeGeometry(), ossimOpjCompressor::writeGeotiffBox(), ossimKakaduCompressor::writeGeotiffBox(), ossimGdalWriter::writeProjectionInfo(), and ossimWriter::writeTiffTags().
165 { return m_projection.get(); }
◆ getProjection() [2/2]
inline
Definition at line 166 of file ossimImageGeometry.h.
166 { return m_projection.get(); }
◆ getTargetRrds()
ossim_uint32 ossimImageGeometry::getTargetRrds ( ) const
Returns
The target zero based reduced resolution data set used for localToWorld and worldToLocal.
See also
setTargetRrds
Definition at line 679 of file ossimImageGeometry.cpp.
References m_targetRrds.
680 {
681  return m_targetRrds;
682 }
◆ getTiePoint() [1/2]
void ossimImageGeometry::getTiePoint ( ossimGpt tie,
bool  edge
) const
This is the bounding upper left point of the image which is not necessarily the image (0, 0) point.
Parameters
tieossimGpt to assign.
edgeIf true the tie point is shifted up and to the right by half the gsd.
Note
Requires projection and image size to be initialized or the latitude and longitue will be set to nan.
The height parameter of the ossimGpt is not touched by this method.
Definition at line 732 of file ossimImageGeometry.cpp.
References ossimProjection::forward(), ossimRefPtr< T >::get(), getBoundingGroundRect(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimProjection::getMetersPerPixel(), ossimIpt::hasNans(), ossimDpt::hasNans(), ossimProjection::inverse(), ossimMapProjection::isGeographic(), ossimGpt::lat, localToWorld(), ossimGpt::lon, m_imageSize, m_projection, ossimGpt::makeNan(), ossim::nan(), ossimGrect::ul(), ossimRefPtr< T >::valid(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by ATP::AtpGenerator::constructChain(), getTiePoint(), and ossimEquationUtil::initInputSources().
733 {
734  ossimGrect grect;
735  getBoundingGroundRect(grect);
736  if ( m_projection.valid() && (m_imageSize.hasNans() == false) )
737  {
738  // Use the easting/northing version of this method if underlying projection is meters:
739  const ossimMapProjection* map_proj =
740  dynamic_cast<const ossimMapProjection*>(m_projection.get());
741  if (map_proj)
742  {
743  if(!map_proj->isGeographic())
744  {
745  ossimDpt enTie;
746  getTiePoint(enTie, edge);
747  if (!enTie.hasNans())
748  tie = m_projection->inverse(enTie);
749  else
750  tie.makeNan();
751  }
752  else
753  {
754  tie = grect.ul();
755  if(edge)
756  {
757  ossimDpt half_pixel_shift = map_proj->getDecimalDegreesPerPixel() * 0.5;
758  tie.lat += half_pixel_shift.y;
759  tie.lon -= half_pixel_shift.x;
760  }
761  }
762  }
763  else
764  {
765
766  // must be a sensor model so we will set to the upper left bounds of the image
767  tie = grect.ul();
768 // std::cout << "GRECT ======= " << grect << "\n";
769 // std::cout << m_projection->getClassName() << std::endl;
770 // ossimDpt pt = m_projection->forward( tie );
771 // std::cout << "FORWARD:" <<pt << std::endl;
772  }
773  }
774
775
776 #if 0
777  // std::cout << "GRECT ======= " << grect << "\n";
778  if ( m_projection.valid() && (m_imageSize.hasNans() == false) )
779  {
780  // Use the easting/northing version of this method if underlying projection is meters:
781  const ossimMapProjection* map_proj =
782  dynamic_cast<const ossimMapProjection*>(m_projection.get());
783  if (map_proj && !map_proj->isGeographic())
784  {
785  ossimDpt enTie;
786  getTiePoint(enTie, edge);
787  if (!enTie.hasNans())
788  tie = m_projection->inverse(enTie);
789  else
790  tie.makeNan();
791  return; // return here only because it bugs Dave
792  }
793
794  // Use projection to ground to establish UL extreme of image:
795  ossimDpt iul (0,0);
796  ossimDpt iur (m_imageSize.x-1, 0);
797  ossimDpt ilr (m_imageSize.x-1, m_imageSize.y-1);
798  ossimDpt ill (0, m_imageSize.y-1);
799  ossimDpt iRight(1, 0);
800  ossimDpt iDown(0, 1);
801
802  ossimGpt gul;
803  ossimGpt gur;
804  ossimGpt glr;
805  ossimGpt gll;
806  ossimGpt gRight;
807  ossimGpt gDown;
808
809  localToWorld(iul, gul);
810  localToWorld(iur, gur);
811  localToWorld(ilr, glr);
812  localToWorld(ill, gll);
813  localToWorld(iRight, gRight);
814  localToWorld(iDown, gDown);
815
816  std::cout << "gul: " << gul << "\n"
817  << "gur: " << gur << "\n"
818  << "glr: " << glr << "\n"
819  << "gll: " << gll << "\n"
820  << "gRight: " << gRight << "\n"
821  << "gDown: " << gDown << "\n";
822  // Determine the direction of the image:
823  if ( gul.lat > gDown.lat ) // oriented north up
824  {
825  if ( gul.lat >= gRight.lat ) // straight up or leaning right
826  {
827  std::cout << "ONE\n";
828  tie.lat = gul.lat;
829  tie.lon = gll.lon;
830  }
831  else // leaning left
832  {
833  std::cout << "TWO\n";
834  tie.lat = gur.lat;
835  tie.lon = gul.lon;
836  }
837  }
838  else // south or on side
839  {
840  if ( gRight.lat >= gul.lat ) // straight down or leaning right
841  {
842  std::cout << "THREE\n";
843  tie.lat = glr.lat;
844  tie.lon = gur.lon;
845  }
846  else // leaning left
847  {
848  std::cout << "FOUR\n";
849  tie.lat = gll.lat;
850  tie.lon = glr.lon;
851  }
852  }
853  std::cout << "TIE BEFORE ==== " << tie << "\n";
854
855  if ( edge )
856  {
857  ossimDpt pt = m_projection->forward( tie );
858  ossimDpt half_pixel_shift = m_projection->getMetersPerPixel() * 0.5;
859  pt.y += half_pixel_shift.y;
860  pt.x -= half_pixel_shift.x;
861  tie = m_projection->inverse( pt );
862  }
863
864  std::cout << "TIE ==== " << tie << "\n";
865  } // if ( (m_imageSize.hasNans() == false) && m_projection.valid() )
866  else
867  {
868  tie.lat = ossim::nan();
869  tie.lon = ossim::nan();
870  }
871 #endif
872 }
void getBoundingGroundRect(ossimGrect &bounding_grect) const
bool valid() const
double nan()
Definition: ossimCommon.h:135
double y
virtual ossimGpt inverse(const ossimDpt &pp) const
void makeNan()
Definition: ossimGpt.h:130
virtual bool isGeographic() const
ossim_float64 lon
void getTiePoint(ossimGpt &tie, bool edge) const
virtual ossimDpt forward(const ossimGpt &wp) const
ossim_int32 y
double x
ossim_int32 x
ossim_float64 lat
◆ getTiePoint() [2/2]
void ossimImageGeometry::getTiePoint ( ossimDpt tie,
bool  edge
) const
Parameters
tieossimDpt to assign.
