Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimPositionQualityEvaluator Class Reference
#include <ossimPositionQualityEvaluator.h>
 ossimPositionQualityEvaluator ()
 default constructor More...
 ossimPositionQualityEvaluator (const ossimEcefPoint &pt, const NEWMAT::Matrix &covMat)
 covariance matrix-based constructor More...
 ossimPositionQualityEvaluator (const ossimEcefPoint &pt, const ossim_float64 &errBiasLOS, const ossim_float64 &errRandLOS, const ossim_float64 &elevAngleLOS, const ossim_float64 &azimAngleLOS, const ossimColumnVector3d &surfN=ossimColumnVector3d(0, 0, 1), const NEWMAT::Matrix &surfCovMat=ossimMatrix3x3::createZero())
 LOS error/geometry-based constructor. More...
 ossimPositionQualityEvaluator (const ossimEcefPoint &pt, const ossim_float64 &errBiasLOS, const ossim_float64 &errRandLOS, const pqeRPCModel &rpc, const ossimColumnVector3d &surfN=ossimColumnVector3d(0, 0, 1), const NEWMAT::Matrix &surfCovMat=ossimMatrix3x3::createZero())
 LOS error/coefficient-based constructor. More...
 ~ossimPositionQualityEvaluator ()
 virtual destructor More...
bool addContributingCovariance (NEWMAT::Matrix &covMat)
 Add contributing covariance matrix. More...
bool addContributingCE_LE (const ossim_float64 &cCE, const ossim_float64 &cLE)
 Add contributing CE/LE. More...
bool subtractContributingCovariance (NEWMAT::Matrix &covMat)
 Subtract contributing covariance matrix. More...
bool subtractContributingCE_LE (const ossim_float64 &cCE, const ossim_float64 &cLE)
 Subtract contributing CE/LE. More...
bool getCovMatrix (NEWMAT::Matrix &covMat) const
 Covariance matrix access. More...
bool computeCE_LE (const pqeProbLev_t pLev, ossim_float64 &CE, ossim_float64 &LE) const
 Compute circular/linear error (CE/LE). More...
bool extractErrorEllipse (const pqeProbLev_t pLev, pqeErrorEllipse &ellipse)
 Extract error ellipse parameters. More...
bool extractErrorEllipse (const pqeProbLev_t pLev, const ossim_float64 &angularIncrement, pqeErrorEllipse &ellipse, pqeImageErrorEllipse_t &ellImage)
 Extract error ellipse parameters; valid only with RPC parameters. More...
bool isValid () const
 State accessor. More...
std::ostream & print (std::ostream &out) const
 Print method. More...
bool decomposeMatrix ()
bool constructMatrix (const ossim_float64 &errBiasLOS, const ossim_float64 &errRandLOS, const ossim_float64 &elevAngleLOS, const ossim_float64 &azimAngleLOS, const ossimColumnVector3d &surfN, const NEWMAT::Matrix &surfCovMat)
bool formCovMatrixFromCE_LE (const ossim_float64 &CE, const ossim_float64 &LE, NEWMAT::Matrix &covMat) const
double compute90PCE () const
bool computeElevAzim (const pqeRPCModel rpc, ossim_float64 &elevAngleLOS, ossim_float64 &azimAngleLOS) const
double polynomial (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const
double dPoly_dLat (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const
double dPoly_dLon (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const
double dPoly_dHgt (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const
ossimColumnVector3d vperp (const ossimColumnVector3d &v1, const ossimColumnVector3d &v2) const
double atan3 (const ossim_float64 y, const ossim_float64 x) const
Private Attributes
bool theEvaluatorValid
ossimGpt thePtG
NEWMAT::Matrix theCovMat
ossimLsrSpace theLocalFrame
pqeErrorEllipse theEllipse
NEWMAT::Matrix theEigenvectors
pqeRPCModel theRpcModel
Detailed Description
Definition at line 67 of file ossimPositionQualityEvaluator.h.
◆ ossimPositionQualityEvaluator() [1/4]
ossimPositionQualityEvaluator::ossimPositionQualityEvaluator ( )
default constructor
Definition at line 56 of file ossimPositionQualityEvaluator.cpp.
57 {
58  if (traceDebug())
59  {
61  << "\nossimPositionQualityEvaluator::ossimPositionQualityEvaluator DEBUG:" << std::endl;
62 #ifdef OSSIM_ID_ENABLED
64  << "OSSIM_ID: " << OSSIM_ID << std::endl;
65 #endif
66  }
67
68  theEvaluatorValid = false;
69  theRpcModel.theType = 'N';
70 }
◆ ossimPositionQualityEvaluator() [2/4]
ossimPositionQualityEvaluator::ossimPositionQualityEvaluator ( const ossimEcefPoint pt,
const NEWMAT::Matrix &  covMat
Parameters
ptCurrent ECF ground estimate.
covMat3X3 ECF covariance matrix.
Definition at line 80 of file ossimPositionQualityEvaluator.cpp.
81 {
82  if (traceDebug())
83  {
85  << "\nossimPositionQualityEvaluator::ossimPositionQualityEvaluator DEBUG:" << std::endl;
86 #ifdef OSSIM_ID_ENABLED
88  << "OSSIM_ID: " << OSSIM_ID << std::endl;
89 #endif
90  }
91  theRpcModel.theType = 'N';
92
93  // Set the point
94  ossimGpt ptG(pt);
95  thePtG = ptG;
96
97  // Define the local frame centered on the point
98  ossimLsrSpace enu(ptG);
99  theLocalFrame = enu;
100
101  // Propagate input ECF cov matrix to local
104
105  // Compute evaluation parameters
107 }
const NEWMAT::Matrix & lsrToEcefRotMatrix() const
NEWMAT::Matrix ecefToLsrRotMatrix() const
◆ ossimPositionQualityEvaluator() [3/4]
const ossim_float64 errBiasLOS,
const ossim_float64 errRandLOS,
const ossim_float64 elevAngleLOS,
const ossim_float64 azimAngleLOS,
const ossimColumnVector3d surfN = ossimColumnVector3d(0,0,1),
const NEWMAT::Matrix &  surfCovMat = ossimMatrix3x3::createZero()
Parameters
errBiasLOS0.68p LOS bias component.
errRandLOS0.68p LOS random component.
elevAngleLOStarget elevation angle.
azimAngleLOStarget azimuth angle.
surfNsurface normal unit vector (defaults to unit Z).
surfCovMatsurface ENU 3X3 covariance matrix (defaults to zero).
