ossimPdalReader Class Reference
#include <ossimPdalReader.h>
Inheritance diagram for ossimPdalReader:
ossimPointCloudHandler ossimPointCloudSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimPdalFileReader ossimRialtoReader
Public Member Functions
 ossimPdalReader ()
 default constructor More...
virtual ~ossimPdalReader ()
 virtual destructor More...
virtual void rewind () const
virtual ossim_uint32 getNumPoints () const
 Returns number of points in the data file. More...
virtual void close ()
 Closes the point cloud file(s). More...
virtual ossim_uint32 getFieldCode () const
 Fetches the data fields ids available from this source, OR'd together for testing against specific field (. More...
virtual void setFieldCode (ossim_uint32 fieldCode)
 Sets the data fields ID of interest for this source, and all input sources connected to this. More...
- Public Member Functions inherited from ossimPointCloudHandler
 ossimPointCloudHandler ()
 ossimPointCloudHandler (ossimObject *owner)
virtual ~ossimPointCloudHandler ()
virtual bool open (const ossimFilename &imageFile)=0
 Method to open input point cloud dataset. More...
virtual void getFileBlock (ossim_uint32 offset, ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const =0
 Fetches up to maxNumPoints points starting at the dataset's <offset> in the order they appear in the data file. More...
virtual void getNextFileBlock (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const
virtual void getBlock (const ossimGrect &bounds, ossimPointBlock &block) const
 Fetches the block of points inside the block bounds. More...
virtual const ossimPointRecordgetMinPoint () const
 Assigns the two points with fields representing the extremes of the dataset. More...
virtual const ossimPointRecordgetMaxPoint () const
virtual void getBounds (ossimGrect &bounds) const
virtual bool canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const
 Handler is always on the start of the pipeline. More...
void normalizeBlock (ossimPointBlock &block)
- Public Member Functions inherited from ossimPointCloudSource
 ossimPointCloudSource (ossimObject *owner=0)
virtual ~ossimPointCloudSource ()
virtual bool hasFields (ossim_uint32 id) const
 Returns true if the data field is available from this source. More...
bool hasRGB () const
 Special for convenience. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
virtual void initialize ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
Protected Member Functions
void parsePointView (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const
 The current point ID (pid) gets updated. More...
void parsePoint (ossimPointRecord *precord) const
 Need to pass allocated ossimPointRecord with field code set to desired fields. More...
virtual void establishMinMax ()
 Computes min and max records using points in the current PointViewSet. More...
virtual void establishAvailableFields ()
- Protected Member Functions inherited from ossimPointCloudSource
 ossimPointCloudSource (const ossimPointCloudSource &rhs)
virtual ~ossimReferenced ()
Protected Attributes
pdal::PointViewSet m_pvs
pdal::PointViewPtr m_currentPV
ossim_uint32 m_currentPvOffset
PointTablePtr m_pointTable
pdal::Stage * m_pdalPipe
pdal::Options m_pdalOptions
ossim_uint32 m_availableFields
- Protected Attributes inherited from ossimPointCloudHandler
ossimFilename m_inputFilename
ossimRefPtr< ossimPointCloudGeometrym_geometry
ossimRefPtr< ossimPointRecordm_minRecord
ossimRefPtr< ossimPointRecordm_maxRecord
ossim_uint32 m_currentPID
- Protected Attributes inherited from ossimPointCloudSource
ossimPointRecord m_nullPCR
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Additional Inherited Members
- Static Public Attributes inherited from ossimPointCloudHandler
static ossim_uint32 DEFAULT_BLOCK_SIZE = 0x400000
Detailed Description
Definition at line 22 of file ossimPdalReader.h.
◆ ossimPdalReader()
ossimPdalReader::ossimPdalReader ( )
default constructor
Definition at line 23 of file ossimPdalReader.cpp.
References ossimPointCloudHandler::m_geometry.
24 : m_currentPV (0),
26  m_pdalPipe (0),
28 {
29  // create unity-transform, geographic geometry. derived classes may overwrite this later
31 }
ossimRefPtr< ossimPointCloudGeometry > m_geometry
◆ ~ossimPdalReader()
ossimPdalReader::~ossimPdalReader ( )
virtual
virtual destructor
Definition at line 34 of file ossimPdalReader.cpp.
References m_pdalPipe.
35 {
36  delete m_pdalPipe;
37 }
Member Function Documentation
◆ close()
virtual void ossimPdalReader::close ( )
inlinevirtual
Implements ossimPointCloudHandler.
Definition at line 38 of file ossimPdalReader.h.
