Public Member Functions | Protected Attributes | Friends | List of all members
ossimplugins::AttitudeData Class Reference
This class is able to read a Attitude data record. More...
#include <AttitudeData.h>
Inheritance diagram for ossimplugins::AttitudeData:
ossimplugins::RadarSatRecord
 AttitudeData ()
 Constructor. More...
 ~AttitudeData ()
 Destructor. More...
 AttitudeData (const AttitudeData &rhs)
 Copy constructor. More...
AttitudeDataoperator= (const AttitudeData &rhs)
 Copy operator. More...
RadarSatRecordInstanciate ()
 This function is able to create a new instance of the class. More...
RadarSatRecordClone ()
 This function is able to create a new instance of the class initialised with the data of the calling instance. More...
void Read (std::istream &is)
 Reads the class data from a stream. More...
void Write (std::ostream &os)
 Writes the class to a stream. More...
int get_npoint ()
 Number of data points. More...
DataPointDataRecordget_att_vect ()
Data points More...
double get_pitch_bias ()
Pitch bias (degrees) More...
double get_roll_bias ()
Roll bias (degrees) More...
double get_yaw_bias ()
Yaw bias (degrees) More...
- Public Member Functions inherited from ossimplugins::RadarSatRecord
 RadarSatRecord (std::string mnemonic)
virtual ~RadarSatRecord ()
 Destructor. More...
 RadarSatRecord (const RadarSatRecord &rhs)
std::string get_mnemonic ()
int _npoint
DataPointDataRecord _att_vect [20]
Data points More...
double _pitch_bias
double _roll_bias
double _yaw_bias
- Protected Attributes inherited from ossimplugins::RadarSatRecord
std::string _mnemonic
Friends
std::ostream & operator<< (std::ostream &os, const AttitudeData &data)
 This function writes the AttitudeData in a stream. More...
std::istream & operator>> (std::istream &is, AttitudeData &data)
 This function reads a AttitudeData from a stream. More...
Detailed Description
Definition at line 28 of file AttitudeData.h.
◆ AttitudeData() [1/2]
ossimplugins::AttitudeData::AttitudeData ( )
Constructor.
Definition at line 18 of file AttitudeData.cpp.
Referenced by Clone(), and Instanciate().
18  : RadarSatRecord("att_data_rec")
19 {
20 }
RadarSatRecord(std::string mnemonic)
Constructor.
◆ ~AttitudeData()
ossimplugins::AttitudeData::~AttitudeData ( )
Destructor.
Definition at line 22 of file AttitudeData.cpp.
23 {
24 }
◆ AttitudeData() [2/2]
ossimplugins::AttitudeData::AttitudeData ( const AttitudeData rhs)
Copy constructor.
Definition at line 69 of file AttitudeData.cpp.
References _att_vect, _npoint, _pitch_bias, _roll_bias, and _yaw_bias.
69  :
70  RadarSatRecord(rhs)
71 {
72  _npoint = rhs._npoint;
73  for (int i=0;i<20;i++)
74  {
75  _att_vect[i] = rhs._att_vect[i];
76  }
77  _pitch_bias = rhs._pitch_bias;
78  _roll_bias = rhs._roll_bias;
79  _yaw_bias = rhs._yaw_bias;
80 }
double _pitch_bias
Definition: AttitudeData.h:141
Constructor.
double _roll_bias
Roll bias (degrees)
Definition: AttitudeData.h:145
double _yaw_bias
Yaw bias (degrees)
Definition: AttitudeData.h:149
int _npoint
Definition: AttitudeData.h:126
DataPointDataRecord _att_vect[20]
Data points
Definition: AttitudeData.h:137
Member Function Documentation
◆ Clone()
RadarSatRecord* ossimplugins::AttitudeData::Clone ( )
inlinevirtual
Implements ossimplugins::RadarSatRecord.
Definition at line 71 of file AttitudeData.h.
References AttitudeData().
72  {
73  return new AttitudeData(*this);
74  };
◆ get_att_vect()
DataPointDataRecord* ossimplugins::AttitudeData::get_att_vect ( )
inline
Data points
Definition at line 102 of file AttitudeData.h.
References _att_vect.
103  {
104  return _att_vect;
105  };
Data points
◆ get_npoint()
int ossimplugins::AttitudeData::get_npoint ( )
inline
Definition at line 95 of file AttitudeData.h.
References _npoint.
96  {
97  return _npoint;
98  };
int _npoint
◆ get_pitch_bias()
double ossimplugins::AttitudeData::get_pitch_bias ( )
inline
Definition at line 109 of file AttitudeData.h.
