Public Member Functions | Private Member Functions | List of all members
ossimRialtoReader Class Reference
#include <ossimRialtoReader.h>
Inheritance diagram for ossimRialtoReader:
ossimPdalReader ossimPointCloudHandler ossimPointCloudSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimRialtoReader ()
 default constructor More...
virtual ~ossimRialtoReader ()
 virtual destructor More...
virtual bool open (const ossimFilename &fname)
 Accepts filename of Rialto database file. More...
virtual void getFileBlock (ossim_uint32 offset, ossimPointBlock &block, ossim_uint32 np=0) const
 Riaalto implementation does not support direct file reads, so this method is stubbed out with a warining message. More...
virtual void getBlock (const ossimGrect &bounds, ossimPointBlock &block) const
 Fetches the block of points inside the block bounds. More...
- Public Member Functions inherited from ossimPdalReader
 ossimPdalReader ()
virtual ~ossimPdalReader ()
virtual void rewind () const
virtual ossim_uint32 getNumPoints () const
 Returns number of points in the data file. More...
virtual void close ()
 Closes the point cloud file(s). More...
virtual ossim_uint32 getFieldCode () const
 Fetches the data fields ids available from this source, OR'd together for testing against specific field (. More...
virtual void setFieldCode (ossim_uint32 fieldCode)
 Sets the data fields ID of interest for this source, and all input sources connected to this. More...
- Public Member Functions inherited from ossimPointCloudHandler
 ossimPointCloudHandler ()
 ossimPointCloudHandler (ossimObject *owner)
virtual ~ossimPointCloudHandler ()
virtual void getNextFileBlock (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const
virtual const ossimPointRecordgetMinPoint () const
 Assigns the two points with fields representing the extremes of the dataset. More...
virtual const ossimPointRecordgetMaxPoint () const
virtual void getBounds (ossimGrect &bounds) const
virtual bool canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const
 Handler is always on the start of the pipeline. More...
void normalizeBlock (ossimPointBlock &block)
- Public Member Functions inherited from ossimPointCloudSource
 ossimPointCloudSource (ossimObject *owner=0)
virtual ~ossimPointCloudSource ()
virtual bool hasFields (ossim_uint32 id) const
 Returns true if the data field is available from this source. More...
bool hasRGB () const
 Special for convenience. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
virtual void initialize ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
virtual void establishMinMax ()
 Computes min and max records using points in the current PointViewSet. More...
virtual void establishAvailableFields ()
Additional Inherited Members
- Static Public Attributes inherited from ossimPointCloudHandler
static ossim_uint32 DEFAULT_BLOCK_SIZE = 0x400000
- Protected Member Functions inherited from ossimPdalReader
void parsePointView (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const
 The current point ID (pid) gets updated. More...
void parsePoint (ossimPointRecord *precord) const
 Need to pass allocated ossimPointRecord with field code set to desired fields. More...
- Protected Member Functions inherited from ossimPointCloudSource
 ossimPointCloudSource (const ossimPointCloudSource &rhs)
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimPdalReader
pdal::PointViewSet m_pvs
pdal::PointViewPtr m_currentPV
ossim_uint32 m_currentPvOffset
PointTablePtr m_pointTable
pdal::Stage * m_pdalPipe
pdal::Options m_pdalOptions
ossim_uint32 m_availableFields
- Protected Attributes inherited from ossimPointCloudHandler
ossimFilename m_inputFilename
ossimRefPtr< ossimPointCloudGeometrym_geometry
ossimRefPtr< ossimPointRecordm_minRecord
ossimRefPtr< ossimPointRecordm_maxRecord
ossim_uint32 m_currentPID
- Protected Attributes inherited from ossimPointCloudSource
ossimPointRecord m_nullPCR
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 21 of file ossimRialtoReader.h.
◆ ossimRialtoReader()
ossimRialtoReader::ossimRialtoReader ( )
default constructor
Definition at line 14 of file ossimRialtoReader.cpp.
15 {
16 }
◆ ~ossimRialtoReader()
ossimRialtoReader::~ossimRialtoReader ( )
virtual
virtual destructor
Definition at line 18 of file ossimRialtoReader.cpp.
19 {
20  close();
21 }
virtual void close()
Member Function Documentation
◆ establishAvailableFields()
virtual void ossimRialtoReader::establishAvailableFields ( )
inlineprivatevirtual
Reimplemented from ossimPdalReader.
