Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimMaskFilter Class Reference
#include <ossimMaskFilter.h>
Inheritance diagram for ossimMaskFilter:
ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Types
enum  ossimFileSelectionMaskType {
  OSSIM_MASK_TYPE_SELECT = 1, OSSIM_MASK_TYPE_INVERT = 2, OSSIM_MASK_TYPE_WEIGHTED = 3, OSSIM_MASK_TYPE_BINARY = 4,
  OSSIM_MASK_TYPE_BINARY_INVERSE = 5, OSSIM_MASK_TYPE_SELECT_CLAMP_MIN = 6
 Enumeration used to identify what the selection type for this mask is to be used: More...
 ossimMaskFilter (ossimObject *owner=NULL)
 Default Constructor. More...
void setMaskSource (ossimImageSource *maskSource)
 This set method is necessary when this object is being added to an ossimImageChain because ossimImageChain::addLast() performs a disconnect of all the input sources, thus losing the assignments made via constructor accepting source pointers. More...
virtual void setMaskType (ossimFileSelectionMaskType type)
 Sets the mask type. More...
virtual void setMaskType (const ossimString &type)
 Sets the mask type from string. More...
virtual ossimFileSelectionMaskType getMaskType () const
 Returns the current mask algorithm used. More...
virtual ossimString getMaskTypeString () const
 Returns the current mask algorithm used as a string. More...
 Main entry point for the algorithm. More...
virtual void initialize ()
virtual bool canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *object) const
virtual ossimRefPtr< ossimImageDataexecuteMaskFilter (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
 Interface to set the mask type. More...
 Adds "mask_type" to list. More...
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
virtual ~ossimMaskFilter ()
 Will delete its owned tile. More...
void allocate ()
ossimRefPtr< ossimImageDataexecuteMaskFilterSelect (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
 will execute the section algorithm. More...
ossimRefPtr< ossimImageDataexecuteMaskFilterInvertSelect (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
 will execute the invert selection algorithm. More...
ossimRefPtr< ossimImageDataexecuteMaskFilterWeighted (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
 will execute the weighted algorithm. More...
ossimRefPtr< ossimImageDataexecuteMaskFilterBinary (ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
 Will execute the binary algorithm. More...
template<class inputT , class maskT >
ossimRefPtr< ossimImageDataexecuteMaskFilterSelection (inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
ossimRefPtr< ossimImageDataexecuteMaskFilterInvertSelection (inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
ossimRefPtr< ossimImageDataexecuteMaskFilterWeighted (inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
ossimRefPtr< ossimImageDataexecuteMaskFilterBinarySelection (inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
virtual ~ossimReferenced ()
ossimFileSelectionMaskType theMaskType
 Member variable that holds the algorithm type to run on the calls to getTile. More...
 Member used to store the result of the applied algorithm type. More...
ossimRefPtr< ossimImageSourcetheMaskSource
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
class ossimMaskFilter
   Requires 2 inputs.  The first input is assumed to be the image input
   and the second input is assumed to be the mask data.  It will only
   use one band of the mask and multi band masks are not supported.
   the number of bands, min pix, max pix, null pix ...etc are mapped
   to the first input.
Keywords:
   mask_type:
keywords description: This keyword can have the following values:
   select, select_clamp, invert, weighted, binary, or binary_inverse
  • select will use the input data and every where the mask is greater than 0 it will copy the input to the output.
  • select_clamp_min If mask pixel is non zero, output pixel is input pixel; else, null pixel value. Differs from select in that output pixel is clamped to min pixel if input pixel is used.
  • invert will use the input data and every where the mask is 0 it will copy the input to the output else it will place a null in the output.
  • weighted will normalize the mask between 0 and 1 and then multiply the input by that normalized value and copy to the output.
  • binary If mask pixel is non zero, output pixel is max pixel value; else, null.
  • binary_inverse If mask pixel is non zero, output pixel is max pixel value; else, null pixel value.
example of keywords:
 mask_type: select
Definition at line 61 of file ossimMaskFilter.h.
◆ ossimFileSelectionMaskType
  • OSSIM_MASK_TYPE_SELECT If the mask is non zero then the input is kept if it's 0 then the input is nulled out.
  • OSSIM_MASK_TYPE_INVERT If the input is non zero then the output is nulled else the input is kept
  • OSSIM_MASK_TYPE_WEIGHTED works as a multiplier of the input data. The mask is normalized to be between 0 and 1 and multiplies the input by that normalized value.
  • OSSIM_MASK_TYPE_BINARY If mask pixel is non zero, output pixel is null pixel value; else, max pixel value.
  • OSSIM_MASK_TYPE_BINARY_INVERSE If mask pixel is non zero, output pixel is max pixel value; else, null pixel value.
  • OSSIM_MASK_TYPE_SELECT_CLAMP_MIN If mask pixel is non zero, output pixel is input pixel; else, null pixel value. Differs from OSSIM_MASK_TYPE_SELECT in that output pixel is clamped to min pixel if input pixel is used. The clampling has the affect of flipping null pixels to min pixel value if the mask pixel is non zero and input pixel is a null.
