Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Private Attributes | List of all members
ossimScalarTypeLut Class Reference
Used to convert from scalar type enumeration to strings and vice versa. More...
#include <ossimScalarTypeLut.h>
Inheritance diagram for ossimScalarTypeLut:
ossimLookUpTable
virtual ~ossimScalarTypeLut ()
ossimScalarType getScalarTypeFromString (const ossimString &s) const
virtual ossimKeyword getKeyword () const
- Public Member Functions inherited from ossimLookUpTable
 ossimLookUpTable (const std::initializer_list< ossimString > &stringInitializer)
 By default if you just give an initializer list with strings then it will assume keys 0..n-1 for each string. More...
virtual ~ossimLookUpTable ()
virtual ossimString getEntryString (ossim_int32 entry_number) const
virtual ossimString getTableIndexString (ossim_uint32 table_index) const
virtual ossimString operator[] (ossim_int32 entry_number) const
virtual ossimString getEntryString (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual ossim_int32 getEntryNumber (const char *entry_string, bool case_insensitive=true) const
virtual ossim_int32 getEntryNumber (const ossimKeywordlist &kwl, const char *prefix=0, bool case_insensitive=true) const
virtual ossim_uint32 getTableSize () const
void dumpValues (std::ostream &out) const
static ossimScalarTypeLutinstance ()
 Returns the static instance of an ossimScalarTypeLut object. More...
- Protected Member Functions inherited from ossimLookUpTable
 ossimLookUpTable (ossim_int32 table_size)
 ossimLookUpTable ()
static ossimScalarTypeLuttheInstance = NULL
Additional Inherited Members
- Public Types inherited from ossimLookUpTable
enum  { NOT_FOUND = -1 }
- Protected Attributes inherited from ossimLookUpTable
std::vector< ossimKeyValueMaptheTable
Detailed Description
See ossimConstants.h for a complete list of enumerations. This class is a singleton, only one of them so all callers must go through the instance method like: ossimScalarTypeLut::instance()->getEntryString(scalar);
Definition at line 27 of file ossimScalarTypeLut.h.
◆ ~ossimScalarTypeLut()
ossimScalarTypeLut::~ossimScalarTypeLut ( )
virtual
Definition at line 199 of file ossimScalarTypeLut.cpp.
References theInstance.
200 {
201  theInstance = NULL;
202 }
static ossimScalarTypeLut * theInstance
◆ ossimScalarTypeLut()
ossimScalarTypeLut::ossimScalarTypeLut ( )
protected
Definition at line 28 of file ossimScalarTypeLut.cpp.
References ossimLookUpTable::ossimKeyValueMap::init(), OSSIM_CFLOAT32, OSSIM_CFLOAT64, OSSIM_CINT16, OSSIM_CINT32, OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT64, OSSIM_SINT8, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT64, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, and ossimLookUpTable::theTable.
Referenced by instance().
29 {
30  //---
31  // Complete initialization of data member "theTable".
32  // Note: Scalar types defined in constants.h file.
