ossimErsSarModel.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // "Copyright Centre National d'Etudes Spatiales"
4 //
5 // License: LGPL
6 //
7 // See LICENSE.txt file in the top level directory for more details.
8 //
9 //----------------------------------------------------------------------------
10 // $Id$
11
12 #include <ossimErsSarModel.h>
13 #include <otb/GalileanEphemeris.h>
15
16 #include <otb/JSDDateTime.h>
17 #include <otb/GMSTDateTime.h>
18 #include <otb/CivilDateTime.h>
19
20 #include <ossim/base/ossimTrace.h>
21 #include <otb/RefPoint.h>
22 #include <erssar/ErsSarLeader.h>
23 #include <otb/SensorParams.h>
24 #include <otb/PlatformPosition.h>
26
27
28 // Static trace for debugging
29 static ossimTrace traceDebug("ossimErsSarModel:debug");
30
31 #include <string>
32 #include <algorithm>
33
34 namespace ossimplugins
35 {
36
37
38  RTTI_DEF1(ossimErsSarModel, "ossimErsSarModel", ossimGeometricSarSensorModel);
39
41  theNumberSRGR(0),
42  thePixelSpacing(0),
43  theErsSarleader(NULL)
44  {
45  theSRGRCoeffset[0][0] = 0.0;
46  theSRGRCoeffset[0][1] = 0.0;
47  theSRGRCoeffset[0][2] = 0.0;
48  }
49
51  {
52  if (theErsSarleader != NULL)
53  {
54  delete theErsSarleader;
55  theErsSarleader = NULL;
56  }
57  }
58
60  {
61  return ossimString("ossimErsSarModel");
62  }
63
65  {
66  return new ossimErsSarModel(*this);
67  }
68
70  {
71  const double c = 2.99792458e+8;
72  double tn = theSRGRCoeffset[0][0] + theSRGRCoeffset[0][1] * col + theSRGRCoeffset[0][2] * col * col ;
73  return tn *(c / 2.0);
74  }
75
76  bool ossimErsSarModel::InitSensorParams(const ossimKeywordlist &kwl, const char *prefix)
77  {
78  const char* wave_length_str = kwl.find(prefix, "wave_length");
79  double wave_length = atof(wave_length_str);
80  const char* fr_str = kwl.find(prefix, "fr");
81  double fr = atof(fr_str) * 1e6;
82  const char* fa_str = kwl.find(prefix, "fa");
83  double fa = atof(fa_str);
84
85  ossimString time_dir_pix = kwl.find(prefix, "time_dir_pix");
86  time_dir_pix.upcase();
87  //std::transform(time_dir_pix.begin(), time_dir_pix.end(), time_dir_pix.begin(), toupper);
88  ossimString time_dir_lin = kwl.find(prefix, "time_dir_lin");
89  time_dir_lin.upcase();
90  //std::transform(time_dir_lin.begin(), time_dir_lin.end(), time_dir_lin.begin(), toupper);
91
92  //ellipsoid parameters
93  const char* ellip_maj_str = kwl.find(prefix, "ellip_maj");
94  double ellip_maj = atof(ellip_maj_str) * 1000.0; // km -> m
95  const char* ellip_min_str = kwl.find(prefix, "ellip_min");
96  double ellip_min = atof(ellip_min_str) * 1000.0; // km -> m
97
98  if (_sensor != NULL)
99  {
100  delete _sensor;
101  }
102
103  _sensor = new SensorParams();
104
105  if (strcmp(time_dir_pix.c_str(), "INCREASE") == 0)
106  {
108  }
109  else
110  {
112  }
113
114  if (strcmp(time_dir_lin.c_str(), "INCREASE") == 0)
115  {
117  }
118  else
119  {
121  }
122
124
125  double nlooks_az = atof(kwl.find(prefix, "nlooks_az"));
126  _sensor->set_nAzimuthLook(nlooks_az);
127  double n_rnglok = atof(kwl.find(prefix, "n_rnglok"));
128  _sensor->set_nRangeLook(n_rnglok);
129
130  _sensor->set_prf(fa);
131  _sensor->set_sf(fr);
132  _sensor->set_rwl(wave_length);
133
134  _sensor->set_semiMajorAxis(ellip_maj) ;
135  _sensor->set_semiMinorAxis(ellip_min) ;
136
137  return true;
138  }
139
141  {
142  static const char MODULE[] = "ossimErsSarModel::open";
143
144  if (traceDebug())
145  {
147  << MODULE << " entered...\n"
148  << "file: " << file << "\n";
149  }
150
151  bool result = false;
152  ossimFilename leaFilename = file;
153
154  /*
155  * Creation of the class allowing to store Leader file metadata
156  */
157  if (theErsSarleader != NULL)
158  {
159  delete theErsSarleader;
160  theErsSarleader = NULL;
161  }
162
164
165  if (leaFilename.exists())
166  {
167  result = isErsLeader(leaFilename);
168  if (result == false)
169  {
170  leaFilename = findErsLeader(file);
171  }
172  result = isErsLeader(leaFilename);
173
174  if (result == true)
175  {
176  if (traceDebug())
177  {
178  ossimNotify(ossimNotifyLevel_DEBUG) << "is ERS leader file..."
