Public Member Functions | Protected Attributes | List of all members
ossimplugins::JSDDateTime Class Reference
This class represents a date. More...
#include <JSDDateTime.h>
 JSDDateTime ()
 constructor More...
 ~JSDDateTime ()
 Destructor. More...
 JSDDateTime (const JSDDateTime &rhs)
 Copy constructor. More...
 JSDDateTime (JulianDate day0hTU, double second, double decimal)
 Constructor with date initialisation. More...
 JSDDateTime (CivilDateTime &rhs)
 Constructor with date initialisation using a CivilDateTime. More...
 JSDDateTime (JulianDate &rhs)
 JSDDateTime (MJDDateTime &rhs)
 Constructor with date initialisation using a MJDDateTime (Modified Julian Date - Used for ENVISAT) More...
JSDDateTimeoperator= (const JSDDateTime &rhs)
 Affectation operator. More...
JulianDate get_day0hTU () const
double get_second () const
double get_decimal () const
void set_day0hTU (JulianDate day)
void set_second (double second)
void set_decimal (double decimal)
void NormDate ()
int AsJulianDate (JulianDate *julian)
 This function converts the current JSDDateTime into Julian Date. More...
int AsGMSTDateTime (GMSTDateTime *GMST)
 This function converts the current JSDDateTime into GMST Date. More...
 operator JulianDate ()
 operator GMSTDateTime ()
JulianDate _day0hTU
 Julian day at 0h00 UT. More...
double _second
double _decimal
Detailed Description
Definition at line 30 of file JSDDateTime.h.
◆ JSDDateTime() [1/6]
ossimplugins::JSDDateTime::JSDDateTime ( )
constructor
Definition at line 28 of file JSDDateTime.cpp.
28  :
29  _day0hTU(0),
30  _second(0.0),
31  _decimal(0.0)
32 {
33 }
JulianDate _day0hTU
Definition: JSDDateTime.h:125
◆ ~JSDDateTime()
ossimplugins::JSDDateTime::~JSDDateTime ( )
Destructor.
Definition at line 35 of file JSDDateTime.cpp.
36 {
37 }
◆ JSDDateTime() [2/6]
ossimplugins::JSDDateTime::JSDDateTime ( const JSDDateTime rhs)
Copy constructor.
Definition at line 39 of file JSDDateTime.cpp.
39  :
40  _day0hTU(rhs._day0hTU),
41  _second(rhs._second),
42  _decimal(rhs._decimal)
43 {
44 }
JulianDate _day0hTU
◆ JSDDateTime() [3/6]
ossimplugins::JSDDateTime::JSDDateTime ( JulianDate  day0hTU,
double  second,
double  decimal
Definition at line 46 of file JSDDateTime.cpp.
46  :
47  _day0hTU(day0hTU),
48  _second(second),
49  _decimal(decimal)
50 {
51 }
JulianDate _day0hTU
◆ JSDDateTime() [4/6]
ossimplugins::JSDDateTime::JSDDateTime ( CivilDateTime rhs)
Definition at line 53 of file JSDDateTime.cpp.
References ossimplugins::CivilDateTime::AsJSDDateTime().
54 {
55  rhs.AsJSDDateTime(this);
56 }
◆ JSDDateTime() [5/6]
ossimplugins::JSDDateTime::JSDDateTime ( JulianDate rhs)
Definition at line 58 of file JSDDateTime.cpp.
References ossimplugins::JulianDate::AsJSDDateTime().
59 {
60  rhs.AsJSDDateTime(this);
61 }
◆ JSDDateTime() [6/6]
ossimplugins::JSDDateTime::JSDDateTime ( MJDDateTime rhs)
Definition at line 64 of file JSDDateTime.cpp.
References _day0hTU, _decimal, _second, ossimplugins::MJDDateTime::get_day(), get_day0hTU(), get_decimal(), ossimplugins::MJDDateTime::get_microsecond(), ossimplugins::MJDDateTime::get_second(), get_second(), NormDate(), ossimplugins::CivilDateTime::set_day(), ossimplugins::CivilDateTime::set_decimal(), ossimplugins::CivilDateTime::set_month(), ossimplugins::CivilDateTime::set_second(), and ossimplugins::CivilDateTime::set_year().