33  //---
34  ossimKeyValueMap entry;
35  entry.init(OSSIM_SCALAR_UNKNOWN, "unknown");
36  theTable.push_back(entry);
37
38  entry.init(OSSIM_UINT8, "ossim_uint8");
39  theTable.push_back(entry);
40
41  entry.init(OSSIM_SINT8, "ossim_sint8");
42  theTable.push_back(entry);
43
44  entry.init(OSSIM_UINT16, "ossim_uint16");
45  theTable.push_back(entry);
46
47  entry.init(OSSIM_SINT16, "ossim_sint16");
48  theTable.push_back(entry);
49
50  entry.init(OSSIM_UINT32, "ossim_uint32");
51  theTable.push_back(entry);
52
53  entry.init(OSSIM_SINT32, "ossim_sint32");
54  theTable.push_back(entry);
55
56  entry.init(OSSIM_UINT64, "ossim_uint64");
57  theTable.push_back(entry);
58
59  entry.init(OSSIM_SINT64, "ossim_sint64");
60  theTable.push_back(entry);
61
62  entry.init(OSSIM_FLOAT32, "ossim_float32");
63  theTable.push_back(entry);
64
65  entry.init(OSSIM_FLOAT64, "ossim_float64");
66  theTable.push_back(entry);
67
68  entry.init(OSSIM_CINT16, "ossim_cint16");
69  theTable.push_back(entry);
70
71  entry.init(OSSIM_CINT32, "ossim_cint32");
72  theTable.push_back(entry);
73
74  entry.init(OSSIM_CFLOAT32, "ossim_cfloat32");
75  theTable.push_back(entry);
76
77  entry.init(OSSIM_CFLOAT64, "ossim_cfloat64");
78  theTable.push_back(entry);
79
80  entry.init(OSSIM_UCHAR, "uchar");
81  theTable.push_back(entry);
82
83  entry.init(OSSIM_USHORT16, "ushort16");
84  theTable.push_back(entry);
85
86  entry.init(OSSIM_SSHORT16, "sshort16");
87  theTable.push_back(entry);
88
89  entry.init(OSSIM_USHORT11, "ushort11");
90  theTable.push_back(entry);
91
92  entry.init(OSSIM_USHORT12, "ushort12");
93  theTable.push_back(entry);
94
95  entry.init(OSSIM_USHORT13, "ushort13");
96  theTable.push_back(entry);
97
98  entry.init(OSSIM_USHORT14, "ushort14");
99  theTable.push_back(entry);
100
101  entry.init(OSSIM_USHORT15, "ushort15");
102  theTable.push_back(entry);
103
104  entry.init(OSSIM_FLOAT, "float");
105  theTable.push_back(entry);
106
107  entry.init(OSSIM_NORMALIZED_FLOAT, "normalized_float");
108  theTable.push_back(entry);
109
110  entry.init(OSSIM_NORMALIZED_DOUBLE, "normalized_double");
111  theTable.push_back(entry);
112
113  entry.init(OSSIM_DOUBLE, "double");
114  theTable.push_back(entry);
115
116  // Short forms:
117
118  entry.init(OSSIM_UINT8, "U8");
119  theTable.push_back(entry);
120
121  entry.init(OSSIM_SINT8, "S8");
122  theTable.push_back(entry);
123
124  entry.init(OSSIM_USHORT11, "U11");
125  theTable.push_back(entry);
126
127  entry.init(OSSIM_USHORT12, "U12");
128  theTable.push_back(entry);
129
130  entry.init(OSSIM_USHORT13, "U13");
131  theTable.push_back(entry);
132
133  entry.init(OSSIM_USHORT14, "U14");
134  theTable.push_back(entry);
135
136  entry.init(OSSIM_USHORT15, "U15");
137  theTable.push_back(entry);
138
139  entry.init(OSSIM_UINT16, "U16");
140  theTable.push_back(entry);
141
142  entry.init(OSSIM_SINT16, "S16");
143  theTable.push_back(entry);
144
145  entry.init(OSSIM_FLOAT32, "F32");
146  theTable.push_back(entry);
147
148  entry.init(OSSIM_FLOAT64, "F64");
149  theTable.push_back(entry);
150
151  entry.init(OSSIM_NORMALIZED_FLOAT, "N32");
152  theTable.push_back(entry);
153
154  entry.init(OSSIM_NORMALIZED_DOUBLE, "N64");
155  theTable.push_back(entry);
156
157  // Forms from old code "radiometry" key in ossimImageMetaData:
158
159  entry.init(OSSIM_UINT8, "8-bit");
160  theTable.push_back(entry);
161
162  entry.init(OSSIM_USHORT11, "11-bit");
163  theTable.push_back(entry);
164
165  entry.init(OSSIM_USHORT12, "12-bit");
166  theTable.push_back(entry);
167
168  entry.init(OSSIM_USHORT13, "13-bit");
169  theTable.push_back(entry);
170
171  entry.init(OSSIM_USHORT14, "14-bit");
172  theTable.push_back(entry);
173
174  entry.init(OSSIM_USHORT15, "15-bit");
175  theTable.push_back(entry);
176
177  entry.init(OSSIM_UINT16, "16-bit unsigned");
178  theTable.push_back(entry);
179
180  entry.init(OSSIM_SINT16, "16-bit signed");
181  theTable.push_back(entry);
182
183  entry.init(OSSIM_UINT32, "32-bit unsigned");
184  theTable.push_back(entry);
185
186  entry.init(OSSIM_FLOAT32, "float");
187  theTable.push_back(entry);
188
189  entry.init(OSSIM_NORMALIZED_FLOAT, "normalized float");
190  theTable.push_back(entry);
191
192  entry.init(OSSIM_FLOAT64, "double");
193  theTable.push_back(entry);
194
195  entry.init(OSSIM_NORMALIZED_DOUBLE, "normalized double");
196  theTable.push_back(entry);
197 }
8 bit signed integer
std::vector< ossimKeyValueMap > theTable
32 bit complex floating point
64 bit floating point
16 bit unsigned integer
16 bit signed integer
32 bit floating point
32 bit unsigned integer
64 bit signed integer
32 bit signed integer
16 bit complex integer
64 bit unsigned integer
64 bit complex floating point
8 bit unsigned integer
32 bit complex integer
16 bit unsigned iteger
8 bit unsigned iteger
Member Function Documentation
◆ getKeyword()
ossimKeyword ossimScalarTypeLut::getKeyword ( ) const
virtual
Returns keyword for lookups from a Keywordlist.