Definition at line 117 of file ossimPositionQualityEvaluator.cpp.
124 {
125  if (traceDebug())
126  {
128  << "\nossimPositionQualityEvaluator::ossimPositionQualityEvaluator DEBUG:" << std::endl;
129 #ifdef OSSIM_ID_ENABLED
131  << "OSSIM_ID: " << OSSIM_ID << std::endl;
132 #endif
133  }
134  theRpcModel.theType = 'N';
135
136  // Set the point
137  ossimGpt ptG(pt);
138  thePtG = ptG;
139
140  // Define the local frame centered on the point
141  ossimLsrSpace enu(ptG);
142  theLocalFrame = enu;
143
144  // Form the covariance matrix
145  if (constructMatrix
146  (errBiasLOS, errRandLOS, elevAngleLOS, azimAngleLOS, surfN, surfCovMat))
147  {
148  // Compute evaluation parameters
150  }
151  else
152  {
153  theEvaluatorValid = false;
154  }
155 }
bool constructMatrix(const ossim_float64 &errBiasLOS, const ossim_float64 &errRandLOS, const ossim_float64 &elevAngleLOS, const ossim_float64 &azimAngleLOS, const ossimColumnVector3d &surfN, const NEWMAT::Matrix &surfCovMat)
◆ ossimPositionQualityEvaluator() [4/4]
Parameters
rpcRPC coefficients.
Definition at line 165 of file ossimPositionQualityEvaluator.cpp.
171 {
172  if (traceDebug())
173  {
175  << "\nossimPositionQualityEvaluator::ossimPositionQualityEvaluator DEBUG:" << std::endl;
176 #ifdef OSSIM_ID_ENABLED
178  << "OSSIM_ID: " << OSSIM_ID << std::endl;
179 #endif
180  }
181
182  // Set the point
183  ossimGpt ptG(pt);
184  thePtG = ptG;
185
186  // Define the local frame centered on the point
187  ossimLsrSpace enu(ptG);
188  theLocalFrame = enu;
189
190  // Set the model parameters
191  theRpcModel = rpc;
192
193  // Compute the target elevation & azimuth angles
194  double elevAngleLOS;
195  double azimAngleLOS;
196  computeElevAzim(rpc, elevAngleLOS, azimAngleLOS);
197
198  // Form the covariance matrix
199  if (constructMatrix
200  (errBiasLOS, errRandLOS, elevAngleLOS, azimAngleLOS, surfN, surfCovMat))
201  {
202  // Compute evaluation parameters
204  }
205  else
206  {
207  theEvaluatorValid = false;
208  }
209 }
bool computeElevAzim(const pqeRPCModel rpc, ossim_float64 &elevAngleLOS, ossim_float64 &azimAngleLOS) const
◆ ~ossimPositionQualityEvaluator()
ossimPositionQualityEvaluator::~ossimPositionQualityEvaluator ( )
virtual destructor
Definition at line 216 of file ossimPositionQualityEvaluator.cpp.
217 {
218  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG)
219  << "DEBUG: ~ossimPositionQualityEvaluator(): returning..." << std::endl;
220 }
Member Function Documentation
◆ addContributingCE_LE()
bool ossimPositionQualityEvaluator::addContributingCE_LE ( const ossim_float64 cCE,
const ossim_float64 cLE
Parameters
cCEcontributing 90% circular error (m).
cLEcontributing 90% linear error (m).
Returns
Definition at line 297 of file ossimPositionQualityEvaluator.cpp.
References addContributingCovariance(), and formCovMatrixFromCE_LE().
298 {
299  NEWMAT::Matrix covMat(3,3);
300
301  formCovMatrixFromCE_LE(cCE, cLE, covMat);
302
303  return addContributingCovariance(covMat);
304 }
bool addContributingCovariance(NEWMAT::Matrix &covMat)
bool formCovMatrixFromCE_LE(const ossim_float64 &CE, const ossim_float64 &LE, NEWMAT::Matrix &covMat) const
◆ addContributingCovariance()
bool ossimPositionQualityEvaluator::addContributingCovariance ( NEWMAT::Matrix &  covMat)
Parameters
covMat3X3 covariance matrix.
Returns
Definition at line 274 of file ossimPositionQualityEvaluator.cpp.
References decomposeMatrix(), theCovMat, and theEvaluatorValid.
Referenced by addContributingCE_LE().
275 {
276  bool matrixOK = (covMat.Nrows()==3) && (covMat.Nrows()==3);
277  if (theEvaluatorValid && matrixOK)
278  {
279  // Add contribution
280  theCovMat += covMat;
281
282  // Update the ellipse parameters
284  }
285
286  return (theEvaluatorValid && matrixOK);
287 }
◆ atan3()
double ossimPositionQualityEvaluator::atan3 ( const ossim_float64  y,
) const
private
Definition at line 989 of file ossimPositionQualityEvaluator.cpp.
References M_PI, ossim::sgn(), TWO_PI, x, and y.
991 {
992  double u,v,pih=0.5*M_PI,result;
993
994  if (x == 0.0)
995  result = M_PI - pih * ossim::sgn(y);
996  else
997  {
998  if (y == 0.0)
999  {
1000  if (x > 0.0)
1001  result = 0.0;
1002  else
1003  result = M_PI;
1004  }
1005  else
1006  {
1007  u = y/x;
1008  v = fabs(u);
1009  result = atan(v);
1010  result *= v/u;
1011  if (x < 0.0)
1012  result += M_PI;
1013  else
1014  if (result < 0.0)
1015  result += TWO_PI;
1016  }
1017  }
1018
1019  return result;
1020
1021 }
ossim_uint32 x
T sgn(T x)
Definition: ossimCommon.h:339
ossim_uint32 y
#define M_PI
#define TWO_PI
◆ compute90PCE()
double ossimPositionQualityEvaluator::compute90PCE ( ) const
private
Definition at line 810 of file ossimPositionQualityEvaluator.cpp.
References nMultiplier, table90, theEllipse, pqeErrorEllipse::theSemiMajorAxis, and pqeErrorEllipse::theSemiMinorAxis.