65 {
66  CivilDateTime referenceCiv;
67
68  /* Initialisation of the MJD reference day (01/01/2000, 0h00) */
69  referenceCiv.set_year(2000);
70  referenceCiv.set_month(01);
71  referenceCiv.set_day(01);
72  referenceCiv.set_second(0);
73  referenceCiv.set_decimal(0.0);
74
75  /* JSD day of the ref. MJD date */
76  JSDDateTime referenceJSD(referenceCiv);
77
78  /* JSD day computation */
79  JulianDate JD((double) rhs.get_day());
80
81  _day0hTU = referenceJSD.get_day0hTU() + JD;
82  _second = referenceJSD.get_second() + (double) rhs.get_second();
83  _decimal = referenceJSD.get_decimal() + 0.000001 * (double) rhs.get_microsecond();
84
85  this->NormDate();
86 }
JulianDate _day0hTU
Member Function Documentation
◆ AsGMSTDateTime()
int ossimplugins::JSDDateTime::AsGMSTDateTime ( GMSTDateTime GMST)
Returns
0 if no error or an int greater than 0 indicating the error
Parameters
julianDate[out] The class that receives the result of the conversion of the current JSDDateTime into GMST Date
Definition at line 105 of file JSDDateTime.cpp.
References _decimal, _second, ossimplugins::GMSTDateTime::AN1900, ossimplugins::GMSTDateTime::AN1950, ossimplugins::GMSTDateTime::AN2000, AsJulianDate(), ossimplugins::JulianDate::get_julianDate(), ossimplugins::GMSTDateTime::get_origine(), ossimplugins::CivilDateTime::JOURCIVIL_LENGTH, set_decimal(), set_second(), ossimplugins::GMSTDateTime::set_tms(), and TWOPI.
Referenced by ossimplugins::ossimRadarSatModel::InitPlatformPosition(), ossimplugins::GeographicEphemeris::ToGalilean(), and ossimplugins::GalileanEphemeris::ToGeographic().
106 {
107  const double TWOPI = 6.28318530717958647693 ;
108  const double OMEGATERRE = 6.28318530717958647693 / 86164.09054 ;
109
110  int etat ;
111  JulianDate jourJulien;
112  double t = 0.0;
113  double tsm0hTU = 0.0;
114  double tsm = 0.0;
115  JSDDateTime date0hTU ;
116
117
118  date0hTU = *this ;
119  date0hTU.set_second(0);
120  date0hTU.set_decimal(0.0);
121
122  etat = date0hTU.AsJulianDate(&jourJulien ) ;
123
124  if (etat == 0)
125  {
126  if (GMST->get_origine() == GMSTDateTime::AN1900)
127  {
128  t = (jourJulien.get_julianDate() - 2415020.0) / 36525.0 ;
129  tsm0hTU = 23925.836 + t * (8640184.542 + t * 0.0929) ;
130  tsm0hTU = tsm0hTU * TWOPI / CivilDateTime::JOURCIVIL_LENGTH ;
131  }
132  else if (GMST->get_origine() == GMSTDateTime::AN1950)
133  {
134  t = jourJulien.get_julianDate() - 2433281.5 ;
135  tsm0hTU = 1.72944494 + t * 6.3003880987 ;
136  }
137  else if (GMST->get_origine() == GMSTDateTime::AN2000)
138  {
139  t = (jourJulien.get_julianDate() - 2451545.0) / 36525.0 ;
140  tsm0hTU = 24110.54841 + t * (8640184.812866
141  + t * (0.093103 - t * 6.210e-6)) ;
142  tsm0hTU = tsm0hTU * TWOPI / CivilDateTime::JOURCIVIL_LENGTH ;
143  }
144  t = tsm0hTU + (_second + _decimal) * OMEGATERRE ;
145  tsm = fmod (t,TWOPI) ;
146  if (tsm < 0.0)
147  {
148  tsm = tsm + TWOPI ;
149  }
150
151  GMST->set_tms(tsm);
152  }
153
154  return etat ;
155 }
static const double JOURCIVIL_LENGTH
◆ AsJulianDate()
int ossimplugins::JSDDateTime::AsJulianDate ( JulianDate julian)
Returns
Parameters
julianDate[out] The classe that receives the result of the conversion of the current JSDDateTime in JulianDate
Definition at line 97 of file JSDDateTime.cpp.
References _day0hTU, _decimal, _second, ossimplugins::JulianDate::get_julianDate(), ossimplugins::CivilDateTime::JOURCIVIL_LENGTH, and ossimplugins::JulianDate::set_julianDate().
Referenced by AsGMSTDateTime(), and ossimplugins::JulianDate::JulianDate().
98 {
100  julian->set_julianDate(jourJulien);
101
102  return 0 ;
103 }
double get_julianDate() const
Definition: JulianDate.h:70
JulianDate _day0hTU
◆ get_day0hTU()
JulianDate ossimplugins::JSDDateTime::get_day0hTU ( ) const
inline
◆ get_decimal()
double ossimplugins::JSDDateTime::get_decimal ( ) const
inline
◆ get_second()
double ossimplugins::JSDDateTime::get_second ( ) const
inline
◆ NormDate()
void ossimplugins::JSDDateTime::NormDate ( )
Definition at line 157 of file JSDDateTime.cpp.
References _day0hTU, _decimal, _second, ossimplugins::fnint(), ossimplugins::JulianDate::get_julianDate(), ossimplugins::inint(), and ossimplugins::CivilDateTime::JOURCIVIL_LENGTH.
