ossimMetadataFileWriter Class Referenceabstract
ossimMetadataFileWriter More...
#include <ossimMetadataFileWriter.h>
Inheritance diagram for ossimMetadataFileWriter:
ossimConnectableObject ossimProcessInterface ossimConnectableObjectListener ossimObject ossimListenerManager ossimPropertyInterface ossimListener ossimReferenced ossimEnviHeaderFileWriter ossimERSFileWriter ossimFgdcFileWriter ossimGeomFileWriter ossimReadmeFileWriter ossimWorldFileWriter
Public Member Functions
 ossimMetadataFileWriter ()
virtual void initialize ()
virtual bool execute ()
virtual void setFilename (const ossimFilename &file)
const ossimFilenamegetFilename () const
 Load state method: More...
virtual void setPixelType (ossimPixelType pixelType)
 Ossim uses a concept of "pixel is point" internally. More...
virtual ossimPixelType getPixelType () const
virtual void setAreaOfInterest (const ossimIrect &areaOfInterest)
 Sets the area of interest to write the meta data for. More...
virtual ossimIrect getAreaOfInterest () const
virtual void getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const =0
 void getMetadatatypeList(std::vector<ossimString>& metadatatypeList)const More...
virtual bool hasMetadataType (const ossimString &metadataType) const =0
 bool hasMetadataType(const ossimString& metadataType) const More...
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimMetadataFileWriter ()
virtual bool writeFile ()=0
 Write out the file. More...
virtual ~ossimReferenced ()
Protected Attributes
ossimFilename theFilename
ossimPixelType thePixelType
ossimIrect theAreaOfInterest
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
Detailed Description
Typical usage something like this:
ossimObject* obj = ossimImageMetaDataWriterRegistry::instance()-> createObject(ossimString("ossimReadmeFileWriter")); if (!obj) { return; } ossimMetadataFileWriter* mw = PTR_CAST(ossimMetadataFileWriter, obj); if (!mw) { return; }
mw->setFilename(xmlFile); mw->loadState(kwl); mw->connectMyInputTo(ih.get()); mw->execute(); delete mw;
Definition at line 50 of file ossimMetadataFileWriter.h.
◆ ossimMetadataFileWriter()
ossimMetadataFileWriter::ossimMetadataFileWriter ( )
Definition at line 32 of file ossimMetadataFileWriter.cpp.
References ossimListenerManager::addListener(), ossimIrect::makeNan(), and theAreaOfInterest.
◆ ~ossimMetadataFileWriter()
ossimMetadataFileWriter::~ossimMetadataFileWriter ( )
protectedvirtual
Member Function Documentation
◆ canConnectMyInputTo()
bool ossimMetadataFileWriter::canConnectMyInputTo ( ossim_int32  myInputIndex,
const ossimConnectableObject object
) const
virtual
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 220 of file ossimMetadataFileWriter.cpp.
References PTR_CAST.
222 {
223  return (object &&
224  ((PTR_CAST(ossimImageSource, object) &&
225  inputIndex == 0)||
226  (PTR_CAST(ossimViewController, object) &&
227  inputIndex == 1)));
228 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ connectInputEvent()
void ossimMetadataFileWriter::connectInputEvent ( ossimConnectionEvent event)
virtual
Reimplemented from ossimConnectableObjectListener.
Definition at line 101 of file ossimMetadataFileWriter.cpp.
References initialize().
102 {
103  initialize();
104 }
◆ disconnectInputEvent()
void ossimMetadataFileWriter::disconnectInputEvent ( ossimConnectionEvent event)
virtual
Definition at line 96 of file ossimMetadataFileWriter.cpp.
97 {
98  initialize();
99 }
◆ execute()
bool ossimMetadataFileWriter::execute ( )
virtual
Implements ossimProcessInterface.
Definition at line 131 of file ossimMetadataFileWriter.cpp.
References initialize(), and theInputConnection.
Referenced by ossimImageFileWriter::writeEnviHeaderFile(), ossimImageFileWriter::writeErsHeaderFile(), ossimImageFileWriter::writeExternalGeometryFile(), ossimImageFileWriter::writeFgdcFile(), ossimImageFileWriter::writeReadmeFile(), and ossimImageFileWriter::writeWorldFile().
132 {
133  bool result = false;
134  if (!theInputConnection)
135  {
136  initialize();
137  if (!theInputConnection)
138  {
139  if (traceDebug())
140  {
142  << "ossimMetadataFileWriter::execute DEBUG:\n"
143  << "theInputConnection is null!"
144  << endl;
145  }
146  return result;
147  }
148  }
149
151  {
152  if (traceDebug())
153  {
155  << "ossimMetadataFileWriter::execute DEBUG:\n"
156  << "theFilename is not set!"
157  << endl;
158  }
159  return result;
160  }
161
162  //---
163  // If theAreaOfInterest hasNans then it was probably not set so use
164  // the bounding rectangle of the input source.