38 { m_currentPV = 0; m_pointTable = 0; }
◆ establishAvailableFields()
void ossimPdalReader::establishAvailableFields ( )
protectedvirtual
Reimplemented in ossimRialtoReader.
Definition at line 311 of file ossimPdalReader.cpp.
References ossimPointRecord::Blue, ossimPointRecord::GpsTime, ossimPointRecord::Green, ossimPointRecord::Infrared, ossimPointRecord::Intensity, m_availableFields, m_currentPV, ossimPointRecord::NumberOfReturns, ossimPointRecord::Red, and ossimPointRecord::ReturnNumber.
312 {
313  m_availableFields = 0;
314  if (!m_currentPV)
315  return;
316
317  if (m_currentPV->hasDim(Id::Enum::Intensity))
319  if (m_currentPV->hasDim(Id::Enum::ReturnNumber))
321  if (m_currentPV->hasDim(Id::Enum::NumberOfReturns))
323  if (m_currentPV->hasDim(Id::Enum::Red))
325  if (m_currentPV->hasDim(Id::Enum::Green))
327  if (m_currentPV->hasDim(Id::Enum::Blue))
329  if (m_currentPV->hasDim(Id::Enum::GpsTime))
331  if (m_currentPV->hasDim(Id::Enum::Infrared))
333 }
◆ establishMinMax()
void ossimPdalReader::establishMinMax ( )
protectedvirtual
Reimplemented in ossimRialtoReader, and ossimPdalFileReader.
Definition at line 203 of file ossimPdalReader.cpp.
References ossimRefPtr< T >::get(), ossimPointRecord::getField(), getFieldCode(), ossimPointRecord::getFieldCode(), ossimPointRecord::getFieldMap(), ossimPointRecord::getPosition(), ossimPointRecord::Green, ossimGpt::hgt, ossimGpt::lat, ossimGpt::lon, m_currentPV, m_currentPvOffset, ossimPointCloudHandler::m_maxRecord, ossimPointCloudHandler::m_minRecord, m_pvs, parsePoint(), ossimPointRecord::Red, rewind(), ossimPointRecord::setField(), ossimPointRecord::setPosition(), and ossimRefPtr< T >::valid().
Referenced by ossimRialtoReader::establishAvailableFields(), and ossimPdalFileReader::establishMinMax().
204 {
205  rewind();
206
207  PointViewSet::iterator pvs_iter = m_pvs.begin();
208  if ((pvs_iter == m_pvs.end()) || (*pvs_iter)->empty())
209  return;
210
211  if (!m_minRecord.valid())
212  {
215  }
216
217  // Latch first point:
218  m_currentPV = *pvs_iter;
221  ossimGpt minPos (m_minRecord->getPosition());
222  ossimGpt maxPos (minPos);
223
224  // Set up loop over all point view sets:
226  while (pvs_iter != m_pvs.end())
227  {
228  // Set up loop over points in each PointView:
229  m_currentPV = *pvs_iter;
230  m_currentPvOffset = 0;
231
232  // Now loop over all points in PV to latch min/max:
233  PointViewIter pv_iter = m_currentPV->begin();
234  while (pv_iter != m_currentPV->end())
235  {
236  parsePoint(opr.get());
237
238  if (opr->getPosition().lat < minPos.lat)
239  minPos.lat = opr->getPosition().lat;
240  if (opr->getPosition().lon < minPos.lon)
241  minPos.lon = opr->getPosition().lon;
242  if (opr->getPosition().hgt < minPos.hgt)
243  minPos.hgt = opr->getPosition().hgt;
244
245  if (opr->getPosition().lat > maxPos.lat)
246  maxPos.lat = opr->getPosition().lat;
247  if (opr->getPosition().lon > maxPos.lon)
248  maxPos.lon = opr->getPosition().lon;
249  if (opr->getPosition().hgt > maxPos.hgt)
250  maxPos.hgt = opr->getPosition().hgt;
251
252  std::map<ossimPointRecord::FIELD_CODES, ossim_float32>::const_iterator field =
253  opr->getFieldMap().begin();
254  while (field != opr->getFieldMap().end())
255  {
256  if (field->second < m_minRecord->getField(field->first))
257  m_minRecord->setField(field->first, field->second);
258  else if (field->second > m_maxRecord->getField(field->first))
259  m_maxRecord->setField(field->first, field->second);
260  ++field;
261  }
262  ++pv_iter;
264  }
265  ++pvs_iter;
266  }
267
268  m_minRecord->setPosition(minPos);
269  m_maxRecord->setPosition(maxPos);
270
271  // Latch overall min and max color band to avoid color distortion when normalizing:
275  if (m_minRecord->hasFields(R|G|B))
276  {
280  float c = std::min(r, std::min(g, b));
281  m_minRecord->setField(R, c);
282  m_minRecord->setField(G, c);
283  m_minRecord->setField(B, c);
284
285  r = m_maxRecord->getField(R);
286  g = m_maxRecord->getField(G);
287  b = m_maxRecord->getField(B);
288  c = std::max(r, std::max(g, b));
289  m_maxRecord->setField(R, c);
290  m_maxRecord->setField(G, c);
291  m_maxRecord->setField(B, c);
292  }
293
294  rewind();
295 }
ossimRefPtr< ossimPointRecord > m_maxRecord
const std::map< FIELD_CODES, ossim_float32 > & getFieldMap() const
bool valid() const
Definition: ossimRefPtr.h:75
float ossim_float32
ossim_float32 getField(FIELD_CODES fc) const
Return the float value of the requested field.
