Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimKmlSuperOverlayWriterFactory Class Reference
Factory for kmlsuperoverlay based image writers. More...
#include <ossimKmlSuperOverlayWriterFactory.h>
Inheritance diagram for ossimKmlSuperOverlayWriterFactory:
ossimImageWriterFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimKmlSuperOverlayWriterFactory ()
 virtual destructor More...
virtual ossimImageFileWritercreateWriterFromExtension (const ossimString &fileExtension) const
 Creates a writer from extension like "sid". More...
virtual ossimImageFileWritercreateWriter (const ossimKeywordlist &kwl, const char *prefix=0) const
 Create that takes a keyword list and prefix. More...
virtual ossimImageFileWritercreateWriter (const ossimString &typeName) const
 createWriter that takes a class name (ossimKakaduWriter) More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (ossimKakaduWriter) More...
virtual void getExtensions (std::vector< ossimString > &extList) const
 Adds "ntf" to list. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds "ossimKakaduWriter" to list. More...
virtual void getImageTypeList (std::vector< ossimString > &imageTypeList) const
 Adds "ossim_kakada_nitf_j2k" to writer list. More...
virtual void getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const
- Public Member Functions inherited from ossimImageWriterFactoryBase
virtual ~ossimImageWriterFactoryBase ()
virtual void getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimKmlSuperOverlayWriterFactoryinstance ()
 static method to return instance (the only one) of this class. More...
 hidden from use default constructor More...
 ossimKmlSuperOverlayWriterFactory (const ossimKmlSuperOverlayWriterFactory &)
 hidden from use copy constructor More...
void operator= (const ossimKmlSuperOverlayWriterFactory &)
virtual ~ossimReferenced ()
static ossimKmlSuperOverlayWriterFactorytheInstance = 0
 static instance of this class More...
Additional Inherited Members
- Public Types inherited from ossimImageWriterFactoryBase
typedef std::vector< ossimRefPtr< ossimImageFileWriter > > ImageFileWriterList
Detailed Description
Definition at line 23 of file ossimKmlSuperOverlayWriterFactory.h.
◆ ~ossimKmlSuperOverlayWriterFactory()
ossimKmlSuperOverlayWriterFactory::~ossimKmlSuperOverlayWriterFactory ( )
virtual
virtual destructor
Definition at line 26 of file ossimKmlSuperOverlayWriterFactory.cpp.
References theInstance.
27 {
28  theInstance = 0;
29 }
static ossimKmlSuperOverlayWriterFactory * theInstance
◆ ossimKmlSuperOverlayWriterFactory() [1/2]
ossimKmlSuperOverlayWriterFactory::ossimKmlSuperOverlayWriterFactory ( )
protected
Definition at line 126 of file ossimKmlSuperOverlayWriterFactory.cpp.
Referenced by instance().
126 {}
◆ ossimKmlSuperOverlayWriterFactory() [2/2]
ossimKmlSuperOverlayWriterFactory::ossimKmlSuperOverlayWriterFactory ( const ossimKmlSuperOverlayWriterFactory )
protected
Definition at line 128 of file ossimKmlSuperOverlayWriterFactory.cpp.
128 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimKmlSuperOverlayWriterFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Returns
pointer to image writer on success, NULL on failure.
Implements ossimObjectFactory.
Definition at line 93 of file ossimKmlSuperOverlayWriterFactory.cpp.
References createWriter().
95 {
96  return createWriter(kwl, prefix);
97 }
virtual ossimImageFileWriter * createWriter(const ossimKeywordlist &kwl, const char *prefix=0) const
◆ createObject() [2/2]
ossimObject * ossimKmlSuperOverlayWriterFactory::createObject ( const ossimString typeName) const
virtual
Parameters
typeNameShould be "ossimKakaduReader".
Returns
Definition at line 99 of file ossimKmlSuperOverlayWriterFactory.cpp.
101 {
102  return createWriter(typeName);
103 }
◆ createWriter() [1/2]
ossimImageFileWriter * ossimKmlSuperOverlayWriterFactory::createWriter ( const ossimKeywordlist kwl,
) const
virtual
Parameters
Returns
pointer to image handler on success, NULL on failure.
Implements ossimImageWriterFactoryBase.
Definition at line 63 of file ossimKmlSuperOverlayWriterFactory.cpp.
