ossimGeneralRasterTileSource.h
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: MIT
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: David Burken
8 //
9 // Description:
10 //
11 // Contains class declaration for ossimGeneralRasterTileSource.
12 // ossimGeneralRasterTileSource is derived from ImageHandler which is
13 // derived from ossimTileSource.
14 //*******************************************************************
15 // $Id: ossimGeneralRasterTileSource.h 21631 2012-09-06 18:10:55Z dburken $
16
17 #ifndef ossimGeneralRasterTileSource_HEADER
18 #define ossimGeneralRasterTileSource_HEADER 1
19
20
24 #include <memory>
25 #include <vector>
26
27 class ossimImageData;
28
30 {
31 public:
32
34
35  virtual ossimString getShortName()const;
36  virtual ossimString getLongName()const;
37
43  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& tile_rect,
44  ossim_uint32 resLevel=0);
45
58  virtual bool getTile(ossimImageData* result, ossim_uint32 resLevel=0);
59
64  virtual ossim_uint32 getNumberOfInputBands() const;
65
71  virtual ossim_uint32 getNumberOfOutputBands() const;
72
77  virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level = 0) const;
78
83  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level = 0) const;
84
89  virtual bool saveState(ossimKeywordlist& kwl,
90  const char* prefix=0)const;
91
96  virtual bool loadState(const ossimKeywordlist& kwl,
97  const char* prefix=0);
98
102  virtual ossimScalarType getOutputScalarType() const;
103
107  virtual ossim_uint32 getTileWidth() const;
108
112  virtual ossim_uint32 getTileHeight() const;
113
121  virtual ossim_uint32 getImageTileWidth() const;
122
130  virtual ossim_uint32 getImageTileHeight() const;
131
132  bool isValidRLevel(ossim_uint32 reduced_res_level) const;
133
134  virtual void close();
135  virtual bool isOpen() const;
136  virtual bool open();
137  virtual bool open(const ossimGeneralRasterInfo& info);
138
143  virtual double getNullPixelValue(ossim_uint32 band=0)const;
144  virtual double getMinPixelValue(ossim_uint32 band=0)const;
145  virtual double getMaxPixelValue(ossim_uint32 band=0)const;
146
148
157  virtual bool isBandSelector() const;
158
167  virtual bool setOutputBandList(const std::vector<ossim_uint32>& band_list);
168
170  virtual void getOutputBandList(std::vector<ossim_uint32>& bandList) const;
171
172 protected:
173  virtual ~ossimGeneralRasterTileSource();
177  virtual bool fillBuffer(const ossimIpt& origin, const ossimIpt& size);
178  virtual bool fillBIP(const ossimIpt& origin, const ossimIpt& size);
179  virtual bool fillBIL(const ossimIpt& origin, const ossimIpt& size);
180  virtual bool fillBSQ(const ossimIpt& origin, const ossimIpt& size);
181  virtual bool fillBsqMultiFile(const ossimIpt& origin, const ossimIpt& size);
182
183  virtual ossimKeywordlist getHdrInfo(ossimFilename hdrFile);
184  virtual ossimKeywordlist getXmlInfo(ossimFilename xmlFile);
185
186  bool initializeHandler();
187
192  std::vector< std::shared_ptr<ossim::istream> > m_fileStrList;
193  // std::vector< std::ifstream* > m_fileStrList;
198  std::vector<ossim_uint32> m_outputBandList;
199
200 private:
201
203  void allocateTile();
204
206  void allocateBuffer( const ossimImageData* tile );
207
208
209 TYPE_DATA
210 };
211
212 #endif /* #ifndef ossimGeneralRasterTileSource_HEADER */
virtual bool open()=0
Pure virtual open.
std::vector< ossim_uint32 > m_outputBandList
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Returns the default processing tile height.
virtual ossimString getShortName() const
Definition: ossimObject.cpp:48
Returns the default processing tile width.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
virtual bool isOpen() const =0
Retuns the min pixel value.
std::vector< std::shared_ptr< ossim::istream > > m_fileStrList
virtual void getOutputBandList(std::vector< ossim_uint32 > &bandList) const
Initializes bandList.
yy_size_t size
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimString getLongName() const
Definition: ossimObject.cpp:53
ossimInterleaveType
Indicates whether or not the image handler can control output band selection via the setOutputBandLis...
ossimScalarType
ossimRefPtr< ossimImageData > m_tile
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
#define OSSIM_DLL
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
unsigned char ossim_uint8
