ossimHistoMatchRemapper.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2000 ImageLinks Inc.
3 //
4 // License: LGPL
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: Garrett Potts
9 //
10 //*******************************************************************
11 // $Id: ossimHistoMatchRemapper.cpp 15833 2009-10-29 01:41:53Z eshirschorn $
15 #include <ossim/base/ossimDpt.h>
17
20 {
21  theBlankTile = NULL;
22 }
23
25  const vector<double>& targetMeanPerBand,
26  const vector<double>& targetSigmaPerBand,
27  const vector<double>& inputMeanPerBand,
28  const vector<double>& inputSigmaPerBand)
29  : ossimImageSourceFilter(inputSource),
30  theTargetMeanPerBand(targetMeanPerBand),
31  theTargetSigmaPerBand(targetSigmaPerBand),
32  theInputMeanPerBand(inputMeanPerBand),
33  theInputSigmaPerBand(inputSigmaPerBand)
34 {
35  theBlankTile = NULL;
36 }
37
38
40 {
41 }
42
44  const ossimIrect& tileRect,
45  ossim_uint32 resLevel)
46 {
49  {
50  tile = theInputConnection->getTile(tileRect, resLevel);
51  }
52  if(!tile.valid())
53  {
54  return NULL;
55  }
56  if((tile.valid() &&
57  ((tile->getDataObjectStatus()==OSSIM_NULL) ||
58  (tile->getDataObjectStatus()==OSSIM_EMPTY))))
59
60  {
61  return tile;
62  }
63
64  theBlankTile->setOrigin(tileRect.ul());
65  ossim_uint32 numberOfBands = (ossim_uint32)theInputMeanPerBand.size();
66
67  numberOfBands = numberOfBands>tile->getNumberOfBands()?tile->getNumberOfBands():numberOfBands;
68  double result = 0;
69  if(isSourceEnabled())
70  {
71  long offsetBound = (long)(tile->getWidth()*tile->getHeight());
72  if(tile->getScalarType() == OSSIM_UCHAR)
73  {
74  for(ossim_uint32 band = 0; band < numberOfBands; ++band)
75  {
76  unsigned char* buf = static_cast<unsigned char*>(tile->getBuf(band));
77  for(long offset=0; offset < offsetBound;++offset)
78  {
79  // if the input has no deviation we will just
80  // do a shift to the target mean
81  if(fabs(theInputSigmaPerBand[band]) < FLT_EPSILON)
82  {
83  result = transLean(buf[offset],
84  theInputMeanPerBand[band],
86  0,
87  255);
88  }
89  else
90  {
91  result = transLeanStretch(buf[offset],
92  theInputMeanPerBand[band],
96  0,
97  255);
98  }
99  result = ((result>255)?255:result);
100  result = ((result<0)?0:result);
101
102  buf[offset] = (unsigned char)result;
103  }
104  }
105  }
106  }
107
108  return tile;
109 }
110
112 {
113  if(!theInputConnection)
114  {
115  return;
116  }
117  theBlankTile = new ossimImageData(this,
120 }
121
123 {
124  return theInputMeanPerBand;
125 }
126
128 {
129  return theInputSigmaPerBand;
130 }
131
133 {
134  return theTargetMeanPerBand;
135 }
136
138 {
139  return theTargetSigmaPerBand;
140 }
141
142 void ossimHistoMatchRemapper::setInputMeanValues(const vector<double>& newValues)
143 {
144  theInputMeanPerBand = newValues;
145 }
146
147 void ossimHistoMatchRemapper::setInputSigmaValues(const vector<double>& newValues)
148 {
149  theInputSigmaPerBand = newValues;
150 }
151
152 void ossimHistoMatchRemapper::setTargetMeanValues(const vector<double>& newValues)
153 {
154  theTargetMeanPerBand = newValues;
155 }
156
157 void ossimHistoMatchRemapper::setTargetSigmaValues(const vector<double>& newValues)
158 {
159  theTargetSigmaPerBand = newValues;
160 }
161
162 double ossimHistoMatchRemapper::transLean // returns vOut
163 (
164  double vIn
165  , double vBias
166  , double vTarget
167  , double vMin
168  , double vMax
169 )
170 {
171  // max change
172  const double vDelta = vTarget - vBias;
173  double weight=0.0;
174
175  // weight max change dependend on proximity to end points
176  if (vIn <= vBias)
177  {
178  weight = fabs((vIn - vMin) / (vBias - vMin));
179  }
180  else
181  {
182  weight = fabs((vMax - vIn) / (vMax - vBias));
183  }
184  return (vIn + (vDelta * weight));
185 };
186
187 double ossimHistoMatchRemapper::transLeanStretch // returns vOut
188  (
189  double vIn
190  , double vBias
191  , double vBiasStretch
192  , double vTarget
193  , double vTargetStretch
194  , double vMin
195  , double vMax
196  )
197 {
198
199  // line segment end points
200  const double x1 = vMin;
201  const double x2 = vBias - vBiasStretch;
202  const double x3 = vBias + vBiasStretch;
203  const double x4 = vMax;
204  const double y1 = 0.0;
205  const double y2 = (vTarget + vTargetStretch) - (vBias + vBiasStretch);
206  const double y3 = (vTarget - vTargetStretch) - (vBias - vBiasStretch);
207  const double y4 = 0.0;
208
209
210  // perform appropriate linear lookup operation based on input value
211  double vOut = vIn;
212  if (vIn <= x2)
213  {
214  vOut = (vIn - x1) * (y2-y1)/(x2-x1) + y1 + vIn;
215  }
216  else
217  if (vIn <= x3)
218  {
219  vOut = (vIn - x2) * (y3-y2)/(x3-x2) + y2 + vIn;
220  }
221  else
222  {
223  vOut = (vIn - x3) * (y4-y3)/(x4-x3) + y3 + vIn;
