ossimGeoAnnotationLineObject Class Reference
#include <ossimGeoAnnotationLineObject.h>
Inheritance diagram for ossimGeoAnnotationLineObject:
ossimGeoAnnotationObject ossimAnnotationObject ossimObject ossimReferenced
Public Member Functions
 ossimGeoAnnotationLineObject (const ossimGpt &start, const ossimGpt &end, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
 ossimGeoAnnotationLineObject (const ossimGeoAnnotationLineObject &rhs)
virtual void applyScale (double x, double y)
virtual void transform (ossimImageGeometry *projection)
 Generic print method. More...
virtual bool intersects (const ossimDrect &rect) const
virtual ossimAnnotationObjectgetNewClippedObject (const ossimDrect &rect) const
virtual void draw (ossimRgbImage &anImage) const
virtual void getBoundingRect (ossimDrect &rect) const
virtual void computeBoundingRect ()
- Public Member Functions inherited from ossimGeoAnnotationObject
 ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
 ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs)
 Saves the current state of this object. More...
- Public Member Functions inherited from ossimAnnotationObject
virtual ~ossimAnnotationObject ()
 ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
virtual void applyScale (const ossimDpt &scale)
virtual ossimDrect getBoundingRect () const
virtual void setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
void getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const
ossim_uint8 getThickness () const
virtual void setThickness (ossim_uint8 thickness)
virtual bool isPointWithin (const ossimDpt &imagePoint) const
virtual ossimString getName () const
virtual void setName (const ossimString &name)
ossim_uint32 getId () const
virtual ossim_uint32 setId ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Protected Member Functions
virtual ~ossimGeoAnnotationLineObject ()
- Protected Member Functions inherited from ossimGeoAnnotationObject
virtual ~ossimGeoAnnotationObject ()
virtual ~ossimReferenced ()
Protected Attributes
ossimAnnotationLineObjecttheProjectedLineObject
ossimGpt theStart
ossimGpt theEnd
- Protected Attributes inherited from ossimAnnotationObject
ossim_uint8 theRed
ossim_uint8 theGreen
ossim_uint8 theBlue
ossim_uint8 theThickness
ossimString theName
ossim_uint32 theId
Additional Inherited Members
- Static Public Member Functions inherited from ossimAnnotationObject
static ossim_uint32 getNextId ()
static void restIdCounter ()
- Static Protected Attributes inherited from ossimAnnotationObject
static ossim_uint32 theIdCounter = 0
Detailed Description
Definition at line 17 of file ossimGeoAnnotationLineObject.h.
◆ ossimGeoAnnotationLineObject() [1/2]
ossimGeoAnnotationLineObject::ossimGeoAnnotationLineObject ( const ossimGpt start,
const ossimGpt end,
unsigned char  r = 255,
unsigned char  g = 255,
unsigned char  b = 255,
long  thickness = 1
Referenced by dup().
◆ ossimGeoAnnotationLineObject() [2/2]
ossimGeoAnnotationLineObject::ossimGeoAnnotationLineObject ( const ossimGeoAnnotationLineObject rhs)
Definition at line 40 of file ossimGeoAnnotationLineObject.cpp.
◆ ~ossimGeoAnnotationLineObject()
ossimGeoAnnotationLineObject::~ossimGeoAnnotationLineObject ( )
protectedvirtual
Definition at line 50 of file ossimGeoAnnotationLineObject.cpp.
References theProjectedLineObject.
51 {
53  {
56  }
57 }
ossimAnnotationLineObject * theProjectedLineObject
Member Function Documentation
◆ applyScale()
void ossimGeoAnnotationLineObject::applyScale ( double  x,
double  y
virtual
Implements ossimAnnotationObject.
Definition at line 64 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::applyScale(), ossimGpt::latd(), ossimGpt::lond(), theEnd, theProjectedLineObject, theStart, x, and y.
