Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimKmlSuperOverlayReaderFactory Class Reference
Factory for Kml SuperOverlay reader. More...
#include <ossimKmlSuperOverlayReaderFactory.h>
Inheritance diagram for ossimKmlSuperOverlayReaderFactory:
ossimImageHandlerFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimKmlSuperOverlayReaderFactory ()
 virtual destructor More...
virtual ossimImageHandleropen (const ossimFilename &fileName, bool openOverview=true) const
 open that takes a file name. More...
virtual ossimImageHandleropen (const ossimKeywordlist &kwl, const char *prefix=0) const
 open that takes a keyword list and prefix. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (ossimKmlSuperOverlayReader) More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list and prefix. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds ossimKmlSuperOverlayReader to the typeList. More...
virtual void getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
 Method to add supported extension to the list, like "kml" or "kmz". More...
- Public Member Functions inherited from ossimImageHandlerFactoryBase
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const
 Open method that takes a stream. More...
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::ImageHandlerState > state) const
virtual ossimRefPtr< ossimImageHandleropenOverview (const ossimFilename &file) const
 Open overview that takes a file name. More...
virtual ossimRefPtr< ossimImageHandleropenOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const
virtual void getImageHandlersBySuffix (ImageHandlerList &result, const ossimString &ext) const
virtual void getImageHandlersByMimeType (ImageHandlerList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimKmlSuperOverlayReaderFactoryinstance ()
 static method to return instance (the only one) of this class. More...
bool hasExcludedExtension (const ossimFilename &file) const
 Method to weed out extensions that this plugin knows it does not support. More...
 hidden from use default constructor More...
 ossimKmlSuperOverlayReaderFactory (const ossimKmlSuperOverlayReaderFactory &)
 hidden from use copy constructor More...
void operator= (const ossimKmlSuperOverlayReaderFactory &)
virtual ~ossimReferenced ()
static ossimKmlSuperOverlayReaderFactorytheInstance = 0
 static instance of this class More...
Additional Inherited Members
- Public Types inherited from ossimImageHandlerFactoryBase
typedef UniqueList< ossimStringUniqueStringList
typedef std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
Detailed Description
Definition at line 21 of file ossimKmlSuperOverlayReaderFactory.h.
◆ ~ossimKmlSuperOverlayReaderFactory()
ossimKmlSuperOverlayReaderFactory::~ossimKmlSuperOverlayReaderFactory ( )
virtual
virtual destructor
Definition at line 31 of file ossimKmlSuperOverlayReaderFactory.cpp.
References theInstance.
32 {
33  theInstance = 0;
34 }
static ossimKmlSuperOverlayReaderFactory * theInstance
◆ ossimKmlSuperOverlayReaderFactory() [1/2]
ossimKmlSuperOverlayReaderFactory::ossimKmlSuperOverlayReaderFactory ( )
protected
Definition at line 148 of file ossimKmlSuperOverlayReaderFactory.cpp.
Referenced by instance().
148 {}
◆ ossimKmlSuperOverlayReaderFactory() [2/2]
ossimKmlSuperOverlayReaderFactory::ossimKmlSuperOverlayReaderFactory ( const ossimKmlSuperOverlayReaderFactory )
protected
Definition at line 150 of file ossimKmlSuperOverlayReaderFactory.cpp.
150 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimKmlSuperOverlayReaderFactory::createObject ( const ossimString typeName) const
virtual
Parameters
typeNameShould be "ossimKmlSuperOverlayReader".
Returns
pointer to image writer on success, NULL on failure.
Implements ossimObjectFactory.
Definition at line 104 of file ossimKmlSuperOverlayReaderFactory.cpp.
References ossimRefPtr< T >::release().
106 {
107  ossimRefPtr<ossimObject> result = 0;
108  if(typeName == "ossimKmlSuperOverlayReader")
109  {
110  result = new ossimKmlSuperOverlayReader;
111  }
112
113  return result.release();
114 }
T * release()
Definition: ossimRefPtr.h:93
◆ createObject() [2/2]
ossimObject * ossimKmlSuperOverlayReaderFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Returns
pointer to image handler on success, NULL on failure.
Definition at line 116 of file ossimKmlSuperOverlayReaderFactory.cpp.
References open().