Reimplemented from ossimLookUpTable.
Definition at line 217 of file ossimScalarTypeLut.cpp.
References ossimKeywordNames::SCALAR_TYPE_KW.
218 {
220 }
static const char * SCALAR_TYPE_KW
◆ getScalarTypeFromString()
ossimScalarType ossimScalarTypeLut::getScalarTypeFromString ( const ossimString s) const
Definition at line 205 of file ossimScalarTypeLut.cpp.
References ossimString::c_str(), ossimLookUpTable::getEntryNumber(), and OSSIM_SCALAR_UNKNOWN.
Referenced by ossimRectilinearDataObject::loadState(), and ossimImageMetaData::updateMetaData().
206 {
207  int scalar_type = getEntryNumber(s.c_str());
208
209  if (scalar_type == -1)
210  {
211  return OSSIM_SCALAR_UNKNOWN;
212  }
213
214  return static_cast<ossimScalarType>(scalar_type);
215 }
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
ossimScalarType
const char * c_str() const
Definition: ossimString.h:396
◆ instance()
ossimScalarTypeLut * ossimScalarTypeLut::instance ( )
static
Definition at line 19 of file ossimScalarTypeLut.cpp.
References ossimScalarTypeLut(), and theInstance.
Referenced by ossim_hdf5::crossesDateline(), demo1(), ossimHdf5Info::dumpNumericalTypeInfo(), ossim_hdf5::getBilinearProjection(), ossimCastTileSourceFilter::getOutputScalarTypeString(), ossimCastTileSourceFilter::getProperty(), ossimEquationCombiner::getProperty(), ossimImageHandler::getProperty(), ossimImageData::getScalarTypeAsString(), ossim_hdf5::getValidBoundingRect(), ossimChipProcTool::initialize(), ossimSrtmSupportData::loadOmd(), ossimTableRemapper::loadState(), ossimCastTileSourceFilter::loadState(), ossimRectilinearDataObject::loadState(), ossimNBandLutDataObject::loadState(), main(), ossimGeoidImage::offsetFromEllipsoid(), ossimCcfHead::print(), ossimTableRemapper::print(), ossimH5ImageDataset::print(), ossimHdf5ImageDataset::print(), ossimRectilinearDataObject::print(), ossim_hdf5::printObject(), ossimTableRemapper::saveState(), ossimCastTileSourceFilter::saveState(), ossimImageMetaData::saveState(), ossimRectilinearDataObject::saveState(), ossimEquationCombiner::saveState(), ossimNBandLutDataObject::saveState(), ossimHdf5ImageDataset::scanForValidImageRect(), ossimCastTileSourceFilter::setOutputScalarType(), ossimBandLutFilter::setOutputScalarType(), ossimCastTileSourceFilter::setProperty(), ossimEquationCombiner::setProperty(), ossimImageMetaData::updateMetaData(), and ossimImageData::write().
20 {
21  if (!theInstance)
22  {
24  }
25  return theInstance;
26 }
Member Data Documentation
◆ theInstance
ossimScalarTypeLut * ossimScalarTypeLut::theInstance = NULL
staticprivate
Definition at line 47 of file ossimScalarTypeLut.h.
Referenced by instance(), and ~ossimScalarTypeLut().