65 {
68  theEnd.lond(theEnd.lond()*x);
69  theEnd.latd(theEnd.latd()*y);
70
72  {
74  }
75 }
ossim_uint32 x
virtual void applyScale(double x, double y)
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
ossim_uint32 y
double latd() const
Definition: ossimGpt.h:87
◆ computeBoundingRect()
void ossimGeoAnnotationLineObject::computeBoundingRect ( )
virtual
◆ draw()
void ossimGeoAnnotationLineObject::draw ( ossimRgbImage anImage) const
virtual
Definition at line 98 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::draw(), and theProjectedLineObject.
99 {
100  theProjectedLineObject->draw(anImage);
101 }
virtual void draw(ossimRgbImage &anImage) const
◆ dup()
ossimObject * ossimGeoAnnotationLineObject::dup ( ) const
virtual
Definition at line 59 of file ossimGeoAnnotationLineObject.cpp.
References ossimGeoAnnotationLineObject().
60 {
61  return new ossimGeoAnnotationLineObject(*this);
62 }
ossimGeoAnnotationLineObject(const ossimGpt &start, const ossimGpt &end, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
◆ getBoundingRect()
void ossimGeoAnnotationLineObject::getBoundingRect ( ossimDrect rect) const
virtual
Definition at line 126 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::getBoundingRect(), and theProjectedLineObject.
127 {
129 }
virtual void getBoundingRect(ossimDrect &rect) const
◆ getNewClippedObject()
ossimAnnotationObject * ossimGeoAnnotationLineObject::getNewClippedObject ( const ossimDrect rect) const
virtual
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 113 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::getNewClippedObject(), intersects(), and theProjectedLineObject.
114 {
115  if(intersects(rect))
116  {
118  {
120  }
121  }
122
123  return (ossimAnnotationObject*)0;
124 }
virtual ossimAnnotationObject * getNewClippedObject(const ossimDrect &rect) const
virtual bool intersects(const ossimDrect &rect) const
◆ intersects()
bool ossimGeoAnnotationLineObject::intersects ( const ossimDrect rect) const
virtual
Definition at line 103 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::intersects(), and theProjectedLineObject.
Referenced by getNewClippedObject().
104 {
106  {
107  return theProjectedLineObject->intersects(rect);
108  }
109
110  return false;
111 }
◆ print()
std::ostream & ossimGeoAnnotationLineObject::print ( std::ostream &  out) const
virtual
Derived classes should re-implement as they see fit.
Returns
std::ostream&
Reimplemented from ossimAnnotationObject.
Definition at line 91 of file ossimGeoAnnotationLineObject.cpp.
References theEnd, and theStart.
92 {
93  out << "start ground: " << theStart << endl;
94  out << "end ground: " << theEnd << endl;
95  return out;
96 }
◆ transform()
void ossimGeoAnnotationLineObject::transform ( ossimImageGeometry projection)
virtual
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 77 of file ossimGeoAnnotationLineObject.cpp.
References ossimAnnotationLineObject::setLine(), theEnd, theProjectedLineObject, theStart, and ossimImageGeometry::worldToLocal().
78 {
79  if(projection)
80  {
81  ossimDpt projectedStart;
82  ossimDpt projectedEnd;
83
84  projection->worldToLocal(theStart, projectedStart);
85  projection->worldToLocal(theEnd, projectedEnd);
86
87  theProjectedLineObject->setLine(projectedStart, projectedEnd);
88  }
89 }
void setLine(const ossimDpt &start, const ossimDpt &end)
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
Member Data Documentation
◆ theEnd
ossimGpt ossimGeoAnnotationLineObject::theEnd
protected
Definition at line 45 of file ossimGeoAnnotationLineObject.h.
Referenced by applyScale(), print(), and transform().
◆ theProjectedLineObject
ossimAnnotationLineObject* ossimGeoAnnotationLineObject::theProjectedLineObject
protected
◆ theStart
ossimGpt ossimGeoAnnotationLineObject::theStart
protected
Definition at line 44 of file ossimGeoAnnotationLineObject.h.