119 {
120  return this->open(kwl, prefix);
121 }
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
◆ getSupportedExtensions()
void ossimKmlSuperOverlayReaderFactory::getSupportedExtensions ( ossimImageHandlerFactoryBase::UniqueStringList extensionList) const
virtual
Parameters
extensionListThe list to add to.
Implements ossimImageHandlerFactoryBase.
Definition at line 129 of file ossimKmlSuperOverlayReaderFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back().
131 {
132  extensionList.push_back(ossimString("kml"));
133  extensionList.push_back(ossimString("kmz"));
134 }
◆ getTypeNameList()
void ossimKmlSuperOverlayReaderFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 123 of file ossimKmlSuperOverlayReaderFactory.cpp.
125 {
126  typeList.push_back(ossimString("ossimKmlSuperOverlayReader"));
127 }
◆ hasExcludedExtension()
bool ossimKmlSuperOverlayReaderFactory::hasExcludedExtension ( const ossimFilename file) const
protected
This is to avoid a costly open on say a tiff or jpeg that is not handled by this plugin.
Returns
true if extension, false if not.
Definition at line 136 of file ossimKmlSuperOverlayReaderFactory.cpp.
References ossimString::downcase(), and ossimFilename::ext().
138 {
139  bool result = true;
140  ossimString ext = file.ext().downcase();
141  if (ext == "kml" || ext == "kmz") //only include the file with .kml or .kmz extension and exclude any other files
142  {
143  result = false;
144  }
145  return result;
146 }
ossimString ext() const
◆ instance()
ossimKmlSuperOverlayReaderFactory * ossimKmlSuperOverlayReaderFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 36 of file ossimKmlSuperOverlayReaderFactory.cpp.
References ossimKmlSuperOverlayReaderFactory(), and theInstance.
37 {
38  if(!theInstance)
39  {
41  }
42  return theInstance;
43 }
◆ open() [1/2]
ossimImageHandler * ossimKmlSuperOverlayReaderFactory::open ( const ossimFilename fileName,
bool  openOverview = true
) const
virtual
Parameters
fileThe file to open.
Returns
Definition at line 45 of file ossimKmlSuperOverlayReaderFactory.cpp.
Referenced by createObject().
47 {
48  if(traceDebug())
49  {
51  << "ossimKmlSuperOverlayReaderFactory::open(filename) DEBUG: entered..."
52  << "\ntrying ossimKakaduNitfReader"
53  << std::endl;
54  }
55
57
58  if ( hasExcludedExtension(fileName) == false )
59  {
60  reader = new ossimKmlSuperOverlayReader;
61  if(reader->open(fileName) == false)
62  {
63  reader = 0;
64  }
65  }
66
67  if(traceDebug())
68  {
70  << "ossimKmlSuperOverlayReaderFactory::open(filename) DEBUG: leaving..."
71  << std::endl;
72  }
73
74  return reader.release();
75 }
virtual bool open()=0
Pure virtual open.
bool hasExcludedExtension(const ossimFilename &file) const
T * release()
◆ open() [2/2]
ossimImageHandler * ossimKmlSuperOverlayReaderFactory::open ( const ossimKeywordlist kwl,
) const
virtual
Parameters
Returns
Definition at line 77 of file ossimKmlSuperOverlayReaderFactory.cpp.
79 {
80  if(traceDebug())
81  {
83  << "ossimKmlSuperOverlayReaderFactory::open(kwl, prefix) DEBUG: entered..."
84  << "Trying ossimKakaduNitfReader"
85  << std::endl;
86  }
87
89  if(reader->loadState(kwl, prefix) == false)
90  {
91  reader = 0;
92  }
93
94  if(traceDebug())
95  {
97  << "ossimKmlSuperOverlayReaderFactory::open(kwl, prefix) DEBUG: leaving..."
98  << std::endl;
99  }
100
101  return reader.release();
102 }
T * release()
◆ operator=()
void ossimKmlSuperOverlayReaderFactory::operator= ( const ossimKmlSuperOverlayReaderFactory )
protected
Definition at line 152 of file ossimKmlSuperOverlayReaderFactory.cpp.
152 {}
Member Data Documentation
◆ theInstance
ossimKmlSuperOverlayReaderFactory * ossimKmlSuperOverlayReaderFactory::theInstance = 0
staticprotected
Definition at line 101 of file ossimKmlSuperOverlayReaderFactory.h.
Referenced by instance(), and ~ossimKmlSuperOverlayReaderFactory().
