Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimKmlSuperOverlayReader Class Reference
#include <ossimKmlSuperOverlayReader.h>
Inheritance diagram for ossimKmlSuperOverlayReader:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimKmlSuperOverlayReader ()
virtual ~ossimKmlSuperOverlayReader ()
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
virtual bool open ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
virtual ossimIrect getImageRectangle (ossim_uint32 reduced_res_level=0) const
ossimScalarType getOutputScalarType () const
virtual bool isOpen () const
ossimMapProjectioncreateDefaultProj (ossim_float64 north, ossim_float64 south, ossim_float64 east, ossim_float64 west)
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
bool getCoordinate (std::vector< ossimRefPtr< ossimXmlNode > > nodes, ossim_float64 &north, ossim_float64 &south, ossim_float64 &east, ossim_float64 &west)
ossimRefPtr< ossimXmlNodefindLatLonNode (std::vector< ossimRefPtr< ossimXmlNode > >nodes)
bool isKmlSuperOverlayFile (std::vector< ossimRefPtr< ossimXmlNode > > nodes)
bool getTopLevelKmlFileInfo ()
Private Attributes
ossimRefPtr< ossimXmlDocumentm_xmlDocument
ossimRefPtr< ossimImageGeometrytheImageGeometry
ossimDrect theImageBound
Additional Inherited Members
virtual void completeOpen ()
virtual ~ossimReferenced ()
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 32 of file ossimKmlSuperOverlayReader.h.
◆ ossimKmlSuperOverlayReader()
ossimKmlSuperOverlayReader::ossimKmlSuperOverlayReader ( )
Definition at line 45 of file ossimKmlSuperOverlayReader.cpp.
47  m_xmlDocument(0),
49 {
50 }
ossimRefPtr< ossimXmlDocument > m_xmlDocument
ossimImageHandler()
Constructor (default):
◆ ~ossimKmlSuperOverlayReader()
ossimKmlSuperOverlayReader::~ossimKmlSuperOverlayReader ( )
virtual
Definition at line 55 of file ossimKmlSuperOverlayReader.cpp.
References close().
56 {
57  close();
58 }
virtual void close()
Member Function Documentation
◆ close()
void ossimKmlSuperOverlayReader::close ( )
virtual
Definition at line 182 of file ossimKmlSuperOverlayReader.cpp.
References m_xmlDocument, theImageGeometry, and ossimRefPtr< T >::valid().
Referenced by open(), and ~ossimKmlSuperOverlayReader().
183 {
184  if (theImageGeometry.valid())
185  {
186  theImageGeometry = 0;
187  }
188  if (m_xmlDocument.valid())
189  {
190  m_xmlDocument = 0;
191  }
192 }
ossimRefPtr< ossimImageGeometry > theImageGeometry
bool valid() const
Definition: ossimRefPtr.h:75
◆ createDefaultProj()
ossimMapProjection * ossimKmlSuperOverlayReader::createDefaultProj ( ossim_float64  north,
ossim_float64  east,
ossim_float64  west
Definition at line 336 of file ossimKmlSuperOverlayReader.cpp.
References ossim::cosd(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimEquDistCylProjection::setOrigin(), and ossimMapProjection::setUlGpt().
Referenced by open().
340 {
342
343  ossim_float64 centerLat = (south + north) / 2.0;
344  ossim_float64 centerLon = (west + east) / 2.0;
345  ossim_float64 deltaLat = north - south;
346
347  // Scale that gives 1024 pixel in the latitude direction.
348  ossim_float64 scaleLat = deltaLat / 1024.0;
349  ossim_float64 scaleLon = scaleLat*ossim::cosd(std::fabs(centerLat));
350  ossimGpt origin(centerLat, centerLon, 0.0);
351  ossimDpt scale(scaleLon, scaleLat);
352
353  // Set the origin.
354  proj->setOrigin(origin);
355
356  // Set the tie point.
357  proj->setUlGpt( ossimGpt(north, west));
358
359  // Set the scale. Note this will handle computing meters per pixel.