Note
Requires projection and image size to be initialized or the easting and northing will be set to nan.
Definition at line 878 of file ossimImageGeometry.cpp.
References ossimProjection::forward(), ossimRefPtr< T >::get(), ossimMapProjection::getMetersPerPixel(), getTiePoint(), ossimIpt::hasNans(), ossimDpt::hasNans(), ossimGpt::hasNans(), ossimGpt::hgt, ossimMapProjection::isGeographic(), ossimMapProjection::lineSampleToEastingNorthing(), m_imageSize, m_projection, ossimDpt::makeNan(), rnToFull(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
879 {
881  {
882  tie.makeNan();
883  return; // return here only because it bugs Dave
884  }
885
886  // Use the geographic version of this method if underlying projection is NOT map in meters:
887  const ossimMapProjection* map_proj = dynamic_cast<const ossimMapProjection*>(m_projection.get());
888  if (!map_proj || map_proj->isGeographic())
889  {
890  // Use the geographic version of this method to establish UL:
891  ossimGpt gTie;
892  gTie.hgt = 0.0;
893  getTiePoint(gTie, edge);
894  if (!gTie.hasNans())
895  tie = m_projection->forward( gTie );
896  else
897  tie.makeNan();
898  return; // return here only because it bugs Dave
899  }
900
901  // The underlying projection is a proper map projection in meters. Use easting northing
902  // directly to avoid shifting the UL tiepoint because of skewed edge in geographic. Note:
903  // assume the image is North up:
904  ossimDpt iul (0,0);
905  ossimDpt ful;
906  rnToFull(iul, 0, ful);
907  map_proj->lineSampleToEastingNorthing(ful, tie);
908  if (edge && !tie.hasNans())
909  {
910  // Shift from pixel-is-point to pixel-is-area
911  ossimDpt half_pixel_shift = map_proj->getMetersPerPixel() * 0.5;
912  tie.y += half_pixel_shift.y;
913  tie.x -= half_pixel_shift.x;
914  }
915 }
bool valid() const
double y
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
void rnToFull(const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimDpt &fullPt) const
rnToFull is a utility method that takes a rn resolution image point and maps it to the full image poi...
virtual void lineSampleToEastingNorthing(const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
Definition: ossimGpt.h:135
double x
void makeNan()
◆ getTransform() [1/2]
const ossim2dTo2dTransform* ossimImageGeometry::getTransform ( ) const
inline
Definition at line 161 of file ossimImageGeometry.h.
Referenced by ossimKakaduJpipImageGeometryFactory::extendGeometry(), ossimImageGeometryFactory::extendGeometry(), ossimQuickbirdNitfTileSource::getImageGeometry(), ossimImageViewProjectionTransform::imageToView(), and ossimImageViewProjectionTransform::viewToImage().
161 { return m_transform.get(); }
◆ getTransform() [2/2]
inline
Definition at line 162 of file ossimImageGeometry.h.
162 { return m_transform.get(); }
◆ hasProjection()
bool ossimImageGeometry::hasProjection ( ) const
inline
◆ hasTransform()
bool ossimImageGeometry::hasTransform ( ) const
inline
Definition at line 193 of file ossimImageGeometry.h.
Referenced by ossimKakaduJpipImageGeometryFactory::extendGeometry(), and ossimImageGeometryFactory::extendGeometry().
193 { return m_transform.valid(); }
bool valid() const
◆ isAffectedByElevation()
bool ossimImageGeometry::isAffectedByElevation ( ) const
Definition at line 332 of file ossimImageGeometry.cpp.
References ossimProjection::isAffectedByElevation(), m_projection, and ossimRefPtr< T >::valid().
Referenced by ossimInfo::getUpIsUpAngle(), ossimImageViewProjectionTransform::getViewSegments(), ossimEquationUtil::initInputSources(), and worldToLocal().
333 {
334  if (m_projection.valid())
336  return false;
337 }
bool valid() const
virtual bool isAffectedByElevation() const =0
Pure virtual method to query if projection is affected by elevation.
◆ isEqualTo()
bool ossimImageGeometry::isEqualTo ( const ossimObject obj,
ossimCompareType  compareType = OSSIM_COMPARE_FULL
) const
virtual
< Maintains full_image-to-world_space transformation
Definition at line 978 of file ossimImageGeometry.cpp.
References ossimRefPtr< T >::get(), ossimObject::isEqualTo(), ossimProjection::isEqualTo(), ossimIpt::isEqualTo(), m_decimationFactors, m_imageSize, m_projection, m_targetRrds, m_transform, OSSIM_COMPARE_IMMEDIATE, and ossimRefPtr< T >::valid().
Referenced by ossimGeoPolyCutter::setView().
979 {
980  bool result = ossimObject::isEqualTo(obj, compareType);
981  const ossimImageGeometry* rhs = dynamic_cast<const ossimImageGeometry*> (&obj);
982  if(rhs&&result) // we know the types are the same
983  {
984  result = ((m_decimationFactors.size() == rhs->m_decimationFactors.size())&&
986  (m_targetRrds == rhs->m_targetRrds));
987
988  if(result)
989  {
990  ossim_uint32 decimationIdx = 0;
991  for(decimationIdx = 0; result&&(decimationIdx < m_decimationFactors.size());++decimationIdx)
992  {
993  result = m_decimationFactors[decimationIdx].isEqualTo(rhs->m_decimationFactors[decimationIdx]);
994  }
995  }
996
997  if(result && compareType==OSSIM_COMPARE_IMMEDIATE)
998  {
999  result = ((m_transform.get() == rhs->m_transform.get())&&
1000  (m_projection.get() == rhs->m_projection.get()));
1001
1002  }
1003  else
1004  {
1005  if(m_transform.valid()&&rhs->m_transform.valid())
1006  {
1007  result = m_transform->isEqualTo(*rhs->m_transform.get());
1008  }
1009  else if(reinterpret_cast<ossim_uint64>(m_transform.get()) | reinterpret_cast<ossim_uint64>(rhs->m_transform.get())) // one is null
1010  {
1011  result = false;
1012  }
1013  if(m_projection.valid()&&rhs->m_projection.valid())
1014  {
1015  result = m_projection->isEqualTo(*rhs->m_projection.get());
1016  }
1017  else if(reinterpret_cast<ossim_uint64>(m_projection.get()) | reinterpret_cast<ossim_uint64>(rhs->m_projection.get())) // one is null
1018  {
1019  result = false;
1020  }
1021
1022  }
1023  }
1024  return result;
1025 }
virtual bool isEqualTo(const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const
bool valid() const
bool isEqualTo(const ossimIpt &rhs, ossimCompareType compareType=OSSIM_COMPARE_FULL) const
Definition: ossimIpt.cpp:261
◆ isMapProjected()
bool ossimImageGeometry::isMapProjected ( ) const
Returns
true if map projected; false, if not.
