Public Member Functions | List of all members
ossimLlxyProjection Class Reference
#include <ossimLlxyProjection.h>
Inheritance diagram for ossimLlxyProjection:
ossimMapProjection ossimProjection ossimObject ossimErrorStatusInterface ossimReferenced
 ossimLlxyProjection ()
 ossimLlxyProjection (const ossimLlxyProjection &rhs)
 ossimLlxyProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin)
 ossimLlxyProjection (const ossimGpt &origin, double latSpacing, double lonSpacing)
virtual ~ossimLlxyProjection ()
virtual bool isGeographic () const
virtual ossimDpt forward (const ossimGpt &worldPoint) const
 All map projections will convert the world coordinate to an easting northing (Meters). More...
virtual ossimGpt inverse (const ossimDpt &projectedPoint) const
 Will take a point in meters and convert it to ground. More...
virtual double getLatSpacing () const
virtual double getLonSpacing () const
virtual void setLatSpacing (double spacing)
virtual void setLonSpacing (double spacing)
virtual void worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSampPt) const
virtual void lineSampleToWorld (const ossimDpt &lineSampPt, ossimGpt &worldPt) const
 Prints data members to stream. More...
virtual bool operator== (const ossimProjection &projection) const
 Compares this to arg projection and returns TRUE if the same. More...
virtual void setMetersPerPixel (const ossimDpt &pt)
virtual void computeDegreesPerPixel (const ossimGpt &ground, const ossimDpt &metersPerPixel, double &deltaLat, double &deltaLon)
virtual void computeMetersPerPixel (const ossimGpt &center, double deltaDegreesPerPixelLat, double deltaDegreesPerPixelLon, ossimDpt &metersPerPixel)
- Public Member Functions inherited from ossimMapProjection
 ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
 ossimMapProjection (const ossimMapProjection &src)
virtual ossimDpt worldToLineSample (const ossimGpt &worldPoint) const
virtual ossimGpt lineSampleToWorld (const ossimDpt &projectedPoint) const
virtual void lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
 This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More...
virtual void lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
virtual void eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const
virtual void eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const
virtual double getFalseEasting () const
virtual double getFalseNorthing () const
virtual double getStandardParallel1 () const
 Derived classes should implement as needed. More...
virtual double getStandardParallel2 () const
virtual void update ()
virtual void setPcsCode (ossim_uint32 pcsCode)
virtual ossim_uint32 getPcsCode () const
 Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More...
virtual ossimString getProjectionName () const
 Returns the projection name. More...
virtual double getA () const
 ACCESS METHODS: More...
virtual double getB () const
virtual double getF () const
virtual const ossimDptgetDecimalDegreesPerPixel () const
 Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More...
virtual const ossimDptgetUlEastingNorthing () const
virtual const ossimGptgetUlGpt () const
virtual const ossimDatumgetDatum () const
const ossimEllipsoidgetEllipsoid () const
const ossimGptgetOrigin () const
virtual void applyScale (const ossimDpt &scale, bool recenterTiePoint)
 Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More...
virtual void setEllipsoid (const ossimEllipsoid &ellipsoid)
 SET METHODS: More...
virtual void setAB (double a, double b)
virtual void setDatum (const ossimDatum *datum)
 Sets theDatum to datum. More...
virtual void setOrigin (const ossimGpt &origin)
 Sets theOrigin to origin. More...
virtual void setDecimalDegreesPerPixel (const ossimDpt &gsd)
virtual void setUlTiePoints (const ossimGpt &gpt)
virtual void setUlTiePoints (const ossimDpt &eastingNorthing)
virtual void setUlEastingNorthing (const ossimDpt &ulEastingNorthing)
virtual void setUlGpt (const ossimGpt &ulGpt)
virtual void assign (const ossimProjection &aProjection)
virtual void computeDegreesPerPixel ()
 Computes the approximate resolution in degrees/pixel. More...
virtual void computeMetersPerPixel ()
 This will go from the ground point and give you an approximate meters per pixel. More...
void setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation)
void setMatrixScale (const ossimDpt &scale)
void setMatrixRotation (double rotation)
void setMatrixTranslation (const ossimDpt &translation)
void snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType)
 Utility method to snap the tie point to some multiple. More...