360  proj->setDecimalDegreesPerPixel(scale);
361
362  return proj;
363 }
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
virtual void setUlGpt(const ossimGpt &ulGpt)
double ossim_float64
virtual void setOrigin(const ossimGpt &origin)
double cosd(double x)
Definition: ossimCommon.h:259
◆ findLatLonNode()
ossimRefPtr< ossimXmlNode > ossimKmlSuperOverlayReader::findLatLonNode ( std::vector< ossimRefPtr< ossimXmlNode > >  nodes)
private
Definition at line 275 of file ossimKmlSuperOverlayReader.cpp.
References ossimRefPtr< T >::valid().
Referenced by getCoordinate().
276 {
277  ossimRefPtr<ossimXmlNode> latlonNode = 0;
278  for (ossim_uint32 i = 0; i < nodes.size(); i++)
279  {
280  if (nodes[i]->getTag().downcase() == "latlonaltbox")
281  {
282  return nodes[i];
283  }
284  }
285  for (ossim_uint32 j = 0; j < nodes.size(); j++)
286  {
287  latlonNode = findLatLonNode(nodes[j]->getChildNodes());
288  if (latlonNode.valid())
289  {
290  return latlonNode;
291  }
292  }
293  return latlonNode;
294 }
bool valid() const
ossimRefPtr< ossimXmlNode > findLatLonNode(std::vector< ossimRefPtr< ossimXmlNode > >nodes)
unsigned int ossim_uint32
◆ getCoordinate()
bool ossimKmlSuperOverlayReader::getCoordinate ( std::vector< ossimRefPtr< ossimXmlNode > >  nodes,
ossim_float64 east,
ossim_float64 west
private
Definition at line 296 of file ossimKmlSuperOverlayReader.cpp.
References ossimString::downcase(), findLatLonNode(), ossimXmlNode::getChildNodes(), ossimString::toFloat64(), and ossimRefPtr< T >::valid().
301 {
302  ossimRefPtr<ossimXmlNode> latlonNode = findLatLonNode(nodes);
303  if (!latlonNode.valid())
304  {
305  return false;
306  }
307
308  std::vector<ossimRefPtr<ossimXmlNode> > latlonNodes = latlonNode->getChildNodes();
309  if (latlonNodes.size() != 4)
310  {
311  return false;
312  }
313  for (ossim_uint32 i = 0; i < latlonNodes.size(); i++)
314  {
315  ossimString str = latlonNodes[i]->getTag().downcase();
316  if (str == "north")
317  {
318  north = latlonNodes[i]->getText().toFloat64();
319  }
320  else if (str == "south")
321  {
322  south = latlonNodes[i]->getText().toFloat64();
323  }
324  else if (str == "east")
325  {
326  east = latlonNodes[i]->getText().toFloat64();
327  }
328  else if (str == "west")
329  {
330  west = latlonNodes[i]->getText().toFloat64();
331  }
332  }
333  return true;
334 }
bool valid() const
const ossimXmlNode::ChildListType & getChildNodes() const
ossim_float64 toFloat64() const
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimKmlSuperOverlayReader::getImageGeometry ( )
virtual
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 235 of file ossimKmlSuperOverlayReader.cpp.
References theImageGeometry.
236 {
237  return theImageGeometry;
238 }
◆ getImageRectangle()
ossimIrect ossimKmlSuperOverlayReader::getImageRectangle ( ossim_uint32  reduced_res_level = 0) const
virtual
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. Note that rrds 0 is the highest resolution rrds.
Definition at line 230 of file ossimKmlSuperOverlayReader.cpp.
References theImageBound.
231 {
232  return theImageBound;
233 }
◆ getImageTileHeight()
ossim_uint32 ossimKmlSuperOverlayReader::getImageTileHeight ( ) const
virtual
Returns the tile width of the image or 0 if the image is not tiled. Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width which can be different than the internal image tile width on disk.
Implements ossimImageHandler.
Definition at line 210 of file ossimKmlSuperOverlayReader.cpp.
