17 #ifndef ossimJpegTileSource_HEADER 18 #define ossimJpegTileSource_HEADER 32 const char* prefix=0);
98 const char* prefix=0)
const;
105 const char* prefix=0);
146 virtual void close();
159 virtual void getPropertyNames(std::vector<ossimString>& propertyNames)
const;
virtual bool open()=0
Pure virtual open.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
ossim_uint8 * theLineBuffer
virtual ossimString getShortName() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
virtual bool isOpen() const =0
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
ossimAppFixedTileCache::ossimAppFixedCacheId theCacheId
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimString getLongName() const
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
ossim_int32 ossimAppFixedCacheId
virtual ossim_uint32 getImageTileWidth() const =0
PrivateData * thePrivateData
This class defines an abstract Handler which all image handlers(loaders) should derive from...
ossimRefPtr< ossimImageData > theCacheTile
ossim_uint32 theNumberOfBands
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossim_uint32 getNumberOfInputBands() const =0
unsigned char ossim_uint8
