Public Member Functions | Private Attributes | Friends | List of all members
ossimH5ImageDataset Class Reference
Class encapsulates a HDF5 Data set that can be loaded as an image. More...
#include <ossimH5ImageDataset.h>
 ossimH5ImageDataset ()
 default constructor More...
 ossimH5ImageDataset (const ossimH5ImageDataset &obj)
 copy constructor More...
 ~ossimH5ImageDataset ()
 destructor More...
void close ()
 Calls H5::DataSet::close then deletes data set. More...
const ossimH5ImageDatasetoperator= (const ossimH5ImageDataset &rhs)
bool initialize (const H5::DataSet &dataset, const std::string &datasetName)
 Opens datasetName and initializes all data members on success. More...
const H5::DataSet * getDataset () const
 Get const pointer to dataset. More...
 Get pointer to dataset. More...
const std::string & getName () const
ossimScalarType getScalarType () const
ossim_uint32 getNumberOfBands () const
ossim_uint32 getNumberOfLines () const
ossim_uint32 getNumberOfSamples () const
bool getSwapFlag () const
const ossimIptgetSubImageOffset () const
const ossimIrectgetValidImageRect () const
void getTileBuf (void *buffer, const ossimIrect &rect, ossim_uint32 band)
 Method to grab a tile(rectangle) from image. More...
std::ostream & print (std::ostream &out) const
 print method. More...
Private Attributes
H5::DataSet * m_dataset
std::string m_datasetName
ossimScalarType m_scalar
ossim_uint32 m_bands
ossim_uint32 m_lines
ossim_uint32 m_samples
ossimIrect m_validRect
 Zero based image rect: More...
ossimEndianm_endian
Friends
OSSIMDLLEXPORT std::ostream & operator<< (std::ostream &out, const ossimH5ImageDataset &obj)
Detailed Description
Definition at line 36 of file ossimH5ImageDataset.h.
◆ ossimH5ImageDataset() [1/2]
ossimH5ImageDataset::ossimH5ImageDataset ( )
default constructor
Definition at line 33 of file ossimH5ImageDataset.cpp.
34  :
35  m_dataset(0),
36  m_datasetName(),
38  m_bands(1),
39  m_lines(0),
40  m_samples(0),
41  m_validRect(),
42  m_endian(0)
43 {
44 }
◆ ossimH5ImageDataset() [2/2]
ossimH5ImageDataset::ossimH5ImageDataset ( const ossimH5ImageDataset obj)
copy constructor
Definition at line 46 of file ossimH5ImageDataset.cpp.
References m_dataset.
47  :
48  m_dataset( ( (obj.m_dataset)?new H5::DataSet(*(obj.m_dataset)):0 ) ),
50  m_scalar(obj.m_scalar),
51  m_bands(obj.m_bands),
52  m_lines(obj.m_lines),
53  m_samples(obj.m_samples),
55  m_endian( obj.m_endian ? new ossimEndian() : 0 )
56 {
57  if ( obj.m_dataset )
58  {
59  m_dataset = new H5::DataSet( *(obj.m_dataset) );
60  }
61 }
◆ ~ossimH5ImageDataset()
ossimH5ImageDataset::~ossimH5ImageDataset ( )
destructor
Definition at line 63 of file ossimH5ImageDataset.cpp.
References close().
64 {
65  close();
66 }
void close()
Member Function Documentation
◆ close()
void ossimH5ImageDataset::close ( )
Definition at line 151 of file ossimH5ImageDataset.cpp.
References m_dataset, and m_endian.
Referenced by initialize(), and ~ossimH5ImageDataset().
152 {
153  if ( m_dataset )
154  {
155  m_dataset->close();
156  delete m_dataset;
157  m_dataset = 0;
158  }
159  if ( m_endian )
160  {
161  delete m_endian;
162  m_endian = 0;
163  }
164 }
◆ getDataset() [1/2]
const H5::DataSet * ossimH5ImageDataset::getDataset ( ) const
This can be null if not open.
Returns
Definition at line 166 of file ossimH5ImageDataset.cpp.
167 {
168  return m_dataset;
169 }
◆ getDataset() [2/2]
Returns
pointer to dataset.
Definition at line 171 of file ossimH5ImageDataset.cpp.
172 {
173  return m_dataset;
174 }
◆ getName()
const std::string & ossimH5ImageDataset::getName ( ) const
Returns
The dataset name. This is the full path used for open.
Definition at line 176 of file ossimH5ImageDataset.cpp.
References m_datasetName.