165  //---
167  {
170  {
171  if (traceDebug())
172  {
174  << "ossimMetadataFileWriter::execute DEBUG:\n"
175  << "theAreaOfInterest is not set!"
176  << endl;
177  }
178  return result;
179  }
180  }
181
183
184  setPercentComplete(0.0);
185
186  result = writeFile();
187
189
190  if (traceDebug())
191  {
193  << "ossimMetadataFileWriter::execute DEBUG:\n"
194  << (result?"successful":"unsuccessful") << " write of file: "
195  << theFilename
196  << endl;
197  }
198
199  return result;
200 }
virtual bool writeFile()=0
Write out the file.
This will return the bounding rect of the source.
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
virtual void setProcessStatus(ossimProcessStatus processStatus)
virtual void setPercentComplete(double percentComplete)
bool hasNans() const
Definition: ossimIrect.h:337
◆ getAreaOfInterest()
ossimIrect ossimMetadataFileWriter::getAreaOfInterest ( ) const
virtual
Returns
theAreaOfInterest.
Definition at line 236 of file ossimMetadataFileWriter.cpp.
References theAreaOfInterest.
237 {
238  return theAreaOfInterest;
239 }
◆ getFilename()
const ossimFilename & ossimMetadataFileWriter::getFilename ( ) const
Definition at line 215 of file ossimMetadataFileWriter.cpp.
References theFilename.
216 {
217  return theFilename;
218 }
◆ getMetadatatypeList()
virtual void ossimMetadataFileWriter::getMetadatatypeList ( std::vector< ossimString > &  metadatatypeList) const
pure virtual
pure virtual
Appends the writers metadata types to the "metadatatypeList".
This is the actual image type name. So for example, ossimTiffWorldFileWriter has tiff_world_file type.
Parameters
metadatatypeListstl::vector<ossimString> list to append to.
Note
All writers should append to the list, not, clear it and then add their types.
Implemented in ossimFgdcFileWriter, ossimEnviHeaderFileWriter, ossimWorldFileWriter, ossimERSFileWriter, ossimReadmeFileWriter, and ossimGeomFileWriter.
Referenced by ossimImageMetaDataWriterFactory::getMetadatatypeList().
◆ getObject() [1/2]
ossimObject * ossimMetadataFileWriter::getObject ( )
virtual
Definition at line 121 of file ossimMetadataFileWriter.cpp.
122 {
123  return this;
124 }
◆ getObject() [2/2]
const ossimObject * ossimMetadataFileWriter::getObject ( ) const
virtual
Definition at line 126 of file ossimMetadataFileWriter.cpp.
127 {
128  return this;
129 }
◆ getPixelType()
ossimPixelType ossimMetadataFileWriter::getPixelType ( ) const
virtual
Definition at line 116 of file ossimMetadataFileWriter.cpp.
References thePixelType.
117 {
118  return thePixelType;
119 }
◆ getProperty()
ossimRefPtr< ossimProperty > ossimMetadataFileWriter::getProperty ( const ossimString name) const
virtual
Reimplemented from ossimConnectableObject.
Definition at line 257 of file ossimMetadataFileWriter.cpp.
References ossimKeywordNames::FILENAME_KW, ossimConnectableObject::getProperty(), ossimFilenameProperty::ossimFilenamePropertyIoType_OUTPUT, ossimFilenameProperty::setIoType(), and theFilename.
258 {
260  {
261  ossimFilenameProperty* filenameProp =
263
265
266  return filenameProp;
267
268  }
269
271 }
void setIoType(ossimFilenamePropertyIoType ioType)
static const char * FILENAME_KW
◆ getPropertyNames()
void ossimMetadataFileWriter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 273 of file ossimMetadataFileWriter.cpp.
References ossimKeywordNames::FILENAME_KW, and ossimConnectableObject::getPropertyNames().
274 {
276  propertyNames.push_back(ossimKeywordNames::FILENAME_KW);
277 }
◆ hasMetadataType()
virtual bool ossimMetadataFileWriter::hasMetadataType ( const ossimString metadataType) const
pure virtual
Parameters
imageTypestring representing image type.
Returns
true if "metadataType" is supported by writer.
Referenced by ossimImageMetaDataWriterFactory::createWriter().
◆ initialize()
void ossimMetadataFileWriter::initialize ( )
virtual
◆ loadState()
bool ossimMetadataFileWriter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Load state method:
This method call base class ossimConnectableObject::loadState then looks for its keywords.
Parameters
kwlKeyword list to initialize from.
prefixUsually something like: "object1."
Returns
This method will alway return true as it is intended to be used in conjuction with the set methods.
Keywords picked up by loadState:
filename: foo.tfw
(pixel_type should be area or point)
pixel_type: area
Reimplemented in ossimFgdcFileWriter, ossimEnviHeaderFileWriter, ossimWorldFileWriter, and ossimERSFileWriter.