void snapTiePointToOrigin ()
void setElevationLookupFlag (bool flag)
bool getElevationLookupFlag () const
ossimUnitType getModelTransformUnitType () const
void setModelTransformUnitType (ossimUnitType unit)
bool hasModelTransform () const
void setProjectionUnits (ossimUnitType units)
ossimUnitType getProjectionUnits () const
 OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More...
 ossimProjection ()
virtual ~ossimProjection ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimErrorStatusInterface ()
bool hasError () const
Additional Inherited Members
- Protected Member Functions inherited from ossimMapProjection
virtual ~ossimMapProjection ()
void updateFromTransform ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimMapProjection
ossimEllipsoid theEllipsoid
 This method verifies that the projection parameters match the current pcs code. More...
ossimGpt theOrigin
const ossimDatumtheDatum
 This is only set if we want to have built in datum shifting. More...
ossimDpt theMetersPerPixel
 Holds the number of meters per pixel. More...
ossimDpt theDegreesPerPixel
 Hold the decimal degrees per pixel. More...
ossimGpt theUlGpt
 Hold tie point in decimal degrees. More...
ossimDpt theUlEastingNorthing
 Hold tie point as easting northing. More...
ossimDpt theFalseEastingNorthing
 Hold the false easting northing. More...
ossim_uint32 thePcsCode
 Projection Coordinate System(PCS) code. More...
bool theElevationLookupFlag
ossimMatrix4x4 theModelTransform
ossimMatrix4x4 theInverseModelTransform
ossimUnitType theModelTransformUnitType
ossimUnitType theProjectionUnits
 Linear units of the projection as indicated in the projection's specification: More...
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 21 of file ossimLlxyProjection.h.
◆ ossimLlxyProjection() [1/4]
ossimLlxyProjection::ossimLlxyProjection ( )
Definition at line 28 of file ossimLlxyProjection.cpp.
References ossimMapProjection::theDegreesPerPixel, and ossimDpt::y.
Referenced by dup().
29 {
30  // set to about 1 meter per pixel
31  theDegreesPerPixel.y = DEFAULT_DEGREES_PER_PIXEL;
32  theDegreesPerPixel.x = DEFAULT_DEGREES_PER_PIXEL;
39 }
double nan()
Definition: ossimCommon.h:135
virtual void computeMetersPerPixel()
double y
Definition: ossimDpt.h:165
double x
Definition: ossimDpt.h:164
◆ ossimLlxyProjection() [2/4]
ossimLlxyProjection::ossimLlxyProjection ( const ossimLlxyProjection rhs)
Definition at line 41 of file ossimLlxyProjection.cpp.
References ossimMapProjection::computeMetersPerPixel(), ossimGpt::datum(), ossimDatum::ellipsoid(), ossim::nan(), ossimMapProjection::theDatum, ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theEllipsoid, ossimMapProjection::theMetersPerPixel, ossimMapProjection::theOrigin, ossimMapProjection::theUlEastingNorthing, ossimMapProjection::theUlGpt, ossimDpt::x, and ossimDpt::y.
42  :
44 {
45  theOrigin = rhs.theOrigin;
46  theUlGpt = rhs.theUlGpt;
57 }
double nan()
double y
ossimGpt theUlGpt
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
ossimMapProjection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
virtual const ossimEllipsoid * ellipsoid() const
Definition: ossimDatum.h:60
double x
const ossimDatum * theDatum
◆ ossimLlxyProjection() [3/4]
ossimLlxyProjection::ossimLlxyProjection ( const ossimEllipsoid ellipsoid,
const ossimGpt origin
Definition at line 79 of file ossimLlxyProjection.cpp.
References ossimMapProjection::computeMetersPerPixel(), ossim::nan(), ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theMetersPerPixel, ossimMapProjection::theOrigin, ossimMapProjection::theUlEastingNorthing, ossimDpt::x, and ossimDpt::y.
81  :ossimMapProjection(ellipsoid, origin)
82 {
83  theDegreesPerPixel.y = 1.0;
84  theDegreesPerPixel.x = 1.0;
91 }
double nan()
double y
virtual ossimGpt origin() const
double x
◆ ossimLlxyProjection() [4/4]
ossimLlxyProjection::ossimLlxyProjection ( const ossimGpt origin,
double  latSpacing,
double  lonSpacing
Definition at line 59 of file ossimLlxyProjection.cpp.