224  }
225
226  return vOut;
227 }
228
230  const char* prefix)
231 {
232  theTargetMeanPerBand.clear();
233  theTargetSigmaPerBand.clear();
234  theInputMeanPerBand.clear();
235  theInputSigmaPerBand.clear();
236  ossim_uint32 result = kwl.getNumberOfSubstringKeys(ossimString(prefix) + "target_mean[0-9]");
237  ossim_uint32 numberOfMatches=0;
238  ossim_uint32 index=0;
239
240  // load target mean
241  while(numberOfMatches < result)
242  {
243  ossimString key = prefix;
244  key += ossimString("target_mean");
245  key += ossimString::toString(index);
246  const char* lookup = kwl.find(key.c_str());
247  if(lookup)
248  {
249  theTargetMeanPerBand.push_back(ossimString(lookup).toDouble());
250  ++numberOfMatches;
251  }
252  ++index;
253  }
254  numberOfMatches = 0;
255  index = 0;
256  result = kwl.getNumberOfSubstringKeys(ossimString(prefix) + "target_sigma[0-9]");
257  // load target sigma
258  while(numberOfMatches < result)
259  {
260  ossimString key = prefix;
261  key += ossimString("target_sigma");
262  key += ossimString::toString(index);
263  const char* lookup = kwl.find(key.c_str());
264  if(lookup)
265  {
266  theTargetSigmaPerBand.push_back(ossimString(lookup).toDouble());
267  ++numberOfMatches;
268  }
269  ++index;
270  }
271
272  numberOfMatches = 0;
273  index = 0;
274  result = kwl.getNumberOfSubstringKeys(ossimString(prefix) + "input_mean[0-9]");
275  // load input mean
276  while(numberOfMatches < result)
277  {
278  ossimString key = prefix;
279  key += ossimString("input_mean");
280  key += ossimString::toString(index);
281  const char* lookup = kwl.find(key.c_str());
282  if(lookup)
283  {
284  theInputMeanPerBand.push_back(ossimString(lookup).toDouble());
285  ++numberOfMatches;
286  }
287  ++index;
288  }
289
290  numberOfMatches = 0;
291  index = 0;
292  result = kwl.getNumberOfSubstringKeys(ossimString(prefix) + "input_sigma[0-9]");
293  // load input sigma
294  while(numberOfMatches < result)
295  {
296  ossimString key = prefix;
297  key += ossimString("input_sigma");
298  key += ossimString::toString(index);
299  const char* lookup = kwl.find(key.c_str());
300  if(lookup)
301  {
302  theInputSigmaPerBand.push_back(ossimString(lookup).toDouble());
303  ++numberOfMatches;
304  }
305  ++index;
306  }
307
308  return true;
309 }
310
312  const char* prefix)
313 {
314  ossim_uint32 index = 1;
315  for(index=1;index <= theTargetMeanPerBand.size();++index)
316  {
317  ossimString key = ossimString("target_mean") + ossimString::toString(index);
318  kwl.add(prefix,
319  key.c_str(),
320  theTargetMeanPerBand[index-1],
321  true);
322  }
323  for(index=1;index <= theTargetSigmaPerBand.size();++index)
324  {
325  ossimString key = ossimString("target_sigma") + ossimString::toString(index);
326  kwl.add(prefix,
327  key.c_str(),
328  theTargetSigmaPerBand[index-1],
329  true);
330  }
331  for(index=1;index <= theInputMeanPerBand.size();++index)
332  {
333  ossimString key = ossimString("input_mean") + ossimString::toString(index);
334  kwl.add(prefix,
335  key.c_str(),
336  theInputMeanPerBand[index-1],
337  true);
338  }
339  for(index=1;index <= theInputSigmaPerBand.size();++index)
340  {
341  ossimString key = ossimString("input_sigma") + ossimString::toString(index);
342  kwl.add(prefix,
343  key.c_str(),
344  theInputSigmaPerBand[index-1],
345  true);
346  }
347  return true;
348 }
349
const vector< double > & getTargetMeanValues() const
double transLean(double vIn, double vBias, double vTarget, double vMin, double vMax)
transLean
ossim_uint32 getNumberOfSubstringKeys(const ossimString &regularExpression) const
vector< double > theInputMeanPerBand
vector< double > theTargetMeanPerBand
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
Numeric to string methods.
const ossimIpt & ul() const
Definition: ossimIrect.h:274
void setInputSigmaValues(const vector< double > &newValues)
void setInputMeanValues(const vector< double > &newValues)
const vector< double > & getInputSigmaValues() const
void setTargetSigmaValues(const vector< double > &newValues)
#define FLT_EPSILON
unsigned int ossim_uint32
vector< double > theInputSigmaPerBand
const vector< double > & getTargetSigmaValues() const
vector< double > theTargetSigmaPerBand
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
virtual void setOrigin(const ossimIpt &origin)
const vector< double > & getInputMeanValues() const
double transLeanStretch(double vIn, double vBias, double vBiasStretch, double vTarget, double vTargetStretch, double vMin, double vMax)
transLeanStretch
ossimRefPtr< ossimImageData > theBlankTile
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL)
const char * c_str() const
Definition: ossimString.h:396
8 bit unsigned iteger
void setTargetMeanValues(const vector< double > &newValues)
