#include <ossimGpkgTileEntry.h>
ossimGpkgTileEntry () | |
default constructor More... | |
ossimGpkgTileEntry (const ossimGpkgTileEntry &obj) | |
const ossimGpkgTileEntry & | operator= (const ossimGpkgTileEntry &obj) |
~ossimGpkgTileEntry () | |
destructor More... | |
void | setTileMatrixSet (const ossimGpkgTileMatrixSetRecord &set) |
Sets the tile matrix set. More... | |
const ossimGpkgTileMatrixSetRecord & | getTileMatrixSet () const |
void | setSrs (const ossimGpkgSpatialRefSysRecord &srs) |
Sets the spatial ref sys. More... | |
const ossimGpkgSpatialRefSysRecord & | getSrs () const |
Spatial ref sys. More... | |
void | addTileMatrix (const ossimGpkgTileMatrixRecord &level) |
Adds a tile matrix level to array. More... | |
const std::vector< ossimGpkgTileMatrixRecord > & | getTileMatrix () const |
void | addTileMatrixExtent (const ossimGpkgNsgTileMatrixExtentRecord &record) |
Adds a tile matrix extent level to array. More... | |
const std::vector< ossimGpkgNsgTileMatrixExtentRecord > & | getTileMatrixExtent () const |
void | sortTileMatrix () |
Sorts the m_tileMatrix by zoom levels with the highest zoom level being at the lowest array index. More... | |
void | sortTileMatrixExtents () |
Sorts the m_tileMatrixExtents by zoom levels with the highest zoom level being at the lowest array index. More... | |
void | saveState (ossimKeywordlist &kwl, const std::string &prefix) const |
Saves the state of object. More... | |
ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel) const |
ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel) const |
void | getSubImageOffset (ossim_uint32 resLevel, ossimIpt &offset) const |
void | getTiePoint (ossimDpt &offset) const |
Gets the tie point from the first tile matrix extents if initialized else from the tile matrix extents. More... | |
void | getGsd (ossim_uint32 index, ossimDpt &gsd) const |
Gets the gsd from tile matrix. More... | |
void | getZoomLevels (std::vector< ossim_int32 > &zoomLevels) const |
Gets zoom levels of all tile matrixes. More... | |
void | getZoomLevelMatrixSizes (std::vector< ossimIpt > &zoomLevelMatrixSizes) const |
Gets zoom level matrix of all tile matrixes. More... | |
ossimRefPtr< ossimMapProjection > | getNewMapProjection () const |
Gets the map projection to include setting the tie and scale. More... | |
std::ostream & | print (std::ostream &out) const |
Print method. More... | |
std::ostream & | printValidate (std::ostream &out) const |
Validate method. More... | |
Private Attributes | |
ossimGpkgSpatialRefSysRecord | m_srs |
ossimGpkgTileMatrixSetRecord | m_tileMatrixSet |
std::vector< ossimGpkgTileMatrixRecord > | m_tileMatrix |
std::vector< ossimGpkgNsgTileMatrixExtentRecord > | m_tileMatrixExtents |
Friends | |
std::ostream & | operator<< (std::ostream &out, const ossimGpkgTileEntry &obj) |
Convenience operator << function. More... | |
Definition at line 34 of file ossimGpkgTileEntry.h.
ossimGpkgTileEntry::ossimGpkgTileEntry | ( | ) |
default constructor
Definition at line 48 of file ossimGpkgTileEntry.cpp.
ossimGpkgTileEntry::ossimGpkgTileEntry | ( | const ossimGpkgTileEntry & | obj | ) |
Definition at line 57 of file ossimGpkgTileEntry.cpp.
ossimGpkgTileEntry::~ossimGpkgTileEntry | ( | ) |
void ossimGpkgTileEntry::addTileMatrix | ( | const ossimGpkgTileMatrixRecord & | level | ) |
level | Level to add. |
Definition at line 102 of file ossimGpkgTileEntry.cpp.
References m_tileMatrix.
Referenced by ossim_gpkg::getTileEntries(), and ossim_gpkg::getTileEntry().
void ossimGpkgTileEntry::addTileMatrixExtent | ( | const ossimGpkgNsgTileMatrixExtentRecord & | record | ) |
Definition at line 112 of file ossimGpkgTileEntry.cpp.