177 {
178  return m_datasetName;
179 }
◆ getNumberOfBands()
ossim_uint32 ossimH5ImageDataset::getNumberOfBands ( ) const
Returns
the number of .
Definition at line 186 of file ossimH5ImageDataset.cpp.
References m_bands.
187 {
188  return m_bands;
189 }
◆ getNumberOfLines()
ossim_uint32 ossimH5ImageDataset::getNumberOfLines ( ) const
Returns
The number of lines.
Definition at line 191 of file ossimH5ImageDataset.cpp.
References ossimIrect::height(), and m_validRect.
192 {
193  return m_validRect.height();
194 }
ossim_uint32 height() const
Definition: ossimIrect.h:487
◆ getNumberOfSamples()
ossim_uint32 ossimH5ImageDataset::getNumberOfSamples ( ) const
Returns
The number of samples.
Definition at line 196 of file ossimH5ImageDataset.cpp.
References m_validRect, and ossimIrect::width().
197 {
198  return m_validRect.width();
199 }
ossim_uint32 width() const
Definition: ossimIrect.h:500
◆ getScalarType()
ossimScalarType ossimH5ImageDataset::getScalarType ( ) const
Returns
The output scalar type.
Definition at line 181 of file ossimH5ImageDataset.cpp.
References m_scalar.
182 {
183  return m_scalar;
184 }
◆ getSubImageOffset()
const ossimIpt & ossimH5ImageDataset::getSubImageOffset ( ) const
Definition at line 206 of file ossimH5ImageDataset.cpp.
References m_validRect, and ossimIrect::ul().
207 {
208  return m_validRect.ul();
209 }
const ossimIpt & ul() const
Definition: ossimIrect.h:274
◆ getSwapFlag()
bool ossimH5ImageDataset::getSwapFlag ( ) const
Returns
The swap flag.
Definition at line 201 of file ossimH5ImageDataset.cpp.
References m_endian.
202 {
203  return (m_endian ? true: false);
204 }
◆ getTileBuf()
void ossimH5ImageDataset::getTileBuf ( void *  buffer,
const ossimIrect rect,
ossim_uint32  band
Parameters
bufferBuffer for data for this method to copy data to. Should be the size of rect * bytes_per_pixel for scalar type.
rectThe zero based rectangle to grab. Rectangle is relative to any sub image offset. E.g. A request for 0,0 is the upper left corner of the valid image rect.
band
Definition at line 216 of file ossimH5ImageDataset.cpp.
References ossimIrect::area(), ossimIrect::height(), m_dataset, m_endian, m_scalar, m_validRect, ossimNotify(), ossimNotifyLevel_WARN, ossimEndian::swap(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
217 {
218  static const char MODULE[] = "ossimH5ImageDataset::getTileBuf";
219
220  if ( m_dataset )
221  {
222  try
223  {
224  // Shift rectangle by the sub image offse (if any) from the m_validRect.
225  ossimIrect irect = rect + m_validRect.ul();
226
227  //--
228  // Turn off the auto-printing when failure occurs so that we can
229  // handle the errors appropriately
230  //---
231  // H5::Exception::dontPrint();
232
233  // NOTE: rank == array dimensions in hdf5 documentation lingo.
234
235  // Get dataspace of the dataset.
236  H5::DataSpace imageDataSpace = m_dataset->getSpace();
237
238  // Number of dimensions of the input dataspace.:
239  const ossim_int32 IN_DIM_COUNT = imageDataSpace.getSimpleExtentNdims();
240
241  // Native type:
242  H5::DataType dataType = m_dataset->getDataType();
243
244  std::vector<hsize_t> inputCount(IN_DIM_COUNT);
245  std::vector<hsize_t> inputOffset(IN_DIM_COUNT);
246
247  if ( IN_DIM_COUNT == 2 )
248  {
249  inputOffset[0] = irect.ul().y;
250  inputOffset[1] = irect.ul().x;
251
252  inputCount[0] = irect.height();
253  inputCount[1] = irect.width();
254  }
255  else
256  {
257  inputOffset[0] = band;
258  inputOffset[1] = irect.ul().y;
259  inputOffset[2] = irect.ul().x;
260
261  inputCount[0] = 1;
262  inputCount[1] = irect.height();
263  inputCount[2] = irect.width();
264  }
265
266  // Define hyperslab in the dataset; implicitly giving strike strike and block NULL.
267  imageDataSpace.selectHyperslab( H5S_SELECT_SET,
268  &inputCount.front(),
269  &inputOffset.front() );
270
271  // Output dataspace dimensions.