179  << "Begin reading Leader file" << std::endl;
180  }
181  /*
182  * Leader file data reading
183  */
184  std::ifstream leaderFile(leaFilename.c_str(), ios::in | ios::binary);
185  leaderFile >> *theErsSarleader;
186  leaderFile.close();
187
188  if (traceDebug())
189  {
191  << "End reading Leader file" << std::endl;
192  }
193
194  //To initialize the whole state, reusing saveState/loadState
195  //FIXME: This could be at the superclass level instead
196  ossimKeywordlist kwl;
197  saveState(kwl);
198  loadState(kwl);
199
200  } // matches: if ( result=isErsLeader(file) == True )
201
202  } // matches: if ( file.exists() )
203
204  if (traceDebug())
205  {
207
209  << MODULE << " exit status = " << (result ? "true" : "false\n")
210  << std::endl;
211  }
212
213
214
215  return result;
216
217  }
218
219
221  const char* /* prefix */) const
222  {
223  static const char MODULE[] = "ossimErsSarModel::saveState";
224
225  if (traceDebug())
226  {
227  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
228  }
229
230  bool result(false);
231
232  //kwl.add(prefix, ossimKeywordNames::TYPE_KW, "ossimErsSarModel", true);
233
234  if (theErsSarleader == NULL)
235  {
236  std::cout << "Error: ErsSarleader is NULL" << std::endl;
237  return false;
238  }
239
240  result = theErsSarleader->saveState(kwl);
241
242  if (traceDebug())
243  {
245  << MODULE << " exit status = " << (result ? "true" : "false\n")
246  << std::endl;
247  }
248
249  return result;
250  }
251
252  bool ossimErsSarModel::loadState(const ossimKeywordlist &kwl, const char *prefix)
253  {
254  static const char MODULE[] = "ossimErsSarModel::loadState";
255
256  if (traceDebug())
257  {
258  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
259  }
260
261  const char* lookup = 0;
262  ossimString s;
263
264  // Check the type first.
265  lookup = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
266  if (lookup)
267  {
268  s = lookup;
269  if (s != getClassName())
270  {
271  return false;
272  }
273  }
274
275  // Load the base class.