Referenced by computeCE_LE().
811 {
812  // Evaluate CE function via linear interpolation
815  ossim_uint32 ndx = int(floor(pRatio*nMultiplier));
816  ossim_float64 alpha;
817
818  if (ndx == nMultiplier)
819  {
820  alpha = table90[ndx];
821  }
822  else
823  {
824  ossim_float64 fac = (pRatio-(ossim_float64)ndx/(ossim_float64)nMultiplier) / 0.05;
825  alpha = fac * (table90[ndx+1]-table90[ndx]) + table90[ndx];
826  }
827
829
830  return CE90;
831 }
const ossim_float64 table90[nTableEntries]
const ossim_uint32 nMultiplier
double ossim_float64
unsigned int ossim_uint32
◆ computeCE_LE()
bool ossimPositionQualityEvaluator::computeCE_LE ( const pqeProbLev_t  pLev,
ossim_float64 CE,
ossim_float64 LE
) const
Parameters
pLevProbability level.
CEpLev% circular error (m).
LEpLev% linear error (m).
Returns
Definition at line 354 of file ossimPositionQualityEvaluator.cpp.
References compute90PCE(), Fac1D, Fac2D90, theCovMat, and theEvaluatorValid.
355 {
356  if (theEvaluatorValid)
357  {
358  // Compute 1D LE
359  LE = sqrt(theCovMat(3,3)) * (ossim_float64)Fac1D[pLev];
360
361  // Compute 2D CE
362  CE = (ossim_float64)Fac2D90[pLev] * compute90PCE();
363  }
364
365  return theEvaluatorValid;
366 }
const ossim_float64 Fac1D[NUM_PROB_LEVELS]
const ossim_float64 Fac2D90[NUM_PROB_LEVELS]
◆ computeElevAzim()
bool ossimPositionQualityEvaluator::computeElevAzim ( const pqeRPCModel  rpc,
) const
private
Definition at line 841 of file ossimPositionQualityEvaluator.cpp.
References ossimGpt::datum(), DEG_PER_RAD, dPoly_dHgt(), dPoly_dLat(), dPoly_dLon(), ossimLsrSpace::ecefToLsrRotMatrix(), ossimDatum::ellipsoid(), ossimGpt::hgt, ossim::isnan(), ossimEllipsoid::jacobianWrtEcef(), ossimGpt::lat, ossimGpt::lon, polynomial(), pqeRPCModel::theHgtOffset, pqeRPCModel::theHgtScale, pqeRPCModel::theLatOffset, pqeRPCModel::theLatScale, pqeRPCModel::theLineDenCoef, pqeRPCModel::theLineNumCoef, pqeRPCModel::theLineScale, theLocalFrame, pqeRPCModel::theLonOffset, pqeRPCModel::theLonScale, thePtG, pqeRPCModel::theSampDenCoef, pqeRPCModel::theSampNumCoef, pqeRPCModel::theSampScale, ossimDpt::u, and ossimDpt::v.
844 {
845  //***
846  // Normalize the lat, lon, hgt:
847  //***
848  double nlat = (thePtG.lat - rpc.theLatOffset) / rpc.theLatScale;
849  double nlon = (thePtG.lon - rpc.theLonOffset) / rpc.theLonScale;
850  double nhgt;
851
852  if( ossim::isnan(thePtG.hgt) )
853  {
854  nhgt = (rpc.theHgtScale - rpc.theHgtOffset) / rpc.theHgtScale;
855  }
856  else
857  {
858  nhgt = (thePtG.hgt - rpc.theHgtOffset) / rpc.theHgtScale;
859  }
860
861  //***
862  // Compute the numerators & denominators
863  //***
864  double Pu = polynomial(nlat, nlon, nhgt, rpc.theLineNumCoef);
865  double Qu = polynomial(nlat, nlon, nhgt, rpc.theLineDenCoef);
866  double Pv = polynomial(nlat, nlon, nhgt, rpc.theSampNumCoef);
867  double Qv = polynomial(nlat, nlon, nhgt, rpc.theSampDenCoef);
868
869  //***
870  // Compute the partials of each polynomial wrt lat, lon, hgt
871  //***
872  double dPu_dLat = dPoly_dLat(nlat, nlon, nhgt, rpc.theLineNumCoef);
873  double dQu_dLat = dPoly_dLat(nlat, nlon, nhgt, rpc.theLineDenCoef);
874  double dPv_dLat = dPoly_dLat(nlat, nlon, nhgt, rpc.theSampNumCoef);
875  double dQv_dLat = dPoly_dLat(nlat, nlon, nhgt, rpc.theSampDenCoef);
876  double dPu_dLon = dPoly_dLon(nlat, nlon, nhgt, rpc.theLineNumCoef);
877  double dQu_dLon = dPoly_dLon(nlat, nlon, nhgt, rpc.theLineDenCoef);
878  double dPv_dLon = dPoly_dLon(nlat, nlon, nhgt, rpc.theSampNumCoef);
879  double dQv_dLon = dPoly_dLon(nlat, nlon, nhgt, rpc.theSampDenCoef);
880  double dPu_dHgt = dPoly_dHgt(nlat, nlon, nhgt, rpc.theLineNumCoef);
881  double dQu_dHgt = dPoly_dHgt(nlat, nlon, nhgt, rpc.theLineDenCoef);