References _pitch_bias.
110  {
111  return _pitch_bias;
112  };
double _pitch_bias
◆ get_roll_bias()
double ossimplugins::AttitudeData::get_roll_bias ( )
inline
Roll bias (degrees)
Definition at line 116 of file AttitudeData.h.
References _roll_bias.
117  {
118  return _roll_bias;
119  };
double _roll_bias
Roll bias (degrees)
◆ get_yaw_bias()
double ossimplugins::AttitudeData::get_yaw_bias ( )
inline
Yaw bias (degrees)
Definition at line 123 of file AttitudeData.h.
References _yaw_bias.
124  {
125  return _yaw_bias;
126  };
double _yaw_bias
Yaw bias (degrees)
◆ Instanciate()
RadarSatRecord* ossimplugins::AttitudeData::Instanciate ( )
inlinevirtual
Definition at line 63 of file AttitudeData.h.
64  {
65  return new AttitudeData();
66  };
◆ operator=()
AttitudeData & ossimplugins::AttitudeData::operator= ( const AttitudeData rhs)
Copy operator.
Definition at line 82 of file AttitudeData.cpp.
83 {
84  _npoint = rhs._npoint;
85  for (int i=0;i<20;i++)
86  {
87  _att_vect[i] = rhs._att_vect[i];
88  }
89  _pitch_bias = rhs._pitch_bias;
90  _roll_bias = rhs._roll_bias;
91  _yaw_bias = rhs._yaw_bias;
92  return *this;
93 }
double _pitch_bias
double _roll_bias
Roll bias (degrees)
double _yaw_bias
Yaw bias (degrees)
int _npoint
Data points
◆ Read()
void ossimplugins::AttitudeData::Read ( std::istream &  is)
inlinevirtual
Definition at line 79 of file AttitudeData.h.
80  {
81  is>>*this;
82  };
◆ Write()
void ossimplugins::AttitudeData::Write ( std::ostream &  os)
inlinevirtual
Definition at line 87 of file AttitudeData.h.
88  {
89  os<<*this;
90  };
◆ operator<<
std::ostream& operator<< ( std::ostream &  os,
const AttitudeData data
friend
Definition at line 26 of file AttitudeData.cpp.
27 {
28  os<<"npoint:"<<data._npoint<<std::endl;
29  for (int i=0;i<20;i++)
30  {
31  os<<"att_vect["<<i<<"]:"<<data._att_vect[i]<<std::endl;
32  }
33  os<<"pitch_bias:"<<data._pitch_bias<<std::endl;
34  os<<"roll_bias:"<<data._roll_bias<<std::endl;
35  os<<"yaw_bias:"<<data._yaw_bias<<std::endl;
36  return os;
37 }
◆ operator>>
std::istream& operator>> ( std::istream &  is,
AttitudeData data
friend
Definition at line 39 of file AttitudeData.cpp.
40 {
41  char buf[6503];
42  buf[6502] = '\0';
43
44  is.read(buf,4);
45  buf[4] = '\0';
46  data._npoint = atoi(buf);
47
48  for (int i=0;i<20;i++)
49  {
50  is>>data._att_vect[i];
51  }
52  is.read(buf,14);
53  buf[14] = '\0';
54  data._pitch_bias = atof(buf);
55
56  is.read(buf,14);
57  buf[14] = '\0';
58  data._roll_bias = atof(buf);
59
60  is.read(buf,14);
61  buf[14] = '\0';
62  data._yaw_bias = atof(buf);
63
64  is.read(buf,6502);
65
66  return is;
67 }
Member Data Documentation
◆ _att_vect
DataPointDataRecord ossimplugins::AttitudeData::_att_vect[20]
protected
◆ _npoint
int ossimplugins::AttitudeData::_npoint
protected
Definition at line 126 of file AttitudeData.h.
Referenced by AttitudeData(), get_npoint(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _pitch_bias
double ossimplugins::AttitudeData::_pitch_bias
protected
Definition at line 141 of file AttitudeData.h.
Referenced by AttitudeData(), get_pitch_bias(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _roll_bias
double ossimplugins::AttitudeData::_roll_bias
protected
Roll bias (degrees)
Definition at line 145 of file AttitudeData.h.
Referenced by AttitudeData(), get_roll_bias(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
◆ _yaw_bias
double ossimplugins::AttitudeData::_yaw_bias
protected
Yaw bias (degrees)
Definition at line 149 of file AttitudeData.h.
Referenced by AttitudeData(), get_yaw_bias(), ossimplugins::operator<<(), operator=(), and ossimplugins::operator>>().