Definition at line 1681 of file ossimImageGeometry.cpp.
References ossimRefPtr< T >::get(), and m_projection.
1682 {
1683  return dynamic_cast<const ossimMapProjection*>( m_projection.get() ) != 0;
1684 }
◆ loadState()
bool ossimImageGeometry::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Returns TRUE if no error encountered.
Definition at line 547 of file ossimImageGeometry.cpp.
References ossimString::c_str(), ossimKeywordlist::find(), ossim2dTo2dTransformRegistry::instance(), ossimProjectionFactoryRegistry::instance(), ossimObject::loadState(), m_decimationFactors, m_imageSize, m_projection, m_targetRrds, m_transform, setProjection(), ossimString::size(), STATIC_TYPE_NAME, ossimIpt::toPoint(), ossimString::toUInt32(), ossim::toVector(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by ossimImageGeometryFactory::createGeometry(), ossimImageHandler::getExternalImageGeometry(), ossimDoqqTileSource::getImageGeometry(), ossimERSTileSource::getImageGeometry(), ossimRpfCacheTileSource::getImageGeometry(), ossimImageCacheBase::getImageGeometry(), ossimGdalOgrVectorAnnotation::loadExternalGeometryFile(), ossimGeoAnnotationSource::loadState(), ossimMemoryImageSource::loadState(), ossimGeoPolyCutter::loadState(), ossimImageViewProjectionTransform::loadState(), ossimOgrVectorTileSource::loadState(), ossimEsriShapeFileFilter::loadState(), and ossimGeneralRasterElevHandler::setFilename().
549 {
550  const char* lookup = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
551  if (lookup)
552  {
554  {
555  ossimObject::loadState(kwl, prefix);
556
557  // m_transform
558  ossimString transformPrefix = ossimString(prefix) + "transform.";
560  createNativeObjectFromRegistry(kwl, transformPrefix.c_str());
561  if( transform.valid() )
562  {
563  m_transform = transform;
564  }
565
566  // m_projection:
567  ossimString projectionPrefix = ossimString(prefix) + "projection.";
569  createProjection(kwl, projectionPrefix.c_str());
570  if( projection.valid() )
571  {
572  m_projection = projection;
573  }
574
575  // m_decimationFactors:
576  ossimString decimations = kwl.find(prefix, "decimations");
577  if( decimations.size() )
578  {
579  m_decimationFactors.clear();
580  ossim::toVector(m_decimationFactors, decimations);
581  }
582
583  // m_imageSize:
584  ossimString imageSize = kwl.find(prefix, "image_size");
585  if( imageSize.size() )
586  {
587  m_imageSize.toPoint(imageSize);
588  }
589
590  // m_targetRrds:
591  ossimString targetRrds = kwl.find(prefix, "target_rrds");
592  if ( targetRrds.size() )
593  {
594  m_targetRrds = ossimString(targetRrds).toUInt32();
595  }
596  }
597  else
598  {
599  // Now look for projection spec (for backwards compatibility):
601  createProjection(kwl, prefix);
602  if (projection)
603  {
604  setProjection(projection);
605  }
606  }
607  }
608  else
609  {
610  //---
611  // Old geometry file with no type keyword:
612  //---
614  createProjection(kwl, prefix);
615  if (projection)
616  {
617  setProjection(projection);
618  }
619  }
620
621  return true;
622 }
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool valid() const
ossim_uint32 toUInt32() const
static const char * TYPE_KW
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
OSSIM_DLL void toVector(std::vector< ossimDpt > &result, const ossimString &stringOfPoints)
Will take a string list separated by spaces and convert to a vector of ossimDpts. ...
std::string::size_type size() const
Definition: ossimString.h:405
void toPoint(const std::string &s)
Initializes this point from string.
Definition: ossimIpt.cpp:170
static ossimProjectionFactoryRegistry * instance()
const char * c_str() const
Definition: ossimString.h:396
static ossim2dTo2dTransformRegistry * instance()
◆ localToWorld() [1/3]
bool ossimImageGeometry::localToWorld ( const ossimDpt local_pt,
ossimGpt world_pt
) const
Exposes the 3D projection from image to world coordinates.
The caller should verify that a valid projection exists before calling this method. Returns TRUE if a valid ground point is available in the ground_pt argument. This method depends on the existence of elevation information. If no DEM is available, the results will be incorrect or inaccurate.
Return a NAN point of no projection is defined:
Definition at line 178 of file ossimImageGeometry.cpp.
References ossimProjection::lineSampleToWorld(), m_projection, m_targetRrds, ossimGpt::makeNan(), rnToFull(), and ossimRefPtr< T >::valid().
Referenced by ossimCoarseGridModel::buildGrid(), calculatePolyBounds(), ATP::AtpTileSource::computeParallax(), RadialProcessor::doRadial(), ossimEsriShapeFileFilter::drawAnnotations(), ossimInfo::getCenterGround(), ossimHlzTool::getChip(), ossimShorelineTool::getChip(), ossimViewshedTool::getChip(), getCornerGpts(), getCrossesDateline(), getDegreesPerPixel(), ossimGdalOgrVectorAnnotation::getFeatures(), ossimGmlSupportData::getGeoBounds(), ossimGmlSupportData::getGeoOrigin(), ossimInfo::getImageBounds(), ossimInfo::getImageGeometryInfo(), ossimImageViewProjectionTransform::getImageToViewBounds(), ossimPdfWriter::getLgiDictCtm(), ossimGmlSupportData::getMapOrigin(), getMetersPerPixel(), getTiePoint(), ossimPointCloudUtilityFilter::getTile(), ossimImageViewProjectionTransform::getViewSegments(), ossimIvtGeomXform::imageToGround(), ossimImageViewProjectionTransform::imageToView(), ATP::AtpGenerator::initialize(), ossimImageViewProjectionTransform::initializeViewSize(), ossimViewshedTool::initProcessingChain(), ossimGeoPolyCutter::invertPolygon(), localToWorld(), main(), ossimTiledElevationDatabase::mapRegion(), northUpAngle(), rnToWorld(), ossimGeneralRasterElevHandler::setFilename(), ossimPotraceTool::transformLineStrings(), ossimPotraceTool::transformPolygons(), upIsUpAngle(), and ossimImageViewProjectionTransform::viewToImage().