References ossimKeywordlist::find(), ossimImageFileWriter::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by createObject().
65 {
67  const char* type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
68  if (type)
69  {
70  writer = createWriter(ossimString(type));
71  if (writer.valid())
72  {
73  if (writer->loadState(kwl, prefix) == false)
74  {
75  writer = 0;
76  }
77  }
78  }
79  return writer.release();
80 }
bool valid() const
Definition: ossimRefPtr.h:75
static const char * TYPE_KW
T * release()
Definition: ossimRefPtr.h:93
◆ createWriter() [2/2]
ossimImageFileWriter * ossimKmlSuperOverlayWriterFactory::createWriter ( const ossimString typeName) const
virtual
Parameters
Returns
Definition at line 82 of file ossimKmlSuperOverlayWriterFactory.cpp.
References ossimRefPtr< T >::release().
84 {
86  if (typeName == "ossimKmlSuperOverlayWriter" || typeName == "ossim_kmlsuperoverlay")
87  {
88  writer = new ossimKmlSuperOverlayWriter;
89  }
90  return writer.release();
91 }
T * release()
◆ createWriterFromExtension()
ossimImageFileWriter * ossimKmlSuperOverlayWriterFactory::createWriterFromExtension ( const ossimString fileExtension) const
virtual
Parameters
fileExtension"sid"
Definition at line 40 of file ossimKmlSuperOverlayWriterFactory.cpp.
42 {
43  ossimImageFileWriter* writer = 0;
44
45  if(fileExtension == "kml" || fileExtension == "kmz")
46  {
47  writer = new ossimKmlSuperOverlayWriter;
48  }
49  return writer;
50 }
Pure virtual base class for image file writers.
◆ getExtensions()
void ossimKmlSuperOverlayWriterFactory::getExtensions ( std::vector< ossimString > &  extList) const
virtual
Adds "ntf" to list.
Parameters
extListList to add to.
Definition at line 105 of file ossimKmlSuperOverlayWriterFactory.cpp.
107 {
108  result.push_back("kml");
109  result.push_back("kmz");
110 }
◆ getImageFileWritersBySuffix()
void ossimKmlSuperOverlayWriterFactory::getImageFileWritersBySuffix ( ossimImageWriterFactoryBase::ImageFileWriterList result,
const ossimString ext
) const
virtual
Reimplemented from ossimImageWriterFactoryBase.
Definition at line 52 of file ossimKmlSuperOverlayWriterFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
54 {
55  ossimString testExt = ext.downcase();
56  if(testExt == "kml" || testExt == "kmz")
57  {
59  }
60 }
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
◆ getImageTypeList()
void ossimKmlSuperOverlayWriterFactory::getImageTypeList ( std::vector< ossimString > &  imageTypeList) const
virtual
Parameters
imageTypeListList to append to.
Definition at line 120 of file ossimKmlSuperOverlayWriterFactory.cpp.
References ossimImageFileWriter::getImageTypeList().
Referenced by getTypeNameList().
121 {
123  writer->getImageTypeList(imageTypeList);
124 }
virtual void getImageTypeList(std::vector< ossimString > &imageTypeList) const =0
void getImageTypeList(std::vector<ossimString>& imageTypeList)const
◆ getTypeNameList()
void ossimKmlSuperOverlayWriterFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 112 of file ossimKmlSuperOverlayWriterFactory.cpp.
References getImageTypeList().
113 {
114  getImageTypeList(typeList);
115 }
◆ instance()
ossimKmlSuperOverlayWriterFactory * ossimKmlSuperOverlayWriterFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 31 of file ossimKmlSuperOverlayWriterFactory.cpp.
References ossimKmlSuperOverlayWriterFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
32 {
33  if(!theInstance)
34  {
36  }
37  return theInstance;
38 }
◆ operator=()
void ossimKmlSuperOverlayWriterFactory::operator= ( const ossimKmlSuperOverlayWriterFactory )
protected
Definition at line 130 of file ossimKmlSuperOverlayWriterFactory.cpp.
130 {}
Member Data Documentation
◆ theInstance
ossimKmlSuperOverlayWriterFactory * ossimKmlSuperOverlayWriterFactory::theInstance = 0
staticprotected
Definition at line 109 of file ossimKmlSuperOverlayWriterFactory.h.
Referenced by instance(), and ~ossimKmlSuperOverlayWriterFactory().
