15 #ifndef ossimAdrgTileSource_HEADER 16 #define ossimAdrgTileSource_HEADER 31 ADRG_TILE_WIDTH = 128,
32 ADRG_TILE_HEIGHT = 128,
33 ADRG_TILE_SIZE = 16384,
112 const char* prefix=0)
const;
119 const char* prefix=0);
136 virtual void close();
142 virtual bool isOpen()
const;
171 virtual void getPropertyNames(std::vector<ossimString>& propertyNames)
const;
179 void adjustToStartOfTile(
ossimIpt& pt)
const;
virtual bool open()=0
Pure virtual open.
ossimRefPtr< ossimImageData > m_Tile
std::basic_ifstream< char > ifstream
Class for char input file streams.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
ossim_uint8 * m_TileBuffer
virtual ossimString getShortName() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual bool isOpen() const =0
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimString getLongName() const
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
ossimAdrgHeader * m_AdrgHeader
unsigned char ossim_uint8