References m_tileMatrixExtents.
void ossimGpkgTileEntry::getGsd | ( | ossim_uint32 | index, |
ossimDpt & | gsd | ||
) | const |
index | to tile matrix array. |
gsd | Initialized by this. Will be nan if matrix is empty. |
Definition at line 303 of file ossimGpkgTileEntry.cpp.
References m_tileMatrix, ossimDpt::makeNan(), ossimDpt::x, and ossimDpt::y.
Referenced by getNewMapProjection().
ossimRefPtr< ossimMapProjection > ossimGpkgTileEntry::getNewMapProjection | ( | ) | const |
Definition at line 339 of file ossimGpkgTileEntry.cpp.
References ossim::acosd(), ossimEpsgProjectionFactory::createProjection(), ossimRefPtr< T >::get(), getGsd(), getTiePoint(), ossimEpsgProjectionFactory::instance(), ossimMapProjection::isGeographic(), ossim::isnan(), ossimDpt::lat, ossimGpt::lat, ossimDpt::lon, ossimGpt::lon, ossimGpkgSpatialRefSysRecord::m_organization, ossimGpkgSpatialRefSysRecord::m_organization_coordsys_id, m_srs, m_tileMatrix, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlTiePoints(), ossimString::string(), ossimString::toString(), ossimString::upcase(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
ossim_uint32 ossimGpkgTileEntry::getNumberOfLines | ( | ossim_uint32 | resLevel | ) | const |
Definition at line 214 of file ossimGpkgTileEntry.cpp.
References ossimGpkgTileMatrixSetRecord::m_max_y, ossimGpkgTileMatrixSetRecord::m_min_y, m_tileMatrix, m_tileMatrixExtents, and m_tileMatrixSet.
ossim_uint32 ossimGpkgTileEntry::getNumberOfSamples | ( | ossim_uint32 | resLevel | ) | const |
Definition at line 242 of file ossimGpkgTileEntry.cpp.
References ossimGpkgTileMatrixSetRecord::m_max_x, ossimGpkgTileMatrixSetRecord::m_min_x, m_tileMatrix, m_tileMatrixExtents, and m_tileMatrixSet.
const ossimGpkgSpatialRefSysRecord & ossimGpkgTileEntry::getSrs | ( | ) | const |
Spatial ref sys.
Definition at line 97 of file ossimGpkgTileEntry.cpp.
References m_srs.
Referenced by ossimGpkgWriter::addLevels().
void ossimGpkgTileEntry::getSubImageOffset | ( | ossim_uint32 | resLevel, |
ossimIpt & | offset | ||
) | const |
Definition at line 270 of file ossimGpkgTileEntry.cpp.
References m_tileMatrix, m_tileMatrixExtents, ossimIpt::x, and ossimIpt::y.
void ossimGpkgTileEntry::getTiePoint | ( | ossimDpt & | offset | ) | const |
Definition at line 287 of file ossimGpkgTileEntry.cpp.
References ossimGpkgTileMatrixSetRecord::m_max_y, ossimGpkgTileMatrixSetRecord::m_min_x, m_tileMatrix, m_tileMatrixExtents, m_tileMatrixSet, ossimDpt::x, and ossimDpt::y.
const std::vector< ossimGpkgTileMatrixRecord > & ossimGpkgTileEntry::getTileMatrix | ( | ) | const |
Definition at line 107 of file ossimGpkgTileEntry.cpp.
const std::vector< ossimGpkgNsgTileMatrixExtentRecord > & ossimGpkgTileEntry::getTileMatrixExtent | ( | ) | const |
Definition at line 118 of file ossimGpkgTileEntry.cpp.
Referenced by ossim_gpkg::getTileEntry().
const ossimGpkgTileMatrixSetRecord & ossimGpkgTileEntry::getTileMatrixSet | ( | ) | const |
Definition at line 87 of file ossimGpkgTileEntry.cpp.