References ossimMapProjection::computeMetersPerPixel(), ossimGpt::datum(), ossimDatum::ellipsoid(), ossimMapProjection::origin(), ossimMapProjection::theDatum, ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theEllipsoid, ossimMapProjection::theMetersPerPixel, ossimMapProjection::theOrigin, ossimMapProjection::theUlEastingNorthing, ossimMapProjection::theUlGpt, ossimDpt::x, and ossimDpt::y.
62  :
64 {
65  theOrigin = origin;
66  theUlGpt = origin;
67  theUlEastingNorthing.y = 0.0;
68  theUlEastingNorthing.x = 0.0;
71  theDegreesPerPixel.y = latSpacing;
72  theDegreesPerPixel.x = lonSpacing;
77 }
double y
ossimGpt theUlGpt
datum().
double x
◆ ~ossimLlxyProjection()
ossimLlxyProjection::~ossimLlxyProjection ( )
virtual
Definition at line 93 of file ossimLlxyProjection.cpp.
94 {
95 }
Member Function Documentation
◆ computeDegreesPerPixel()
void ossimLlxyProjection::computeDegreesPerPixel ( const ossimGpt ground,
const ossimDpt metersPerPixel,
double &  deltaLat,
double &  deltaLon
virtual
This will go from the ground point and give you an approximate lat and lon per pixel. the Delta Lat and delta lon will be in degrees.
Definition at line 106 of file ossimLlxyProjection.cpp.
References ossimGpt::metersPerDegree(), ossimDpt::x, and ossimDpt::y.
110 {
111  ossimDpt mpd = ground.metersPerDegree();
112  ossimDpt dpm(1.0/mpd.x,
113  1.0/mpd.y);
114  deltaLat = metersPerPixel.y*dpm.y;
115  deltaLon = metersPerPixel.x*dpm.x;
116 }
double y
double x
ossimDpt metersPerDegree() const
Definition: ossimGpt.cpp:498
◆ computeMetersPerPixel()
void ossimLlxyProjection::computeMetersPerPixel ( const ossimGpt center,
virtual
This will go from the ground point and give you an approximate meters per pixel. the Delta Lat and delta lon will be in degrees.
Definition at line 122 of file ossimLlxyProjection.cpp.
126 {
127  metersPerPixel = center.metersPerDegree();
128  metersPerPixel.x *= deltaDegreesPerPixelLon;
129  metersPerPixel.y *= deltaDegreesPerPixelLat;
130 }
double y
double x
◆ dup()
ossimObject * ossimLlxyProjection::dup ( ) const
virtual
Implements ossimProjection.
Definition at line 97 of file ossimLlxyProjection.cpp.
References ossimLlxyProjection().
98 {
99  return new ossimLlxyProjection(*this);
100 }
◆ forward()
ossimDpt ossimLlxyProjection::forward ( const ossimGpt worldPoint) const
virtual
Definition at line 272 of file ossimLlxyProjection.cpp.
References worldToLineSample().
273 {
274  ossimDpt result;
275
276  worldToLineSample(worldPoint, result);
277
278  return result;
279 }
virtual void worldToLineSample(const ossimGpt &worldPoint, ossimDpt &lineSampPt) const
◆ getLatSpacing()
double ossimLlxyProjection::getLatSpacing ( ) const
virtual
METHOD: getLatSpacing() Returns the latitude spacing as a double representing decimal degrees.
Definition at line 313 of file ossimLlxyProjection.cpp.
314 {
315  return theDegreesPerPixel.y;
316 }
double y
◆ getLonSpacing()
double ossimLlxyProjection::getLonSpacing ( ) const
virtual
METHOD: getLonSpacing() Returns the longitude spacing as a double representing decimal degrees.
Definition at line 318 of file ossimLlxyProjection.cpp.
References ossimMapProjection::theDegreesPerPixel, and ossimDpt::x.
319 {
320  return theDegreesPerPixel.x;
321 }
double x
◆ inverse()
ossimGpt ossimLlxyProjection::inverse ( const ossimDpt projectedPoint) const
virtual
Definition at line 281 of file ossimLlxyProjection.cpp.
References lineSampleToWorld().