211 {
212  return 0;
213 }
◆ getImageTileWidth()
ossim_uint32 ossimKmlSuperOverlayReader::getImageTileWidth ( ) const
virtual
Definition at line 215 of file ossimKmlSuperOverlayReader.cpp.
216 {
217  return 0;
218 }
◆ getInternalImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimKmlSuperOverlayReader::getInternalImageGeometry ( ) const
virtual
Definition at line 177 of file ossimKmlSuperOverlayReader.cpp.
178 {
179  return theImageGeometry;
180 }
◆ getNumberOfInputBands()
ossim_uint32 ossimKmlSuperOverlayReader::getNumberOfInputBands ( ) const
virtual
Returns the number 0 for bands for kml super overlay Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 200 of file ossimKmlSuperOverlayReader.cpp.
201 {
202  return 0;
203 }
◆ getNumberOfLines()
ossim_uint32 ossimKmlSuperOverlayReader::getNumberOfLines ( ossim_uint32  reduced_res_level = 0) const
virtual
Returns the number of bands in the image. Satisfies pure virtual from ImageHandler class.
Definition at line 220 of file ossimKmlSuperOverlayReader.cpp.
References ossimDrect::height(), and theImageBound.
221 {
222  return theImageBound.height();
223 }
ossim_float64 height() const
Definition: ossimDrect.h:517
◆ getNumberOfOutputBands()
ossim_uint32 ossimKmlSuperOverlayReader::getNumberOfOutputBands ( ) const
virtual
Definition at line 205 of file ossimKmlSuperOverlayReader.cpp.
206 {
207  return 0;
208 }
◆ getNumberOfSamples()
ossim_uint32 ossimKmlSuperOverlayReader::getNumberOfSamples ( ossim_uint32  reduced_res_level = 0) const
virtual
Returns the number of bands available from an image. Satisfies pure virtual from ImageHandler class.
Definition at line 225 of file ossimKmlSuperOverlayReader.cpp.
References theImageBound, and ossimDrect::width().
226 {
227  return theImageBound.width();
228 }
ossim_float64 width() const
Definition: ossimDrect.h:522
◆ getOutputScalarType()
ossimScalarType ossimKmlSuperOverlayReader::getOutputScalarType ( ) const
virtual
Definition at line 240 of file ossimKmlSuperOverlayReader.cpp.
References OSSIM_SCALAR_UNKNOWN.
241 {
242  return OSSIM_SCALAR_UNKNOWN;
243 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimKmlSuperOverlayReader::getTile ( const ossimIrect tileRect,
ossim_uint32  resLevel = 0
virtual
Returns a null pointer for kml super overlay. Satisfies pure virtual from ImageHandler class.
Definition at line 194 of file ossimKmlSuperOverlayReader.cpp.
196 {
197  return 0;
198 }
◆ getTopLevelKmlFileInfo()
bool ossimKmlSuperOverlayReader::getTopLevelKmlFileInfo ( )
private
Definition at line 365 of file ossimKmlSuperOverlayReader.cpp.
References ossimString::c_str(), ossimObject::getClassName(), m_xmlDocument, ossimFilename::noExtension(), ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossimXmlDocument::read(), ossimFilename::rename(), and ossimImageHandler::theImageFile.
366 {
368  ossimFilename tmpZipfile = ossimString(theImageFile.noExtension() + ".zip");
369  unzFile unzipfile = unzOpen(tmpZipfile.c_str());
370  if (!unzipfile)
371  {
374  "Unable to open target zip file..");
375
376  tmpZipfile.rename(ossimString(tmpZipfile.noExtension() + ".kmz"));//if open fails, rename the file back to .kmz
377  return false;
378  }
379
380  std::string kmzStringBuffer;
381
382  if (unzGoToFirstFile(unzipfile) == UNZ_OK)
383  {
384  if (unzOpenCurrentFile(unzipfile) == UNZ_OK)
385  {
386  unsigned char buffer[4096] = {0};
387  int bytesRead = 0;
388  int read = 1;
389  while (read > 0)
390  {
391  read = unzReadCurrentFile(unzipfile, buffer, 4096);
392  bytesRead += read;
393  }
394  if ( bytesRead )
395  {
396  for (int i = 0; i < bytesRead; ++i)
397  {
398  // Copy to string casting to char.