179 {
181  if (!m_projection.valid())
182  {
183  world_pt.makeNan();
184  return false;
185  }
186
187  // First transform local pixel to full-image pixel:
188  ossimDpt full_image_pt;
189  rnToFull(local_pt, m_targetRrds, full_image_pt);
190
191  // Perform projection to world coordinates:
192  m_projection->lineSampleToWorld(full_image_pt, world_pt);
193
194
195  // Put longitude between -180 and +180 and latitude between -90 and +90 if not so.
196  // world_pt.wrap();
197
198  return true;
199 }
bool valid() const
void makeNan()
virtual void lineSampleToWorld(const ossimDpt &lineSampPt, ossimGpt &worldPt) const =0
◆ localToWorld() [2/3]
bool ossimImageGeometry::localToWorld ( const ossimDrect local_rect,
ossimGrect world_rect
) const
Definition at line 201 of file ossimImageGeometry.cpp.
References ossimDrect::ll(), localToWorld(), ossimDrect::lr(), ossimDrect::ul(), and ossimDrect::ur().
202 {
203  ossimGpt gp1, gp2, gp3, gp4;
204  if ( localToWorld(local_rect.ul(), gp1) && localToWorld(local_rect.ur(), gp2) &&
205  localToWorld(local_rect.lr(), gp3) && localToWorld(local_rect.ll(), gp4))
206  {
207  world_rect = ossimGrect(gp1, gp2, gp3, gp4);
208  return true;
209  }
210  return false;
211 }
◆ localToWorld() [3/3]
const double &  h_ellipsoid,
ossimGpt world_pt
) const
Exposes the 3D projection from image to world coordinates given a constant height above ellipsoid.
Definition at line 218 of file ossimImageGeometry.cpp.
References ossimProjection::lineSampleHeightToWorld(), m_projection, m_targetRrds, ossimGpt::makeNan(), rnToFull(), ossimRefPtr< T >::valid(), and ossimGpt::wrap().
221 {
223  if (!m_projection.valid())
224  {
225  world_pt.makeNan();
226  return false;
227  }
228
229  // First transform local pixel to full-image pixel:
230  ossimDpt full_image_pt;
231  rnToFull(local_pt, m_targetRrds, full_image_pt);
232
233  // Perform projection to world coordinates:
234  m_projection->lineSampleHeightToWorld(full_image_pt, h_ellipsoid, world_pt);
235
236  // Put longitude between -180 and +180 and latitude between -90 and +90 if not so.
237  world_pt.wrap();
238
239  return true;
240 }
bool valid() const
void makeNan()
ossim_uint32 m_targetRrds
Target rrds for localToWorld and worldToLocal methods.
void wrap()
Wrap method to maintain longitude between -180 and +180 and latitude between -90 and +90...
Definition: ossimGpt.h:305
virtual void lineSampleHeightToWorld(const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const =0
Maintains full_image-to-world_space transformation.
◆ northUpAngle()
ossim_float64 ossimImageGeometry::northUpAngle ( ) const
Returns
Returns the angle to "north up" in decimal degrees, ossim::nan on error.
Definition at line 1645 of file ossimImageGeometry.cpp.
References getBoundingRect(), ossimGpt::hasNans(), ossimDrect::hasNans(), localToWorld(), ossimDrect::lr(), m_projection, ossimDrect::midPoint(), ossim::nan(), ossimDrect::ul(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimInfo::getNorthUpAngle().
1646 {
1647  ossim_float64 result = ossim::nan();
1648
1649  if ( m_projection.valid() )
1650  {
1651  ossimDrect bounds;
1652  getBoundingRect( bounds );
1653
1654  if( !bounds.hasNans() )
1655  {
1656  ossimDpt centerIpt = bounds.midPoint();
1657
1658  ossimDpt midBottomIpt( centerIpt.x, bounds.lr().y );
1659  ossimDpt midTopIpt( centerIpt.x, bounds.ul().y );
1660
1661  ossimGpt midBottomGpt;
1662  ossimGpt midTopGpt;
1663
1664  localToWorld( midBottomIpt, midBottomGpt );
1665  localToWorld( midTopIpt, midTopGpt );
1666
1667  if ( !midBottomGpt.hasNans() && !midTopGpt.hasNans() )
1668  {
1669  result = midBottomGpt.azimuthTo( midTopGpt );
1670
1671  if(result < 0) result += 360.0;
1672  }
1673  }
1674
1675  } // Matches: if ( m_projection.valid() )
1676
1677  return result;
1678
1679 } // End: ossimImageGeometry::northUpAngle()
bool valid() const
double nan()
Get the bounding rect of (0, 0) to (imageSize.x-1, imageSize.y-1).
double y
ossimRefPtr< ossimProjection > m_projection
double x
◆ open()
bool ossimImageGeometry::open ( const ossimFilename image)
Shortcut way of getting to an image's geometry when access to pixels is not needed.
Parameters
imageImage to open
Returns
true if open was successful and a valid geometry was initialized.
Definition at line 84 of file ossimImageGeometry.cpp.
References ossimImageHandler::getImageGeometry(), ossimImageHandlerRegistry::instance(), ossimImageHandlerRegistry::open(), and ossimRefPtr< T >::valid().
Referenced by ossimChipProcTool::newIdentityProjection(), and ossimChipProcTool::setAoiToInputs().
85 {
87  if (!handler.valid())
88  return false;
89
91  if (!geom.valid())
92  return false;
93
94  *this = *geom;
95  return true;
96 }
virtual ossimImageHandler * open(const ossimFilename &fileName, bool trySuffixFirst=true, bool openOverview=true) const
open that takes a filename.
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
static ossimImageHandlerRegistry * instance()
◆ operator=()
const ossimImageGeometry & ossimImageGeometry::operator= ( const ossimImageGeometry copy_this)
Replaces any existing transform and projection with those in the copy_this object.
Definition at line 687 of file ossimImageGeometry.cpp.
References ossimObject::dup(), ossimProjection::dup(), m_decimationFactors, m_imageSize, m_projection, m_targetRrds, m_transform, and ossimRefPtr< T >::valid().
688 {
689  if (this != &copy_this)
690  {
691  // Get deep copy of 2D transform if one exists:
692  if (copy_this.m_transform.valid())
693  {
695  }
696
697  // Now establish a deep copy of the projection, if any:
698  if (copy_this.m_projection.valid())
699  {
700  m_projection = (ossimProjection*) copy_this.m_projection->dup();
701  }
702
703  // the Gsd should already be solved from the source we are copying from
704  m_imageSize = copy_this.m_imageSize;
706  m_targetRrds = copy_this.m_targetRrds;
707  }
708  return *this;
709 }
virtual ossimObject * dup() const =0
ossimRefPtr< ossim2dTo2dTransform > m_transform
Maintains local_image-to-full_image transformation.
bool valid() const
Definition: ossimObject.cpp:29
std::vector< ossimDpt > m_decimationFactors
List of decimation factors for R-levels.