882  double dPv_dHgt = dPoly_dHgt(nlat, nlon, nhgt, rpc.theSampNumCoef);
883  double dQv_dHgt = dPoly_dHgt(nlat, nlon, nhgt, rpc.theSampDenCoef);
884
885  //***
886  // Compute partials of quotients U and V wrt lat, lon, hgt
887  //***
888  double dU_dLat = (Qu*dPu_dLat - Pu*dQu_dLat)/(Qu*Qu);
889  double dU_dLon = (Qu*dPu_dLon - Pu*dQu_dLon)/(Qu*Qu);
890  double dU_dHgt = (Qu*dPu_dHgt - Pu*dQu_dHgt)/(Qu*Qu);
891  double dV_dLat = (Qv*dPv_dLat - Pv*dQv_dLat)/(Qv*Qv);
892  double dV_dLon = (Qv*dPv_dLon - Pv*dQv_dLon)/(Qv*Qv);
893  double dV_dHgt = (Qv*dPv_dHgt - Pv*dQv_dHgt)/(Qv*Qv);
894
895  //***
896  // Apply necessary scale factors
897  //***
898  dU_dLat *= rpc.theLineScale/rpc.theLatScale;
899  dU_dLon *= rpc.theLineScale/rpc.theLonScale;
900  dU_dHgt *= rpc.theLineScale/rpc.theHgtScale;
901  dV_dLat *= rpc.theSampScale/rpc.theLatScale;
902  dV_dLon *= rpc.theSampScale/rpc.theLonScale;
903  dV_dHgt *= rpc.theSampScale/rpc.theHgtScale;
904
905  dU_dLat *= DEG_PER_RAD;
906  dU_dLon *= DEG_PER_RAD;
907  dV_dLat *= DEG_PER_RAD;
908  dV_dLon *= DEG_PER_RAD;
909
910  // Save the partials referenced to ECF
911  ossimEcefPoint location(thePtG);
912  NEWMAT::Matrix jMat(3,3);
913  thePtG.datum()->ellipsoid()->jacobianWrtEcef(location, jMat);
914  ossimDpt pWRTx;
915  ossimDpt pWRTy;
916  ossimDpt pWRTz;
917  // Line
918  pWRTx.u = dU_dLat*jMat(1,1)+dU_dLon*jMat(2,1)+dU_dHgt*jMat(3,1);
919  pWRTy.u = dU_dLat*jMat(1,2)+dU_dLon*jMat(2,2)+dU_dHgt*jMat(3,2);
920  pWRTz.u = dU_dLat*jMat(1,3)+dU_dLon*jMat(2,3)+dU_dHgt*jMat(3,3);
921  // Samp
922  pWRTx.v = dV_dLat*jMat(1,1)+dV_dLon*jMat(2,1)+dV_dHgt*jMat(3,1);
923  pWRTy.v = dV_dLat*jMat(1,2)+dV_dLon*jMat(2,2)+dV_dHgt*jMat(3,2);
924  pWRTz.v = dV_dLat*jMat(1,3)+dV_dLon*jMat(2,3)+dV_dHgt*jMat(3,3);
925
926  // Form required partials in local frame
927  NEWMAT::Matrix jECF(3,2);
928  jECF(1,1) = pWRTx.u;
929  jECF(1,2) = pWRTx.v;
930  jECF(2,1) = pWRTy.u;
931  jECF(2,2) = pWRTy.v;
932  jECF(3,1) = pWRTz.u;
933  jECF(3,2) = pWRTz.v;
934  NEWMAT::Matrix jLSR(3,2);
935  jLSR = theLocalFrame.ecefToLsrRotMatrix()*jECF;
936  double dU_dx = jLSR(1,1);
937  double dU_dy = jLSR(2,1);
938  double dU_dz = jLSR(3,1);
939  double dV_dx = jLSR(1,2);
940  double dV_dy = jLSR(2,2);
941  double dV_dz = jLSR(3,2);
942
943  // Compute azimuth & elevation angles
944  double den = dU_dy*dV_dx - dV_dy*dU_dx;
945  double dY = dU_dx*dV_dz - dV_dx*dU_dz;
946  double dX = dV_dy*dU_dz - dU_dy*dV_dz;
947  double dy_dH = dY / den;
948  double dx_dH = dX / den;
949
950  azimAngleLOS = atan2(dx_dH, dy_dH);
951  elevAngleLOS = atan2(1.0, sqrt(dy_dH*dy_dH+dx_dH*dx_dH));
952
953  if (traceDebug())
954  {
955  ossimNotify(ossimNotifyLevel_DEBUG)<<"DEBUG: computeElevAzim..."<<endl;
957  " el,az = "<<elevAngleLOS*DEG_PER_RAD<<" "<<azimAngleLOS*DEG_PER_RAD<<endl;
958  }
959
960  return true;
961 }
double dPoly_dHgt(const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const
#define DEG_PER_RAD
double u
Definition: ossimDpt.h:164
double polynomial(const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const
double dPoly_dLat(const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
ossim_float64 lon
Definition: ossimGpt.h:266
virtual const ossimEllipsoid * ellipsoid() const
Definition: ossimDatum.h:60
double dPoly_dLon(const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const
void jacobianWrtEcef(const ossimEcefPoint &location, NEWMAT::Matrix &jMat) const
ossim_float64 lat
Definition: ossimGpt.h:265
double v
Definition: ossimDpt.h:165
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ constructMatrix()
bool ossimPositionQualityEvaluator::constructMatrix ( const ossim_float64 errBiasLOS,
const ossimColumnVector3d surfN,
private
Definition at line 541 of file ossimPositionQualityEvaluator.cpp.