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
virtual ossim_uint32 getFieldCode() const
Fetches the data fields ids available from this source, OR&#39;d together for testing against specific fi...
void parsePoint(ossimPointRecord *precord) const
ossim_float64 lon
Definition: ossimGpt.h:266
virtual bool hasFields(ossim_uint32 code_mashup) const
Argument can be mash-up of OR&#39;d codes for check of multiple fields.
#define max(a, b)
Definition: auxiliary.h:76
Returns mash-up of OR&#39;d codes of multiple fields being stored.
virtual void rewind() const
const ossimGpt & getPosition() const
Returns the 3D position vector in the dataset&#39;s coodinate reference system (available from the ossimP...
ossim_float64 lat
Definition: ossimGpt.h:265
void setField(FIELD_CODES fc, ossim_float32 value)
void setPosition(const ossimGpt &p)
ossimRefPtr< ossimPointRecord > m_minRecord
#define min(a, b)
Definition: auxiliary.h:75
◆ getFieldCode()
virtual ossim_uint32 ossimPdalReader::getFieldCode ( ) const
inlinevirtual
See also
ossimPointRecord::FIELD_CODES). e.g. (though should use hasField()),
bool hasIntensity = getFields() & ossimPointRecord::Intensity;
Reimplemented from ossimPointCloudSource.
Definition at line 46 of file ossimPdalReader.h.
Referenced by establishMinMax().
46 { return m_availableFields; }
◆ getNumPoints()
ossim_uint32 ossimPdalReader::getNumPoints ( ) const
virtual
Implements ossimPointCloudSource.
Reimplemented in ossimPdalFileReader.
Definition at line 297 of file ossimPdalReader.cpp.
References m_pvs.
298 {
299  ossim_uint32 numPoints = 0;
300
301  PointViewSet::iterator pvs_iter = m_pvs.begin();
302  while (pvs_iter != m_pvs.end())
303  {
304  numPoints += (*pvs_iter)->size();
305  ++pvs_iter;
306  }
307
308  return numPoints;
309 }
unsigned int ossim_uint32
◆ parsePoint()
void ossimPdalReader::parsePoint ( ossimPointRecord precord) const
protected
The pointNum is the point index into the point view
Definition at line 108 of file ossimPdalReader.cpp.
References ossimPointRecord::Blue, ossimPointCloudGeometry::convertPos(), ossimPointRecord::GpsTime, ossimPointRecord::Green, ossimPointRecord::hasFields(), ossimPointRecord::Infrared, ossimPointRecord::Intensity, m_currentPV, m_currentPvOffset, ossimPointCloudHandler::m_geometry, ossimPointRecord::NumberOfReturns, ossimPointRecord::Red, ossimPointRecord::ReturnNumber, ossimPointRecord::setField(), ossimPointRecord::setPosition(), ossimDpt3d::x, ossimDpt3d::y, and ossimDpt3d::z.
Referenced by establishMinMax(), and parsePointView().
