ossimImageHandlerFactory.h
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: MIT
4 //
5 // Author: David Burken
6 //
7 // Description:
8 //
9 // Contains class declaration for ossimImageHandlerFactoryMaker.
10 //*******************************************************************
11 // $Id$
12
13 #ifndef ossimImageHandlerFactory_HEADER
14 #define ossimImageHandlerFactory_HEADER 1
15
17 #include <ossim/base/ossimString.h>
18
19 class ossimImageHandler;
20 class ossimFilename;
21 class ossimKeywordlist;
22
23 //*******************************************************************
24 // CLASS: ossimImageHandlerFactory
25 //*******************************************************************
27 {
28 public:
29  virtual ~ossimImageHandlerFactory();
30  static ossimImageHandlerFactory* instance();
31
36  virtual ossimImageHandler* open(const ossimFilename& fileName,
37  bool openOverview=true)const;
38  virtual ossimImageHandler* open(const ossimKeywordlist& kwl,
39  const char* prefix=0)const;
40
41  virtual ossimRefPtr<ossimImageHandler> open(std::shared_ptr<ossim::ImageHandlerState> state)const;
50  std::shared_ptr<ossim::istream>& str,
51  const std::string& connectionString,
52  bool openOverview ) const;
53
62  const ossimFilename& file ) const;
63
64  virtual ossimObject* createObject(const ossimString& typeName)const;
65
69  virtual ossimObject* createObject(const ossimKeywordlist& kwl,
70  const char* prefix=0)const;
71
77  virtual void getTypeNameList(std::vector<ossimString>& typeList)const;
81
82 protected:
83
104  ossimRefPtr<ossimImageHandler> openSrcRecord(std::shared_ptr<ossim::istream>& str,
105  const std::string& connectionString,
106  bool openOverview ) const;
107
119 // virtual ossimImageHandler* openFromExtension(
120 // const ossimFilename& fileName) const;
121
125
127
128 TYPE_DATA
129 };
130
131 #endif
Open method that looks at extension e.g.
ossimImageHandlerFactory(const ossimImageHandlerFactory &)
#define OSSIMDLLEXPORT
virtual void getTypeNameList(std::vector< ossimString > &typeList) const =0
virtual void getImageHandlersBySuffix(ImageHandlerList &result, const ossimString &ext) const
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
Open overview that takes a file name.
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const =0
virtual void getSupportedExtensions(ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const =0
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossimObject * createObject(const ossimString &typeName) const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
ossimReferenced & operator=(const ossimReferenced &)
static ossimImageHandlerFactory * theInstance
std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
virtual void getImageHandlersByMimeType(ImageHandlerList &result, const ossimString &mimeType) const
