ossimGdalTileSource.h
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Garrett Potts
8 //
9 // Description:
10 //
11 // Contains class definition for the class "ossimGdalTileSource".
12 //
13 //*******************************************************************
14 // $Id: ossimGdalTileSource.h 22960 2014-11-06 15:42:13Z okramer $
15
16 #ifndef ossimGdalTileSource_HEADER
17 #define ossimGdalTileSource_HEADER 1
18
22 #include <ossim/base/ossimIrect.h>
23 #include <ossim/base/ossimString.h>
25 #include <gdal.h>
26 #include <vector>
28
29 class ossimImageData;
30
32 {
33 public:
35  virtual ~ossimGdalTileSource();
36
41  virtual ossimString getShortName()const;
42
43  virtual ossimString getLongName()const;
44  virtual ossimString getClassName()const;
45
46  virtual void close();
47
56  virtual bool open();
57
63  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& tileRect,
64  ossim_uint32 resLevel=0);
65
70  virtual ossim_uint32 getNumberOfInputBands() const;
71
77  virtual ossim_uint32 getNumberOfOutputBands() const;
78
83  virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level = 0) const;
84
89  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level = 0) const;
90
97
102  virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level = 0) const;
103
108  virtual bool saveState(ossimKeywordlist& kwl,
109  const char* prefix=0)const;
110
115  virtual bool loadState(const ossimKeywordlist& kwl,
116  const char* prefix=0);
117
124
130
134  virtual ossimScalarType getOutputScalarType() const;
135
142  ossimScalarType getInputScalarType() const;
143
147  virtual ossim_uint32 getTileWidth() const;
148
152  virtual ossim_uint32 getTileHeight() const;
153
160  virtual ossim_uint32 getImageTileWidth() const;
161
168  virtual ossim_uint32 getImageTileHeight() const;
169
173  virtual ossim_uint32 getCurrentEntry()const;
174
179  virtual bool setCurrentEntry(ossim_uint32 entryIdx);
180
184  virtual void getEntryList(std::vector<ossim_uint32>& entryList)const;
185
190  virtual void getEntryNames(
191  std::vector<ossimString>& entryStringList) const;
192
193  virtual bool isOpen()const;
194
195  virtual double getNullPixelValue(ossim_uint32 band=0)const;
196  virtual double getMinPixelValue(ossim_uint32 band=0)const;
197  virtual double getMaxPixelValue(ossim_uint32 band=0)const;
198
208  virtual void setProperty(ossimRefPtr<ossimProperty> property);
209
214  virtual ossimRefPtr<ossimProperty> getProperty(const ossimString& name) const;
215
220  virtual void getPropertyNames(std::vector<ossimString>& propertyNames) const;
221
239  virtual void getDecimationFactor(ossim_uint32 resLevel,
240  ossimDpt& result) const;
241
242  GDALDriverH getDriver();
243
244  virtual bool setOutputBandList(const std::vector<ossim_uint32>& band_list);
245
254  void setPreservePaletteIndexesFlag(bool flag);
255
257  bool getPreservePaletteIndexesFlag() const;
258
267  virtual bool isIndexedData() const;
268
269 private:
270
277  ossimRefPtr<ossimImageData> getTileBlockRead(const ossimIrect& tileRect,
278  ossim_uint32 resLevel);
279
285  ossimString filterSubDatasetsString(const ossimString& subString) const;
286
287  void computeMinMax();
288  void loadIndexTo3BandTile(const ossimIrect& clipRect,
289  ossim_uint32 aGdalBandStart = 1,
290  ossim_uint32 anOssimBandStart = 0);
291  template<class InputType, class OutputType>
292  void loadIndexTo3BandTileTemplate(InputType in,
293  OutputType out,
294  const ossimIrect& clipRect,
295  ossim_uint32 aGdalBandStart = 1,
296  ossim_uint32 anOssimBandStart = 0);
297
298  bool isIndexTo3Band(int bandNumber = 1)const;
299  bool isIndexTo1Band(int bandNumber = 1)const;
300  ossim_uint32 getIndexBandOutputNumber(int bandNumber)const;
301  bool isIndexed(int aGdalBandNumber = 1)const;
302  void getMaxSize(ossim_uint32 resLevel,
303  int& maxX,
304  int& maxY)const;
305  bool isBlocked(int band)const;
306  void populateLut();
307
312  GDALRasterBandH resolveRasterBand( ossim_uint32 resLevel,
313  int gdalBandIndex ) const;
314
315  ossimRefPtr<ossimImageGeometry> getExternalImageGeometryFromXml() const;
316  void deleteRlevelCache();
317  void setRlevelCache();
319  void getDefaults();
320
321  GDALDatasetH theDataset;
322  GDALDriverH theDriver;
323
326  std::vector<ossim_uint8> theGdalBuffer;
328  mutable GDALDataType theGdtType;
329  mutable GDALDataType theOutputGdtType;
334  std::vector<ossimString> theSubDatasets;
338  vector<ossim_uint32> m_outputBandList;
340
341  std::vector<ossimAppFixedTileCache::ossimAppFixedCacheId> m_rlevelBlockCache;
342
343 TYPE_DATA
344 };
345
346 #endif
virtual bool open()=0
Pure virtual open.
bool isBlocked(bool *blocked, int x, int y)
ossimRefPtr< ossimImageData > theSingleBandTile
virtual void getEntryNames(std::vector< ossimString > &entryNames) const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Returns the default processing tile height.
std::vector< ossimString > theSubDatasets
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
virtual ossimString getShortName() const
Definition: ossimObject.cpp:48
Returns the default processing tile width.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isOpen() const =0
Retuns the min pixel value.
vector< ossim_uint32 > m_outputBandList
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimString getLongName() const
Definition: ossimObject.cpp:53
virtual ossim_uint32 getCurrentEntry() const
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
#define OSSIM_PLUGINS_DLL
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
std::vector< ossim_uint8 > theGdalBuffer
ossimScalarType
virtual ossim_uint32 getImageTileWidth() const =0
ossim_uint32 theEntryNumberToRender
std::vector< ossimAppFixedTileCache::ossimAppFixedCacheId > m_rlevelBlockCache
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
