#include <ossimImageMetaDataWriterFactory.h>
~ossimImageMetaDataWriterFactory () | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual ossimRefPtr< ossimMetadataFileWriter > | createWriter (const ossimString &type) const |
Creates a writer from either a class name or a string representing the meta data type like "tiff_world_file". More... | |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
This should return the type name of all objects in all factories. More... | |
virtual void | getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const |
Satisfies pure virtual from ossimImageMetaDataWriterFactoryBase. More... | |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimImageMetaDataWriterFactory * | instance () |
ossimImageMetaDataWriterFactory (const ossimImageMetaDataWriterFactory &rhs) | |
const ossimImageMetaDataWriterFactory & | operator= (const ossimImageMetaDataWriterFactory &rhs) |
ossimImageMetaDataWriterFactoryBase () | |
ossimImageMetaDataWriterFactoryBase (const ossimImageMetaDataWriterFactoryBase &) | |
const ossimImageMetaDataWriterFactoryBase & | operator= (const ossimImageMetaDataWriterFactoryBase &) |
virtual | ~ossimReferenced () |
Static Protected Attributes | |
static ossimImageMetaDataWriterFactory * | theInstance = NULL |
Definition at line 21 of file ossimImageMetaDataWriterFactory.h.
ossimImageMetaDataWriterFactory::~ossimImageMetaDataWriterFactory | ( | ) |
Definition at line 33 of file ossimImageMetaDataWriterFactory.cpp.
References theInstance.
protected |
Definition at line 28 of file ossimImageMetaDataWriterFactory.cpp.
Referenced by instance().
protected |
Definition at line 205 of file ossimImageMetaDataWriterFactory.cpp.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 48 of file ossimImageMetaDataWriterFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createObject().
Creates and object given a keyword list.
Definition at line 88 of file ossimImageMetaDataWriterFactory.cpp.
References createObject(), ossimKeywordlist::find(), ossimObject::loadState(), and ossimKeywordNames::TYPE_KW.
Implements ossimImageMetaDataWriterFactoryBase.
Definition at line 112 of file ossimImageMetaDataWriterFactory.cpp.
References ossimObject::getClassName(), and ossimMetadataFileWriter::hasMetadataType().
Appends the meta data writers types from each of the supported meta data writers in this factor to the "metadatatypeList".
This is the actual metadata type name like: ossim_geometry envi_header tiff_world_file jpeg_world_file
metadatatypeList | stl::vector<ossimString> List to append to. |
Definition at line 181 of file ossimImageMetaDataWriterFactory.cpp.
References ossimMetadataFileWriter::getMetadatatypeList().
This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 169 of file ossimImageMetaDataWriterFactory.cpp.
static |
Definition at line 38 of file ossimImageMetaDataWriterFactory.cpp.
References ossimImageMetaDataWriterFactory(), and theInstance.
Referenced by ossimImageMetaDataWriterRegistry::ossimImageMetaDataWriterRegistry().
protected |
Definition at line 211 of file ossimImageMetaDataWriterFactory.cpp.
staticprotected |
Definition at line 75 of file ossimImageMetaDataWriterFactory.h.
Referenced by instance(), ossimImageMetaDataWriterFactory(), and ~ossimImageMetaDataWriterFactory().