399  kmzStringBuffer.push_back( static_cast<char>(buffer[i]) );
400  }
401  }
402  }
403  else
404  {
405  tmpZipfile.rename(ossimString(tmpZipfile.noExtension() + ".kmz"));//if read fails, rename the file back to .kmz
406  unzCloseCurrentFile(unzipfile);
407  unzClose(unzipfile);
408  return false;
409  }
410  }
411  else
412  {
413  tmpZipfile.rename(ossimString(tmpZipfile.noExtension() + ".kmz"));
414  unzClose(unzipfile);
415  return false;
416  }
417  unzCloseCurrentFile(unzipfile);
418  unzClose(unzipfile);
419
420  std::istringstream in(kmzStringBuffer);
421  if ( in.good() )
422  {
424  m_xmlDocument->read( in );
425  }
426  else
427  {
428  tmpZipfile.rename(ossimString(tmpZipfile.noExtension() + ".kmz"));
429  return false;
430  }
431
432  tmpZipfile.rename(ossimString(tmpZipfile.noExtension() + ".kmz"));
433
434  return true;
435 }
OSSIMDLLEXPORT void ossimSetError(const char *className, ossim_int32 error, const char *fmtString=0,...)
ossimFilename noExtension() const
static const ossimErrorCode OSSIM_ERROR
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
const char * c_str() const
Definition: ossimString.h:396
bool read(std::istream &in)
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
bool rename(const ossimFilename &destFile, bool overwriteDestinationFlag=true) const
◆ isKmlSuperOverlayFile()
bool ossimKmlSuperOverlayReader::isKmlSuperOverlayFile ( std::vector< ossimRefPtr< ossimXmlNode > >  nodes)
private
Definition at line 254 of file ossimKmlSuperOverlayReader.cpp.
255 {
256  for (ossim_uint32 i = 0; i < nodes.size(); i++)
257  {
258  if (nodes[i]->getTag().downcase() == "placemark") //means vector kml file with point, polygon, or lines
259  {
260  return false;
261  }
262
263  if (nodes[i]->getTag().downcase() == "region" || nodes[i]->getTag().downcase() == "networkLink") //means super overlay kml file
264  {
265  return true;
266  }
267  }
268  for (ossim_uint32 i = 0; i < nodes.size(); i++)
269  {
270  return isKmlSuperOverlayFile(nodes[i]->getChildNodes());
271  }
272  return false;
273 }
bool isKmlSuperOverlayFile(std::vector< ossimRefPtr< ossimXmlNode > > nodes)
◆ isOpen()
bool ossimKmlSuperOverlayReader::isOpen ( ) const
virtual
Returns
true if open, false if not.
Definition at line 245 of file ossimKmlSuperOverlayReader.cpp.
References ossimString::empty(), and ossimImageHandler::theImageFile.
246 {
247  if (theImageFile.empty())
248  {
249  return false;
250  }
251  return true;
252 }
bool empty() const
Definition: ossimString.h:411
◆ loadState()
bool ossimKmlSuperOverlayReader::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 172 of file ossimKmlSuperOverlayReader.cpp.
References ossimImageHandler::loadState().
173 {
174  return ossimImageHandler::loadState(kwl, prefix);
175 }
◆ open()
bool ossimKmlSuperOverlayReader::open ( )
virtual
Returns
Note
This method relies on the data member ossimImageData::theImageFile being set. Callers should do a "setFilename" prior to calling this method or use the ossimImageHandler::open that takes a file name and an entry index.
Definition at line 63 of file ossimKmlSuperOverlayReader.cpp.
