Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
ossimNgaProjectionFactory Class Reference
#include <ossimNgaProjectionFactory.h>
Inheritance diagram for ossimNgaProjectionFactory:
ossimProjectionFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ossimProjectioncreateProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const
 takes a filename. More...
virtual ossimProjectioncreateProjection (const ossimString &name) const
 Take a projection type name. More...
virtual ossimProjectioncreateProjection (const ossimKeywordlist &kwl, const char *prefix) const
 Take a keywordlist. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossimProjectionFactoryBase
virtual ossimProjectioncreateProjection (ossimImageHandler *handler) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimNgaProjectionFactoryinstance ()
 Implements singleton pattern. More...
 ossimNgaProjectionFactory ()
 Constructor loads all SRS CSV files specified in the ossim prefs. More...
- Protected Member Functions inherited from ossimProjectionFactoryBase
ossimProjectioncreateProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const
 This method takes the filename and tries to find an external ".geom" file. More...
virtual ~ossimReferenced ()
Detailed Description
Definition at line 15 of file ossimNgaProjectionFactory.h.
◆ ossimNgaProjectionFactory()
ossimNgaProjectionFactory::ossimNgaProjectionFactory ( )
inlineprotected
Protected as part of singleton implementation.
Definition at line 60 of file ossimNgaProjectionFactory.h.
60 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimNgaProjectionFactory::createObject ( const ossimString typeName) const
virtual
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 71 of file ossimNgaProjectionFactory.cpp.
References createProjection().
73 {
74  return createProjection(typeName);
75 }
virtual ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
takes a filename.
◆ createObject() [2/2]
ossimObject * ossimNgaProjectionFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Creates and object given a keyword list.
Definition at line 77 of file ossimNgaProjectionFactory.cpp.
79 {
80  return createProjection(kwl, prefix);
81 }
takes a filename.
◆ createProjection() [1/3]
ossimProjection * ossimNgaProjectionFactory::createProjection ( const ossimFilename filename,
) const
virtual
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implements ossimProjectionFactoryBase.
Definition at line 34 of file ossimNgaProjectionFactory.cpp.
References ossimProjectionFactoryBase::createProjectionFromGeometryFile().
Referenced by createObject().
36  {
37  // Check for external geometry file.
38  return createProjectionFromGeometryFile(filename, entryIdx);
39 }
ossimProjection * createProjectionFromGeometryFile(const ossimFilename &imageFile, ossim_uint32 entryIdx) const
◆ createProjection() [2/3]
ossimProjection * ossimNgaProjectionFactory::createProjection ( const ossimString name) const
virtual
Definition at line 49 of file ossimNgaProjectionFactory.cpp.
References ossimString::after(), ossimEllipsoidFactory::create(), ossimEllipsoidFactory::instance(), and ossimString::toInt().
51 {
52  ossimProjection* proj = 0;
53  if ((!ossimString(spec).downcase().contains("nga")) && (spec.after(":").toInt() == 235))
54  {
56  proj = new ossimMercatorProjection(*e, ossimGpt(0,0), 0, 0, 0.857385503731176);
57  }
58
59  return proj;
60 }
static ossimEllipsoidFactory * instance()
const ossimEllipsoid * create(const ossimString &code) const
◆ createProjection() [3/3]
ossimProjection * ossimNgaProjectionFactory::createProjection ( const ossimKeywordlist kwl,
const char *  prefix
) const
virtual
Take a keywordlist.
Definition at line 65 of file ossimNgaProjectionFactory.cpp.
67 {
68  return 0;
69 }
◆ getTypeNameList()
void ossimNgaProjectionFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 83 of file ossimNgaProjectionFactory.cpp.
84 {
85  typeList.push_back(ossimString("NGA:235 \"Scaled World Mercator\""));
86 }
◆ instance()
ossimNgaProjectionFactory * ossimNgaProjectionFactory::instance ( )
static
Definition at line 27 of file ossimNgaProjectionFactory.cpp.
Referenced by ossimProjectionFactoryRegistry::initializeDefaults().
28 {
29  static ossimNgaProjectionFactory inst;
30
31  return &inst;
32 }