547 {
548  bool constructOK = true;
549  ossimColumnVector3d lsrNorm(0.0,0.0,1.0);
550
551  // Set the total error
552  ossim_float64 eTot = sqrt(errBiasLOS*errBiasLOS + errRandLOS*errRandLOS);
553  if (eTot == 0.0)
554  eTot = 0.001;
555
556  // Set the LOS unit vector
557  double elC = elevAngleLOS;
558  double azC = azimAngleLOS;
559  ossimColumnVector3d LOS(sin(azC)*cos(elC), cos(azC)*cos(elC), sin(elC));
560
561  if (traceDebug())
562  {
563  ossimNotify(ossimNotifyLevel_DEBUG)<<"DEBUG: constructMatrix..."<<endl;
565  <<" tEl,tAz: "<<elC*DEG_PER_RAD<<" "<<azC*DEG_PER_RAD<<endl;
567  <<" LOS: "<<LOS<<endl;
569  <<" eTot: "<<eTot<<endl;
570  }
571
572
573  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
574  // Set ENU-referenced terrain slope normal
575  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
576  ossimColumnVector3d tSlopeN = surfN.unit();
577  if (traceDebug())
578  {
579  ossimNotify(ossimNotifyLevel_DEBUG) <<" tSlopeN: "<<tSlopeN<<endl;
580  }
581
582  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
583  // Compute normal to plane containing LOS and terrain normal
584  // this is direction of minor axis unless geometry causes swap
585  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
586  ossimColumnVector3d pMinU(0,1,0);
587  ossimColumnVector3d pMinAxis = LOS.cross(tSlopeN);
588  if (pMinAxis.magnitude() > DBL_EPSILON)
589  {
590  pMinU = pMinAxis.unit();
591  }
592  if (traceDebug())
593  {
594  ossimNotify(ossimNotifyLevel_DEBUG) <<" pMinU: "<<pMinU<<endl;
595  }
596
597  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
598  // Compute nominal major axis direction from cross
599  // product of minor axis vector and terrain slope normal
600  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
601  ossimColumnVector3d pMaxU = (tSlopeN.cross(pMinU)).unit();
602  if (traceDebug())
603  {
604  ossimNotify(ossimNotifyLevel_DEBUG) <<" pMaxU: "<<pMaxU<<endl;
605  }
606
607
608  // Compute elevation angle relative to terrain plane and check for positive
609  double elevAngTerr = acos(pMaxU.dot(LOS));
610  if (traceDebug())
611  {
612  ossimNotify(ossimNotifyLevel_DEBUG)<<" elev angle rel to surface: "
613  <<elevAngTerr*DEG_PER_RAD<<endl;
614  }
615
616  if (elevAngTerr > 0.0)
617  {
618  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
619  // Compute the LOS error the surface plane
620  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
621  double planeErrorL = eTot/sin(elevAngTerr);
622
623  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~
624  // Project axes to horizontal
625  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~
626  ossimColumnVector3d pL = vperp(pMaxU, lsrNorm);
627  ossimColumnVector3d pN = vperp(pMinU, lsrNorm);
628
629  ossimColumnVector3d eL = pL * planeErrorL;
630  ossimColumnVector3d eN = pN * eTot;
631  double magL = eL.magnitude();
632  double magN = eN.magnitude();
633
634  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
635  // Compute vertical component due to intersection geometry
636  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
637  ossimColumnVector3d pV = pMaxU - pL;
638  ossimColumnVector3d eV = pV * planeErrorL;
639  double magV = eV.magnitude();
640
641  if (traceDebug())
642  {
644  <<" Projected horizontal/vertical components...."<<endl
645  <<" pL: "<<pL<<" magL: "<<magL<<endl
646  <<" pN: "<<pN<<" magN: "<<magN<<endl
647  <<" pV: "<<pV<<" magV: "<<magV<<endl;
648  }
649
650
651
652
653  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
654  // Now compute the contributions of the surface uncertainty
655  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
656
657  // Terrain slope angle
658  double tSlope = acos(tSlopeN.dot(lsrNorm));
659
660  // Vertical & horizontal components from surface covariance matrix
661  double surfSigV = sqrt(surfCovMat(3,3));
662  double surfSigH = sqrt((surfCovMat(1,1)+surfCovMat(2,2))/2.0);
663  double surfSigV_h = surfSigH * tan(tSlope);
664
665  // Effective total vertical error component includes
666  // horizontal uncertainty induced by local slope
667  double vSigTot = sqrt(surfSigV*surfSigV + surfSigV_h*surfSigV_h);
668
669  // Project to surface normal direction to bring it into the L-surfN plane
670  ossimColumnVector3d s_surfN = (lsrNorm.dot(tSlopeN))*tSlopeN;
671  if (traceDebug())
672  {
673  ossimNotify(ossimNotifyLevel_DEBUG) <<" Surface uncertainty...."<<endl;
674  ossimNotify(ossimNotifyLevel_DEBUG) <<" tSlope angle: "<<tSlope*DEG_PER_RAD<<endl;
675  ossimNotify(ossimNotifyLevel_DEBUG) <<" s_surfN(unit): "<<s_surfN<<endl;
676  }
677  s_surfN = s_surfN * vSigTot;
678  double sigTn = s_surfN.magnitude();
679
680  // Compute corresponding error in LOS direction
681  double sigVl = sigTn/sin(elevAngTerr);
682
683  // Resolve total vertical error to components based on intersection geometry
684  ossimColumnVector3d vSigHvec = sigVl * vperp(LOS, lsrNorm);
685  ossimColumnVector3d vSigVvec = sigVl * (LOS.dot(lsrNorm))*lsrNorm;
686  double vSigH = vSigHvec.magnitude();
687  double vSigV = vSigVvec.magnitude();
688  if (traceDebug())
689  {
691  <<" s_surfN: "<<s_surfN
692  <<"\n vSigHvec: "<<vSigHvec
693  <<"\n vSigVvec: "<<vSigVvec<<endl;
694  }
695
696
697  if (traceDebug())
698  {
699  ossimNotify(ossimNotifyLevel_DEBUG)<<"----------------------------"<<endl;
700  ossimNotify(ossimNotifyLevel_DEBUG)<<" surfSigH: "<<surfSigH<<endl;
701  ossimNotify(ossimNotifyLevel_DEBUG)<<" surfSigV: "<<surfSigV<<endl;
702  ossimNotify(ossimNotifyLevel_DEBUG)<<" vSigTot: "<<vSigTot<<endl;
703  ossimNotify(ossimNotifyLevel_DEBUG)<<" vSigH: "<<vSigH<<endl;
704  ossimNotify(ossimNotifyLevel_DEBUG)<<" vSigV: "<<vSigV<<endl;
