Public Member Functions | Protected Attributes | List of all members
ossimplugins::RefPoint Class Reference
This class handles the referential point. More...
#include <RefPoint.h>
 RefPoint ()
 Constuctor. More...
 ~RefPoint ()
 Destructor. More...
 RefPoint (const RefPoint &rhs)
 Copy constructor. More...
RefPointoperator= (const RefPoint &rhs)
 Affectation operator. More...
void set_ephemeris (Ephemeris *ephemeris)
void set_distance (double distance)
void set_pix_line (double pix_line)
void set_pix_col (double pix_col)
Ephemerisget_ephemeris ()
double get_distance () const
double get_pix_line () const
double get_pix_col () const
RefPointClone ()
bool saveState (ossimKeywordlist &kwl, const char *prefix=0) const
 Method to save object state to a keyword list. More...
bool loadState (const ossimKeywordlist &kwl, const char *prefix=0)
 Method to the load (recreate) the state of the object from a keyword list. More...
Ephemeris_ephemeris
double _distance
double _pix_line
double _pix_col
Detailed Description
Definition at line 29 of file RefPoint.h.
◆ RefPoint() [1/2]
ossimplugins::RefPoint::RefPoint ( )
Constuctor.
Definition at line 26 of file RefPoint.cpp.
26  :
27  _ephemeris(0),
28  _distance(0.0),
29  _pix_line(0.0),
30  _pix_col(0.0)
31 {
32 }
Ephemeris * _ephemeris
Definition: RefPoint.h:80
◆ ~RefPoint()
ossimplugins::RefPoint::~RefPoint ( )
Destructor.
Definition at line 34 of file RefPoint.cpp.
References _ephemeris.
35 {
36  if(_ephemeris != 0)
37  {
38  delete _ephemeris;
39  }
40 }
◆ RefPoint() [2/2]
ossimplugins::RefPoint::RefPoint ( const RefPoint rhs)
Copy constructor.
Definition at line 42 of file RefPoint.cpp.
References _ephemeris, and ossimplugins::Ephemeris::Clone().
42  :
43  _distance(rhs._distance),
44  _pix_line(rhs._pix_line),
45  _pix_col(rhs._pix_col)
46 {
47  _ephemeris = rhs._ephemeris->Clone();
48 }
virtual Ephemeris * Clone()
This function creatse a copy of the current class.
Definition: Ephemeris.h:58
Member Function Documentation
◆ Clone()
RefPoint* ossimplugins::RefPoint::Clone ( )
inline
Definition at line 59 of file RefPoint.h.
Referenced by ossimplugins::ossimGeometricSarSensorModel::set_refPoint().
60  {
61  return new RefPoint(*this);
62  };
RefPoint()
Constuctor.
Definition: RefPoint.cpp:26
◆ get_distance()
double ossimplugins::RefPoint::get_distance ( ) const
◆ get_ephemeris()
Ephemeris * ossimplugins::RefPoint::get_ephemeris ( )
◆ get_pix_col()
double ossimplugins::RefPoint::get_pix_col ( ) const
◆ get_pix_line()
double ossimplugins::RefPoint::get_pix_line ( ) const
Definition at line 100 of file RefPoint.cpp.
References _pix_line.
Referenced by ossimplugins::ossimGeometricSarSensorModel::getTime().
101 {
102  return _pix_line;
103 }
◆ loadState()
bool ossimplugins::RefPoint::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
Returns
true if load OK, false on error
Definition at line 137 of file RefPoint.cpp.
References _distance, _ephemeris, _pix_col, _pix_line, ossimKeywordlist::find(), ossimplugins::Ephemeris::loadState(), and ossimString::toDouble().
Referenced by ossimplugins::ossimGeometricSarSensorModel::loadState().