References close(), createDefaultProj(), ossimString::downcase(), ossimFilename::ext(), ossimXmlNode::getChildNodes(), getCoordinate(), ossimXmlDocument::getRoot(), getTopLevelKmlFileInfo(), isKmlSuperOverlayFile(), isOpen(), m_xmlDocument, ossimDrect::makeNan(), theImageBound, ossimImageHandler::theImageFile, theImageGeometry, ossimRefPtr< T >::valid(), and ossimImageGeometry::worldToLocal().
64 {
65  // const char* MODULE = "ossimKmlSuperOverlayReader::open";
66  bool result = false;
67
68  if(isOpen())
69  {
70  close();
71  }
72
73  if (theImageFile.ext().downcase() == "kmz")
74  {
75  result = getTopLevelKmlFileInfo();
76  if (result == false)
77  {
78  return result;
79  }
80  }
81  else
82  {
84  }
85
86  if ( m_xmlDocument.valid() )
87  {
89  if (rootNode.valid())
90  {
91  std::vector<ossimRefPtr<ossimXmlNode> > nodes = rootNode->getChildNodes();
92  result = isKmlSuperOverlayFile(nodes);
93
94  if (result == false) //let gdal kml handle vector kml file
95  {
96  return result;
97  }
98
99  ossim_float64 north = 0.0;
100  ossim_float64 south = 0.0;
101  ossim_float64 east = 0.0;
102  ossim_float64 west = 0.0;
103  result = getCoordinate(nodes, north, south, east, west);
104
105  if (result == false)
106  {
107  return result;
108  }
109
110  if (!theImageGeometry.valid())
111  {
112  theImageGeometry = new ossimImageGeometry(0, createDefaultProj(north, south, east, west));
113  if (theImageGeometry.valid())
114  {
115  result = true;
116
118
119  //if the projection is default or geographic, uses the bounding of the OGR Layer
120  vector<ossimGpt> points;
121  points.push_back(ossimGpt(north, west));
122  points.push_back(ossimGpt(north, east));
123  points.push_back(ossimGpt(south, east));
124  points.push_back(ossimGpt(south, west));
125
126
127  std::vector<ossimDpt> rectTmp;
128  rectTmp.resize(points.size());
129  for(std::vector<ossimGpt>::size_type index=0; index < points.size(); ++index)
130  {
131  theImageGeometry->worldToLocal(points[(int)index], rectTmp[(int)index]);
132  }
133
134  ossimDrect rect = ossimDrect(rectTmp[0],
135  rectTmp[1],
136  rectTmp[2],
137  rectTmp[3]);
138
139  theImageBound = rect;
140  }
141  else
142  {
143  result = false;
144  }
145  }
146  }
147  else
148  {
149  result = false;
150  }
151  }
152  else
153  {
154  result = false;
155  }
156
157  return result;
158 }
void makeNan()
Definition: ossimDrect.h:388
bool valid() const
ossimMapProjection * createDefaultProj(ossim_float64 north, ossim_float64 south, ossim_float64 east, ossim_float64 west)
virtual bool isOpen() const
ossimString ext() const
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossimRefPtr< ossimXmlNode > getRoot()
bool getCoordinate(std::vector< ossimRefPtr< ossimXmlNode > > nodes, ossim_float64 &north, ossim_float64 &south, ossim_float64 &east, ossim_float64 &west)
◆ saveState()
bool ossimKmlSuperOverlayReader::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 163 of file ossimKmlSuperOverlayReader.cpp.
References ossimImageHandler::saveState().
165 {
166  return ossimImageHandler::saveState(kwl, prefix);
167 }
Member Data Documentation
◆ m_xmlDocument
ossimRefPtr<ossimXmlDocument> ossimKmlSuperOverlayReader::m_xmlDocument
private
Definition at line 146 of file ossimKmlSuperOverlayReader.h.
Referenced by close(), getTopLevelKmlFileInfo(), and open().
◆ theImageBound
ossimDrect ossimKmlSuperOverlayReader::theImageBound
private
◆ theImageGeometry
ossimRefPtr<ossimImageGeometry> ossimKmlSuperOverlayReader::theImageGeometry
private