276 // bool result = ossimGeometricSarSensorModel::loadState(kwl, prefix);
277  bool result = false;
278  result = InitPlatformPosition(kwl, prefix);
279  if (!result)
280  {
281  if (traceDebug())
282  {
284  << MODULE
285  << "\nCan't init platform position \n";
286  }
287  }
288
289  if (result)
290  {
291  result = InitSensorParams(kwl, prefix);
292  if (!result)
293  {
294  if (traceDebug())
295  {
297  << MODULE
298  << "\nCan't init sensor parameters \n";
299  }
300  }
301  }
302
303  if (result)
304  {
305  result = InitRefPoint(kwl, prefix);
306  if (!result)
307  {
308  if (traceDebug())
309  {
311  << MODULE
312  << "\nCan't init ref point \n";
313  }
314  }
315  }
316
317  if (result)
318  {
319  result = InitSRGR(kwl, prefix);
320  if (!result)
321  {
322  if (traceDebug())
323  {
325  << MODULE
326  << "\nCan't init ref point \n";
327  }
328  }
329  }
330
331  return result;
332  }
333
334  bool ossimErsSarModel::InitPlatformPosition(const ossimKeywordlist &kwl, const char *prefix)
335  {
336  // const double PI = 3.14159265358979323846 ;
337  CivilDateTime ref_civil_date;
338  /*
339  * Ephemerisis reference date retrieval
340  */
341  const char* eph_year_str = kwl.find(prefix, "eph_year");
342  int eph_year = atoi(eph_year_str);
343  const char* eph_month_str = kwl.find(prefix, "eph_month");
344  int eph_month = atoi(eph_month_str);
345  const char* eph_day_str = kwl.find(prefix, "eph_day");
346  int eph_day = atoi(eph_day_str);
347  const char* eph_sec_str = kwl.find(prefix, "eph_sec");
348  double eph_sec = atof(eph_sec_str);
349
350  ref_civil_date.set_year(eph_year);
351  ref_civil_date.set_month(eph_month);
352  ref_civil_date.set_day(eph_day);
353  ref_civil_date.set_second((int)eph_sec);
354  ref_civil_date.set_decimal(eph_sec - (double)((int)eph_sec));
355
356  JSDDateTime ref_jsd_date(ref_civil_date);
357
358  /*
359  * Ephemerisis time interval retrieval
360  */
361  const char* eph_int_str = kwl.find(prefix, "eph_int");
362  double eph_int = atof(eph_int_str);
363  /*
364  * Ephemerisis number retrieval
365  */
366  const char* neph_str = kwl.find(prefix, "neph");
367  int neph = atoi(neph_str);
368
369  Ephemeris** ephemeris = new Ephemeris*[neph];
370
371  /*
372  * Ephemerisis retrieval
373  */
374  for (int i = 0; i < neph; i++)
375  {
376  double pos[3];
377  double vit[3];
378  char name[64];
379
380
381  sprintf(name, "eph%i_posX", i);
382  const char* px_str = kwl.find(prefix, name);
383  pos[0] = atof(px_str);
384
385  sprintf(name, "eph%i_posY", i);
386  const char* py_str = kwl.find(prefix, name);
387  pos[1] = atof(py_str);
388
389  sprintf(name, "eph%i_posZ", i);
390  const char* pz_str = kwl.find(prefix, name);
391  pos[2] = atof(pz_str);
392
393
394  sprintf(name, "eph%i_velX", i);
395  const char* vx_str = kwl.find(prefix, name);
396  vit[0] = atof(vx_str);
397
398  sprintf(name, "eph%i_velY", i);
399  const char* vy_str = kwl.find(prefix, name);
400  vit[1] = atof(vy_str);
401
402  sprintf(name, "eph%i_velZ", i);
403  const char* vz_str = kwl.find(prefix, name);
404  vit[2] = atof(vz_str);
405
406  /*
407  * Ephemerisis date
408  */
409  JSDDateTime date(ref_jsd_date);
410  date.set_second(date.get_second() + i * eph_int);
411  date.NormDate();
412
413  GeographicEphemeris* eph = new GeographicEphemeris(date, pos, vit);
414
415  ephemeris[i] = eph;
416  }
417
418  /*
419  * Antenna position interpolator creation
420  */
421  if (_platformPosition != NULL)
422  {
423  delete _platformPosition;
424  }
425  _platformPosition = new PlatformPosition(ephemeris, neph);
426
427  /*
428  * Free of memory used by the ephemerisis list
429  */
430  for (int i = 0; i < neph; i++)
431  {
432  delete ephemeris[i];
