Public Member Functions | Protected Member Functions | List of all members
ossimplugins::SarSensor Class Reference
This class provides basic location services for SAR sensors. More...
#include <SarSensor.h>
Inheritance diagram for ossimplugins::SarSensor:
ossimplugins::Sensor
 SarSensor (SensorParams *params, PlatformPosition *position)
 Constructor. More...
virtual ~SarSensor ()
 Destructor. More...
virtual int ImageToWorld (double distance, JSDDateTime time, double height, double &lon, double &lat) const
 This function is able to convert image coordinates into geodetic world coordinates using a geometric SAR sensor model. More...
int localisationSAR (GeographicEphemeris posSpeed, double lambda, double dist, double fDop, int sensVisee, double equRadius, double polRadius, double h, RectangularCoordinate *cart) const
 This function is able to convert image coordinates into rectangular world coordinates. More...
Additional Inherited Members
- Private Member Functions inherited from ossimplugins::Sensor
virtual ~Sensor ()
 Destructor. More...
- Private Attributes inherited from ossimplugins::Sensor
SensorParams_params
PlatformPosition_position
Detailed Description
Definition at line 31 of file SarSensor.h.
◆ SarSensor()
ossimplugins::SarSensor::SarSensor ( SensorParams params,
PlatformPosition position
Constructor.
Remarks
This constructor creates a copy of params and position
Definition at line 29 of file SarSensor.cpp.
29  : Sensor(params, position)
30 {
31 }
Sensor(SensorParams *params, PlatformPosition *position)
Constructor.
Definition: Sensor.cpp:22
◆ ~SarSensor()
ossimplugins::SarSensor::~SarSensor ( )
virtual
Destructor.
Definition at line 33 of file SarSensor.cpp.
34 {
35 }
Member Function Documentation
◆ ImageToWorld()
int ossimplugins::SarSensor::ImageToWorld ( double  distance,
JSDDateTime  time,
double  height,
double &  lon,
double &  lat
) const
virtual
Parameters
distance: Slant range of the image point
time: Azimuth time of the image point
height: Altitude of the world point
Return values
lon: Longitude of the world point
lat: Latitude of the world point
Remarks
: the doppler frequency is set to zero in this implementation
Implements ossimplugins::Sensor.
Definition at line 37 of file SarSensor.cpp.
References ossimplugins::Sensor::_params, ossimplugins::Sensor::_position, ossimplugins::RectangularCoordinate::AsGeodesicCoordinates(), distance(), ossimplugins::SensorParams::get_dopcen(), ossimplugins::SensorParams::get_dopcenLinear(), ossimplugins::SensorParams::get_rwl(), ossimplugins::SensorParams::get_semiMajorAxis(), ossimplugins::SensorParams::get_semiMinorAxis(), ossimplugins::SensorParams::get_sightDirection(), ossimplugins::Coordinate::get_x(), ossimplugins::Coordinate::get_y(), ossimplugins::PlatformPosition::Interpolate(), localisationSAR(), ossimplugins::SensorParams::Right, and TWOPI.
Referenced by ossimplugins::ossimGeometricSarSensorModel::lineSampleHeightToWorld().
38 {
39  const double TWOPI = 6.28318530717958647693 ;
40
41  double semiMajorAxis = _params->get_semiMajorAxis() ; // default : WGS84
42  double semiMinorAxis = _params->get_semiMinorAxis() ; // default : WGS84
43
44  double lambda = _params->get_rwl();
45  int sensVisee ;
46  if (_params->get_sightDirection() == SensorParams::Right) sensVisee = 1 ;
47  else sensVisee = -1 ;
48
49  Ephemeris* satPosition = _position->Interpolate(time);
50
51  GeographicEphemeris *geoEph = (GeographicEphemeris*)satPosition;
52
53  RectangularCoordinate cart;
54
55  double dopplerCentroid = _params->get_dopcen();
56  double dopcenLinear = _params->get_dopcenLinear();
57  if (dopcenLinear != 0.0)
58  {
59  dopplerCentroid += dopcenLinear * distance/1000; // Hz/km
60  }
61
62  // note : the Doppler frequency is set to zero
63  int etatLoc = localisationSAR(*geoEph, lambda, distance, dopplerCentroid, sensVisee, semiMajorAxis , semiMinorAxis , height, &cart);
64
65  GeodesicCoordinate geo;
66  cart.AsGeodesicCoordinates(semiMajorAxis , semiMinorAxis, &geo);
67  lon = (geo.get_x())*360.0/TWOPI;
68  lat = (geo.get_y())*360.0/TWOPI;
69
70  delete satPosition;
71
72  return etatLoc ;
73 }
int localisationSAR(GeographicEphemeris posSpeed, double lambda, double dist, double fDop, int sensVisee, double equRadius, double polRadius, double h, RectangularCoordinate *cart) const
Definition: SarSensor.cpp:75
Ephemeris * Interpolate(JSDDateTime date) const
This function interpolates its ephemeris to create a new ephemeris at the given date and time...