Referenced by ossimplugins::ossimGeometricSarSensorModel::getTime(), ossimplugins::ossimErsSarModel::InitPlatformPosition(), ossimplugins::ossimAlosPalsarModel::InitPlatformPosition(), ossimplugins::ossimRadarSatModel::InitPlatformPosition(), and JSDDateTime().
158 {
159  const double epsilon = 1.0e-12 ;
160
161  int k, iu, iv, iw ;
162  double u, v, w, ru, rv, rw ;
163
164
165  w = _day0hTU.get_julianDate() - 0.5 ;
166  if (fabs (w - fnint (w)) < epsilon)
167  {
168  iw = (int)inint(w) ;
169  rw = 0.0 ;
170  }
171  else
172  {
173  iw = (int)w ;
174  rw = w - (double)iw ;
175  if ((iw < 0) && (rw != 0.0))
176  {
177  iw = iw - 1 ;
178  rw = rw + 1.0 ;
179  }
180  }
181
183  if (fabs(v - fnint (v)) < epsilon)
184  {
185  iv = (int)inint (v) ;
186  rv = 0.0 ;
187  }
188  else
189  {
190  iv = (int)v ;
191  rv = v - (double)iv ;
192  if ((iv < 0) && (rv != 0.0))
193  {
194  iv = iv - 1 ;
195  rv = rv + 1.0 ;
196  }
197  }
198
199  u = _decimal + rv ;
200  iu = (int)u ;
201  ru = u - (double)iu ;
202  if ((iu < 0) && (ru != 0.0))
203  {
204  iu = iu - 1 ;
205  ru = ru + 1.0 ;
206  }
207
208  iv = iv + iu ;
209  k = iv / ((int)inint(CivilDateTime::JOURCIVIL_LENGTH)) ;
210  iw = iw + k ;
211  iv = iv - k * ((int)inint(CivilDateTime::JOURCIVIL_LENGTH)) ;
212  if (iv < 0)
213  {
214  iw = iw - 1 ;
215  iv = iv + (int)inint(CivilDateTime::JOURCIVIL_LENGTH) ;
216  }
217
218  _decimal = ru ;
219  _second = (double)iv ;
220  _day0hTU = (double)iw + 0.5 ;
221 }
JulianDate _day0hTU
double fnint(double x)
Definition: Arithmetic.h:35
long inint(double x)
Definition: Arithmetic.h:26
◆ operator GMSTDateTime()
ossimplugins::JSDDateTime::operator GMSTDateTime ( )
Definition at line 230 of file JSDDateTime.cpp.
231 {
232  GMSTDateTime date;
233  this->AsGMSTDateTime(&date);
234  return date;
235 }
int AsGMSTDateTime(GMSTDateTime *GMST)
◆ operator JulianDate()
ossimplugins::JSDDateTime::operator JulianDate ( )
Definition at line 223 of file JSDDateTime.cpp.
224 {
225  JulianDate date;
226  this->AsJulianDate(&date);
227  return date;
228 }
int AsJulianDate(JulianDate *julian)
Definition: JSDDateTime.cpp:97
◆ operator=()
JSDDateTime & ossimplugins::JSDDateTime::operator= ( const JSDDateTime rhs)
Definition at line 88 of file JSDDateTime.cpp.
References _day0hTU, _decimal, and _second.
89 {
90  _day0hTU = rhs._day0hTU;
91  _second = rhs._second;
92  _decimal = rhs._decimal;
93
94  return *this;
95 }
JulianDate _day0hTU
◆ set_day0hTU()
void ossimplugins::JSDDateTime::set_day0hTU ( JulianDate  day)
inline
Definition at line 86 of file JSDDateTime.h.
Referenced by ossimplugins::CivilDateTime::AsJSDDateTime(), ossimplugins::JulianDate::AsJSDDateTime(), and ossimplugins::Ephemeris::loadState().
87  {
88  _day0hTU = day;
89  }
JulianDate _day0hTU
◆ set_decimal()
void ossimplugins::JSDDateTime::set_decimal ( double  decimal)
inline
◆ set_second()
void ossimplugins::JSDDateTime::set_second ( double  second)
inline
Member Data Documentation
◆ _day0hTU
JulianDate ossimplugins::JSDDateTime::_day0hTU
protected
Definition at line 125 of file JSDDateTime.h.
Referenced by AsJulianDate(), JSDDateTime(), NormDate(), and operator=().
◆ _decimal
double ossimplugins::JSDDateTime::_decimal
protected
Definition at line 127 of file JSDDateTime.h.
Referenced by AsGMSTDateTime(), AsJulianDate(), JSDDateTime(), NormDate(), and operator=().
◆ _second
double ossimplugins::JSDDateTime::_second
protected
Definition at line 126 of file JSDDateTime.h.