◆ operator==()
bool ossimImageGeometry::operator== ( const ossimImageGeometry other) const
Returns TRUE if argument geometry has exactly the same instances for transform and m_projection.
This should be expanded to permit different instances of same transforms
This may need to be expanded to permit different instances of same transforms
Definition at line 477 of file ossimImageGeometry.cpp.
References decimationFactor(), m_projection, and m_transform.
478 {
479  return ((m_transform == other.m_transform) && (m_projection == other.m_projection) &&
480  (decimationFactor(0) == other.decimationFactor(0)) );
481 }
Returns the decimation factor from R0 for the resolution level specified.
◆ print()
std::ostream & ossimImageGeometry::print ( std::ostream &  out) const
virtual
Prints contents to output stream.
Definition at line 439 of file ossimImageGeometry.cpp.
References m_decimationFactors, m_imageSize, m_projection, m_targetRrds, m_transform, ossim2dTo2dTransform::print(), ossimProjection::print(), and ossimRefPtr< T >::valid().
Referenced by ossimImageViewProjectionTransform::print().
440 {
441  out << "type: ossimImageGeometry" << std::endl;
442  if(m_transform.valid())
443  {
444  out << " m_transform: ";
445  m_transform->print(out);
446  }
447  else
448  {
449  out << " No transform defined. Using identity transform.\n";
450  }
451
452  if(m_projection.valid())
453  {
454  out << " m_projection: ";
455  m_projection->print(out);
456  }
457  else
458  {
459  out << " No projection defined. ";
460  }
461
462  for ( std::vector<ossimDpt>::size_type i = 0; i < m_decimationFactors.size(); ++i )
463  {
464  cout << "m_decimationFactors[" << i << "]: " << m_decimationFactors[i] << "\n";
465  }
466
467  out << "m_imageSize: " << m_imageSize
468  << "\nm_targetRrds: " << m_targetRrds << "\n";
469
470  return out;
471 }
bool valid() const
Generic print method.
◆ rnToFull()
void ossimImageGeometry::rnToFull ( const ossimDpt rnPt,
ossimDpt fullPt
) const
rnToFull is a utility method that takes a rn resolution image point and maps it to the full image point.
Parameters
rnPtIs a point in resolution n.
resolutionLevelIs the resolution of the point rnPt. a value of 0 is the local image
Definition at line 116 of file ossimImageGeometry.cpp.
References ossim2dTo2dTransform::forward(), ossimDpt::hasNans(), m_transform, undecimatePoint(), and ossimRefPtr< T >::valid().
Referenced by getTiePoint(), ossimImageViewProjectionTransform::imageToView(), localToWorld(), and ossimImageViewProjectionTransform::viewToImage().
119 {
120  // Back out the decimation.
121  ossimDpt localPt;
122  undecimatePoint(rnPt, resolutionLevel, localPt);
123
124  // Remove any shift/rotation.
125  if ( m_transform.valid() && !localPt.hasNans() )
126  {
127  m_transform->forward(localPt, fullPt);
128  }
129  else
130  {
131  fullPt = localPt; // No transform (shift/rotation)
132  }
133 }
virtual void forward(const ossimDpt &input, ossimDpt &output) const =0
void undecimatePoint(const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimDpt &outPt) const
Method to back out decimation of a point.
bool valid() const
◆ rnToRn()
void ossimImageGeometry::rnToRn ( const ossimDpt inRnPt,
ossim_uint32  inResolutionLevel,
ossim_uint32  outResolutionLevel,
ossimDpt outRnPt
) const
rnToRn is a utility method that takes a rn resolution image point and maps it to the another rn resolution image point.
Parameters
inRnPtIs a point in resolution n.
inResolutionLevelIs the resolution of the point inRnPt.
outResolutionLevelIs the resolution of the point outRnPt.
outRnPtIs the result of the transform.
Definition at line 98 of file ossimImageGeometry.cpp.
References decimatePoint(), and undecimatePoint().
Referenced by rnToWorld(), and worldToRn().
100 {
101  if (inResolutionLevel != outResolutionLevel)
102  {
103  // Back out the decimation.
104  ossimDpt pt;
105  undecimatePoint(inRnPt, inResolutionLevel, pt);
106
107  // Decimate to new level.
108  decimatePoint(pt, outResolutionLevel, outRnPt);
109  }
110  else
111  {
112  outRnPt = inRnPt; // No transform required.
113  }
114 }
Method to apply decimation of a point.
◆ rnToWorld()
void ossimImageGeometry::rnToWorld ( const ossimDpt rnPt,
ossimGpt wpt
) const
rnToWorld is a utility method that takes a rn resolution image point and maps it to the world point.
Parameters
wptIs the result of the transform
Definition at line 154 of file ossimImageGeometry.cpp.
References localToWorld(), m_targetRrds, and rnToRn().
Referenced by ossimElevRemapper::elevRemap(), and ossimPointCloudImageHandler::getTile().
157 {
158  ossimDpt localPt;
159  rnToRn(rnPt, resolutionLevel, m_targetRrds, localPt);
160  localToWorld(localPt, wpt);
161 }
void rnToRn(const ossimDpt &inRnPt, ossim_uint32 inResolutionLevel, ossim_uint32 outResolutionLevel, ossimDpt &outRnPt) const
rnToRn is a utility method that takes a rn resolution image point and maps it to the another rn resol...
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
◆ saveState()
bool ossimImageGeometry::saveState ( ossimKeywordlist kwl,
) const
virtual
Saves the transform (if any) and projection (if any) states to the KWL.
Definition at line 627 of file ossimImageGeometry.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), getMetersPerPixel(), m_decimationFactors, m_imageSize, m_projection, m_targetRrds, m_transform, ossim2dTo2dTransform::saveState(), ossimObject::saveState(), ossimProjection::saveState(), ossimIpt::toString(), ossimDpt::toString(), ossim::toStringList(), and ossimRefPtr< T >::valid().
Referenced by ossimHdf5Tool::execute(), ossimSubImageTool::execute(), ossimInfo::getImageGeometryInfo(), ossimImageHandler::saveImageGeometry(), ossimElevRemapper::saveState(), ossimGdalOgrVectorAnnotation::saveState(), ossimMemoryImageSource::saveState(), ossimImageViewProjectionTransform::saveState(), ossimOgrVectorTileSource::saveState(), ossimEsriShapeFileFilter::saveState(), and ossimGeoPdfReader::saveState().