Definition at line 55 of file ossimMetadataFileWriter.cpp.
References ossimString::contains(), ossimString::downcase(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimConnectableObject::loadState(), OSSIM_PIXEL_IS_AREA, OSSIM_PIXEL_IS_POINT, ossimKeywordNames::PIXEL_TYPE_KW, setFilename(), ossimConnectableObject::theInputListIsFixedFlag, ossimConnectableObject::theInputObjectList, ossimConnectableObject::theOutputListIsFixedFlag, and thePixelType.
Referenced by ossimERSFileWriter::loadState(), ossimEnviHeaderFileWriter::loadState(), and ossimFgdcFileWriter::loadState().
57 {
58  bool result = ossimConnectableObject::loadState(kwl, prefix);
59
60  // Get the filename...
61  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
62  if(lookup)
63  {
64  ossimString filename = lookup;
65
66  setFilename(filename);
67  }
68
69  // Note: Defaulted to point in constructor.
70  lookup = kwl.find(prefix, ossimKeywordNames::PIXEL_TYPE_KW);
71  if (lookup)
72  {
73  ossimString s = lookup;
74  s.downcase();
75  if (s.contains("area"))
76  {
78  }
79  else if (s.contains("point"))
80  {
82  }
83  }
84
85  if(theInputObjectList.size() != 1)
86  {
87  theInputObjectList.resize(1);
89  }
90
92
93  return result;
94 }
bool contains(char aChar) const
Definition: ossimString.h:58
ConnectableObjectList theInputObjectList
Holds a list of input objects.
static const char * PIXEL_TYPE_KW
Indicates whether the theInputObjectList is fixed.
virtual void setFilename(const ossimFilename &file)
Indicates whether the theOutputObjectList is fixed.
◆ propertyEvent()
void ossimMetadataFileWriter::propertyEvent ( ossimPropertyEvent event)
virtual
Definition at line 106 of file ossimMetadataFileWriter.cpp.
107 {
108  initialize();
109 }
◆ setAreaOfInterest()
void ossimMetadataFileWriter::setAreaOfInterest ( const ossimIrect areaOfInterest)
virtual
Parameters
areaOfInterestSets theAreaOfInterest.
Note
By default the writers will use "theInputConnection->getBoundingRect()" if theAreaOfInterest has nans.
Definition at line 230 of file ossimMetadataFileWriter.cpp.
232 {
233  theAreaOfInterest = areaOfInterest;
234 }
◆ setFilename()
void ossimMetadataFileWriter::setFilename ( const ossimFilename file)
virtual
◆ setPercentComplete()
void ossimMetadataFileWriter::setPercentComplete ( double  percentComplete)
virtual
Reimplemented from ossimProcessInterface.
Definition at line 202 of file ossimMetadataFileWriter.cpp.
References ossimListenerManager::fireEvent(), and ossimProcessInterface::setPercentComplete().
203 {
205  ossimProcessProgressEvent event(this,
206  percentComplete);
207  fireEvent(event);
208 }
virtual void fireEvent(ossimEvent &event)
◆ setPixelType()
void ossimMetadataFileWriter::setPixelType ( ossimPixelType  pixelType)
virtual
This means that if you say a tie point is 30.0N -81.0W, the center of the pixel at the tie point is 30.0N -81.0W.
Definition at line 111 of file ossimMetadataFileWriter.cpp.
112 {
113  thePixelType = pixelType;
114 }
◆ setProperty()
void ossimMetadataFileWriter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
property interface
Definition at line 241 of file ossimMetadataFileWriter.cpp.
References ossimKeywordNames::FILENAME_KW, setFilename(), ossimConnectableObject::setProperty(), ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
242 {
243  if(!property.valid())return;
244
245  ossimString name = property->getName();
246
248  {
249  setFilename(property->valueToString());
250  }
251  else
252  {
254  }
255 }
virtual void valueToString(ossimString &valueResult) const =0
bool valid() const
Definition: ossimRefPtr.h:75
◆ writeFile()
virtual bool ossimMetadataFileWriter::writeFile ( )
protectedpure virtual
Write out the file.
Returns
Implemented in ossimFgdcFileWriter, ossimWorldFileWriter, ossimEnviHeaderFileWriter, ossimERSFileWriter, ossimGeomFileWriter, and ossimReadmeFileWriter.
Member Data Documentation
◆ theAreaOfInterest
ossimIrect ossimMetadataFileWriter::theAreaOfInterest
protected
◆ theFilename
ossimFilename ossimMetadataFileWriter::theFilename
protected
◆ theInputConnection
ossimImageSource* ossimMetadataFileWriter::theInputConnection
protected
◆ thePixelType
ossimPixelType ossimMetadataFileWriter::thePixelType
protected
