ossimImageCacheBase.h
Go to the documentation of this file.
1 //-----------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Mingjie Su
6 //
7 // Description: This class give the capability to access tiles from the
8 // input frames.
9 //
10 //-----------------------------------------------------------------------
11 //$Id: ossimImageCacheBase.h 2685 2011-06-07 16:24:41Z david.burken $
12 #ifndef ossimImageCacheBase_HEADER
13 #define ossimImageCacheBase_HEADER 1
16
17 class ossimRpfToc;
18 class ossimRpfTocEntry;
19 class ossimRpfFrame;
20
22 {
23 public:
24
31
35  virtual void close();
36
39  virtual bool open() = 0;
40
47  virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level = 0) const;
48
55  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level = 0) const;
56
63  virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level = 0) const ;
64
65
74  virtual bool saveState(ossimKeywordlist& kwl,
75  const char* prefix=0)const;
76
103  virtual bool loadState(const ossimKeywordlist& kwl,
104  const char* prefix=0);
105
106
114  virtual ossim_uint32 getNumberOfInputBands()const;
115
123  virtual ossim_uint32 getNumberOfOutputBands()const;
124
128  virtual ossim_uint32 getTileWidth() const;
129
133  virtual ossim_uint32 getTileHeight() const;
134
141  virtual ossim_uint32 getImageTileWidth() const;
142
149  virtual ossim_uint32 getImageTileHeight() const;
150
151  virtual void getEntryList(std::vector<ossim_uint32>& entryList)const;
152
158  bool isValidRLevel(ossim_uint32 reduced_res_level) const;
159
165  bool isOpen()const;
166
199
200 protected:
206  virtual ~ossimImageCacheBase();
207
212  void setActualImageRect();
213
223  void checkLongitude(ossim_float64& leftLon, const ossim_float64& rightLon) const;
224
234  {
236  :theRow(-1),
237  theCol(-1),
238  thePixelRow(-1),
239  thePixelCol(-1)
240  {}
242  ossim_int32 col,
243  ossim_int32 pixelRow,
244  ossim_int32 pixelCol,
245  const ossimRpfFrameEntry& entry)
246  :theRow(row),
247  theCol(col),
248  thePixelRow(pixelRow),
249  thePixelCol(pixelCol),
250  theFrameEntry(entry)
251  {}
253  :theRow(rhs.theRow),
254  theCol(rhs.theCol),
255  thePixelRow(rhs.thePixelRow),
256  thePixelCol(rhs.thePixelCol),
257  theFrameEntry(rhs.theFrameEntry)
258  {}
264  };
265
266
278  vector<ossimFrameEntryData> getIntersectingEntries(const ossimIrect& rect);
279
280  void deleteAll();
281
282  bool buildFrameEntryArray(ossimFilename imageFile, ossim_uint32 frameWidth, ossim_uint32 frameHeight);
283  virtual void establishDecimationFactors();
284
289
296
303
308
312  std::vector<ossimString> m_fileNames;
313
318
320
321  // data to use in property retrieval
322
331
332  std::vector< std::vector<ossimRpfFrameEntry> > m_frameEntryArray;
333
334 TYPE_DATA
335 };
336
337 #endif /* #ifndef ossimImageCacheBase_HEADER */
virtual bool open()=0
Pure virtual open.
ossimFrameEntryData(const ossimFrameEntryData &rhs)
ossim_uint32 m_numberOfBands
This is the actual data returned from a getTile request.
ossim_uint32 m_numberOfSamples
This will be computed based on the frames organized within the directory.
ossimFrameEntryData(ossim_int32 row, ossim_int32 col, ossim_int32 pixelRow, ossim_int32 pixelCol, const ossimRpfFrameEntry &entry)
#define OSSIMDLLEXPORT
ossimIrect m_actualImageRect
This holds the image bounds for the current entry.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Protected structure that is only used internally by this class.
Returns the default processing tile height.
Returns the default processing tile width.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
virtual bool isOpen() const =0
double ossim_float64
ossimRpfFrame * m_workFrame
std::vector< std::vector< ossimRpfFrameEntry > > m_frameEntryArray
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
ossim_uint32 m_numOfFramesHorizontal
unsigned int ossim_uint32
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
Virtual method determines the decimation factors at each resolution level.
ossimIpt m_tileSize
The size of the output tile.
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
std::vector< ossimString > m_fileNames
The size of the input frames.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
ossim_uint32 m_numOfFramesVertical
virtual ossim_uint32 getNumberOfInputBands() const =0
ossim_uint32 m_numberOfLines
int ossim_int32
