ossimGdalDataset.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file
4 //
5 // Author: David Burken
6 //
7 // Description: A gdal data set from an ossim image handler.
8 //
9 //----------------------------------------------------------------------------
10 // $Id$
11
12 #include <ossimGdalDataset.h>
13 #include <ossimGdalType.h>
15 #include <ossim/base/ossimNotify.h>
16 #include <ossim/base/ossimTrace.h>
19 #include <fstream>
20
21 static GDALDriver *poOssimGdalDriver = 0;
22
23 static const ossimTrace traceDebug(ossimString("ossimGdalDataset:debug"));
24
25
26 CPL_C_START
28 CPL_C_END
29
30 #ifdef OSSIM_ID_ENABLED
31 static const char OSSIM_ID[] = "$Id: ossimGdalDataset.cpp 23003 2014-11-24 17:13:40Z dburken $";
32 #endif
33
35  : theImageHandler(0)
36 {
37  if (!poOssimGdalDriver)
38  {
40  poDriver = poOssimGdalDriver;
41  }
42
43  if (traceDebug())
44  {
46  << "ossimGdalDataset::ossimGdalDataset entered..."
47  << std::endl;
48 #ifdef OSSIM_ID_ENABLED
50  << "OSSIM_ID: "
51  << OSSIM_ID
52  << std::endl;
53 #endif
54  }
55 }
56
58
59 {
60  if (traceDebug())
61  {
63  << "ossimGdalDataset::~ossimGdalDataset "
64  << "\n"
65  << std::endl;
66  }
67
68  if (theImageHandler.valid())
69  theImageHandler = 0;
70 }
71
73 {
75
76  if ( !theImageHandler.valid() )
77  {
78  if (traceDebug())
79  {
81  << "ossimGdalDataset::open DEBUG:"
82  << "\nCould not open: " << file.c_str() << std::endl;
83  }
84  return false;
85  }
86
87  if (traceDebug())
88  {
90  << "ossimGdalDataset::open DEBUG:"
91  << "\nOpened: " << file.c_str() << std::endl;
92  }
93
94  init();
95  return true;
96 }
97
98
99 GDALDataset* ossimGdalDataset::Open( GDALOpenInfo * poOpenInfo )
100
101 {
102  if (traceDebug())
103  {
105  << "ossimGdalDataset::Open entered..."
106  << std::endl;
107  }
108
109  ossimFilename f = poOpenInfo->pszFilename;
110  GDALDataset* ds = new ossimGdalDataset;
111  if ( ((ossimGdalDataset*)ds)->open(f) == true)
112  {
113  return ds;
114  }
115
116  return 0;
117 }
118
120 {
121  if (traceDebug())
122  {
124  << "ossimGdalDataset::setImageHandler entered..."
125  << std::endl;
126  }
127
128  theImageHandler = ih;
129  init();
130 }
131
133 {
134  return theImageHandler.get();
135 }
136
138 {
139  return theImageHandler.get();
140 }
141
143 {
145  sDescription = f.c_str();
146
147  if (theImageHandler.valid())
148  {
149  oOvManager.Initialize( this, f.c_str() );
150  }
151 }
152
154 {
155  nRasterXSize = theImageHandler->getImageRectangle(0).width();
156  nRasterYSize = theImageHandler->getImageRectangle(0).height();
158  eAccess = GA_ReadOnly;
159
160  if (traceDebug())
161  {
163  << "ossimGdalDataset::init DEBUG:"
164  << "\nWidth: " << nRasterXSize
165  << "\nHeight: " << nRasterYSize
166  << "\nBands: " << nBands << std::endl;
167  }
168
169  for( int iBand = 0; iBand < nBands; ++iBand )
170  {
172  new ossimGdalDatasetRasterBand( this,
173  iBand+1,
174  theImageHandler.get());
175  SetBand( iBand+1, rb );
176  }
177 }
178
179 void ossimGdalDataset::setGdalAcces(GDALAccess access)
180 {
181  eAccess = access;
182 }
183
185  int band,
186  ossimImageHandler* ih)
187  : GDALPamRasterBand(),
188  theImageHandler(ih)
189
190 {
191  if (traceDebug())
192  {
194  << "ossimGdalDatasetRasterBand::ossimGdalDatasetRasterBand entered..."
195  << "band: " << band
196  << std::endl;
197  }
198  if (!ih)
199  {
200  return;
201  }
202
203  poDS = ds;
204  nBand = band;
205
206  nRasterXSize = theImageHandler->getImageRectangle(0).width();
207  nRasterYSize = theImageHandler->getImageRectangle(0).height();
208
209  // eAccess = GA_ReadOnly;
210  eAccess = GA_Update;
211
212  ossimGdalType gt;
213  eDataType = gt.toGdal(theImageHandler->getOutputScalarType());
214
215  nBlockXSize = theImageHandler->getTileWidth();
216  nBlockYSize = theImageHandler->getTileHeight();
217
218  // ESH 06/2009: Prevent divide by zero.