433  }
434  delete[] ephemeris;
435
436  return true;
437  }
438
439  bool ossimErsSarModel::InitRefPoint(const ossimKeywordlist &kwl, const char *prefix)
440  {
441  const char* sc_lin_str = kwl.find(prefix, "sc_lin");
442  double sc_lin = atof(sc_lin_str);
443
444  const char* sc_pix_str = kwl.find(prefix, "sc_pix");
445  double sc_pix = atof(sc_pix_str);
446
447  const char* inp_sctim_str = kwl.find(prefix, "inp_sctim");
448
449  const char* rng_gate_str = kwl.find(prefix, "zero_dop_range_time_f_pixel");
450  double rng_gate = atof(rng_gate_str);
451
452  if (_refPoint == NULL)
453  {
454  _refPoint = new RefPoint();
455  }
456
457  _refPoint->set_pix_col(sc_pix);
458  _refPoint->set_pix_line(sc_lin);
459
460  char year_str[5];
461  for (int i = 0; i < 4; i++)
462  {
463  year_str[i] = inp_sctim_str[i];
464  }
465  year_str[4] = '\0';
466
467  char month_str[3];
468  for (int i = 4; i < 6; i++)
469  {
470  month_str[i-4] = inp_sctim_str[i];
471  }
472  month_str[2] = '\0';
473
474  char day_str[3];
475  for (int i = 6; i < 8; i++)
476  {
477  day_str[i-6] = inp_sctim_str[i];
478  }
479  day_str[2] = '\0';
480
481  char hour_str[3];
482  for (int i = 8; i < 10; i++)
483  {
484  hour_str[i-8] = inp_sctim_str[i];
485  }
486  hour_str[2] = '\0';
487
488  char min_str[3];
489  for (int i = 10; i < 12; i++)
490  {
491  min_str[i-10] = inp_sctim_str[i];
492  }
493  min_str[2] = '\0';
494
495  char sec_str[3];
496  for (int i = 12; i < 14; i++)
497  {
498  sec_str[i-12] = inp_sctim_str[i];
499  }
500  sec_str[2] = '\0';
501
502  char mili_str[4];
503  for (int i = 14; i < 17; i++)
504  {
505  mili_str[i-14] = inp_sctim_str[i];
506  }
507  mili_str[3] = '\0';
508
509  int year = atoi(year_str);
510  int month = atoi(month_str);
511  int day = atoi(day_str);
512  int hour = atoi(hour_str);
513  int min = atoi(min_str);
514  int sec = atoi(sec_str);
515  double mili = atof(mili_str);
516
517
518  CivilDateTime date(year, month, day, hour * 3600 + min * 60 + sec, mili / 1000.0);
519
520  if (_platformPosition != NULL)
521  {
522  Ephemeris * ephemeris = _platformPosition->Interpolate((JSDDateTime)date);
523  if (ephemeris == NULL) return false ;
524  _refPoint->set_ephemeris(ephemeris);
525
526  delete ephemeris;
527  }
528  else
529  {
530  return false;
531  }
532
533  double c = 2.99792458e+8;
534
535  double distance = (rng_gate * 1e-3 + ((double)sc_pix) * _sensor->get_nRangeLook() / _sensor->get_sf()) * (c / 2.0);
536
538
539  // in order to use ossimSensorModel::lineSampleToWorld
540  const char* nbCol_str = kwl.find(prefix, "num_pix");
541  const char* nbLin_str = kwl.find(prefix, "num_lines");
542  theImageSize.x = atoi(nbCol_str);
543  theImageSize.y = atoi(nbLin_str);
545
546  // Ground Control Points extracted from the model : corner points
547  std::list<ossimGpt> groundGcpCoordinates ;
548  std::list<ossimDpt> imageGcpCoordinates ;
549  // first line first pix
550  const char* lon_str = kwl.find("first_line_first_pixel_lon");
551  double lon = atof(lon_str);
552  const char* lat_str = kwl.find("first_line_first_pixel_lat");
553  double lat = atof(lat_str);
554  if (lon > 180.0) lon -= 360.0;
555  ossimDpt imageGCP1(0, 0);
556  ossimGpt groundGCP1(lat, lon, 0.0);
557  groundGcpCoordinates.push_back(groundGCP1) ;
558  imageGcpCoordinates.push_back(imageGCP1) ;
559  // first line last pix
560  lon_str = kwl.find("first_line_last_pixel_lon");
561  lon = atof(lon_str);
562  lat_str = kwl.find("first_line_last_pixel_lat");
563  lat = atof(lat_str);
564  if (lon > 180.0) lon -= 360.0;
565  ossimDpt imageGCP2(theImageSize.x - 1, 0);
566  ossimGpt groundGCP2(lat, lon, 0.0);
567  groundGcpCoordinates.push_back(groundGCP2) ;
