12 #ifndef ossimAutRegUtil_HEADER 13 #define ossimAutRegUtil_HEADER 1 51 OSSIM_AUTREG_OP_UNKNOWN = 0,
52 OSSIM_AUTREG_OP_COREG = 1,
53 OSSIM_AUTREG_OP_MASREG = 2
98 void summarizeSolution()
const;
104 void saveAdjustment();
130 bool delineateROIs();
136 bool populateObsSet();
147 void initializeSrcKwl();
150 void initializeOcvKwl();
153 void initializeOaxKwl();
164 void configureTieMeasGenerator();
169 void configureAdjustmentExecutive();
215 void createIdentityProjection(
int idx);
254 std::vector< ossimRefPtr<ossimSingleImageChain> >
m_imgLayer;
285 bool m_controlImage[2];
288 #endif // #ifndef ossimAutRegUtil_HEADER ossimRefPtr< ossimKeywordlist > m_kwl
Hold all options passed into intialize.
ossimColumnVector3d m_LatLonHgtControlSigmas
ossimReferenced allows for shared object ref counting if the reference count ever gets to 0 or less i...
std::vector< ossimRefPtr< ossimSingleImageChain > > m_imgLayer
Array of image source chains.
ossimRefPtr< ossimObject > m_tGenObj
std::ostream * m_rep
Report stream pointer.
ossimRefPtr< ossimKeywordlist > m_oaxKwl
Hold contents of oax config file if –oax_config_file is used.
unsigned int ossim_uint32
ossimAutRegOperation
emumerated operations
ossimRefPtr< ossimKeywordlist > m_srcKwl
Hold contents of src file if –src is used.
ossimRefPtr< ossimKeywordlist > m_ocvKwl
Hold contents of OpenCV config file if –ocv_config_file is used.
ossimTieMeasurementGeneratorInterface * m_tGen
Tie point generator interface.
std::vector< ossimIrect > m_roiRects
Correlation ROIs.
ossimAutRegOperation m_operation
Enumerated operation to perform.
ossimRefPtr< ossimAdjustmentExecutive > m_adjExec
Adjustment executive interface.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
bool m_showMatchWindow
OpenCV match window display flag.
ossimReferenced & operator=(const ossimReferenced &)
ossimColumnVector3d m_LatLonHgtSigmas
A priori tie point sigmas.
std::basic_ostream< char > ostream
Base class for char output streams.
ossimRefPtr< ossimObservationSet > m_obsSet
Observation set.