628 {
629  bool good_save = true;
630
631  // m_transform:
632  if (m_transform.valid())
633  {
634  ossimString transformPrefix = ossimString(prefix) + "transform.";
635  good_save = m_transform->saveState(kwl, transformPrefix.c_str());
636  }
637
638  // m_projection:
639  if (m_projection.valid())
640  {
641  ossimString projectionPrefix = ossimString(prefix) + "projection.";
642  good_save &= m_projection->saveState(kwl, projectionPrefix.c_str());
643  }
644
645  // m_gsd:
646  ossimDpt gsd;
647  getMetersPerPixel(gsd);
648  kwl.add(prefix, "gsd", gsd.toString(), true);
649
650  // m_decimationFactors:
651  if(m_decimationFactors.size())
652  {
653  ossimString resultPoints;
655  kwl.add(prefix, "decimations", resultPoints, true);
656  }
657  else
658  {
659  kwl.add(prefix, "decimations", "", true);
660  }
661
662  // m_imageSize:
663  kwl.add(prefix, "image_size", m_imageSize.toString(), true);
664
665  // m_targetRrds;
666  kwl.add(prefix, "target_rrds", m_targetRrds, true);
667
668  // Base class:
669  good_save &= ossimObject::saveState(kwl, prefix);
670
671  return good_save;
672 }
ossimString toString() const
Definition: ossimIpt.cpp:139
bool valid() const
OSSIM_DLL void toStringList(ossimString &resultStringOfPoints, const std::vector< ossimDpt > &pointList, char separator=' ')
Will take a vector of ossimDpt and convert to a string list separated by spaces For example: (45...
Definition: ossimObject.cpp:95
Returns the GSD associated with this image in the active projection.
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimDpt.cpp:160
◆ setDiscreteDecimation()
void ossimImageGeometry::setDiscreteDecimation ( const std::vector< ossimDpt > &  decimation_list)
inline
Sets the decimation scheme to a discrete list of decimation factors.
Definition at line 318 of file ossimImageGeometry.h.
319  { m_decimationFactors = decimation_list; }
◆ setImageSize()
void ossimImageGeometry::setImageSize ( const ossimIpt size)
inline
◆ setProjection()
void ossimImageGeometry::setProjection ( ossimProjection projection)
◆ setTargetRrds()
void ossimImageGeometry::setTargetRrds ( ossim_uint32  rrds)
Set m_targetRrds data member.
This is used by methods worldToRn and localToWorld that do not take a rrds argument and methods rnToWorld and worldToRn. If the target rrds is set to 2, then the resulting point from worldToLocal is relative to reduced resolution level 2. Vice versa for localToWorld it is assumed the local point is relative to the target reduced resolution data set.
Parameters
rrdsTarget (zero based) reduced resolution data set.
Definition at line 674 of file ossimImageGeometry.cpp.
675 {
676  m_targetRrds = rrds;
677 }
◆ setTransform()
void ossimImageGeometry::setTransform ( ossim2dTo2dTransform transform)
Sets the transform to be used for local-to-full-image coordinate transformation.
Definition at line 316 of file ossimImageGeometry.cpp.
References m_transform.
Referenced by ossimKakaduJpipImageGeometryFactory::createGeometry(), ossimKakaduJpipImageGeometryFactory::extendGeometry(), ossimImageGeometryFactory::extendGeometry(), ossimQuickbirdNitfTileSource::getImageGeometry(), and ossimQbTileFilesHandler::getImageGeometry().
317 {
318  m_transform = transform;
319 }
◆ undecimatePoint()
void ossimImageGeometry::undecimatePoint ( const ossimDpt rnPt,
ossimDpt outPt
) const
protected
Parameters
outPtIs the result of the transform a non-decimated point.
Definition at line 918 of file ossimImageGeometry.cpp.
Referenced by rnToFull(), and rnToRn().
921 {
922  // Back out the decimation.
923  ossimDpt decimation = decimationFactor(resolutionLevel);
924
925  //---
926  // If no nans and one or both of the factors is not 1.0 decimation should
927  // be applied.
928  //---
929  if ( (decimation.x != 1.0) || (decimation.y != 1.0) )
930  {
931  if ( !decimation.hasNans() && !rnPt.hasNans() )
932  {
933  outPt.x = rnPt.x * (1.0/decimation.x);
934  outPt.y = rnPt.y * (1.0/decimation.y);
935  }
936  else
937  {
938  outPt.makeNan();
939  }
940  }
941  else
942  {
943  outPt = rnPt; // No decimation.
944  }
945 }
double y
Definition: ossimDpt.h:165
bool hasNans() const
double x
Definition: ossimDpt.h:164
void makeNan()
◆ upIsUpAngle() [1/2]
ossim_float64 ossimImageGeometry::upIsUpAngle ( const ossimDpt pt) const
Returns
Returns the angle to "up is up" in decimal degrees, 0.0 if image is not affected by elevation, ossim::nan on error.
Definition at line 1479 of file ossimImageGeometry.cpp.
References ossim::almostEqual(), ossim::atan2d(), FLT_EPSILON, getBoundingRect(), ossimDpt::hasNans(), ossimDrect::hasNans(), ossimProjection::isAffectedByElevation(), ossim::isnan(), ossimDpt::length(), localToWorld(), m_projection, ossimDrect::midPoint(), ossim::nan(), ossimRefPtr< T >::valid(), worldToLocal(), ossimDpt::x, and ossimDpt::y.
1480 {
1481  ossim_float64 result = ossim::nan();
1482
1483  if ( m_projection.valid() )
1484  {
1486  {
1487  const int NUMBER_OF_SAMPLES = 9;
1488
1489  // In meters. This is about a height of a 6 to 7 story building.
1490  const double ELEVATION_DISPLACEMENT = 20;
1491
1492  ossimDrect bounds;
1493  getBoundingRect( bounds );
1494
1495  if( !bounds.hasNans() )
1496  {
1497  // only need an average
1498  // so will keep the test close to the pixel location
1499  // we are sampling
1500  // let's get rid of the scale
1501  ossim_float64 widthPercent = 1;//bounds.width()*.1;
1502  ossim_float64 heightPercent = 1;//bounds.height()*.1;
1503
1504  //---
1505  // Sanity check to make sure that taking 10 percent out on the image
1506  // gets us to at least 1 pixel away.
1507  //---
1508  // if(widthPercent < 1.0) widthPercent = 1.0;
1509  // if(heightPercent < 1.0) heightPercent = 1.0;
1510
1511  // set up some work variables to help calculate the average partial
1512  //
1513  std::vector<ossimDpt> ipts(NUMBER_OF_SAMPLES);
1514  std::vector<ossimGpt> gpts(NUMBER_OF_SAMPLES);
1515  std::vector<ossimDpt> iptsDisplacement(NUMBER_OF_SAMPLES);
1516  std::vector<ossimDpt> partials(NUMBER_OF_SAMPLES);
1517  ossimDpt averageDelta(0.0,0.0);
1518  ossimDpt centerIpt = pt;
1519  if(centerIpt.hasNans())
1520  {
1521  centerIpt = bounds.midPoint();
1522  }
1523  //---
1524  // Lets take an average displacement about the center point (3x3 grid)
1525  // we will go 10 percent out of the width and height of the image and
1526  // look at the displacement at those points and average them we will
1527  // use the average displacement to compute the up is up rotation.
