Base class for all point-cloud file readers. More...
#include <ossimPointCloudHandler.h>
ossimPointCloudHandler () | |
ossimPointCloudHandler (ossimObject *owner) | |
virtual | ~ossimPointCloudHandler () |
virtual bool | open (const ossimFilename &imageFile)=0 |
Method to open input point cloud dataset. More... | |
virtual void | close ()=0 |
Closes the point cloud file(s). More... | |
virtual void | getFileBlock (ossim_uint32 offset, ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const =0 |
Fetches up to maxNumPoints points starting at the dataset's <offset> in the order they appear in the data file. More... | |
virtual void | getNextFileBlock (ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const |
virtual void | rewind () const |
virtual void | getBlock (const ossimGrect &bounds, ossimPointBlock &block) const |
Fetches the block of points inside the block bounds. More... | |
virtual const ossimPointRecord * | getMinPoint () const |
Assigns the two points with fields representing the extremes of the dataset. More... | |
virtual const ossimPointRecord * | getMaxPoint () const |
virtual void | getBounds (ossimGrect &bounds) const |
virtual bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const |
Handler is always on the start of the pipeline. More... | |
void | normalizeBlock (ossimPointBlock &block) |
ossimPointCloudSource (ossimObject *owner=0) | |
virtual | ~ossimPointCloudSource () |
virtual ossim_uint32 | getNumPoints () const =0 |
Returns the total number of points in the dataset (not just the block returned in getPoints) More... | |
virtual ossim_uint32 | getFieldCode () const |
Fetches the data fields ids available from this source, OR'd together for testing against specific field (. More... | |
virtual void | setFieldCode (ossim_uint32 fieldCode) |
Sets the data fields ID of interest for this source, and all input sources connected to this. More... | |
virtual bool | hasFields (ossim_uint32 id) const |
Returns true if the data field is available from this source. More... | |
bool | hasRGB () const |
Special for convenience. More... | |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual void | initialize () |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
Static Public Attributes | |
static ossim_uint32 | DEFAULT_BLOCK_SIZE = 0x400000 |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimPointCloudSource (const ossimPointCloudSource &rhs) | |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Definition at line 26 of file ossimPointCloudHandler.h.
ossimPointCloudHandler::ossimPointCloudHandler | ( | ) |
Definition at line 16 of file ossimPointCloudHandler.cpp.
ossimPointCloudHandler::ossimPointCloudHandler | ( | ossimObject * | owner | ) |
Definition at line 21 of file ossimPointCloudHandler.cpp.
Definition at line 28 of file ossimPointCloudHandler.cpp.
inlinevirtual |
Reimplemented from ossimPointCloudSource.
Definition at line 81 of file ossimPointCloudHandler.h.
pure virtual |
Implemented in ossimPdalReader, and ossimGenericPointCloudHandler.
Referenced by ossimPointCloudImageHandler::close().
If the height components of the bounds are NaN, then only the horizontal bounds are considered. Thread-safe version accepts data block object from caller. The block object is cleared before points are pushed on the vector. The block size will be non-zero if points were found.
Implements ossimPointCloudSource.
Reimplemented in ossimRialtoReader.
Definition at line 38 of file ossimPointCloudHandler.cpp.
References ossimPointBlock::addPoint(), ossimPointBlock::clear(), DEFAULT_BLOCK_SIZE, getNextFileBlock(), ossimPointBlock::getPoints(), ossimGrect::pointWithin(), rewind(), and ossimPointBlock::size().
Referenced by ossimPointCloudImageHandler::getTile(), and ossimHlzTool::PatchProcessorJob::level2Test().
Definition at line 66 of file ossimPointCloudHandler.cpp.
References ossimPointRecord::getPosition(), m_maxRecord, m_minRecord, ossimGrect::makeNan(), and ossimRefPtr< T >::valid().
Referenced by ossimPointCloudImageHandler::getImageGeometry(), ossimPointCloudImageHandler::getValidImageVertices(), ossimHlzTool::PatchProcessorJob::level2Test(), ossimPointCloudImageHandler::setGSD(), test_pdal(), and test_rialto().
pure virtual |
Thread-safe implementation accepts an allocated block from the calling method. caller can check block.size() to see if block is full.
Implemented in ossimPdalFileReader, ossimRialtoReader, and ossimGenericPointCloudHandler.
Referenced by getNextFileBlock().
inlinevirtual |
Definition at line 74 of file ossimPointCloudHandler.h.
Referenced by ossimPointCloudImageHandler::setCurrentEntry().
inlinevirtual |
Useful for normalizing and establishing bounds.
Definition at line 73 of file ossimPointCloudHandler.h.
Definition at line 32 of file ossimPointCloudHandler.cpp.
References getFileBlock(), and m_currentPID.
Referenced by getBlock(), and ossimPointCloudImageHandler::getTile().
void ossimPointCloudHandler::normalizeBlock | ( | ossimPointBlock & | block | ) |
Definition at line 74 of file ossimPointCloudHandler.cpp.
References ossimPointRecord::getField(), ossimPointBlock::getFieldCodesAsList(), m_maxRecord, m_minRecord, max, min, ossimPointRecord::setField(), ossimPointBlock::size(), and ossimRefPtr< T >::valid().
pure virtual |
imageFile | Name of point data file to be opened. (or basename for multi-file sets.) |
Referenced by ossimPointCloudHandlerRegistry::open(), and ossimPdalReaderFactory::open().
inlinevirtual |
Reimplemented in ossimPdalReader.
Definition at line 63 of file ossimPointCloudHandler.h.
static |
Definition at line 29 of file ossimPointCloudHandler.h.
mutableprotected |
Definition at line 92 of file ossimPointCloudHandler.h.
Referenced by ossimGenericPointCloudHandler::getFileBlock(), getNextFileBlock(), ossimPdalReader::parsePointView(), and ossimPdalReader::rewind().
protected |
Definition at line 89 of file ossimPointCloudHandler.h.
Referenced by ossimPdalReader::ossimPdalReader(), and ossimPdalReader::parsePoint().
protected |
Definition at line 88 of file ossimPointCloudHandler.h.
protected |
Definition at line 91 of file ossimPointCloudHandler.h.
Referenced by ossimPdalReader::establishMinMax(), getBounds(), normalizeBlock(), ossimGenericPointCloudHandler::ossimGenericPointCloudHandler(), and ossimPdalReader::parsePointView().
protected |
Definition at line 90 of file ossimPointCloudHandler.h.