Definition at line 52 of file ossimRialtoReader.h.
References ossimPdalReader::establishMinMax().
52 { establishMinMax(); }
virtual void establishMinMax()
◆ establishMinMax()
void ossimRialtoReader::establishMinMax ( )
privatevirtual
Definition at line 100 of file ossimRialtoReader.cpp.
References ossimPointRecord::Blue, ossimString::contains(), ossimPointRecord::GpsTime, ossimPointRecord::Green, ossimGpt::hgt, ossimPointRecord::Infrared, ossimPointRecord::Intensity, ossimGpt::lat, ossimGpt::lon, ossimPointRecord::NumberOfReturns, ossimPointRecord::Red, and ossimPointRecord::ReturnNumber.
101 {
102  if (!m_pdalPipe)
103  return;
104
105  if (!m_minRecord.valid())
106  {
109  }
110
111  m_availableFields = 0;
112  if (!m_pdalPipe)
113  return;
114
115  ossimGpt minGpt, maxGpt;
116  RialtoReader* reader = (RialtoReader*) m_pdalPipe;
117  const GpkgMatrixSet& info = reader->getMatrixSet();
118  const std::vector<GpkgDimension>& dimList = info.getDimensions();
119  std::vector<GpkgDimension>::const_iterator dim_iter = dimList.begin();
120
121  while (dim_iter != dimList.end())
122  {
123  double min_value = dim_iter->getMinimum();
124  double max_value = dim_iter->getMaximum();
125  ossimString dimName = dim_iter->getName();
126
127  if (dimName.contains("X")) // longitude in rialto world
128  {
129  minGpt.lon = min_value;
130  maxGpt.lon = max_value;
131  }
132  if (dimName.contains("Y")) // latitude in rialto world
133  {
134  minGpt.lat = min_value;
135  maxGpt.lat = max_value;
136  }
137  if (dimName.contains("Z")) // height (meters) in rialto world
138  {
139  minGpt.hgt = min_value;
140  maxGpt.hgt = max_value;
141  }
142  if (dimName.contains("Intensity"))
143  {
145  m_minRecord->setField(ossimPointRecord::Intensity, (float) min_value);
146  m_maxRecord->setField(ossimPointRecord::Intensity, (float) max_value);
147  }
148  else if (dimName.contains("ReturnNumber"))
149  {
153  }
154  else if (dimName.contains("NumberOfReturns"))
155  {
159  }
160  else if (dimName.contains("Red"))
161  {
163  m_minRecord->setField(ossimPointRecord::Red, (float) min_value);
164  m_maxRecord->setField(ossimPointRecord::Red, (float) max_value);
165  }
166  else if (dimName.contains("Green"))
167  {
169  m_minRecord->setField(ossimPointRecord::Green, (float) min_value);
170  m_maxRecord->setField(ossimPointRecord::Green, (float) max_value);
171  }
172  else if (dimName.contains("Blue"))
173  {
175  m_minRecord->setField(ossimPointRecord::Blue, (float) min_value);
176  m_maxRecord->setField(ossimPointRecord::Blue, (float) max_value);
177  }
178  else if (dimName.contains("GpsTime"))
179  {
181  m_minRecord->setField(ossimPointRecord::GpsTime, (float) min_value);
182  m_maxRecord->setField(ossimPointRecord::GpsTime, (float) max_value);
183  }
184  else if (dimName.contains("Infrared"))
185  {
187  m_minRecord->setField(ossimPointRecord::Infrared, (float) min_value);
188  m_maxRecord->setField(ossimPointRecord::Infrared, (float) max_value);
189  }
190  ++dim_iter;
191  }
192
193  m_minRecord->setPosition(minGpt);
194  m_maxRecord->setPosition(maxGpt);
195
196  // TODO: REMOVE DEBUG
197  {
198  cout<<"minPt: "<<*m_minRecord<<endl;
199  cout<<"maxPt: "<<*m_maxRecord<<endl;
200  }
201 }
ossimRefPtr< ossimPointRecord > m_maxRecord
bool valid() const
Definition: ossimRefPtr.h:75
bool contains(char aChar) const
Definition: ossimString.h:58
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
ossim_float64 lon
Definition: ossimGpt.h:266
ossim_float64 lat
Definition: ossimGpt.h:265
void setField(FIELD_CODES fc, ossim_float32 value)
void setPosition(const ossimGpt &p)
ossimRefPtr< ossimPointRecord > m_minRecord
◆ getBlock()
void ossimRialtoReader::getBlock ( const ossimGrect bounds,
ossimPointBlock block
) const
virtual
If the height components of the bounds are NaN, then only the horizontal bounds are considered. Thread-safe version accepts data block object from caller. The block object is cleared before points are pushed on the vector. The block size will be non-zero if points were found.