SightDirection get_sightDirection() const
Definition: SensorParams.h:88
double get_semiMajorAxis() const
Definition: SensorParams.h:143
PlatformPosition * _position
Definition: Sensor.h:55
double get_dopcenLinear() const
Definition: SensorParams.h:168
double get_semiMinorAxis() const
Definition: SensorParams.h:148
SensorParams * _params
Definition: Sensor.h:54
float distance(double lat1, double lon1, double lat2, double lon2, int units)
◆ localisationSAR()
int ossimplugins::SarSensor::localisationSAR ( GeographicEphemeris  posSpeed,
double  lambda,
double  dist,
double  fDop,
int  sensVisee,
double  equRadius,
double  polRadius,
double  h,
) const
protected
Definition at line 75 of file SarSensor.cpp.
References ossimplugins::Equation::get_nbrSol(), ossimplugins::Ephemeris::get_position(), ossimplugins::Equation::get_solutions(), ossimplugins::Ephemeris::get_speed(), n, ossimplugins::Coordinate::set_coordinates(), ossimplugins::Equation::Solve(), x, and y.
Referenced by ImageToWorld().
79 {
80  double coordCart[3];
81  coordCart[0]=0.0;
82  coordCart[1]=0.0;
83  coordCart[2]=0.0;
84
85
86  double rho2 , k , a , b , c , d , u , v , w ;
87  double x[4] , y[4] , z[4] , r[4] ;
88  bool isEnd;
89
90
91  /* Initialization of characteristical values */
92  /* note : for precise computation : */
93  /* - ranges are processed in mm */
94  /* - velocities are processed in km/s */
95  /* - frequencies are processed in kHz */
96  const double KILO = 1.0e-3 ;
97  const double MEGA = 1.0e-6 ;
98  const double EPSILON = 1.0e-12 ;
99
100
101  double dist1 = dist * MEGA ;
102  double fDop1 = fDop * KILO ;
103
104  double he = (equRadius + h) * MEGA ; /* Equatorial radius + h */
105  double hp = (polRadius + h) * MEGA ; /* Polar radius + h */
106
107  double posX = posSpeed.get_position()[0] * MEGA ;
108  double posY = posSpeed.get_position()[1] * MEGA ;
109  double posZ = posSpeed.get_position()[2] * MEGA ;
110  double speedX = - posSpeed.get_speed()[0] * KILO ;
111  double speedY = - posSpeed.get_speed()[1] * KILO ;
112  double speedZ = - posSpeed.get_speed()[2] * KILO ;
113
114
115  /* Coefficients computation and equation solving */
116  int state = 0;
117  u = speedX * posY - speedY * posX ;
118  a = (speedX / u) * (1.0 - (he / hp) * (he / hp)) / 2.0 ;
119  b = (speedX * posZ - speedZ * posX) / u ;
120  rho2 = posX * posX + posY * posY + posZ * posZ ;
121  k = posX * speedX + posY * speedY + posZ * speedZ -
122  lambda * dist1 * fDop1 / 2.0 ;
123  c = (speedX * (he * he + rho2 - dist1 * dist1) - 2.0 * k * posX) / (2.0 * u);
124
125  u = speedZ - b * speedY ;
126  v = c * speedY - k ;
127  w = v * v - (speedX * speedX) * (he * he - c * c) ;
128
129  std::complex<double> aa[5];
130  aa[0] = std::complex<double>(w,0.0); /* Constant coefficient */
131  w = 2.0 * (u * v - (b * c) * (speedX * speedX)) ;
132  aa[1] = std::complex<double>(w,0.0) ; /* First order coefficient */
133  w = u * u + 2.0 * a * v * speedY +