1528  //---
1529
1530  // top row:
1531
1532  // 45 degree left quadrant
1533  // RP - FIX POINTS IN FIRST ROW
1534  ipts[0] = centerIpt + ossimDpt(-widthPercent, -heightPercent);
1535  // 45 degree middle top
1536  ipts[1] = centerIpt + ossimDpt(0.0,heightPercent);
1537  // 45 degree right quadrant
1538  ipts[2] = centerIpt + ossimDpt(widthPercent, -heightPercent);
1539
1540  // middle row
1541  ipts[3] = centerIpt + ossimDpt(-widthPercent, 0.0); // left middle
1542  ipts[4] = centerIpt;
1543  ipts[5] = centerIpt + ossimDpt(widthPercent, 0.0);
1544
1545  // bottom row
1546  ipts[6] = centerIpt + ossimDpt(-widthPercent, heightPercent);
1547  ipts[7] = centerIpt + ossimDpt(0.0, heightPercent);
1548  ipts[8] = centerIpt + ossimDpt(widthPercent, heightPercent);
1549
1550  ossim_uint32 idx = 0;
1551  for(idx = 0; idx < ipts.size(); ++idx)
1552  {
1553  double h = 0.0;
1554  localToWorld(ipts[idx], gpts[idx]);
1555  h = gpts[idx].height();
1556  if(ossim::isnan(h)) h = 0.0;
1557  gpts[idx].height(h + ELEVATION_DISPLACEMENT);
1558  worldToLocal(gpts[idx], iptsDisplacement[idx]);
1559  averageDelta = averageDelta + (iptsDisplacement[idx] - ipts[idx]);
1560  }
1561
1562  ossim_float64 averageLength = averageDelta.length();
1563  if(averageLength < 1) return false;
1564
1565  if(!ossim::almostEqual((double)0.0, (double)averageLength))
1566  {
1567  averageDelta = averageDelta/averageLength;
1568  }
1569  // RP - the rest of this calculation seems to be leading to less accurate results.
1570  // We already have the average image space displacement from raising the height for 9 points in the image
1571  // Just rotate based on this displacement,
1572  // scaling based on the image size distorts the direction of the up vector, leading to inaccurate results for non-square images
1573  //
1574  //ossimDpt averageLocation = (ossimDpt(averageDelta.x*bounds.width(),
1575  // averageDelta.y*bounds.height())+centerIpt) ;
1576  //ossimGpt averageLocationGpt;
1577  //ossimGpt centerGpt;
1578
1579  //localToWorld(averageLocation, averageLocationGpt);
1580  //localToWorld(ipts[0], centerGpt);
1581
1582  ossimDpt deltaPt = averageDelta; //averageLocation - centerIpt;
1583  ossimDpt deltaUnitPt = deltaPt;
1584  double len = deltaPt.length();
1585  if(len > FLT_EPSILON)
1586  {
1587  deltaUnitPt = deltaUnitPt/len;
1588  }
1589
1590  // Image space model positive y is down. Let's reflect to positve y up.
1591  deltaUnitPt.y *= -1.0; // Reflect y to be right handed.
1592
1593  result = ossim::atan2d(deltaUnitPt.x, deltaUnitPt.y);
1594
1595  //---
1596  // We are essentially simulating camera rotation so negate the rotation
1597  // value.
1598  //---
1599  result *= -1;
1600
1601  if(result < 0) result += 360.0;
1602
1603  } // Matches: if( bounds.hasNans() == false )
1604  }
1605  else
1606  {
1607  result = 0;
1608  }
1609
1610  } // Matches: if ( m_projection.valid() && m_projection->isAffectedByElevation() )
1611
1612  return result;
1613
1614 }
bool valid() const
bool almostEqual(T x, T y, T tolerance=FLT_EPSILON)
Definition: ossimCommon.h:53
double nan()
void getBoundingRect(ossimIrect &bounding_rect) const
double y
double length() const
Definition: ossimDpt.h:81
double ossim_float64
#define FLT_EPSILON
unsigned int ossim_uint32
double atan2d(double y, double x)
Definition: ossimCommon.h:267
Definition: ossimDrect.h:396
Definition: ossimDpt.h:67
ossimDpt midPoint() const
Definition: ossimDrect.h:817
double x
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ upIsUpAngle() [2/2]
ossim_float64 ossimImageGeometry::upIsUpAngle ( ) const
Definition at line 1617 of file ossimImageGeometry.cpp.
References getBoundingRect(), ossimDrect::hasNans(), ossimProjection::isAffectedByElevation(), m_projection, ossimDrect::midPoint(), ossim::nan(), and ossimRefPtr< T >::valid().
1618 {
1619  ossim_float64 result = ossim::nan();
1620
1621  if ( m_projection.valid() )
1622  {
1624  {
1625
1626  ossimDrect bounds;
1627  getBoundingRect( bounds );
1628
1629  if( !bounds.hasNans() )
1630  {
1631  return upIsUpAngle(bounds.midPoint());
1632  }
1633  }
1634  else
1635  {
1636  result = 0;
1637  }
1638
1639  } // Matches: if ( m_projection.valid() && m_projection->isAffectedByElevation() )
1640
1641  return result;
1642
1643 } // End: ossimImageGeometry::upIsUpAngle()
bool valid() const
double nan()
ossim_float64 upIsUpAngle() const
◆ worldToLocal() [1/2]
bool ossimImageGeometry::worldToLocal ( const ossimGpt world_pt,
ossimDpt local_pt
) const
The caller should verify that a valid projection exists before calling this method. Returns TRUE if a valid image point is available in the local_pt argument.
Definition at line 247 of file ossimImageGeometry.cpp.
References fullToRn(), ossimElevManager::getHeightAboveEllipsoid(), ossimGpt::hgt, ossimElevManager::instance(), isAffectedByElevation(), ossimGpt::isHgtNan(), m_projection, m_targetRrds, ossimDpt::makeNan(), ossimRefPtr< T >::valid(), and ossimProjection::worldToLineSample().
