Public Member Functions | Protected Attributes | List of all members
ossimplugins::JulianDate Class Reference
This class represents a date in the julian referential. More...
#include <JulianDate.h>
 JulianDate ()
 constructor More...
 ~JulianDate ()
 Destructor. More...
 JulianDate (const JulianDate &rhs)
 Copy constructor. More...
 JulianDate (CivilDateTime &rhs)
 Constructor with date initialisation using a CivilDateTime. More...
 JulianDate (JSDDateTime &rhs)
 Constructor with date initialisation using a JSDDateTime. More...
 JulianDate (double julianDate)
 Constructor with date initialisation. More...
JulianDateoperator= (const JulianDate &rhs)
 Affectation operator. More...
JulianDateoperator+ (const JulianDate &rhs)
 Summation operator. More...
void set_julianDate (double julianDate)
double get_julianDate () const
int AsJSDDateTime (JSDDateTime *JSDdate)
 This function converts the current JulianDate in JSDDateTime. More...
int AsGMSTDateTime (GMSTDateTime *GMST)
 This function converts the current JulianDate into GMSTDateTime. More...
 operator JSDDateTime ()
 operator GMSTDateTime ()
double _julianDate
Detailed Description
Definition at line 27 of file JulianDate.h.
◆ JulianDate() [1/5]
ossimplugins::JulianDate::JulianDate ( )
constructor
Definition at line 27 of file JulianDate.cpp.
27  :
28  _julianDate(0.0)
29 {
30 }
◆ ~JulianDate()
ossimplugins::JulianDate::~JulianDate ( )
Destructor.
Definition at line 47 of file JulianDate.cpp.
48 {
49 }
◆ JulianDate() [2/5]
ossimplugins::JulianDate::JulianDate ( const JulianDate rhs)
Copy constructor.
Definition at line 51 of file JulianDate.cpp.
51  :
52  _julianDate(rhs._julianDate)
53 {
54 }
◆ JulianDate() [3/5]
ossimplugins::JulianDate::JulianDate ( CivilDateTime rhs)
Definition at line 32 of file JulianDate.cpp.
References ossimplugins::CivilDateTime::AsJulianDate().
33 {
34  rhs.AsJulianDate(this);
35 }
◆ JulianDate() [4/5]
ossimplugins::JulianDate::JulianDate ( JSDDateTime rhs)
Definition at line 42 of file JulianDate.cpp.
References ossimplugins::JSDDateTime::AsJulianDate().
43 {
44  rhs.AsJulianDate(this);
45 }
◆ JulianDate() [5/5]
ossimplugins::JulianDate::JulianDate ( double  julianDate)
Definition at line 37 of file JulianDate.cpp.
37  :
38  _julianDate(julianDate)
39 {
40 }
Member Function Documentation
◆ AsGMSTDateTime()
int ossimplugins::JulianDate::AsGMSTDateTime ( GMSTDateTime GMST)
Returns
0 if no error or an int greater than 0 indicating the error
Parameters
GMSTDateTime[out] The class that receives the result of the conversion of the current JulianDate into GMSTDateTime
Definition at line 84 of file JulianDate.cpp.
References _julianDate, ossimplugins::GMSTDateTime::AN1900, ossimplugins::GMSTDateTime::AN1950, ossimplugins::GMSTDateTime::AN2000, ossimplugins::GMSTDateTime::get_origine(), ossimplugins::CivilDateTime::JOURCIVIL_LENGTH, n, ossimplugins::GMSTDateTime::set_tms(), and TWOPI.