272  const ossim_int32 OUT_DIM_COUNT = 3;
273  std::vector<hsize_t> outputCount(OUT_DIM_COUNT);
274  outputCount[0] = 1; // single band
275  outputCount[1] = irect.height(); // lines
276  outputCount[2] = irect.width(); // samples
277
278  // Output dataspace offset.
279  std::vector<hsize_t> outputOffset(OUT_DIM_COUNT);
280  outputOffset[0] = 0;
281  outputOffset[1] = 0;
282  outputOffset[2] = 0;
283
284  // Output dataspace.
285  H5::DataSpace bufferDataSpace( OUT_DIM_COUNT, &outputCount.front());
286  bufferDataSpace.selectHyperslab( H5S_SELECT_SET,
287  &outputCount.front(),
288  &outputOffset.front() );
289
290  // Read data from file into the buffer.
291  m_dataset->read( buffer, dataType, bufferDataSpace, imageDataSpace );
292
293  if ( m_endian )
294  {
295  // If the m_endian pointer is initialized(not zero) swap the bytes.
296  m_endian->swap( m_scalar, buffer, irect.area() );
297  }
298
299  // Cleanup:
300  bufferDataSpace.close();
301  dataType.close();
302  imageDataSpace.close();
303
304  // memSpace.close();
305  // dataType.close();
306  // dataSpace.close();
307  }
308  catch( const H5::FileIException& error )
309  {
311  << MODULE << " caught H5::FileIException!" << std::endl;
312  error.printError();
313  }
314
315  // catch failure caused by the DataSet operations
316  catch( const H5::DataSetIException& error )
317  {
319  << MODULE << " caught H5::DataSetIException!" << std::endl;
320  error.printError();
321  }
322
323  // catch failure caused by the DataSpace operations
324  catch( const H5::DataSpaceIException& error )
325  {
327  << MODULE << " caught H5::DataSpaceIException!" << std::endl;
328  error.printError();
329  }
330
331  // catch failure caused by the DataSpace operations
332  catch( const H5::DataTypeIException& error )
333  {
335  << MODULE << " caught H5::DataTypeIException!" << std::endl;
336  error.printError();
337  }
338  catch( ... )
339  {
341  << MODULE << " caught unknown exception !" << std::endl;
342  }
343
344  } // Matches: if ( m_dataset )
345
346 } // End: ossimH5ImageDataset::getTileBuf
ossim_int32 y
Definition: ossimIpt.h:142
ossim_uint32 area() const
Definition: ossimIrect.h:396
ossim_int32 x
Definition: ossimIpt.h:141
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
int ossim_int32
◆ getValidImageRect()
const ossimIrect & ossimH5ImageDataset::getValidImageRect ( ) const
Definition at line 211 of file ossimH5ImageDataset.cpp.
References m_validRect.
212 {
213  return m_validRect;
214 }
◆ initialize()
bool ossimH5ImageDataset::initialize ( const H5::DataSet &  dataset,
const std::string &  datasetName
Returns
Definition at line 95 of file ossimH5ImageDataset.cpp.
References ossim::byteOrder(), close(), ossim_hdf5::getByteOrder(), ossim_hdf5::getExtents(), ossim_hdf5::getScalarType(), ossim_hdf5::getValidBoundingRect(), m_bands, m_dataset, m_datasetName, m_endian, m_lines, m_samples, m_scalar, m_validRect, OSSIM_SCALAR_UNKNOWN, and ossim::scalarSizeInBytes().
Referenced by ossimH5ImageHandler::addImageDatasetEntries().
97 {
98  bool result = false;
99
100  // Clear old stuff.
101  close();
102
103  m_dataset = new H5::DataSet( dataset );
104  m_datasetName = datasetName;
105
107  {
108  // Get the extents:
109  std::vector<ossim_uint32> extents;
110  ossim_hdf5::getExtents( m_dataset, extents );
111  if ( extents.size() >= 2 )
112  {
113  m_samples = extents[1];
114  m_lines = extents[0];
115  if ( extents.size() >= 3 )
116  {
117  m_bands = extents[2];
118  }
119  else
120  {
121  m_bands = 1;
122  }
123
124  // Scalar type:
126
128  {
129  result = true;
130
131  // Byte swapping logic:
132  if ( ( ossim::scalarSizeInBytes( m_scalar ) > 1 ) &&
134  {
135  m_endian = new ossimEndian();
136  }
137  }
138  }
139  }
140
141  if ( !result )
142  {
143  // One dimensional dataset:
144  close();
145  }
146
147  return result;
148
149 } // End: ossimH5ImageDataset::initialize
void close()
ossimScalarType getScalarType(const H5::DataSet *dataset)
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
OSSIM_DLL ossim_uint32 scalarSizeInBytes(ossimScalarType scalarType)
ossimByteOrder getByteOrder(const H5::AbstractDs *dataset)
bool getValidBoundingRect(H5::DataSet &dataset, const std::string &name, ossimIrect &rect)
Gets the valid bounding rect of the dataset excluding nulls on front and back.
void getExtents(const H5::DataSet *dataset, std::vector< ossim_uint32 > &extents)
◆ operator=()
const ossimH5ImageDataset & ossimH5ImageDataset::operator= ( const ossimH5ImageDataset rhs)
Definition at line 68 of file ossimH5ImageDataset.cpp.
