ossimLlxyProjection.h
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: David Burken
6 //
7 // Description:
8 //
9 // Contains class declaration for ossimLlxy. This is a simple "latitude /
10 // longitude to x / y" projection. Note that "origin" and "tie_point" are
11 // synonymous in this projection.
12 //
13 //*******************************************************************
14 // $Id: ossimLlxyProjection.h 19651 2011-05-25 18:49:22Z gpotts $
15
16 #ifndef ossimLlxyProjection_HEADER
17 #define ossimLlxyProjection_HEADER
18
20
22 {
23 public:
26  ossimLlxyProjection(const ossimEllipsoid& ellipsoid,
27  const ossimGpt& origin);
28  ossimLlxyProjection(const ossimGpt& origin,
29  double latSpacing, // decimal degrees
30  double lonSpacing);
31
32  virtual ~ossimLlxyProjection();
33
34  virtual ossimObject *dup()const;
35
36  virtual bool isGeographic()const;
37
38  virtual ossimDpt forward(const ossimGpt &worldPoint) const;
39  virtual ossimGpt inverse(const ossimDpt &projectedPoint) const;
40
45  virtual double getLatSpacing() const;
46
51  virtual double getLonSpacing() const;
52
57  virtual void setLatSpacing(double spacing);
58
63  virtual void setLonSpacing(double spacing);
64
69  virtual void worldToLineSample(const ossimGpt& worldPoint,
70  ossimDpt& lineSampPt) const;
71
76  virtual void lineSampleToWorld(const ossimDpt& lineSampPt,
77  ossimGpt& worldPt) const;
78
79
84  virtual bool saveState(ossimKeywordlist& kwl,
85  const char* prefix=0)const;
86
91  virtual bool loadState(const ossimKeywordlist& kwl,
92  const char* prefix=0);
93
94  virtual std::ostream& print(std::ostream& out) const;
95
96  virtual bool operator==(const ossimProjection& projection) const;
97
98  // virtual ossimDpt getMetersPerPixel() const;
99  virtual void setMetersPerPixel(const ossimDpt& pt);
105  virtual void computeDegreesPerPixel(const ossimGpt& ground,
106  const ossimDpt& metersPerPixel,
107  double &deltaLat,
108  double &deltaLon);
109
110
116  virtual void computeMetersPerPixel(const ossimGpt& center,
117  double deltaDegreesPerPixelLat,
118  double deltaDegreesPerPixelLon,
119  ossimDpt &metersPerPixel);
120
121 private:
122
123 TYPE_DATA
124 };
125
126 #endif
virtual ossimObject * dup() const =0
#define OSSIMDLLEXPORT
virtual ossimDpt worldToLineSample(const ossimGpt &worldPoint) const
virtual void computeMetersPerPixel()
This will go from the ground point and give you an approximate meters per pixel.
virtual bool isGeographic() const
virtual ossimGpt inverse(const ossimDpt &projectedPoint) const =0
virtual void setMetersPerPixel(const ossimDpt &gsd)
virtual ossimGpt lineSampleToWorld(const ossimDpt &projectedPoint) const
virtual bool operator==(const ossimProjection &projection) const
Compares this to arg projection and returns TRUE if the same.
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossimDpt forward(const ossimGpt &worldPoint) const =0
virtual void computeDegreesPerPixel()
Computes the approximate resolution in degrees/pixel.
Prints data members to stream.
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