References m_tileMatrixSet.
void ossimGpkgTileEntry::getZoomLevelMatrixSizes | ( | std::vector< ossimIpt > & | zoomLevelMatrixSizes | ) | const |
zoomLevelMatrixSizes | Intitialized by this. |
Definition at line 327 of file ossimGpkgTileEntry.cpp.
void ossimGpkgTileEntry::getZoomLevels | ( | std::vector< ossim_int32 > & | zoomLevels | ) | const |
zoomLevels | Intitialized by this. |
Definition at line 316 of file ossimGpkgTileEntry.cpp.
const ossimGpkgTileEntry & ossimGpkgTileEntry::operator= | ( | const ossimGpkgTileEntry & | obj | ) |
Definition at line 66 of file ossimGpkgTileEntry.cpp.
References m_srs, m_tileMatrix, m_tileMatrixExtents, and m_tileMatrixSet.
std::ostream & ossimGpkgTileEntry::print | ( | std::ostream & | out | ) | const |
Print method.
out | Stream to print to. |
Definition at line 151 of file ossimGpkgTileEntry.cpp.
References saveState().
Referenced by operator<<().
std::ostream & ossimGpkgTileEntry::printValidate | ( | std::ostream & | out | ) | const |
Validate method.
Prints data from database and computed values.
Definition at line 159 of file ossimGpkgTileEntry.cpp.
References ossimGpkgTileMatrixSetRecord::getHeight(), ossimGpkgTileMatrixSetRecord::getWidth(), m_tileMatrix, m_tileMatrixSet, and ossimGpkgDatabaseRecordBase::print().
void ossimGpkgTileEntry::saveState | ( | ossimKeywordlist & | kwl, |
const std::string & | prefix | ||
) | const |
kwl | Initialized by this. |
prefix | e.g. "image0.". Can be empty. |
Definition at line 135 of file ossimGpkgTileEntry.cpp.
References m_srs, m_tileMatrix, m_tileMatrixSet, ossimGpkgTileMatrixSetRecord::saveState(), ossimGpkgSpatialRefSysRecord::saveState(), ossimString::string(), and ossimString::toString().
Referenced by print().
void ossimGpkgTileEntry::setSrs | ( | const ossimGpkgSpatialRefSysRecord & | srs | ) |
srs |
Definition at line 92 of file ossimGpkgTileEntry.cpp.
References m_srs.
void ossimGpkgTileEntry::setTileMatrixSet | ( | const ossimGpkgTileMatrixSetRecord & | set | ) |
set |
Definition at line 82 of file ossimGpkgTileEntry.cpp.
void ossimGpkgTileEntry::sortTileMatrix | ( | ) |
The highest zoom level is the best resolution in ossim. In other words if zoom level 21 is highest zoom level this is equal to r0 (reduced resolution 0.
Definition at line 123 of file ossimGpkgTileEntry.cpp.
void ossimGpkgTileEntry::sortTileMatrixExtents | ( | ) |
Definition at line 128 of file ossimGpkgTileEntry.cpp.
friend |
obj | Object to print. |
Definition at line 208 of file ossimGpkgTileEntry.cpp.
private |
Definition at line 176 of file ossimGpkgTileEntry.h.
Referenced by getNewMapProjection(), getSrs(), operator=(), saveState(), and setSrs().
private |
Definition at line 178 of file ossimGpkgTileEntry.h.
Referenced by addTileMatrix(), getGsd(), getNewMapProjection(), getNumberOfLines(), getNumberOfSamples(), getSubImageOffset(), getTiePoint(), getTileMatrix(), getZoomLevelMatrixSizes(), getZoomLevels(), operator=(), printValidate(), saveState(), and sortTileMatrix().
private |
Definition at line 179 of file ossimGpkgTileEntry.h.
Referenced by addTileMatrixExtent(), getNumberOfLines(), getNumberOfSamples(), getSubImageOffset(), getTiePoint(), getTileMatrixExtent(), operator=(), and sortTileMatrixExtents().
private |
Definition at line 177 of file ossimGpkgTileEntry.h.
Referenced by getNumberOfLines(), getNumberOfSamples(), getTiePoint(), getTileMatrixSet(), operator=(), printValidate(), saveState(), and setTileMatrixSet().