219  nBlockXSize = (nBlockXSize==0) ? 1 : nBlockXSize;
220  nBlockYSize = (nBlockYSize==0) ? 1 : nBlockYSize;
221
222  nBlocksPerRow = nRasterXSize / nBlockXSize;
223  nBlocksPerColumn = nRasterYSize / nBlockYSize;
224  if (nRasterXSize % nBlockXSize) ++nBlocksPerRow;
225  if (nRasterYSize % nBlockYSize) ++nBlocksPerColumn;
226
227  nBlockReads = 0;
228  bForceCachedIO = false;
229 }
230
232 {
233 }
234
236  int nBlockYOff,
237  void * pImage )
238 {
239  if ( !theImageHandler.valid() || !pImage)
240  {
241  return CE_Failure;
242  }
243
244  ossimIpt startPt(nBlockXOff*nBlockXSize, nBlockYOff*nBlockYSize);
245 // ossimIpt endPt( min(startPt.x+nBlockXSize-1, nRasterXSize-1),
246 // min(startPt.y+nBlockYSize-1, nRasterYSize-1));
247  ossimIpt endPt( startPt.x+nBlockXSize-1,
248  startPt.y+nBlockYSize-1);
249  ossimIrect rect( startPt, endPt);
250
252
253  if (id.valid())
254  {
255  if( (id->getDataObjectStatus() == OSSIM_FULL) ||
257  {
258  id->unloadBand(pImage, rect, nBand-1);
259  return CE_None;
260  }
261  }
262
263  memset(pImage, 0, nBlockXSize * nBlockYSize);
264
265  return CE_None;
266 }
267
268 double ossimGdalDatasetRasterBand::GetNoDataValue( int * /* pbSuccess */)
269
270 {
271  if (traceDebug())
272  {
274  << "ossimGdalDatasetRasterBand::GetNoDataValue entered..."
275  << "\n"
276  << std::endl;
277  }
278
279  return 0.0;
280 }
281
283
284 {
285  GDALDriver *poDriver;
286
287  if( poOssimGdalDriver == 0 )
288  {
289  poDriver = new GDALDriver();
290  poOssimGdalDriver = poDriver;
291
292  poDriver->SetDescription( "ossimGdalDataset" );
293  poDriver->SetMetadataItem( GDAL_DMD_LONGNAME,
294  "ossim data set" );
295  poDriver->pfnOpen = ossimGdalDataset::Open;
296  GetGDALDriverManager()->RegisterDriver( poDriver );
297  }
298 }
void initGdalOverviewManager()
Calls gdal&#39;s oOvManager.Initialize.
void init()
Initializes this object from the image handler.
virtual ossimImageHandler * open(const ossimFilename &fileName, bool trySuffixFirst=true, bool openOverview=true) const
open that takes a filename.
bool valid() const
Definition: ossimRefPtr.h:75
static GDALDataset * Open(GDALOpenInfo *)
Open for static gdal driver.
void setImageHandler(ossimImageHandler *ih)
Sets theImageHandler.
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
const ossimImageHandler * getImageHandler() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual void unloadBand(void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, ossimInterleaveType il_type=OSSIM_BSQ, OverwriteBandRule ow_type=NULL_RULE) const
This routine is designed for overwriting a selected band of the destination buffer &#39;dest&#39; by an indep...
void setGdalAcces(GDALAccess access)
Set the access data member.
virtual const ossimFilename & getFilename() const
Returns the filename.
ossimGdalDatasetRasterBand(ossimGdalDataset *ds, int band, ossimImageHandler *ih)
Constructor that takes a ossimGdalDataset, band and image handler.
virtual ~ossimGdalDataset()
virtual destructor
virtual ~ossimGdalDatasetRasterBand()
virtual destructor
ossimGdalDataset This is a gdal data set that wraps an ossim image handler.
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
ossim_uint32 width() const
Definition: ossimIrect.h:500
ossimRefPtr< ossimImageHandler > theImageHandler
virtual CPLErr IReadBlock(int nBlockXOff, int nBlockYOff, void *pImage)
Read block method.
ossimGdalDatasetRasterBand Represents a single band within the image.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
CPL_C_START void GDALRegister_ossimGdalDataset(void)
ossimGdalDataset()
default constructor
ossim_int32 y
Definition: ossimIpt.h:142
virtual double GetNoDataValue(int *pbSuccess=0)
This returns 0 right now and should probably be implemented if anything serious is to be done with th...
const char * c_str() const
Definition: ossimString.h:396
static ossimImageHandlerRegistry * instance()
ossim_int32 x
Definition: ossimIpt.h:141
bool open(const ossimFilename &file)
open method.
GDALDataType toGdal(ossimScalarType) const
friend class ossimGdalDatasetRasterBand