109 {
110  if (!point)
111  return;
112
113  ossimDpt3d dpt3d;
114  ossim_uint8 I8;
115  float F32;
116
117  // The ossimPointRecord should already be initialized with the desired fields set to default
118  // values (i.e., their NULL values):
119  const IdList& idList = m_currentPV->dims();
120  IdList::const_iterator dim_iter = idList.begin();
121  while (dim_iter != idList.end())
122  {
123  Id::Enum id = *dim_iter;
124  switch (id)
125  {
126  case Id::Enum::X: // always do position
127  dpt3d.x = m_currentPV->getFieldAs<double>(Id::Enum::X, m_currentPvOffset);
128  break;
129  case Id::Enum::Y: // always do position
130  dpt3d.y = m_currentPV->getFieldAs<double>(Id::Enum::Y, m_currentPvOffset);
131  break;
132  case Id::Enum::Z: // always do position
133  dpt3d.z = m_currentPV->getFieldAs<double>(Id::Enum::Z, m_currentPvOffset);
134  break;
135  case Id::Enum::ReturnNumber:
136  if (point->hasFields(ossimPointRecord::ReturnNumber))
137  {
138  I8 = m_currentPV->getFieldAs<uint8_t>(Id::Enum::ReturnNumber, m_currentPvOffset);
139  point->setField(ossimPointRecord::ReturnNumber, (ossim_float32) I8);
140  }
141  break;
142  case Id::Enum::NumberOfReturns:
143  if (point->hasFields(ossimPointRecord::NumberOfReturns))
144  {
145  I8 = m_currentPV->getFieldAs<uint8_t>(Id::Enum::NumberOfReturns, m_currentPvOffset);
146  point->setField(ossimPointRecord::NumberOfReturns, (ossim_float32) I8);
147  }
148  break;
149  case Id::Enum::Intensity:
150  if (point->hasFields(ossimPointRecord::Intensity))
151  {
152  F32 = m_currentPV->getFieldAs<float>(Id::Enum::Intensity, m_currentPvOffset);
153  point->setField(ossimPointRecord::Intensity, (ossim_float32) F32);
154  }
155  break;
156  case Id::Enum::Red:
157  if (point->hasFields(ossimPointRecord::Red))
158  {
159  F32 = m_currentPV->getFieldAs<float>(Id::Enum::Red, m_currentPvOffset);
160  point->setField(ossimPointRecord::Red, (ossim_float32) F32);
161  }
162  break;
163  case Id::Enum::Green:
164  if (point->hasFields(ossimPointRecord::Green))
165  {
166  F32 = m_currentPV->getFieldAs<float>(Id::Enum::Green, m_currentPvOffset);
167  point->setField(ossimPointRecord::Green, (ossim_float32) F32);
168  }
169  break;
170  case Id::Enum::Blue:
171  if (point->hasFields(ossimPointRecord::Blue))
172  {
173  F32 = m_currentPV->getFieldAs<float>(Id::Enum::Blue, m_currentPvOffset);
174  point->setField(ossimPointRecord::Blue, (ossim_float32) F32);
175  }
176  break;
177  case Id::Enum::Infrared:
178  if (point->hasFields(ossimPointRecord::Infrared))
179  {
180  F32 = m_currentPV->getFieldAs<float>(Id::Enum::Infrared, m_currentPvOffset);
181  point->setField(ossimPointRecord::Infrared, (ossim_float32) F32);
182  }
183  break;
184  case Id::Enum::GpsTime:
185  if (point->hasFields(ossimPointRecord::GpsTime))
186  {
187  F32 = m_currentPV->getFieldAs<float>(Id::Enum::GpsTime, m_currentPvOffset);
188  point->setField(ossimPointRecord::GpsTime, (ossim_float32) F32);
189  }
190  break;
191  default:
192  break;
193  }
194  ++dim_iter;
195  }
196
197  // Need to convert X, Y, Z to geographic point (if necessary).
198  ossimGpt pos;
199  m_geometry->convertPos(dpt3d, pos);
200  point->setPosition(pos);
201 }
float ossim_float32
double z
Definition: ossimDpt3d.h:145
void convertPos(const ossimDpt3d &stored_pos, ossimGpt &converted_gpos) const
Method converts a generic 3D point as stored in the argument ossim3Dpt object, and converts it to an ...
double x
Definition: ossimDpt3d.h:143
double y
Definition: ossimDpt3d.h:144
unsigned char ossim_uint8
◆ parsePointView()
void ossimPdalReader::parsePointView ( ossimPointBlock block,
ossim_uint32  maxNumPoints = 0xFFFFFFFF
) const
protected
The block is added to – pre-existing points remain or get overwritten if pid matches existing.
Definition at line 49 of file ossimPdalReader.cpp.
References ossimPointBlock::addPoint(), ossimPointRecord::Blue, ossimRefPtr< T >::get(), ossimPointRecord::getField(), ossimPointBlock::getFieldCode(), ossimPointRecord::Green, ossimPointCloudSource::hasRGB(), ossimPointRecord::Intensity, ossimPointCloudHandler::m_currentPID, m_currentPvOffset, ossimPointCloudHandler::m_maxRecord, ossimPointCloudHandler::m_minRecord, parsePoint(), ossimPointRecord::Red, ossimPointRecord::setField(), ossimPointRecord::setPointId(), ossimPointBlock::size(), and size.
