55 :theData(pt.
x, pt.
y, pt.z)
97 os <<
"(ossimEcefPoint) " <<
"nan nan nan";
100 os <<
theData;
105 instance.
print(os);
return os;
double lond() const
Will convert the radian measure to degrees.
std::ostream & operator<<(std::ostream &os, const ossimEcefPoint &instance)
double latd() const
void toPoint(const std::string &s)
Initializes this point from string.
void print(std::ostream &os=ossimNotify(ossimNotifyLevel_INFO)) const
const ossimDatum * datum() const
datum().
unsigned int ossim_uint32
virtual const ossimEllipsoid * ellipsoid() const
void latLonHeightToXYZ(double lat, double lon, double height, double &x, double &y, double &z) const
const ossimColumnVector3d & data() const
ossimString toString(ossim_uint32 precision=15) const
To string method.
ossimEcefVector operator-(const ossimEcefPoint &) const
ossimEcefPoint operator+(const ossimEcefVector &) const
std::basic_ostream< char > ostream
Base class for char output streams.
ossimColumnVector3d theData
To string method.
