ossimEnvisatAsarModel.h
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // "Copyright Centre National d'Etudes Spatiales"
4 //
5 // License: LGPL
6 //
7 // See LICENSE.txt file in the top level directory for more details.
8 //
9 //----------------------------------------------------------------------------
10 // $Id$
11
12 #ifndef ossimEnvisatAsarModel_H
13 #define ossimEnvisatAsarModel_H
14
15 #include <otb/JSDDateTime.h>
18 #include <ossim/base/ossimIpt.h>
20 #include <ossim/base/ossimGpt.h>
21 #include <ossim/base/ossimDpt.h>
23
24 #include <iostream>
25
26 namespace ossimplugins
27 {
28
29
30 class PlatformPosition;
31 class SensorParams;
32 class RefPoint;
38 {
39 public:
44
48  virtual ~ossimEnvisatAsarModel();
49
54  virtual ossimString getClassName() const;
55
59  virtual ossimObject* dup() const;
60
65  virtual double getSlantRangeFromGeoreferenced(double col) const;
66
74  bool open(const ossimFilename& file);
75
82  virtual bool saveState(ossimKeywordlist& kwl,
83  const char* prefix=0) const;
84
90  virtual bool loadState (const ossimKeywordlist &kwl, const char *prefix=0);
91
96  virtual std::ostream& print(std::ostream& out) const;
97
98 protected:
99
103  int _n_srgr;
107  std::vector< std::vector<double> > _srgr_coefset;
111  std::vector<JSDDateTime> _srgr_update;
116
117 private:
118  virtual bool InitPlatformPosition(const ossimKeywordlist &kwl, const char *prefix);
119  virtual bool InitSensorParams(const ossimKeywordlist &kwl, const char *prefix);
120  virtual bool InitRefPoint(const ossimKeywordlist &kwl, const char *prefix);
124  virtual bool InitSRGR(const ossimKeywordlist &kwl, const char *prefix);
128  std::vector<double> FindSRGRSetNumber(JSDDateTime date) const;
129  TYPE_DATA
130
135
136 };
137 }
138
139 #endif
Method to return the class name.
Initializes the Slant Range for each Ground Range data sets : _n_srgr,_srgr_coefset,_srgr_update,_pixel_spacing,_isProductGeoreferenced.
Method to save object state to a keyword list.
std::vector< double > FindSRGRSetNumber(JSDDateTime date) const
Finds the SRGR data set which update time is the closest to the center scene time.
This function associates an image column number to a slant range when the image is georeferenced (gro...
This class allows for direct localisation and indirect localisation using the geometric model of SAR ...
int _n_srgr
Slant Range to Ground Range (SRGR) number of coefficients sets.
#define TYPE_DATA
Definition: ossimRtti.h:339
Method to the load (recreate) the state of the object from a keyword list.
bool open(const ossimFilename &file)
Method to intantial model from a file.
This class is able to read the Envisat file structure.
TYPE_DATA EnvisatAsarData * _EnvisatAsarData
List of metadata contained in the Data file.
std::vector< std::vector< double > > _srgr_coefset
SRGR coefficient sets.
Initializes the Reference Point from a projection keywordlist.
This class is able to direct localisation and indirect localisation using the EnvisatAsar sensor mode...
Initializes the Sensor Params from a projection keywordlist.
std::vector< JSDDateTime > _srgr_update
SRGR coefficient sets update times.
Initializes the Platform Position from a projection keywordlist.
virtual ossimObject * dup() const
Returns pointer to a new instance, copy of this.
This class represents a date.
Definition: JSDDateTime.h:30
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
