ossimMaskFilter.h
Go to the documentation of this file.
1 //*******************************************************************
2  // Copyright (C) 2000 ImageLinks Inc.
3  //
4  // License: MIT
5  //
6  // See LICENSE.txt file in the top level directory for more details.
7  //
8  // Author: Garrett Potts
9  // Modified by: Elan Sharghi (1/20/2009)
10  // Description: Class declaration for ossimMaskFilter.
11  //
12  //*************************************************************************
13  // $Id: ossimMaskFilter.h 20409 2011-12-22 16:57:05Z dburken $
14 #ifndef ossimMaskFilter_HEADER
15 #define ossimMaskFilter_HEADER 1
17
62 {
63 public:
90  {
92  OSSIM_MASK_TYPE_SELECT = 1,
94  OSSIM_MASK_TYPE_INVERT = 2,
96  OSSIM_MASK_TYPE_WEIGHTED = 3,
98  OSSIM_MASK_TYPE_BINARY = 4,
100  OSSIM_MASK_TYPE_BINARY_INVERSE = 5,
102  OSSIM_MASK_TYPE_SELECT_CLAMP_MIN = 6,
103  };
104
108  ossimMaskFilter(ossimObject* owner=NULL);
109
117  void setMaskSource(ossimImageSource* maskSource);
118
124  virtual void setMaskType(ossimFileSelectionMaskType type);
125
133  virtual void setMaskType(const ossimString& type);
134
139  virtual ossimFileSelectionMaskType getMaskType() const;
140
145  virtual ossimString getMaskTypeString() const;
146
152  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& rect,
153  ossim_uint32 resLevel=0);
154
155  virtual void initialize();
156  virtual bool loadState(const ossimKeywordlist& kwl,
157  const char* prefix=0);
158
159  virtual bool saveState(ossimKeywordlist& kwl,
160  const char* prefix=0)const;
161
162  virtual bool canConnectMyInputTo(ossim_int32 index, const ossimConnectableObject* object)const;
163
164  virtual ossim_uint32 getNumberOfInputBands() const;
165
166
167  virtual ossimRefPtr<ossimImageData> executeMaskFilter(
168  ossimRefPtr<ossimImageData> imageSourceData,
169  ossimRefPtr<ossimImageData> maskSourceData);
170
172  virtual void setProperty(ossimRefPtr<ossimProperty> property);
173
176  const ossimString& name)const;
177
179  virtual void getPropertyNames(std::vector<ossimString>& propertyNames)const;
180
181 protected:
185  virtual ~ossimMaskFilter();
186
187  void allocate();
188
194  ossimRefPtr<ossimImageData> executeMaskFilterSelect(
195  ossimRefPtr<ossimImageData> imageSourceData,
196  ossimRefPtr<ossimImageData> maskSourceData);
197
202  ossimRefPtr<ossimImageData> executeMaskFilterInvertSelect(
203  ossimRefPtr<ossimImageData> imageSourceData,
204  ossimRefPtr<ossimImageData> maskSourceData);
205
211  ossimRefPtr<ossimImageData> executeMaskFilterWeighted(
212  ossimRefPtr<ossimImageData> imageSourceData,
213  ossimRefPtr<ossimImageData> maskSourceData);
214
219  ossimRefPtr<ossimImageData> executeMaskFilterBinary(
220  ossimRefPtr<ossimImageData> imageSourceData,
221  ossimRefPtr<ossimImageData> maskSourceData);
222
223  template <class inputT, class maskT>
224  ossimRefPtr<ossimImageData> executeMaskFilterSelection(
225  inputT dummyInput,
226  maskT dummyMask,
227  ossimRefPtr<ossimImageData> imageSourceData,
228  ossimRefPtr<ossimImageData> maskSourceData);
229
230  template <class inputT, class maskT>
231  ossimRefPtr<ossimImageData> executeMaskFilterInvertSelection(
232  inputT dummyInput,
233  maskT dummyMask,
234  ossimRefPtr<ossimImageData> imageSourceData,
235  ossimRefPtr<ossimImageData> maskSourceData);
236
237  template <class inputT, class maskT>
238  ossimRefPtr<ossimImageData> executeMaskFilterWeighted(
239  inputT dummyInput,
240  maskT dummyMask,
241  ossimRefPtr<ossimImageData> imageSourceData,
242  ossimRefPtr<ossimImageData> maskSourceData);
243
244  template <class inputT, class maskT>
245  ossimRefPtr<ossimImageData> executeMaskFilterBinarySelection(
246  inputT dummyInput,
247  maskT dummyMask,
248  ossimRefPtr<ossimImageData> imageSourceData,
249  ossimRefPtr<ossimImageData> maskSourceData);
250
255
262
263  TYPE_DATA
264 };
265
266 #endif /* #ifndef ossimMaskFilter_HEADER */
#define OSSIMDLLEXPORT
Member used to store the result of the applied algorithm type.
ossimFileSelectionMaskType theMaskType
Member variable that holds the algorithm type to run on the calls to getTile.
#define TYPE_DATA
Definition: ossimRtti.h:339
ossimRefPtr< ossimImageSource > theMaskSource
unsigned int ossim_uint32
virtual void initialize()=0
virtual bool canConnectMyInputTo(ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0
required to be overriden by derived classes
Enumeration used to identify what the selection type for this mask is to be used: ...
virtual ossim_uint32 getNumberOfInputBands() const =0
int ossim_int32