85 {
86  const double TWOPI = 6.28318530717958647693 ;
87  const double OMEGATERRE = 6.28318530717958647693 / 86164.09054 ;
88
89  int etat=0 , n ;
90  double j0hTU = 0.0;
91  double tsm0hTU = 0.0;
92  double t = 0.0;
93  double d = 0.0;
94  double tsm = 0.0;
95
96
97  n = (int)(_julianDate - 0.5) ;
98  j0hTU = (double)n + 0.5 ;
99  d = _julianDate - j0hTU ;
100
101  if (etat == 0)
102  {
103  if (GMST->get_origine() == GMSTDateTime::AN1900)
104  {
105  t = (j0hTU - 2415020.0) / 36525.0 ;
106  tsm0hTU = 23925.836 + t * (8640184.542 + t * 0.0929) ;
107  tsm0hTU = tsm0hTU * TWOPI / CivilDateTime::JOURCIVIL_LENGTH ;
108  }
109  else if (GMST->get_origine() == GMSTDateTime::AN1950)
110  {
111  t = j0hTU - 2433281.5 ;
112  tsm0hTU = 1.72944494 + t * 6.3003880987 ;
113  }
114  else if (GMST->get_origine() == GMSTDateTime::AN2000)
115  {
116  t = (j0hTU - 2451545.0) / 36525.0 ;
117  tsm0hTU = 24110.54841 + t * (8640184.812866 + t * (0.093103 - t * 6.210e-6)) ;
118  tsm0hTU = tsm0hTU * TWOPI / CivilDateTime::JOURCIVIL_LENGTH ;
119  }
120  t = tsm0hTU + d * CivilDateTime::JOURCIVIL_LENGTH * OMEGATERRE ;
121  tsm = fmod (t,TWOPI) ;
122  if (tsm < 0.0)
123  {
124  tsm = tsm + TWOPI ;
125  }
126
127  GMST->set_tms(tsm);
128  }
129
130  return etat ;
131 }
static const double JOURCIVIL_LENGTH
os2<< "> n<< " > nendobj n
◆ AsJSDDateTime()
int ossimplugins::JulianDate::AsJSDDateTime ( JSDDateTime JSDdate)
Returns
Parameters
JSDdate[out] The classe that receives the result of the conversion of the current JulianDate in JSDDateTime
Definition at line 68 of file JulianDate.cpp.
References _julianDate, ossimplugins::JSDDateTime::get_second(), ossimplugins::CivilDateTime::JOURCIVIL_LENGTH, ossimplugins::JSDDateTime::set_day0hTU(), ossimplugins::JSDDateTime::set_decimal(), and ossimplugins::JSDDateTime::set_second().
Referenced by ossimplugins::JSDDateTime::JSDDateTime().
69 {
70  int k ;
71  double r ;
72
73  k = (int)(_julianDate - 0.5) ;
74  double jJul0hTU = (double)k + 0.5;
75
76  JSDdate->set_day0hTU (jJul0hTU);
77  r = (_julianDate - jJul0hTU) * CivilDateTime::JOURCIVIL_LENGTH ;
78  JSDdate->set_second(floor (r));
79  JSDdate->set_decimal(r - JSDdate->get_second()) ;
80
81  return 0 ;
82 }
◆ get_julianDate()
double ossimplugins::JulianDate::get_julianDate ( ) const
inline
◆ operator GMSTDateTime()
ossimplugins::JulianDate::operator GMSTDateTime ( )
Definition at line 140 of file JulianDate.cpp.
141 {
142  GMSTDateTime date;
143  AsGMSTDateTime(&date);
144  return date;
145 }
int AsGMSTDateTime(GMSTDateTime *GMST)
Definition: JulianDate.cpp:84
◆ operator JSDDateTime()
ossimplugins::JulianDate::operator JSDDateTime ( )
Definition at line 133 of file JulianDate.cpp.
134 {
135  JSDDateTime date;
136  AsJSDDateTime(&date);
137  return date;
138 }
int AsJSDDateTime(JSDDateTime *JSDdate)
Definition: JulianDate.cpp:68
◆ operator+()
JulianDate & ossimplugins::JulianDate::operator+ ( const JulianDate rhs)
Summation operator.
Definition at line 62 of file JulianDate.cpp.
References _julianDate.
63 {
64  _julianDate += rhs._julianDate;
65  return *this;
66 }
◆ operator=()
JulianDate & ossimplugins::JulianDate::operator= ( const JulianDate rhs)
Definition at line 56 of file JulianDate.cpp.
57 {
58  _julianDate = rhs._julianDate;
59  return *this;
60 }
◆ set_julianDate()
void ossimplugins::JulianDate::set_julianDate ( double  julianDate)
inline
Definition at line 65 of file JulianDate.h.
Referenced by ossimplugins::CivilDateTime::AsJulianDate(), and ossimplugins::JSDDateTime::AsJulianDate().
66  {
67  _julianDate = julianDate;
68  }
Member Data Documentation
◆ _julianDate
double ossimplugins::JulianDate::_julianDate
protected
Definition at line 95 of file JulianDate.h.
Referenced by AsGMSTDateTime(), AsJSDDateTime(), operator+(), and operator=().