282 {
283  ossimGpt result;
284
285  lineSampleToWorld(projectedPoint, result);
286
287  return result;
288 }
virtual void lineSampleToWorld(const ossimDpt &lineSampPt, ossimGpt &worldPt) const
◆ isGeographic()
bool ossimLlxyProjection::isGeographic ( ) const
virtual
Definition at line 308 of file ossimLlxyProjection.cpp.
309 {
310  return true;
311 }
◆ lineSampleToWorld()
void ossimLlxyProjection::lineSampleToWorld ( const ossimDpt lineSampPt,
ossimGpt worldPt
) const
virtual
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 147 of file ossimLlxyProjection.cpp.
References ossimGpt::datum(), ossimElevManager::getHeightAboveEllipsoid(), ossimGpt::hgt, ossimElevManager::instance(), ossimGpt::latd(), ossimDpt::line, ossimGpt::lond(), ossimGpt::makeNan(), ossimDpt::samp, ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theElevationLookupFlag, ossimMapProjection::theOrigin, ossimMapProjection::theUlGpt, ossimDpt::x, and ossimDpt::y.
Referenced by inverse().
149 {
150  worldPt.makeNan();
151  // Start with the origin. This will keep the origin's datum.
152  worldPt.datum(theOrigin.datum());
153
154  double lat = theUlGpt.latd() - (lineSampPt.line * theDegreesPerPixel.y);
155  double lon = theUlGpt.lond() + (lineSampPt.samp * theDegreesPerPixel.x);
156
157  //---
158  // Assuming the origin had a lon between -180 and 180 and lat between -90
159  // and 90.
160  //---
161 // if (lon > 180.0)
162 // {
163 // lon -= 360.0;
164 // }
165 // else if (lon < -180.0)
166 // {
167 // lon += 360.0;
168 // }
169 // if (lat > 90.0)
170 // {
171 // lat -= 90.0;
172 // }
173 // else if (lat < -90.0)
174 // {
175 // lat = -180.0 - lat;
176 // }
177
178  worldPt.latd(lat);
179  worldPt.lond(lon);
181  {
183  }
184 }
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
double samp
double y
void makeNan()
Definition: ossimGpt.h:130
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
ossimGpt theUlGpt
double latd() const
Definition: ossimGpt.h:87
datum().
double line
virtual double getHeightAboveEllipsoid(const ossimGpt &gpt)
double x
◆ loadState()
bool ossimLlxyProjection::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 216 of file ossimLlxyProjection.cpp.
References ossimMapProjection::computeDegreesPerPixel(), ossimMapProjection::computeMetersPerPixel(), ossimDpt::hasNans(), ossimGpt::hasNans(), ossimMapProjection::loadState(), ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theMetersPerPixel, ossimMapProjection::theOrigin, ossimDpt::x, and ossimDpt::y.
218 {
219  // Base class...
220  ossimMapProjection::loadState(kwl, prefix);
221
222  if (theOrigin.hasNans() == false)
223  {
224  if ( (theDegreesPerPixel.hasNans() == false) &&
226  {
227  // Compute meters per pixel from origin and decimal degrees.
232  }
233  else if( (theMetersPerPixel.hasNans() == false) &&
235  {
236  // Compute decimal degrees per pixel from origin and meters.
241  }
242  else
243  {
244  // Assign some value.
245  theDegreesPerPixel.y = DEFAULT_DEGREES_PER_PIXEL;
246  theDegreesPerPixel.x = DEFAULT_DEGREES_PER_PIXEL;
251  }
252  }
253
254  return true;
255 }
double y
bool hasNans() const
Definition: ossimDpt.h:67
Definition: ossimGpt.h:135
double x
virtual void computeDegreesPerPixel()
◆ operator==()
bool ossimLlxyProjection::operator== ( const ossimProjection projection) const
virtual
NOTE: As currently implemented in OSSIM, map projections also contain image geometry information like tiepoint and scale. This operator is only concerned with the map specification and ignores image geometry differences.
Definition at line 257 of file ossimLlxyProjection.cpp.
References ossimMapProjection::theDegreesPerPixel, ossimDpt::x, and ossimDpt::y.