Referenced by ossimChipperUtil::addCrossHairAnnotation(), ossimChipProcTool::computeAdjustedViewFromGrect(), ossimGeoPdfReader::computeBoundingRect(), computeGroundToImagePartials(), computeImageToGroundPartialsWRTAdjParam(), ATP::AtpTileSource::computeParallax(), ossimChipProcTool::getChip(), ossimImageElevationHandler::getHeightAboveMSL(), ossimGeneralRasterElevHandler::getHeightAboveMSLFileTemplate(), ossimGeneralRasterElevHandler::getHeightAboveMSLMemoryTemplate(), ossimImageViewProjectionTransform::getImageToViewBounds(), ossimChipperUtil::getIrect(), ossimPointObservation::getResiduals(), ossimPointCloudImageHandler::getValidImageVertices(), ossimImageViewProjectionTransform::getViewSegments(), ossimIvtGeomXform::groundToImage(), ossimImageViewProjectionTransform::imageToView(), ossimRangeDomeTileSource::initialize(), ossimGdalOgrVectorAnnotation::initializeBoundingRec(), ossimImageViewProjectionTransform::initializeViewSize(), ossimViewshedTool::initProcessingChain(), ossimTiledElevationDatabase::mapRegion(), ossimGeoidImage::offsetFromEllipsoidTemplate(), ossimKmlSuperOverlayReader::open(), ossimViewshedTool::paintReticle(), ossimImageElevationHandler::pointHasCoverage(), ossimPointCloudImageHandler::setGSD(), ossimGeoAnnotationPolyLineObject::transform(), ossimGeoAnnotationLineObject::transform(), ossimGeoAnnotationMultiPolyObject::transform(), ossimGeoAnnotationMultiPolyLineObject::transform(), ossimGeoAnnotationMultiEllipseObject::transform(), ossimGeoAnnotationBitmap::transform(), ossimGeoAnnotationGdBitmapFont::transform(), ossimGeoAnnotationEllipseObject::transform(), ossimGeoAnnotationPolyObject::transform(), ossimGeoAnnotationFontObject::transform(), ossimGeoPolyCutter::transformVertices(), upIsUpAngle(), ossimImageViewProjectionTransform::viewToImage(), worldToLocal(), and worldToRn().
248 {
249  bool result = true;
250
251  if ( m_projection.valid() )
252  {
253  //const ossimEquDistCylProjection* eqProj =
254  // dynamic_cast<const ossimEquDistCylProjection*>( m_projection.get() );
255
256  ossimDpt full_image_pt;
257
258  //***** GCP
259  // I am having major problems with the call and is messing up on Image that are edge to edge -180 to 180.
260  // It appears to wrap and think that the image is onl 1 pixel wide. I am commenting out for now
261  // until a better solution can be done for points that wrap. We need a general implementation that will work
262  // with any projector
263  //
264
265  //if ( eqProj && (m_imageSize.hasNans() == false) )
266  // {
267  // Call specialized method to handle wrapping...
268  // eqProj->worldToLineSample( world_pt, m_imageSize, full_image_pt );
269  // }
270  // else if( isAffectedByElevation() )
271  if( isAffectedByElevation() )
272  {
273  ossimGpt copyPt( world_pt );
274  if(world_pt.isHgtNan())
275  {
276  copyPt.hgt = ossimElevManager::instance()->getHeightAboveEllipsoid(copyPt);
277  }
278
279  // Perform projection from world coordinates to full-image space:
280  m_projection->worldToLineSample(copyPt, full_image_pt);
281  }
282  else
283  {
284  // Perform projection from world coordinates to full-image space:
285  m_projection->worldToLineSample(world_pt, full_image_pt);
286  }
287
288  // Transform to local space:
289  fullToRn(full_image_pt, m_targetRrds, local_pt);
290  }
291  else // No projection set:
292  {
293  local_pt.makeNan();
294  result = false;
295  }
296
297  return result;
298
299 } // End: ossimImageGeometry::worldToLocal(const ossimGpt&, ossimDpt&)
Returns TRUE if this geometry is sensitive to elevation.
bool valid() const
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
bool isHgtNan() const
Definition: ossimGpt.h:143
virtual double getHeightAboveEllipsoid(const ossimGpt &gpt)
void fullToRn(const ossimDpt &fullPt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
fullToRn is a utility method that takes a full image point and maps it to a rn resolution image point...
virtual void worldToLineSample(const ossimGpt &worldPoint, ossimDpt &lineSampPt) const =0
void makeNan()
Definition: ossimDpt.h:65
◆ worldToLocal() [2/2]
bool ossimImageGeometry::worldToLocal ( const ossimGrect world_rect,
) const
Definition at line 301 of file ossimImageGeometry.cpp.
References ossimGrect::ll(), ossimGrect::lr(), ossimGrect::ul(), ossimGrect::ur(), and worldToLocal().
302 {
303  ossimDpt dp1, dp2, dp3, dp4;
304  if ( worldToLocal(world_rect.ul(), dp1) && worldToLocal(world_rect.ur(), dp2) &&
305  worldToLocal(world_rect.lr(), dp3) && worldToLocal(world_rect.ll(), dp4))
306  {
307  local_rect = ossimDrect(dp1, dp2, dp3, dp4);
308  return true;
309  }
310  return false;
311 }
const ossimGpt & ul() const
Definition: ossimGrect.h:252
ossimGpt ur() const
Definition: ossimGrect.h:257
const ossimGpt & lr() const
Definition: ossimGrect.h:269
ossimGpt ll() const
Definition: ossimGrect.h:263
◆ worldToRn()
void ossimImageGeometry::worldToRn ( const ossimGpt wpt,
ossimDpt rnPt
) const
worldToRn is a utility method that takes a world point allows one to transform all the way back to an rn point.
Parameters
wptGround point.
rnPtIs the resoltion point.
Definition at line 163 of file ossimImageGeometry.cpp.
References m_targetRrds, rnToRn(), and worldToLocal().
Referenced by ossimPointCloudImageHandler::getTile().
166 {
167  ossimDpt localPt;
168  worldToLocal(wpt, localPt);
169  rnToRn(localPt, m_targetRrds, resolutionLevel, rnPt);
170 }
Member Data Documentation
◆ m_decimationFactors
std::vector<ossimDpt> ossimImageGeometry::m_decimationFactors
protected
Definition at line 481 of file ossimImageGeometry.h.
Referenced by decimationFactor(), decimationFactors(), isEqualTo(), loadState(), operator=(), print(), and saveState().
◆ m_imageSize
ossimIpt ossimImageGeometry::m_imageSize
protected
◆ m_projection
ossimRefPtr<ossimProjection> ossimImageGeometry::m_projection
protected
◆ m_targetRrds
ossim_uint32 ossimImageGeometry::m_targetRrds
protected
Definition at line 485 of file ossimImageGeometry.h.
Referenced by getTargetRrds(), isEqualTo(), loadState(), localToWorld(), operator=(), print(), rnToWorld(), saveState(), setTargetRrds(), worldToLocal(), and worldToRn().
◆ m_transform
ossimRefPtr<ossim2dTo2dTransform> ossimImageGeometry::m_transform
protected
Definition at line 479 of file ossimImageGeometry.h.
Referenced by fullToRn(), getDegreesPerPixel(), getMetersPerPixel(), isEqualTo(), loadState(), operator=(), operator==(), print(), rnToFull(), saveState(), and setTransform().