References m_bands, m_dataset, m_datasetName, m_endian, m_lines, m_samples, m_scalar, and m_validRect.
69 {
70  if ( this != &rhs )
71  {
72  if ( m_dataset )
73  {
74  delete m_dataset;
75  }
76  if ( rhs.m_dataset )
77  {
78  m_dataset = new H5::DataSet( *(rhs.m_dataset) );
79  }
80  else
81  {
82  m_dataset = 0;
83  }
85  m_scalar = rhs.m_scalar;
86  m_bands = rhs.m_bands;
87  m_lines = rhs.m_lines;
88  m_samples = rhs.m_samples;
90  m_endian = ( rhs.m_endian ? new ossimEndian() : 0 );
91  }
92  return *this;
93 }
◆ print()
std::ostream & ossimH5ImageDataset::print ( std::ostream &  out) const
print method.
Returns
std::ostream&
Definition at line 349 of file ossimH5ImageDataset.cpp.
References ossimLookUpTable::getEntryString(), ossimScalarTypeLut::instance(), m_bands, m_dataset, m_datasetName, m_endian, m_lines, m_samples, m_scalar, and m_validRect.
Referenced by operator<<().
350 {
351  out << "ossimH5ImageDataset: "
352  << "\nH5::DataSet::id: " << (m_dataset?m_dataset->getId():0)
353  << "\nname: " << m_datasetName
354  << "\nscalar: " << ossimScalarTypeLut::instance()->getEntryString( m_scalar )
355  << "\nbands: " << m_bands
356  << "\nlines: " << m_lines
357  << "\nsamples: " << m_samples
358  << "\nvalid rect: " << m_validRect
359  << "\nswap_flage: " << (m_endian?"true":"false")
360  << std::endl;
361  return out;
362 }
virtual ossimString getEntryString(ossim_int32 entry_number) const
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
◆ operator<<
OSSIMDLLEXPORT std::ostream& operator<< ( std::ostream &  out,
friend
Definition at line 364 of file ossimH5ImageDataset.cpp.
365 {
366  return obj.print( out );
367 }
std::ostream & print(std::ostream &out) const
print method.
Member Data Documentation
◆ m_bands
ossim_uint32 ossimH5ImageDataset::m_bands
private
Definition at line 126 of file ossimH5ImageDataset.h.
Referenced by getNumberOfBands(), initialize(), operator=(), and print().
◆ m_dataset
H5::DataSet* ossimH5ImageDataset::m_dataset
private
◆ m_datasetName
std::string ossimH5ImageDataset::m_datasetName
private
Definition at line 124 of file ossimH5ImageDataset.h.
Referenced by getName(), initialize(), operator=(), and print().
◆ m_endian
ossimEndian* ossimH5ImageDataset::m_endian
private
Definition at line 138 of file ossimH5ImageDataset.h.
Referenced by close(), getSwapFlag(), getTileBuf(), initialize(), operator=(), and print().
◆ m_lines
ossim_uint32 ossimH5ImageDataset::m_lines
private
Definition at line 127 of file ossimH5ImageDataset.h.
Referenced by initialize(), operator=(), and print().
◆ m_samples
ossim_uint32 ossimH5ImageDataset::m_samples
private
Definition at line 128 of file ossimH5ImageDataset.h.
◆ m_scalar
ossimScalarType ossimH5ImageDataset::m_scalar
private
Definition at line 125 of file ossimH5ImageDataset.h.
Referenced by getScalarType(), getTileBuf(), initialize(), operator=(), and print().
◆ m_validRect
ossimIrect ossimH5ImageDataset::m_validRect
private
H5 data can have null rows on the front or end. The valid rect is the scanned rectangle disregarding leading or trailing nulls. This does not handle null rows in the middle of the image.
Definition at line 137 of file ossimH5ImageDataset.h.
Referenced by getNumberOfLines(), getNumberOfSamples(), getSubImageOffset(), getTileBuf(), getValidImageRect(), initialize(), operator=(), and print().