568  imageGcpCoordinates.push_back(imageGCP2) ;
569  // last line last pix
570  lon_str = kwl.find("last_line_last_pixel_lon");
571  lon = atof(lon_str);
572  lat_str = kwl.find("last_line_last_pixel_lat");
573  lat = atof(lat_str);
574  if (lon > 180.0) lon -= 360.0;
575  ossimDpt imageGCP3(theImageSize.x - 1, theImageSize.y - 1);
576  ossimGpt groundGCP3(lat, lon, 0.0);
577  groundGcpCoordinates.push_back(groundGCP3) ;
578  imageGcpCoordinates.push_back(imageGCP3) ;
579  // last line first pix
580  lon_str = kwl.find("last_line_first_pixel_lon");
581  lon = atof(lon_str);
582  lat_str = kwl.find("last_line_first_pixel_lat");
583  lat = atof(lat_str);
584  if (lon > 180.0) lon -= 360.0;
585  ossimDpt imageGCP4(0, theImageSize.y - 1);
586  ossimGpt groundGCP4(lat, lon, 0.0);
587  groundGcpCoordinates.push_back(groundGCP4) ;
588  imageGcpCoordinates.push_back(imageGCP4) ;
589
590  // Default optimization
591  optimizeModel(groundGcpCoordinates, imageGcpCoordinates) ;
592
593  return true;
594  }
595
596  bool ossimErsSarModel::InitSRGR(const ossimKeywordlist &kwl, const char* /* prefix */)
597  {
598  // Product type = PRI
599  ossimString filename(kwl.find("filename"));
600  filename.upcase();
601  //std::transform(filename.begin(), filename.end(), filename.begin(), toupper);
602  string::size_type loc = filename.find("PRI");
603  if (loc != string::npos)
604  {
606  }
607  else
608  {
609  _isProductGeoreferenced = false;
610  }
611
612  // Number of SRGR Coef
613  theNumberSRGR = 3;
614
615  // Range time for first mid and last pixel
616  double t1 = atof(kwl.find("zero_dop_range_time_f_pixel")) * 1e-3;
617  double t2 = atof(kwl.find("zero_dop_range_time_c_pixel")) * 1e-3;
618  double t3 = atof(kwl.find("zero_dop_range_time_l_pixel")) * 1e-3;
619
620  // Range pixels numbers corresponding
621  // Todo : check if it works with "DECREASING LINE TIME"
622  // double x1 = 0.0;
623  double x2 = atof(kwl.find("sc_pix")) - 1.0;
624  double x3 = 2.0 * (x2 + 1.0) - 1.0 ;
625
626  theSRGRCoeffset[0][0] = t1;
627  theSRGRCoeffset[0][1] = ((t2 - t1) / (x2 * x2) + (t1 - t3) / (x3 * x3)) / ((1.0 / x2) - (1.0 / x3));
628  theSRGRCoeffset[0][2] = ((t2 - t1) / x2 + (t1 - t3) / x3) / (x2 - x3);
629
630  return true;
631  }
632
634  {
635  std::ifstream candidate(file.c_str(), ios::in | ios::binary);
636  char ersFileName[16];
637
638  candidate.seekg(48);
639  if (candidate.bad() || candidate.eof())
640  {
641  return false;
642  }
643  candidate.read(ersFileName, 16);
644  if (candidate.bad() || candidate.eof())
645  {
646  return false;
647  }
648  candidate.close();
649
650  ossimString ersString(ersFileName);
651
652  if ((ersString.find("ERS") == 0) &&
653  (ersString.find(".SAR.") == 4) &&
654  (ersString.find("LEAD") == 12))
655  {
656  return true;
657  }
658  else
659  {
660  return false;
661  }
662
663  }
664
666  {
667  ossimFilename leaFile = file;
668  ossimString datString("DAT_01");
669  ossimString nulString("NUL_DAT");
670  ossimString vdfString("VDF_DAT");
671  ossimString leaString("LEA_01");
672  if ((file.fileNoExtension() == datString)
673  || (file.fileNoExtension() == nulString)
674  || (file.fileNoExtension() == leaString))
675  {
676  leaFile.setFile(leaString);
677  if (leaFile.exists())
678  {
679  return leaFile;
680  }
681  }
682  return file;
683  }
684
685 }
686
Method to the load (recreate) the state of the object from a keyword list.
This class represent an ephemeris in Geographic coordinates system.
bool open(const ossimFilename &file)
Method to instantiate model from the leader file.
virtual bool isErsLeader(const ossimFilename &file) const
This class is able to read the Leader file of the ErsSar file structure.