138 {
139  bool result = true;
140
141  std::string pfx;
142  if (prefix)
143  {
144  pfx = prefix;
145  }
146  pfx += PREFIX;
147
148
149  if (!_ephemeris)
150  {
151  _ephemeris = new Ephemeris();
152  }
153
154  result = _ephemeris->loadState(kwl, pfx.c_str());
155
156  const char* lookup = 0;
157  ossimString s;
158  double d;
159
160  lookup = kwl.find(pfx.c_str(), DISTANCE_KW);
161  if (lookup)
162  {
163  s = lookup;
164  d = s.toDouble();
165  _distance = d;
166  }
167  else
168  {
169  result = false;
170  }
171
172  lookup = kwl.find(pfx.c_str(), LINE_KW);
173  if (lookup)
174  {
175  s = lookup;
176  d = s.toDouble();
177  _pix_line = d;
178  }
179  else
180  {
181  result = false;
182  }
183
184  lookup = kwl.find(pfx.c_str(), COL_KW);
185  if (lookup)
186  {
187  s = lookup;
188  d = s.toDouble();
189  _pix_col = d;
190  }
191  else
192  {
193  result = false;
194  }
195
196  return result;
197 }
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
Definition: Ephemeris.cpp:100
double toDouble() const
◆ operator=()
RefPoint & ossimplugins::RefPoint::operator= ( const RefPoint rhs)
Definition at line 50 of file RefPoint.cpp.
References _distance, _ephemeris, _pix_col, _pix_line, and ossimplugins::Ephemeris::Clone().
51 {
52  _distance = rhs._distance;
53  _pix_line = rhs._pix_line;
54  _pix_col = rhs._pix_col;
55  if(_ephemeris != 0)
56  {
57  delete _ephemeris;
58  _ephemeris = 0;
59  }
60  _ephemeris = rhs._ephemeris->Clone();
61
62  return *this;
63 }
◆ saveState()
bool ossimplugins::RefPoint::saveState ( ossimKeywordlist kwl,
) const
Parameters
kwlKeyword list to save to.
prefixadded to keys when saved.
Returns
Definition at line 110 of file RefPoint.cpp.
References _distance, _ephemeris, _pix_col, _pix_line, ossimKeywordlist::add(), and ossimplugins::Ephemeris::saveState().
Referenced by ossimplugins::ossimGeometricSarSensorModel::saveState().
111 {
112  bool result = true;
113
114  std::string pfx;
115  if (prefix)
116  {
117  pfx = prefix;
118  }
119  pfx += PREFIX;
120
121  if (_ephemeris)
122  {
123  result = _ephemeris->saveState(kwl, pfx.c_str());
124  }
125  else
126  {
127  result = false;
128  }
129
130  kwl.add(pfx.c_str(), DISTANCE_KW, _distance);
131  kwl.add(pfx.c_str(), LINE_KW, _pix_line);
132  kwl.add(pfx.c_str(), COL_KW, _pix_col);
133
134  return result;
135 }
bool saveState(ossimKeywordlist &kwl, const char *prefix=0) const
Definition: Ephemeris.cpp:78
◆ set_distance()
void ossimplugins::RefPoint::set_distance ( double  distance)
◆ set_ephemeris()
void ossimplugins::RefPoint::set_ephemeris ( Ephemeris ephemeris)
◆ set_pix_col()
void ossimplugins::RefPoint::set_pix_col ( double  pix_col)
◆ set_pix_line()
void ossimplugins::RefPoint::set_pix_line ( double  pix_line)
Member Data Documentation
◆ _distance
double ossimplugins::RefPoint::_distance
protected
Definition at line 81 of file RefPoint.h.
Referenced by get_distance(), loadState(), operator=(), saveState(), and set_distance().
◆ _ephemeris
Ephemeris* ossimplugins::RefPoint::_ephemeris
protected
◆ _pix_col
double ossimplugins::RefPoint::_pix_col
protected
Definition at line 83 of file RefPoint.h.
Referenced by get_pix_col(), loadState(), operator=(), saveState(), and set_pix_col().
◆ _pix_line
double ossimplugins::RefPoint::_pix_line
protected
Definition at line 82 of file RefPoint.h.
Referenced by get_pix_line(), loadState(), operator=(), saveState(), and set_pix_line().