50 {
51  ossim_uint32 field_code = block.getFieldCode();
52  while (m_currentPvOffset < m_currentPV->size())
53  {
54  if (block.size() == maxNumPoints)
55  break;
56
57  // Convert point data to OSSIM-friendly format:
58 #ifdef NORMALIZE_FIELDS
59  ossim_float32 minI, delI, minC, delC;
60  bool hasIntensity = false;
61  bool hasRGB = false;
62  if (field_code & ossimPointRecord::Intensity)
63  {
64  hasIntensity = true;
67  }
69  if ((field_code & rgb_code) == rgb_code)
70  {
71  hasRGB = true;
74  }
75 #endif
76
77  // cout << "ossimPdalReader::parsePointView() -- point_id = "<< point_id<<endl;
78
79  // Reads directly from the PDAL point buffer:
80  ossimRefPtr<ossimPointRecord> opr = new ossimPointRecord(field_code);
81  parsePoint(opr.get());
82
83  // Normalize intensity and color:
84 #ifdef NORMALIZE_FIELDS
85  if (hasIntensity)
86  {
87  float normI = (opr->getField(ossimPointRecord::Intensity) - minI) / delI;
89  }
90  if (hasRGB)
91  {
92  float normC = (opr->getField(ossimPointRecord::Red) - minC) / delC;
93  opr->setField(ossimPointRecord::Red, normC);
94  normC = (opr->getField(ossimPointRecord::Green) - minC) / delC;
95  opr->setField(ossimPointRecord::Green, normC);
96  normC = (opr->getField(ossimPointRecord::Blue) - minC) / delC;
97  opr->setField(ossimPointRecord::Blue, normC);
98  }
99 #endif
100
101  // Add this point to the output block:
102  opr->setPointId(m_currentPID++);
103  block.addPoint(opr.get());
105  }
106 }
Returns OR&#39;d mash-up of ossimPointRecord field codes being stored (or desired to be stored) ...
float ossim_float32
virtual void addPoint(ossimPointRecord *point)
Adds single point to the tail of the list.
yy_size_t size
virtual ossim_uint32 size() const
Returns allocated size.
bool hasRGB() const
void setPointId(ossim_uint32 id)
◆ rewind()
void ossimPdalReader::rewind ( ) const
virtual
Reimplemented from ossimPointCloudHandler.
Definition at line 39 of file ossimPdalReader.cpp.
References ossimPointCloudHandler::m_currentPID, m_currentPV, m_currentPvOffset, and m_pvs.
40 {
42  if (m_pvs.size())
43  m_currentPV = *(m_pvs.begin());
44  else
45  m_currentPV = 0;
46  m_currentPID = 0;
47 }
◆ setFieldCode()
virtual void ossimPdalReader::setFieldCode ( ossim_uint32  fieldCode)
inlinevirtual
This is an OR'd mash-up of
See also
Definition at line 52 of file ossimPdalReader.h.
52 { m_availableFields = fieldCode; }
Member Data Documentation
◆ m_availableFields
ossim_uint32 ossimPdalReader::m_availableFields
protected
Definition at line 74 of file ossimPdalReader.h.
Referenced by establishAvailableFields().
◆ m_currentPV
pdal::PointViewPtr ossimPdalReader::m_currentPV
mutableprotected
Definition at line 69 of file ossimPdalReader.h.
Referenced by establishAvailableFields(), establishMinMax(), parsePoint(), and rewind().
◆ m_currentPvOffset
ossim_uint32 ossimPdalReader::m_currentPvOffset
mutableprotected
Definition at line 70 of file ossimPdalReader.h.
Referenced by establishMinMax(), parsePoint(), parsePointView(), and rewind().
◆ m_pdalOptions
pdal::Options ossimPdalReader::m_pdalOptions
mutableprotected
Definition at line 73 of file ossimPdalReader.h.
◆ m_pdalPipe
pdal::Stage* ossimPdalReader::m_pdalPipe
protected
Definition at line 72 of file ossimPdalReader.h.
Referenced by ~ossimPdalReader().
◆ m_pointTable
PointTablePtr ossimPdalReader::m_pointTable
mutableprotected
Definition at line 71 of file ossimPdalReader.h.
◆ m_pvs
pdal::PointViewSet ossimPdalReader::m_pvs
mutableprotected
Definition at line 68 of file ossimPdalReader.h.
Referenced by establishMinMax(), getNumPoints(), and rewind().