258 {
259  const ossimLlxyProjection* proj = dynamic_cast<const ossimLlxyProjection*>(&projection);
260
261  if(!proj)
262  {
263  return false;
264  }
265
266  return ( // (theOrigin == proj->theOrigin) && // tmp... fix gpt!
269 }
double y
double x
◆ print()
std::ostream & ossimLlxyProjection::print ( std::ostream &  out) const
virtual
Returns stream&.
Definition at line 186 of file ossimLlxyProjection.cpp.
References ossimMapProjection::print(), ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theOrigin, ossimDpt::x, and ossimDpt::y.
187 {
188  out << setiosflags(ios::fixed) << setprecision(15)
189  << "ossimLlxyProjection dump:"
190  << "\norigin: " << theOrigin
191  << "\nlatitude spacing in decimal degrees: " << theDegreesPerPixel.y
192  << "\nlongitude spacing in decimal degrees: " << theDegreesPerPixel.x
193  << "\n\nossimMapProjection dump:\n" << endl;
194
195  return ossimMapProjection::print(out);
196 }
double y
double x
◆ saveState()
bool ossimLlxyProjection::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 207 of file ossimLlxyProjection.cpp.
References ossimMapProjection::saveState().
Referenced by ossimElevImageSource::getImageGeometry().
209 {
210  // Base class...
211  ossimMapProjection::saveState(kwl, prefix);
212
213  return true;
214 }
◆ setLatSpacing()
void ossimLlxyProjection::setLatSpacing ( double  spacing)
virtual
METHOD: setLatSpacing(double spacing) Set the latitude spacing as a double representing decimal degrees.
Definition at line 290 of file ossimLlxyProjection.cpp.
References ossimGpt::metersPerDegree(), ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theMetersPerPixel, and ossimDpt::y.
291 {
292  theDegreesPerPixel.y = spacing;
293
294  // Update the meters per pixel.
295  ossimDpt pt = ossimGpt(0.0, 0.0).metersPerDegree();
297 }
double y
◆ setLonSpacing()
void ossimLlxyProjection::setLonSpacing ( double  spacing)
virtual
METHOD: setLonSpacing(double spacing) Set the latitude spacing as a double representing decimal degrees.
Definition at line 299 of file ossimLlxyProjection.cpp.
References ossimGpt::metersPerDegree(), ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theMetersPerPixel, and ossimDpt::x.
300 {
301  theDegreesPerPixel.x = spacing;
302
303  // Update the meters per pixel.
304  ossimDpt pt = ossimGpt(0.0, 0.0).metersPerDegree();
306 }
double x
◆ setMetersPerPixel()
void ossimLlxyProjection::setMetersPerPixel ( const ossimDpt pt)
virtual
Definition at line 198 of file ossimLlxyProjection.cpp.
References ossimMapProjection::computeDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theMetersPerPixel, ossimMapProjection::theOrigin, ossimDpt::x, and ossimDpt::y.
199 {
205 }
double y
virtual void setMetersPerPixel(const ossimDpt &gsd)
double x
◆ worldToLineSample()
void ossimLlxyProjection::worldToLineSample ( const ossimGpt worldPoint,
ossimDpt lineSampPt
) const
virtual
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 132 of file ossimLlxyProjection.cpp.
References ossimGpt::changeDatum(), ossimGpt::datum(), ossimGpt::latd(), ossimDpt::line, ossimGpt::lond(), ossimDpt::samp, ossimMapProjection::theDegreesPerPixel, ossimMapProjection::theOrigin, ossimMapProjection::theUlGpt, ossimDpt::x, and ossimDpt::y.
Referenced by forward().
134 {
135  ossimGpt gpt = worldPoint;
136
137  if (*theOrigin.datum() != *gpt.datum())
138  {
139  // Apply datum shift if it's not the same.
140  gpt.changeDatum(theOrigin.datum());
141  }
142
143  lineSampPt.line = (theUlGpt.latd() - gpt.latd()) / theDegreesPerPixel.y;
144  lineSampPt.samp = (gpt.lond() - theUlGpt.lond()) / theDegreesPerPixel.x;
145 }
double lond() const
double samp
double y
ossimGpt theUlGpt
double latd() const
void changeDatum(const ossimDatum *datum)
This will actually perform a shift.
Definition: ossimGpt.cpp:316
datum().
double line
double x
