Factory for PNG image reader. More...
#include <ossimPdalReaderFactory.h>
virtual | ~ossimPdalReaderFactory () |
virtual destructor More... | |
virtual ossimPdalReader * | open (const ossimFilename &fileName) const |
virtual ossimPdalReader * | open (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
virtual void | getSupportedExtensions (std::vector< ossimString > &extList) const |
virtual | ~ossimPointCloudHandlerFactory () |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimPdalReaderFactory * | instance () |
ossimPdalReaderFactory () | |
hidden from use default constructor More... | |
ossimPdalReaderFactory (const ossimPdalReaderFactory &) | |
hidden from use copy constructor More... | |
void | operator= (const ossimPdalReaderFactory &) |
virtual | ~ossimReferenced () |
Static Protected Attributes | |
static ossimPdalReaderFactory * | m_instance = 0 |
static instance of this class More... | |
Definition at line 22 of file ossimPdalReaderFactory.h.
virtual destructor
Definition at line 19 of file ossimPdalReaderFactory.cpp.
References m_instance.
protected |
Definition at line 94 of file ossimPdalReaderFactory.cpp.
Referenced by instance().
protected |
Definition at line 98 of file ossimPdalReaderFactory.cpp.
Creates an object given a type name.
Implements ossimPointCloudHandlerFactory.
Definition at line 61 of file ossimPdalReaderFactory.cpp.
References ossimRefPtr< T >::release().
Creates and object given a keyword list.
Reimplemented from ossimPointCloudHandlerFactory.
Definition at line 75 of file ossimPdalReaderFactory.cpp.
References open().
Definition at line 87 of file ossimPdalReaderFactory.cpp.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Implements ossimObjectFactory.
Definition at line 81 of file ossimPdalReaderFactory.cpp.
Referenced by ossimSharedLibraryInitialize().
static |
Definition at line 24 of file ossimPdalReaderFactory.cpp.
References m_instance, and ossimPdalReaderFactory().
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
Definition at line 33 of file ossimPdalReaderFactory.cpp.
References ossimPointCloudHandler::open(), and ossimRefPtr< T >::release().
Referenced by createObject().
Definition at line 47 of file ossimPdalReaderFactory.cpp.
References ossimSource::loadState(), and ossimRefPtr< T >::release().
protected |
Definition at line 102 of file ossimPdalReaderFactory.cpp.
staticprotected |
Definition at line 54 of file ossimPdalReaderFactory.h.
Referenced by instance(), and ~ossimPdalReaderFactory().