705  ossimNotify(ossimNotifyLevel_DEBUG)<<"----------------------------"<<endl;
706  }
707
708
709
710  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
711  // Add vSigH contribution (vSigH in L-surfN plane)
712  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
713  magL = sqrt(magL*magL + vSigH*vSigH);
714
715  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
716  // Compute the axes magnitudes & rotation angle
717  // These parameters represent the horizontal error
718  // due to acquisition geometry & terrain slope
719  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
720  double theta;
721  double pMax, pMin;
722  if (magL > magN)
723  {
724  pMax = magL;
725  pMin = magN;
726  theta = atan3(pL[1],pL[0]);
727  }
728  else
729  {
730  pMax = magN;
731  pMin = magL;
732  theta = atan3(pN[1],pN[0]);
733  }
734
735
736  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
737  // Form final covariance matrix from axes & rotation angle
738  // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
739  NEWMAT::Matrix Cov(2,2);
740  NEWMAT::Matrix Vcomp(2,2);
741  NEWMAT::DiagonalMatrix Dcomp(2);
742
743  Dcomp(1,1) = pMax*pMax;
744  Dcomp(2,2) = pMin*pMin;
745  Vcomp(1,1) = cos(theta);
746  Vcomp(2,1) = sin(theta);
747  Vcomp(1,2) =-Vcomp(2,1);
748  Vcomp(2,2) = Vcomp(1,1);
749  Cov = Vcomp*Dcomp*Vcomp.t();
750
751  // Load full 3X3 matrix in local frame
752  NEWMAT::Matrix covMat(3,3);
753  covMat(1,1) = Cov(1,1);
754  covMat(1,2) = Cov(1,2);
755  covMat(1,3) = 0.0;
756  covMat(2,1) = Cov(2,1);
757  covMat(2,2) = Cov(2,2);
758  covMat(2,3) = 0.0;
759  covMat(3,1) = covMat(1,3);
760  covMat(3,2) = covMat(2,3);
761  covMat(3,3) = magV*magV + vSigV*vSigV;
762
763  // Save the matrix in local frame
764  theCovMat = covMat;
765
766  } //end if (elevAngTerr > 0.0)
767  else
768  {
769  constructOK = false;
771  << "WARNING: ossimPositionQualityEvaluator::constructMatrix(): "
772  << "\n terrain-referenced elev ang: "<<elevAngTerr*DEG_PER_RAD
773  << std::endl;
774  }
775
776
777  return constructOK;
778 }
ossimColumnVector3d cross(const ossimColumnVector3d &rhs) const
double dot(const ossimColumnVector3d &rhs) const
#define DEG_PER_RAD
ossimColumnVector3d vperp(const ossimColumnVector3d &v1, const ossimColumnVector3d &v2) const
ossimColumnVector3d unit() const
#define DBL_EPSILON
double atan3(const ossim_float64 y, const ossim_float64 x) const
◆ decomposeMatrix()
bool ossimPositionQualityEvaluator::decomposeMatrix ( )
private
Definition at line 500 of file ossimPositionQualityEvaluator.cpp.
References theCovMat.
Referenced by addContributingCovariance(), and subtractContributingCovariance().
501 {
502  // Decompose upper left 2X2 partition
503  NEWMAT::SymmetricMatrix S(2);
504  S<<theCovMat(1,1)<<theCovMat(1,2)<<theCovMat(2,2);
505  NEWMAT::DiagonalMatrix D;
506  NEWMAT::Matrix V;
507  NEWMAT::Jacobi(S,D,V);
508  theEllipse.theSemiMinorAxis = sqrt(D(1,1));
509  theEllipse.theSemiMajorAxis = sqrt(D(2,2));
510  theEigenvectors = V;
511
512  // Compute error ellipse orientation
513  // (ccw rotation of major axis from x-axis)
514  ossim_float64 sin2theta = 2.0*theCovMat(1,2);
515  ossim_float64 cos2theta = theCovMat(1,1)-theCovMat(2,2);
516  if (cos2theta == 0.0)
517  {
518  return false;
519  }
520  else
521  {
522  // Convert "ccw from x-axis" to "cw from y-axis(N)"
523  double rotAngle = atan3(sin2theta, cos2theta)/2.0;
524  theEllipse.theAzimAngle = M_PI/2.0 - rotAngle;
525  if (theEllipse.theAzimAngle < 0.0)
527  }
528
529  return true;
530 }
#define M_PI
#define TWO_PI
void Jacobi(const SymmetricMatrix &, DiagonalMatrix &)
Definition: jacobi.cpp:110
◆ dPoly_dHgt()
double ossimPositionQualityEvaluator::dPoly_dHgt ( const double &  nlat,
const double &  nlon,
const double &  nhgt,
const double *  coeffs
) const
private
Definition at line 1122 of file ossimPositionQualityEvaluator.cpp.
References theRpcModel, and pqeRPCModel::theType.
Referenced by computeElevAzim().
1127 {
1128  double dr;
1129
1130  if (theRpcModel.theType == 'A')
1131  {
1132  dr = c[3] + c[5]*L + c[6]*P + c[7]*L*P + 2*c[10]*H + c[13]*L*L +
1133  c[16]*P*P + 2*c[17]*L*H + 2*c[18]*P*H + 3*c[19]*H*H;
1134  }
1135  else
1136  {
1137  dr = c[3] + c[5]*L + c[6]*P + 2*c[9]*H + c[10]*L*P + 2*c[13]*L*H +
1138  2*c[16]*P*H + c[17]*L*L + c[18]*P*P + 3*c[19]*H*H;
1139  }
1140  return dr;
1141 }
◆ dPoly_dLat()
double ossimPositionQualityEvaluator::dPoly_dLat ( const double &  nlat,
) const
private
Definition at line 1065 of file ossimPositionQualityEvaluator.cpp.
1070 {
1071  double dr;
1072
1073  if (theRpcModel.theType == 'A')
1074  {
1075  dr = c[2] + c[4]*L + c[6]*H + c[7]*L*H + 2*c[9]*P + c[12]*L*L +
1076  2*c[14]*L*P + 3*c[15]*P*P +2*c[16]*P*H + c[18]*H*H;
1077  }
1078  else
1079  {
1080  dr = c[2] + c[4]*L + c[6]*H + 2*c[8]*P + c[10]*L*H + 2*c[12]*L*P +
1081  c[14]*L*L + 3*c[15]*P*P + c[16]*H*H + 2*c[18]*P*H;
1082  }
1083
1084  return dr;
1085 }
◆ dPoly_dLon()
double ossimPositionQualityEvaluator::dPoly_dLon ( const double &  nlat,
) const
private
Definition at line 1094 of file ossimPositionQualityEvaluator.cpp.
1099 {
1100  double dr;
1101
1102  if (theRpcModel.theType == 'A')
1103  {
1104  dr = c[1] + c[4]*P + c[5]*H + c[7]*P*H + 2*c[8]*L + 3*c[11]*L*L +
1105  2*c[12]*L*P + 2*c[13]*L*H + c[14]*P*P + c[17]*H*H;
1106  }
1107  else
1108  {
1109  dr = c[1] + c[4]*P + c[5]*H + 2*c[7]*L + c[10]*P*H + 3*c[11]*L*L +
1110  c[12]*P*P + c[13]*H*H + 2*c[14]*P*L + 2*c[17]*L*H;
1111  }
1112  return dr;
1113 }
◆ extractErrorEllipse() [1/2]
bool ossimPositionQualityEvaluator::extractErrorEllipse ( const pqeProbLev_t  pLev,
pqeErrorEllipse ellipse
Parameters
ellipsepLev% error ellipse.
