Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimImageMetaDataWriterRegistry Class Reference
#include <ossimImageMetaDataWriterRegistry.h>
Inheritance diagram for ossimImageMetaDataWriterRegistry:
ossimImageMetaDataWriterFactoryBase ossimObjectFactory ossimObject ossimReferenced
 ~ossimImageMetaDataWriterRegistry ()
void registerFactory (ossimImageMetaDataWriterFactoryBase *factory)
void unregisterFactory (ossimImageMetaDataWriterFactoryBase *factory)
bool findFactory (ossimImageMetaDataWriterFactoryBase *factory) const
virtual ossimObjectcreateObject (const ossimString &typeName) const
 Creates an object given a type name. More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list. More...
virtual ossimRefPtr< ossimMetadataFileWritercreateWriter (const ossimString &type) const
 Creates a writer from either a class name or a string representing the meta data type like "tiff_world_file". More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 This should return the type name of all objects in all factories. More...
virtual void getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const
 Initializes list with meta data types from all registered metadata factories. More...
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimImageMetaDataWriterRegistryinstance ()
 ossimImageMetaDataWriterRegistry (const ossimImageMetaDataWriterRegistry &rhs)
const ossimImageMetaDataWriterRegistryoperator= (const ossimImageMetaDataWriterRegistry &rhs)
- Protected Member Functions inherited from ossimImageMetaDataWriterFactoryBase
 ossimImageMetaDataWriterFactoryBase ()
 ossimImageMetaDataWriterFactoryBase (const ossimImageMetaDataWriterFactoryBase &)
const ossimImageMetaDataWriterFactoryBaseoperator= (const ossimImageMetaDataWriterFactoryBase &)
virtual ~ossimReferenced ()
std::vector< ossimImageMetaDataWriterFactoryBase * > theFactoryList
Detailed Description
Definition at line 15 of file ossimImageMetaDataWriterRegistry.h.
◆ ~ossimImageMetaDataWriterRegistry()
ossimImageMetaDataWriterRegistry::~ossimImageMetaDataWriterRegistry ( )
Definition at line 24 of file ossimImageMetaDataWriterRegistry.cpp.
References ossimObjectFactoryRegistry::instance(), and ossimFactoryListInterface< T, NativeType >::unregisterFactory().
25 {
27 }
static ossimObjectFactoryRegistry * instance()
void unregisterFactory(T *factory)
Will remove the factory from the registry.
◆ ossimImageMetaDataWriterRegistry() [1/2]
ossimImageMetaDataWriterRegistry::ossimImageMetaDataWriterRegistry ( )
protected
Definition at line 18 of file ossimImageMetaDataWriterRegistry.cpp.
References ossimObjectFactoryRegistry::instance(), ossimImageMetaDataWriterFactory::instance(), registerFactory(), and ossimFactoryListInterface< T, NativeType >::registerFactory().
19 {
22 }
void registerFactory(ossimImageMetaDataWriterFactoryBase *factory)
static ossimImageMetaDataWriterFactory * instance()
void registerFactory(T *factory, bool pushToFrontFlag=false)
Will register a factory to the factory list.
◆ ossimImageMetaDataWriterRegistry() [2/2]
ossimImageMetaDataWriterRegistry::ossimImageMetaDataWriterRegistry ( const ossimImageMetaDataWriterRegistry rhs)
protected
Definition at line 153 of file ossimImageMetaDataWriterRegistry.cpp.
155 {
156 }
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimImageMetaDataWriterRegistry::createObject ( const ossimString typeName) const
virtual
Implements ossimObjectFactory.
Definition at line 67 of file ossimImageMetaDataWriterRegistry.cpp.
References theFactoryList.
69 {
70  ossimObject* result = NULL;
71  std::vector<ossimImageMetaDataWriterFactoryBase*>::const_iterator factory;
72
73  factory = theFactoryList.begin();
74  while((factory != theFactoryList.end()) && !result)
75  {
76  result = (*factory)->createObject(typeName);
77  ++factory;
78  }
79
80  return result;
81 }
◆ createObject() [2/2]
ossimObject * ossimImageMetaDataWriterRegistry::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Definition at line 83 of file ossimImageMetaDataWriterRegistry.cpp.