Reimplemented from ossimPointCloudHandler.
Definition at line 63 of file ossimRialtoReader.cpp.
References ossimPointBlock::clear(), ossimGpt::lat, ossimGpt::lon, ossimGrect::lr(), and ossimGrect::ul().
Referenced by test_rialto().
64 {
65  // getBlock() (unlike getFileBlock) necessarily starts with an empty data buffer. Only the
66  // field code is referenced to know which fields to pick out of the PDAL table.
67  block.clear();
68
69  // First set up the bounds to be understood by the PDAL rialto reader:
70  double minx = bounds.ul().lon;
71  double maxx = bounds.lr().lon;
72  double miny = bounds.lr().lat;
73  double maxy = bounds.ul().lat;
74  BOX2D bbox_rect (minx, miny, maxx, maxy);
75  std::string bbox_name ("bounds");
76  Option pdalOption;
77  pdalOption.setName(bbox_name);
78  m_pdalOptions.remove(pdalOption);
79  m_pdalOptions.add(bbox_name, bbox_rect);
80  m_pdalPipe->setOptions(m_pdalOptions);
81  m_pointTable = PointTablePtr(new PointTable);
82  m_pdalPipe->prepare(*m_pointTable);
83
84  // Fetch the points:
85  m_pvs = m_pdalPipe->execute(*m_pointTable);
86
87  // Set up loop over all point view sets:
88  m_currentPID = 0;
89  PointViewSet::iterator pvs_iter = m_pvs.begin();
90  while (pvs_iter != m_pvs.end())
91  {
92  // Set up loop over points in each PointView:
93  m_currentPV = *pvs_iter;
95  parsePointView(block);
96  ++pvs_iter;
97  }
98 }
std::shared_ptr< pdal::PointTable > PointTablePtr
void parsePointView(ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const
virtual void clear()
Resets any storage to empty.
ossim_float64 lon
const ossimGpt & ul() const
Definition: ossimGrect.h:252
ossim_float64 lat
const ossimGpt & lr() const
Definition: ossimGrect.h:269
◆ getFileBlock()
void ossimRialtoReader::getFileBlock ( ossim_uint32  offset,
ossimPointBlock block,
ossim_uint32  np = 0
) const
virtual
Implements ossimPointCloudHandler.
Definition at line 53 of file ossimRialtoReader.cpp.
References ossimPointBlock::clear(), ossimNotify(), and ossimNotifyLevel_WARN.
56 {
57  // Rialto does not support file-based reads. Only allowed through the Db
58  ossimNotify(ossimNotifyLevel_WARN) << "ossimRialtoReader::getFileBlock() WARNING: "
59  "Rialto does not support file-based reads. Returning blank point block."<<endl;
60  block.clear();
61 }
◆ open()
bool ossimRialtoReader::open ( const ossimFilename fname)
virtual
Returns TRUE if successful.
Definition at line 23 of file ossimRialtoReader.cpp.
References ossimNotify().
24 {
25  m_inputFilename = db_name;
26  rewind();
27
28  if (!m_inputFilename.ext().contains("gpkg"))
29  return false;
30  try
31  {
32  // Connect to Rialto:
33  m_pdalOptions.add("filename", m_inputFilename.string());
34  m_pdalPipe = new RialtoReader;
35  m_pdalOptions.add("verbose", LogLevel::Debug);
36  m_pdalPipe->setOptions(m_pdalOptions);
37  m_pointTable = PointTablePtr(new PointTable);
38  m_pdalPipe->prepare(*m_pointTable);
39  }
40  catch (std::exception& e)
41  {
42  ossimNotify() << e.what() << endl;
43  return false;
44  }
45
47
49
50  return true;
51 }
virtual void rewind() const
ossimString ext() const
ossimRefPtr< ossimPointCloudGeometry > m_geometry
const std::string & string() const
Definition: ossimString.h:414