Definition: ErsSarLeader.h:40
void set_sightDirection(SightDirection sight)
Definition: SensorParams.h:93
This class represents a date and time in the civil format.
Definition: CivilDateTime.h:30
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
void set_rwl(double rwl)
Definition: SensorParams.h:83
ossimFilename & setFile(const ossimString &f)
This class handles the platform position.
RTTI_DEF1(ossimAlosPalsarModel, "ossimAlosPalsarModel", ossimGeometricSarSensorModel)
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
virtual double getSlantRangeFromGeoreferenced(double col) const
This function associates an image column number to a slant range when the image is georeferenced (gro...
This class handles the referential point.
Definition: RefPoint.h:29
void set_lin_direction(int dir)
Definition: SensorParams.h:128
void set_second(int second)
double get_nRangeLook() const
Definition: SensorParams.h:118
This class handles the sensor parameters.
Definition: SensorParams.h:29
ErsSarLeader * theErsSarleader
List of metadata contained in the Leader file.
virtual bool InitRefPoint(const ossimKeywordlist &kwl, const char *prefix)
Initializes the Reference Point from a projection keywordlist.
Ephemeris * Interpolate(JSDDateTime date) const
This function interpolates its ephemeris to create a new ephemeris at the given date and time...
void set_pix_line(double pix_line)
Definition: RefPoint.cpp:80
double theSRGRCoeffset[1][3]
SRGR coefficient sets.
static const char * TYPE_KW
void set_pix_col(double pix_col)
Definition: RefPoint.cpp:85
bool _isProductGeoreferenced
True iff the product is ground range.
void set_semiMinorAxis(double value)
Definition: SensorParams.h:158
void set_second(double second)
Definition: JSDDateTime.h:91
This class represents an ephemeris.
Definition: Ephemeris.h:28
void set_decimal(double decimal)
bool exists() const
virtual ~ossimErsSarModel()
Destructor.
void set_semiMajorAxis(double value)
Definition: SensorParams.h:153
double get_second() const
Definition: JSDDateTime.h:76
int theNumberSRGR
Slant Range for each Ground Range (SRGR) number of coefficients sets.
virtual bool InitSRGR(const ossimKeywordlist &kwl, const char *prefix)
Initializes the Slant Range for each Ground Range data sets : theNumberSRGR,theSRGRCoeffset,_srgr_update,thePixelSpacing,_isProductGeoreferenced.
virtual bool InitPlatformPosition(const ossimKeywordlist &kwl, const char *prefix)
Initializes the Platform Position from a projection keywordlist.
void set_nRangeLook(double look)
Definition: SensorParams.h:138
ossimDrect theImageClipRect
PlatformPosition * _platformPosition
Handle the position of the platform.
virtual ossimFilename findErsLeader(const ossimFilename &file) const
virtual bool InitSensorParams(const ossimKeywordlist &kwl, const char *prefix)
Initializes the Sensor Params from a projection keywordlist.
ossim_int32 y
Definition: ossimIpt.h:142
ossimFilename fileNoExtension() const
Method to save object state to a keyword list.
const char * c_str() const
Definition: ossimString.h:396
void set_nAzimuthLook(double look)
Definition: SensorParams.h:133
virtual ossimObject * dup() const
Returns pointer to a new instance, copy of this.
ossim_int32 x
Definition: ossimIpt.h:141
virtual bool optimizeModel(const std::list< ossimGpt > &groundCoordinates, const std::list< ossimDpt > &imageCoordinates)
This function optimizes the model according to a list of Ground Control Points.
void set_prf(double prf)
Definition: SensorParams.h:73
void set_ephemeris(Ephemeris *ephemeris)
Definition: RefPoint.cpp:65
void set_col_direction(int dir)
Definition: SensorParams.h:123
This class represents a date.
Definition: JSDDateTime.h:30
float distance(double lat1, double lon1, double lat2, double lon2, int units)
void set_distance(double distance)
Definition: RefPoint.cpp:75
void set_sf(double sf)
Definition: SensorParams.h:78
std::string::size_type find(const std::string &s, std::string::size_type pos=0) const
Searches for s as a substring of *this, beginning at character pos of *this.
Definition: ossimString.h:753
#define min(a, b)
Definition: auxiliary.h:75
virtual ossimString getClassName() const
Method to return the class name.