Returns
Definition at line 376 of file ossimPositionQualityEvaluator.cpp.
References Fac2D, pqeErrorEllipse::theAzimAngle, pqeErrorEllipse::theCenter, theEllipse, theEvaluatorValid, thePtG, pqeErrorEllipse::theSemiMajorAxis, and pqeErrorEllipse::theSemiMinorAxis.
Referenced by extractErrorEllipse().
377 {
378  if (theEvaluatorValid)
379  {
380  // Scale the axes
381  ellipse.theSemiMinorAxis =
383  ellipse.theSemiMajorAxis =
385
386  // Orientation angle
388
389  // Center position
390  ellipse.theCenter = thePtG;
391  }
392
393  return theEvaluatorValid;
394 }
const ossim_float64 Fac2D[NUM_PROB_LEVELS]
◆ extractErrorEllipse() [2/2]
const ossim_float64 angularIncrement,
pqeErrorEllipse ellipse,
pqeImageErrorEllipse_t ellImage
Parameters
angularIncrementAngular increment for ellipse point spacing (deg)
ellImagepLev% image space error ellipse.
Returns
Definition at line 404 of file ossimPositionQualityEvaluator.cpp.
References extractErrorEllipse(), ossimGpt::height(), ossim::isnan(), ossimGpt::latd(), ossimGpt::lond(), M_PI, polynomial(), pqeErrorEllipse::theAzimAngle, theEvaluatorValid, pqeRPCModel::theHgtOffset, pqeRPCModel::theHgtScale, pqeRPCModel::theLatOffset, pqeRPCModel::theLatScale, pqeRPCModel::theLineDenCoef, pqeRPCModel::theLineNumCoef, pqeRPCModel::theLineOffset, pqeRPCModel::theLineScale, theLocalFrame, pqeRPCModel::theLonOffset, pqeRPCModel::theLonScale, theRpcModel, pqeRPCModel::theSampDenCoef, pqeRPCModel::theSampNumCoef, pqeRPCModel::theSampOffset, pqeRPCModel::theSampScale, pqeErrorEllipse::theSemiMajorAxis, pqeErrorEllipse::theSemiMinorAxis, pqeRPCModel::theType, TWO_PI, x, and y.
408 {
409  bool computeImageEllipse = true;
410
411  if (theRpcModel.theType == 'N')
412  computeImageEllipse = false;
413
414  if (theEvaluatorValid && computeImageEllipse)
415  {
416  // Get object space ellipse parameters
417  extractErrorEllipse(pLev, ellipse);
418
419  //***
420  // Generate the image space ellipse point at 'angularIncrement' spacing
421  //***
422  int numSteps = 360/(int)angularIncrement;
423
424  // Semi-axes components
425  double dxMaj = ellipse.theSemiMajorAxis*sin(ellipse.theAzimAngle);
426  double dyMaj = ellipse.theSemiMajorAxis*cos(ellipse.theAzimAngle);
427  double dxMin = ellipse.theSemiMinorAxis*sin(ellipse.theAzimAngle+M_PI/2.0);
428  double dyMin = ellipse.theSemiMinorAxis*cos(ellipse.theAzimAngle+M_PI/2.0);
429
430  for (int j = 0; j<=numSteps; ++j)
431  {
432
433  // Compute current ENU ellipse point
434  double ang = TWO_PI*j/numSteps;
435  double sang = sin(ang);
436  double cang = cos(ang);
437  double x = dxMaj*cang + dxMin*sang;
438  double y = dyMaj*cang + dyMin*sang;
439  double z = 0.0;
440
441  ossimLsrPoint cpLSR(x, y, z, theLocalFrame);
442  ossimEcefPoint cp = ossimEcefPoint(cpLSR);
443  ossimGpt cpG(cp);
444  double lat = cpG.latd();
445  double lon = cpG.lond();
446  double hgt = cpG.height();
447
448  // Normalize the lat, lon, hgt:
449  double nlat = (lat - theRpcModel.theLatOffset) /
451  double nlon = (lon - theRpcModel.theLonOffset) /
453  double nhgt;
454
455  if( ossim::isnan(hgt) )
456  {
459  }
460  else
461  {
463  }
464
465  //***
466  // Compute the normalized line (Un) and sample (Vn)
467  //***
468  double Pu = polynomial(nlat, nlon, nhgt, theRpcModel.theLineNumCoef);
469  double Qu = polynomial(nlat, nlon, nhgt, theRpcModel.theLineDenCoef);
470  double Pv = polynomial(nlat, nlon, nhgt, theRpcModel.theSampNumCoef);
471  double Qv = polynomial(nlat, nlon, nhgt, theRpcModel.theSampDenCoef);
472  double Un = Pu / Qu;
473  double Vn = Pv / Qv;
474
475  //***
476  // Compute the actual line (U) and sample (V):
477  //***
480
481  ossimDpt img(V,U);
482  ellImage.push_back(img);
483
484  }
485  }
486
487  return (theEvaluatorValid && computeImageEllipse);
488 }
ossim_uint32 x
ossim_uint32 y
#define M_PI
#define TWO_PI
bool extractErrorEllipse(const pqeProbLev_t pLev, pqeErrorEllipse &ellipse)
◆ formCovMatrixFromCE_LE()
bool ossimPositionQualityEvaluator::formCovMatrixFromCE_LE ( const ossim_float64 CE,
const ossim_float64 LE,
) const
private
Definition at line 788 of file ossimPositionQualityEvaluator.cpp.
Referenced by addContributingCE_LE(), and subtractContributingCE_LE().
791 {
792  covMat = 0.0;
793  covMat(1,1) = CE/2.146;
794  covMat(2,2) = CE/2.146;
795  covMat(3,3) = LE/1.6449;
796  covMat(1,1) *= covMat(1,1);
797  covMat(2,2) *= covMat(2,2);
798  covMat(3,3) *= covMat(3,3);
799
800  return true;
801 }
◆ getCovMatrix()
bool ossimPositionQualityEvaluator::getCovMatrix ( NEWMAT::Matrix &  covMat) const
Parameters
Returns
Definition at line 256 of file ossimPositionQualityEvaluator.cpp.
