60 tileRect.
lr().
y + 1));
165 <<
"ossim3x3ConvolutionFilter::getTile WARNING:\n" 167 <<
" Not supported by ossim3x3ConvolutionFilter" << endl;
196 inputW +
std::abs(outputOrigin.
x - inputOrigin.
x);
201 T* ulKernelStartBuf = NULL;
202 T* leftKernelStartBuf = NULL;
203 T* llKernelStartBuf = NULL;
205 for(
ossim_int32 band = 0; band < numberOfBands; ++band)
207 T* inputBuf =
static_cast<T*
>(inputData->
getBuf(band))+startInputOffset;
208 T* outputBuf =
static_cast<T*
>(outputData->
getBuf(band));
211 T nullPix =
static_cast<T
>(inputData->
getNullPix(band));
214 if(inputBuf&&outputBuf)
219 ulKernelStartBuf = inputBuf + (rowOffset + ulKernelStart);
220 leftKernelStartBuf = inputBuf + (rowOffset + leftKernelStart);
221 llKernelStartBuf = inputBuf + (rowOffset + llKernelStart);
225 if((ulKernelStartBuf[0] != nullPix)&&
226 (ulKernelStartBuf[1] != nullPix)&&
227 (ulKernelStartBuf[2] != nullPix)&&
228 (leftKernelStartBuf[0] != nullPix)&&
229 (leftKernelStartBuf[1] != nullPix)&&
230 (leftKernelStartBuf[2] != nullPix)&&
231 (llKernelStartBuf[0] != nullPix)&&
232 (llKernelStartBuf[1] != nullPix)&&
233 (llKernelStartBuf[2] != nullPix))
235 sum =
theKernel[0][0]*(double)ulKernelStartBuf[0] +
236 theKernel[0][1]*(
double)ulKernelStartBuf[1] +
237 theKernel[0][2]*(double)ulKernelStartBuf[2] +
238 theKernel[1][0]*(
double)leftKernelStartBuf[0] +
239 theKernel[1][1]*(double)leftKernelStartBuf[1] +
240 theKernel[1][2]*(
double)leftKernelStartBuf[2] +
241 theKernel[2][0]*(double)llKernelStartBuf[0] +
242 theKernel[2][1]*(
double)llKernelStartBuf[1] +
243 theKernel[2][2]*(double)llKernelStartBuf[2];
249 else if(sum < minPix)
255 *outputBuf =
static_cast<T
>(sum);
259 *outputBuf = oNullPix;
266 ++leftKernelStartBuf;
294 inputW +
x - inputOrigin.
x);
299 T* ulKernelStartBuf = NULL;
300 T* leftKernelStartBuf = NULL;
301 T* llKernelStartBuf = NULL;
303 for(
ossim_uint32 band = 0; band < numberOfBands; ++band)
305 T* inputBuf =
static_cast<T*
>(inputData->
306 T* outputBuf =
static_cast<T*
>(outputData->
getBuf(band));
310 if(inputBuf&&outputBuf)
315 ulKernelStartBuf = inputBuf + (rowOffset + ulKernelStart);
316 leftKernelStartBuf = inputBuf + (rowOffset + leftKernelStart);
317 llKernelStartBuf = inputBuf + (rowOffset + llKernelStart);
320 sum =
321 theKernel[0][1]*(
322 theKernel[0][2]*(double)ulKernelStartBuf[2] +
323 theKernel[1][0]*(
324 theKernel[1][1]*(double)leftKernelStartBuf[1] +
325 theKernel[1][2]*(
326 theKernel[2][0]*(double)llKernelStartBuf[0] +
327 theKernel[2][1]*(
328 theKernel[2][2]*(double)llKernelStartBuf[2];
334 else if(sum < minPix)
340 *outputBuf =
static_cast<T
>(sum);
348 ++leftKernelStartBuf;
385 if(!property)
return;
386 if(property->
getName() ==
"Kernel")
392 theKernel[0][0] = (*matrixProperty)(0,0);
393 theKernel[1][0] = (*matrixProperty)(1,0);
394 theKernel[2][0] = (*matrixProperty)(2,0);
395 theKernel[0][1] = (*matrixProperty)(0,1);
396 theKernel[1][1] = (*matrixProperty)(1,1);
397 theKernel[2][1] = (*matrixProperty)(2,1);
398 theKernel[0][2] = (*matrixProperty)(0,2);
399 theKernel[1][2] = (*matrixProperty)(1,2);
400 theKernel[2][2] = (*matrixProperty)(2,2);
419 property->resize(3,3);
429 property->setCacheRefreshBit();
439 propertyNames.push_back(
"Kernel");
443 const char* prefix)
const 490 const char* v = kwl.
find(newPrefix.
c_str(),
595 tempMin += (k<0.0) ? k*inputMax : k*inputMin;
596 tempMax += (k>0.0) ? k*inputMax : k*inputMin;
ossim3x3ConvolutionFilter(ossimObject *owner=NULL)
RTTI_DEF1(ossim3x3ConvolutionFilter, "ossim3x3ConvolutionFilter", ossimImageSourceFilter)
void allocate()
Allocates theTile.
Numeric to string methods.
const ossimIpt & ul() const
void convolvePartial(T, ossimRefPtr< ossimImageData > inputData, ossimRefPtr< ossimImageData > outputData)
virtual void initialize()
void clearNullMinMax()
Clears data members theNullPixValue, theMinPixValue, and theMaxPixValue.
void convolveFull(T, ossimRefPtr< ossimImageData > inputData, ossimRefPtr< ossimImageData > outputData)
void computeNullMinMax()
Computes null, min, and max considering input connection and theKernel.
Initialize the data buffer.
virtual ~ossim3x3ConvolutionFilter()
OSSIM_DLL double defaultMin(ossimScalarType scalarType)
OSSIM_DLL double defaultNull(ossimScalarType scalarType)
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
const ossimIpt & lr() const
vector< double > theMinPixValue
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void setKernel(double kernel[3][3])
virtual void makeBlank()
vector< double > theMaxPixValue
OSSIM_DLL double defaultMax(ossimScalarType scalarType)
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
virtual void getKernel(double kernel[3][3])
vector< double > theNullPixValue
virtual const ossimIpt & getOrigin() const
const ossimString & getName() const