86 {
87  ossimObject* result = NULL;
88  std::vector<ossimImageMetaDataWriterFactoryBase*>::const_iterator factory;
89
90  factory = theFactoryList.begin();
91  while((factory != theFactoryList.end()) && !result)
92  {
93  result = (*factory)->createObject(kwl, prefix);
94  ++factory;
95  }
96  return result;
97 }
◆ createWriter()
ossimRefPtr< ossimMetadataFileWriter > ossimImageMetaDataWriterRegistry::createWriter ( const ossimString type) const
virtual
Returns
ossimRefPtr<ossimMetadataFileWriter>
Note
Return can have a null pointer if type is not found in a factory so the caller should always check the pointer like: ossimRefPtr<ossimMetadataFileWriter> mw = ossimImageMetaDataWriterRegistry::instance("ossim_readme"); if (!mw.valid()) { // not in factory }
Implements ossimImageMetaDataWriterFactoryBase.
Definition at line 100 of file ossimImageMetaDataWriterRegistry.cpp.
101 {
103
104  std::vector<ossimImageMetaDataWriterFactoryBase*>::const_iterator factory;
105  factory = theFactoryList.begin();
106  while((factory != theFactoryList.end()) && !result)
107  {
108  result = (*factory)->createWriter(type);
109  ++factory;
110  }
111  return result;
112 }
◆ findFactory()
bool ossimImageMetaDataWriterRegistry::findFactory ( ossimImageMetaDataWriterFactoryBase factory) const
Definition at line 58 of file ossimImageMetaDataWriterRegistry.cpp.
Referenced by registerFactory().
60 {
61  return (std::find(theFactoryList.begin(),
62  theFactoryList.end(),
63  factory)!=theFactoryList.end());
64 }
◆ getMetadatatypeList()
void ossimImageMetaDataWriterRegistry::getMetadatatypeList ( std::vector< ossimString > &  metadatatypeList) const
virtual
This is the actual image type name like: ossim_geometry envi_header tiff_world_file jpeg_world_file
Parameters
metadatatypeListstl::vector<ossimString> list to append to.
Note
Since this is the master registry for all meta data factories this method starts by clearing the metadatatypeList.
Definition at line 134 of file ossimImageMetaDataWriterRegistry.cpp.
136 {
137  //---
138  // Since this is the master registry for all meta data writer factories
139  // we will start with a cleared list.
140  //---
141  metadatatypeList.clear();
142
143  std::vector<ossimImageMetaDataWriterFactoryBase*>::const_iterator iter =
144  theFactoryList.begin();
145
146  while(iter != theFactoryList.end())
147  {
148  (*iter)->getMetadatatypeList(metadatatypeList);
149  ++iter;
150  }
151 }
◆ getTypeNameList()
void ossimImageMetaDataWriterRegistry::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 114 of file ossimImageMetaDataWriterRegistry.cpp.
116 {
117  std::vector<ossimString> result;
118  std::vector<ossimImageMetaDataWriterFactoryBase*>::const_iterator iter =
119  theFactoryList.begin();
120
121  while(iter != theFactoryList.end())
122  {
123  result.clear();
124  (*iter)->getTypeNameList(result);
125
126  // now append to the end of the typeList.
127  typeList.insert(typeList.end(),
128  result.begin(),
129  result.end());
130  ++iter;
131  }
132 }
◆ instance()
ossimImageMetaDataWriterRegistry * ossimImageMetaDataWriterRegistry::instance ( )
static
◆ operator=()
const ossimImageMetaDataWriterRegistry & ossimImageMetaDataWriterRegistry::operator= ( const ossimImageMetaDataWriterRegistry rhs)
protected
Definition at line 159 of file ossimImageMetaDataWriterRegistry.cpp.
161 {
162  return *this;
163 }
◆ registerFactory()
void ossimImageMetaDataWriterRegistry::registerFactory ( ossimImageMetaDataWriterFactoryBase factory)
Definition at line 36 of file ossimImageMetaDataWriterRegistry.cpp.
References findFactory(), and theFactoryList.
Referenced by ossimImageMetaDataWriterRegistry().
38 {
39  if(factory&&!findFactory(factory))
40  {
41  theFactoryList.push_back(factory);
42  }
43 }
bool findFactory(ossimImageMetaDataWriterFactoryBase *factory) const
◆ unregisterFactory()
void ossimImageMetaDataWriterRegistry::unregisterFactory ( ossimImageMetaDataWriterFactoryBase factory)
Definition at line 45 of file ossimImageMetaDataWriterRegistry.cpp.
47 {
48  std::vector<ossimImageMetaDataWriterFactoryBase*>::iterator iter =
49  std::find(theFactoryList.begin(),
50  theFactoryList.end(),
51  factory);
52  if(iter != theFactoryList.end())
53  {
54  theFactoryList.erase(iter);
55  }
56 }
Member Data Documentation
◆ theFactoryList
std::vector<ossimImageMetaDataWriterFactoryBase*> ossimImageMetaDataWriterRegistry::theFactoryList
protected