References theCovMat, and theEvaluatorValid.
257 {
258  if (theEvaluatorValid)
259  {
260  covMat = theCovMat;
261  }
262
263  return theEvaluatorValid;
264 }
◆ isValid()
bool ossimPositionQualityEvaluator::isValid ( void  ) const
inline
State accessor.
Definition at line 224 of file ossimPositionQualityEvaluator.h.
◆ polynomial()
double ossimPositionQualityEvaluator::polynomial ( const double &  nlat,
) const
private
Definition at line 1030 of file ossimPositionQualityEvaluator.cpp.
Referenced by computeElevAzim(), and extractErrorEllipse().
1035 {
1036  double r;
1037
1038  if (theRpcModel.theType == 'A')
1039  {
1040  r = c[ 0] + c[ 1]*L + c[ 2]*P + c[ 3]*H +
1041  c[ 4]*L*P + c[ 5]*L*H + c[ 6]*P*H + c[ 7]*L*P*H +
1042  c[ 8]*L*L + c[ 9]*P*P + c[10]*H*H + c[11]*L*L*L +
1043  c[12]*L*L*P + c[13]*L*L*H + c[14]*L*P*P + c[15]*P*P*P +
1044  c[16]*P*P*H + c[17]*L*H*H + c[18]*P*H*H + c[19]*H*H*H;
1045  }
1046  else
1047  {
1048  r = c[ 0] + c[ 1]*L + c[ 2]*P + c[ 3]*H +
1049  c[ 4]*L*P + c[ 5]*L*H + c[ 6]*P*H + c[ 7]*L*L +
1050  c[ 8]*P*P + c[ 9]*H*H + c[10]*L*P*H + c[11]*L*L*L +
1051  c[12]*L*P*P + c[13]*L*H*H + c[14]*L*L*P + c[15]*P*P*P +
1052  c[16]*P*H*H + c[17]*L*L*H + c[18]*P*P*H + c[19]*H*H*H;
1053  }
1054
1055  return r;
1056 }
◆ print()
std::ostream & ossimPositionQualityEvaluator::print ( std::ostream &  out) const
Print method.
Definition at line 230 of file ossimPositionQualityEvaluator.cpp.
References DEG_PER_RAD, pqeErrorEllipse::theAzimAngle, theCovMat, theEllipse, theEvaluatorValid, thePtG, pqeErrorEllipse::theSemiMajorAxis, and pqeErrorEllipse::theSemiMinorAxis.
231 {
232  out << "\nPositionQualityEvaluator Summary..."<<std::endl;
233  out << " theEvaluatorValid: ";
234  if (theEvaluatorValid)
235  out<<"True"<<std::endl;
236  else
237  out<<"False"<<std::endl;
238  out << " thePtG: "<<thePtG<<std::endl;
239  out << " theCovMat [m]:\n"<<theCovMat;
240  out << fixed << setprecision(1);
241  out << " theEllipse: "<<theEllipse.theSemiMajorAxis<<" "
243  <<" [m, 1 sigma] at ";
244  out << theEllipse.theAzimAngle*DEG_PER_RAD<<" [deg] azimuth"<<endl;
245
246  return out;
247 }
#define DEG_PER_RAD
◆ subtractContributingCE_LE()
bool ossimPositionQualityEvaluator::subtractContributingCE_LE ( const ossim_float64 cCE,
Parameters
Returns
Definition at line 337 of file ossimPositionQualityEvaluator.cpp.
References formCovMatrixFromCE_LE(), and subtractContributingCovariance().
338 {
339  NEWMAT::Matrix covMat(3,3);
340
341  formCovMatrixFromCE_LE(cCE, cLE, covMat);
342
343  return subtractContributingCovariance(covMat);
344 }
bool subtractContributingCovariance(NEWMAT::Matrix &covMat)
◆ subtractContributingCovariance()
bool ossimPositionQualityEvaluator::subtractContributingCovariance ( NEWMAT::Matrix &  covMat)
Parameters
Returns
Definition at line 314 of file ossimPositionQualityEvaluator.cpp.
Referenced by subtractContributingCE_LE().
315 {
316  bool matrixOK = (covMat.Nrows()==3) && (covMat.Nrows()==3);
317  if (theEvaluatorValid && matrixOK)
318  {
319  // Subtract contribution
320  theCovMat -= covMat;
321
322  // Update the ellipse parameters
324  }
325
326  return (theEvaluatorValid && matrixOK);
327 }
◆ vperp()
ossimColumnVector3d ossimPositionQualityEvaluator::vperp ( const ossimColumnVector3d v1,
const ossimColumnVector3d v2
) const
private
Definition at line 971 of file ossimPositionQualityEvaluator.cpp.
References ossimColumnVector3d::dot().
972 {
973
974  double scale = v1.dot(v2)/v2.dot(v2);
975  ossimColumnVector3d v = v2*scale;
976
977  ossimColumnVector3d p = v1 - v;
978
979  return p;
980 }
Member Data Documentation
◆ theCovMat
NEWMAT::Matrix ossimPositionQualityEvaluator::theCovMat
private
◆ theEigenvectors
NEWMAT::Matrix ossimPositionQualityEvaluator::theEigenvectors
private
Definition at line 243 of file ossimPositionQualityEvaluator.h.
◆ theEllipse
pqeErrorEllipse ossimPositionQualityEvaluator::theEllipse
private
Definition at line 242 of file ossimPositionQualityEvaluator.h.
Referenced by compute90PCE(), extractErrorEllipse(), and print().
◆ theEvaluatorValid
bool ossimPositionQualityEvaluator::theEvaluatorValid
private
◆ theLocalFrame
ossimLsrSpace ossimPositionQualityEvaluator::theLocalFrame
private
Definition at line 241 of file ossimPositionQualityEvaluator.h.
◆ thePtG
ossimGpt ossimPositionQualityEvaluator::thePtG
private
Definition at line 239 of file ossimPositionQualityEvaluator.h.
Referenced by computeElevAzim(), extractErrorEllipse(), and print().
◆ theRpcModel
pqeRPCModel ossimPositionQualityEvaluator::theRpcModel
private
