ossimScalarTypeLut.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: David Burken
6 //
7 // Description:
8 //
9 // Contains class definition for ossimScalarTypeLUT.
10 //
11 //*******************************************************************
12 // $Id: ossimScalarTypeLut.cpp 22072 2013-01-04 13:46:52Z dburken $
13
15 #include <ossim/base/ossimString.h>
16
18
20 {
21  if (!theInstance)
22  {
24  }
25  return theInstance;
26 }
27
29 {
30  //---
31  // Complete initialization of data member "theTable".
32  // Note: Scalar types defined in constants.h file.
33  //---
34  ossimKeyValueMap entry;
35  entry.init(OSSIM_SCALAR_UNKNOWN, "unknown");
36  theTable.push_back(entry);
37
38  entry.init(OSSIM_UINT8, "ossim_uint8");
39  theTable.push_back(entry);
40
41  entry.init(OSSIM_SINT8, "ossim_sint8");
42  theTable.push_back(entry);
43
44  entry.init(OSSIM_UINT16, "ossim_uint16");
45  theTable.push_back(entry);
46
47  entry.init(OSSIM_SINT16, "ossim_sint16");
48  theTable.push_back(entry);
49
50  entry.init(OSSIM_UINT32, "ossim_uint32");
51  theTable.push_back(entry);
52
53  entry.init(OSSIM_SINT32, "ossim_sint32");
54  theTable.push_back(entry);
55
56  entry.init(OSSIM_UINT64, "ossim_uint64");
57  theTable.push_back(entry);
58
59  entry.init(OSSIM_SINT64, "ossim_sint64");
60  theTable.push_back(entry);
61
62  entry.init(OSSIM_FLOAT32, "ossim_float32");
63  theTable.push_back(entry);
64
65  entry.init(OSSIM_FLOAT64, "ossim_float64");
66  theTable.push_back(entry);
67
68  entry.init(OSSIM_CINT16, "ossim_cint16");
69  theTable.push_back(entry);
70
71  entry.init(OSSIM_CINT32, "ossim_cint32");
72  theTable.push_back(entry);
73
74  entry.init(OSSIM_CFLOAT32, "ossim_cfloat32");
75  theTable.push_back(entry);
76
77  entry.init(OSSIM_CFLOAT64, "ossim_cfloat64");
78  theTable.push_back(entry);
79
80  entry.init(OSSIM_UCHAR, "uchar");
81  theTable.push_back(entry);
82
83  entry.init(OSSIM_USHORT16, "ushort16");
84  theTable.push_back(entry);
85
86  entry.init(OSSIM_SSHORT16, "sshort16");
87  theTable.push_back(entry);
88
89  entry.init(OSSIM_USHORT11, "ushort11");
90  theTable.push_back(entry);
91
92  entry.init(OSSIM_USHORT12, "ushort12");
93  theTable.push_back(entry);
94
95  entry.init(OSSIM_USHORT13, "ushort13");
96  theTable.push_back(entry);
97
98  entry.init(OSSIM_USHORT14, "ushort14");
99  theTable.push_back(entry);
100
101  entry.init(OSSIM_USHORT15, "ushort15");
102  theTable.push_back(entry);
103
104  entry.init(OSSIM_FLOAT, "float");
105  theTable.push_back(entry);
106
107  entry.init(OSSIM_NORMALIZED_FLOAT, "normalized_float");
108  theTable.push_back(entry);
109
110  entry.init(OSSIM_NORMALIZED_DOUBLE, "normalized_double");
111  theTable.push_back(entry);
112
113  entry.init(OSSIM_DOUBLE, "double");
114  theTable.push_back(entry);
115
116  // Short forms:
117
118  entry.init(OSSIM_UINT8, "U8");
119  theTable.push_back(entry);
120
121  entry.init(OSSIM_SINT8, "S8");
122  theTable.push_back(entry);
123
124  entry.init(OSSIM_USHORT11, "U11");
125  theTable.push_back(entry);
126
127  entry.init(OSSIM_USHORT12, "U12");
128  theTable.push_back(entry);
129
130  entry.init(OSSIM_USHORT13, "U13");
131  theTable.push_back(entry);
132
133  entry.init(OSSIM_USHORT14, "U14");
134  theTable.push_back(entry);
135
136  entry.init(OSSIM_USHORT15, "U15");
137  theTable.push_back(entry);
138
139  entry.init(OSSIM_UINT16, "U16");
140  theTable.push_back(entry);
141
142  entry.init(OSSIM_SINT16, "S16");
143  theTable.push_back(entry);
144
145  entry.init(OSSIM_FLOAT32, "F32");
146  theTable.push_back(entry);
147
148  entry.init(OSSIM_FLOAT64, "F64");
149  theTable.push_back(entry);
150
151  entry.init(OSSIM_NORMALIZED_FLOAT, "N32");
152  theTable.push_back(entry);
153
154  entry.init(OSSIM_NORMALIZED_DOUBLE, "N64");
155  theTable.push_back(entry);
156
157  // Forms from old code "radiometry" key in ossimImageMetaData:
158
159  entry.init(OSSIM_UINT8, "8-bit");
160  theTable.push_back(entry);
161
162  entry.init(OSSIM_USHORT11, "11-bit");
163  theTable.push_back(entry);
164
165  entry.init(OSSIM_USHORT12, "12-bit");
166  theTable.push_back(entry);
167
168  entry.init(OSSIM_USHORT13, "13-bit");
169  theTable.push_back(entry);
170
171  entry.init(OSSIM_USHORT14, "14-bit");
172  theTable.push_back(entry);
173
174  entry.init(OSSIM_USHORT15, "15-bit");
175  theTable.push_back(entry);
176
177  entry.init(OSSIM_UINT16, "16-bit unsigned");
178  theTable.push_back(entry);
179
180  entry.init(OSSIM_SINT16, "16-bit signed");
181  theTable.push_back(entry);
182
183  entry.init(OSSIM_UINT32, "32-bit unsigned");
184  theTable.push_back(entry);
185
186  entry.init(OSSIM_FLOAT32, "float");
187  theTable.push_back(entry);
188
189  entry.init(OSSIM_NORMALIZED_FLOAT, "normalized float");
190  theTable.push_back(entry);
191
192  entry.init(OSSIM_FLOAT64, "double");
193  theTable.push_back(entry);
194
195  entry.init(OSSIM_NORMALIZED_DOUBLE, "normalized double");
196  theTable.push_back(entry);
197 }
198
200 {
201  theInstance = NULL;
202 }
203
206 {
207  int scalar_type = getEntryNumber(s.c_str());
208
209  if (scalar_type == -1)
210  {
211  return OSSIM_SCALAR_UNKNOWN;
212  }
213
214  return static_cast<ossimScalarType>(scalar_type);
215 }
216
218 {
220 }
8 bit signed integer
std::vector< ossimKeyValueMap > theTable
void init(ossim_int32 key, const ossimString &value)
32 bit complex floating point
ossimScalarType getScalarTypeFromString(const ossimString &s) const
64 bit floating point
16 bit unsigned integer
virtual ossimKeyword getKeyword() const
16 bit signed integer
32 bit floating point
32 bit unsigned integer
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
64 bit signed integer
32 bit signed integer
static ossimScalarTypeLut * theInstance
ossimScalarType
16 bit complex integer
Used to convert from scalar type enumeration to strings and vice versa.
64 bit unsigned integer
const char * c_str() const
Definition: ossimString.h:396
static const char * SCALAR_TYPE_KW
64 bit complex floating point
8 bit unsigned integer
32 bit complex integer
16 bit unsigned iteger
8 bit unsigned iteger
