28 os<<
"npoint:"<<data.
_npoint<<std::endl;
29 for (
int i=0;i<20;i++)
31 os<<
"att_vect["<<i<<
"]:"<<data.
_att_vect[i]<<std::endl;
35 os<<
"yaw_bias:"<<data.
_yaw_bias<<std::endl;
48 for (
int i=0;i<20;i++)
73 for (
int i=0;i<20;i++)
85 for (
int i=0;i<20;i++)
double _pitch_bias
Pitch bias (degrees)
This class is the base class of all the record classes.
std::ostream & operator<<(std::ostream &os, const AlosPalsarData &data)
double _roll_bias
Roll bias (degrees)
std::istream & operator>>(std::istream &is, AlosPalsarData &data)
AttitudeData()
Constructor.
double _yaw_bias
Yaw bias (degrees)
~AttitudeData()
Destructor.
std::basic_istream< char > istream
Base class for char input streams.
int _npoint
Number of data points.
AttitudeData & operator=(const AttitudeData &rhs)
Copy operator.
This class is able to read a Attitude data record.
DataPointDataRecord _att_vect[20]
Data points
std::basic_ostream< char > ostream
Base class for char output streams.