134  (speedX * speedX) * ((he / hp) * (he / hp) + b * b + 2.0 * a * c) ;
135  aa[2] = std::complex<double>(w,0.0) ; /* Second order coefficient */
136  w = 2.0 * a * (u * speedY - b * speedX * speedX) ;
137  aa[3] = std::complex<double>(w,0.0) ; /* Third order coefficient */
138  w = (speedX * speedX + speedY * speedY) * a * a ;
139  aa[4] = std::complex<double>(w,0.0) ; /* Fourth order coefficient */
140
141  Equation eq(4,aa); /* Equation solving */
142  eq.Solve();
143
144  int n = eq.get_nbrSol();
145  const std::complex<double> *root = eq.get_solutions();
146
147  int nRoot = 0 ;
148  for (int i = 0 ; i < n ; i++) /* Real root selection */
149  {
150  d = fabs(root[i].imag()) ;
151  if (d < EPSILON)
152  {
153  z[nRoot] = root[i].real();
154  y[nRoot] = (a * z[nRoot] - b) * z[nRoot] + c ;
155  x[nRoot] = (k - (speedY * y[nRoot] + speedZ * z[nRoot])) / speedX ;
156  nRoot = nRoot + 1 ;
157  }
158  }
159  if (nRoot == 0)
160  state = 2 ; /* No root */
161
162
163  /* Computed roots sort */
164
165  if (state == 0)
166  {
167  int indice[4] ;
168  for (int i = 0 ; i < nRoot ; i++)
169  {
170  /* Computation of the "distance" between roots images and equation values */
171  u = x[i] - posX ;
172  v = y[i] - posY ;
173  w = z[i] - posZ ;
174  r[i] = fabs ((u * u + v * v + w * w) / (dist1 * dist1) - 1.0 ) ;
175  u = u * speedX ;
176  v = v * speedY ;
177  w = w * speedZ ;
178  if (fabs (fDop) > EPSILON)
179  r[i] = r[i] + fabs (1.0 + 2.0 * (u + v + w) / (lambda * dist1 * fDop1));
180  else
181  r[i] = r[i] + fabs (2.0 * (u + v + w) / (lambda * dist1)) ;
182  u = x[i] / he ;
183  v = y[i] / he ;
184  w = z[i] / hp ;
185  r[i] = r[i] + fabs (u * u + v * v + w * w - 1.0) ;
186  indice[i] = i ;
187  }
188
189  /* Roots sort by increasing differences */
190  isEnd = false ;
191  while (!isEnd)
192  {
193  isEnd = true;
194  for (int i = 0 ; i < (nRoot - 1) ; i++)
195  {
196  int i1 = indice[i] ;
197  int i2 = indice[i+1] ;
198  if (r[i2] < r[i1])
199  {
200  indice[i] = i2 ;
201  indice[i+1] = i1 ;
202  isEnd = false ;
203  }
204  }
205  }
206
207  /* Selection of the correct root (corresponding to the imaging direction) */
208  isEnd = false ;
209  int i = 0 ;
210  while (!isEnd && (i < nRoot))
211  {
212  int i1 = indice[i] ;
213  u = posY * speedZ - posZ * speedY ;
214  v = posZ * speedX - posX * speedZ ;
215  w = posX * speedY - posY * speedX ;
216  a = x[i1] - posX ;
217  b = y[i1] - posY ;
218  c = z[i1] - posZ ;
219  d = (a * u + b * v + c * w) * sensVisee;
220  if (d >= 0.0)
221  {
222  coordCart[0] = x[i1] / MEGA ; /* Coordinates in the */
223  coordCart[1] = y[i1] / MEGA ; /* geographic referential, */
224  coordCart[2] = z[i1] / MEGA ; /* in legal units (m) */
225  isEnd = true;
226  }
227  i++ ;
228  }
229  if (!isEnd)
230  state = 1 ; /* No root in the imaging direction */
231  }
232
233  cart->set_coordinates(coordCart[0], coordCart[1], coordCart[2]);
234  return state ;
235 }
ossim_uint32 x
ossim_uint32 y
os2<< "> n<< " > nendobj n