Enumerator
standard select if mask is true then keep
standard invert if mask is true the don't keep
weighted operation.
Normalize the mask and multiply the input
binary image>
inverse binary image>
Standard select if mask is true then keep with min.
Definition at line 89 of file ossimMaskFilter.h.
◆ ossimMaskFilter()
ossimMaskFilter::ossimMaskFilter ( ossimObject owner = NULL)
Definition at line 28 of file ossimMaskFilter.cpp.
29  :
30  ossimImageSource(owner, 1, 1, true, false),
32  theTile(0)
33 {
34 }
ossimImageSource(ossimObject *owner=0)
◆ ~ossimMaskFilter()
ossimMaskFilter::~ossimMaskFilter ( )
protectedvirtual
Definition at line 36 of file ossimMaskFilter.cpp.
37 {
38 }
Member Function Documentation
◆ allocate()
void ossimMaskFilter::allocate ( )
protected
Definition at line 110 of file ossimMaskFilter.cpp.
References ossimImageDataFactory::create(), ossimConnectableObject::getInput(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and theTile.
Referenced by getTile().
111 {
112  if(getInput())
113  {
115  theTile->initialize();
116  }
117 }
virtual void initialize()
Initialize the data buffer.
◆ canConnectMyInputTo()
bool ossimMaskFilter::canConnectMyInputTo ( ossim_int32  myInputIndex,
const ossimConnectableObject object
) const
virtual
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 95 of file ossimMaskFilter.cpp.
References PTR_CAST.
97 {
98  return (PTR_CAST(ossimImageSource, object)!= 0);
99 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ executeMaskFilter()
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilter ( ossimRefPtr< ossimImageData imageSourceData,
ossimRefPtr< ossimImageData maskSourceData
virtual
Definition at line 119 of file ossimMaskFilter.cpp.
References ossimImageData::dup(), executeMaskFilterBinary(), executeMaskFilterInvertSelect(), executeMaskFilterSelect(), executeMaskFilterWeighted(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getOrigin(), ossimImageData::getWidth(), ossimImageData::initialize(), ossimImageData::loadTile(), OSSIM_MASK_TYPE_BINARY, OSSIM_MASK_TYPE_BINARY_INVERSE, OSSIM_MASK_TYPE_INVERT, OSSIM_MASK_TYPE_SELECT, OSSIM_MASK_TYPE_SELECT_CLAMP_MIN, OSSIM_MASK_TYPE_WEIGHTED, ossimDataObject::setDataObjectStatus(), ossimImageData::setOrigin(), ossimImageData::setWidthHeight(), theMaskType, and theTile.
122 {
123  if(!theTile)
124  {
125  theTile = (ossimImageData*)imageSourceData->dup();
126  if(!theTile->getBuf())
127  {
128  theTile->initialize();
129  }
130  }
131  else
132  {
133  ossim_uint32 tw = theTile->getWidth();
135  ossim_uint32 dw = imageSourceData->getWidth();
136  ossim_uint32 dh = imageSourceData->getHeight();
137
138  theTile->setWidthHeight(imageSourceData->getWidth(),
139  imageSourceData->getHeight());
140  theTile->setOrigin(imageSourceData->getOrigin());
141  if((tw*th) != (dw*dh))
142  {
143  theTile->initialize();
144  }
145  theTile->setDataObjectStatus(imageSourceData->getDataObjectStatus());
146  }
147  theTile->loadTile(imageSourceData.get());
148  theTile->setDataObjectStatus(imageSourceData->getDataObjectStatus());
149  switch(theMaskType)
150  {
153  {
154  return executeMaskFilterSelect(theTile, maskSourceData);
155  }
157  {
158  return executeMaskFilterInvertSelect(theTile, maskSourceData);
159  }
161  {
162  return executeMaskFilterWeighted(theTile, maskSourceData);
163  }
166  {
167  return executeMaskFilterBinary(theTile, maskSourceData);
168  }
169  }
170
171  return imageSourceData;
172 }
virtual void setWidthHeight(ossim_uint32 w, ossim_uint32 h)
ossimRefPtr< ossimImageData > executeMaskFilterBinary(ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
ossimRefPtr< ossimImageData > executeMaskFilterInvertSelect(ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
virtual ossimObject * dup() const
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
unsigned int ossim_uint32
ossimRefPtr< ossimImageData > executeMaskFilterSelect(ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
virtual void setOrigin(const ossimIpt &origin)
ossimRefPtr< ossimImageData > executeMaskFilterWeighted(ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
virtual void setDataObjectStatus(ossimDataObjectStatus status) const
Full list found in ossimConstants.h.
virtual const ossimIpt & getOrigin() const
◆ executeMaskFilterBinary()
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilterBinary ( ossimRefPtr< ossimImageData imageSourceData,
protected
Copies the values in the mask to each tile. Values will be either NULL or MAX pixel value, typically 0 or 255.
Definition at line 379 of file ossimMaskFilter.cpp.
References executeMaskFilterBinarySelection(), ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
Referenced by executeMaskFilter().
381 {
382  if(maskSourceData->getScalarType() != OSSIM_UCHAR)
383  {
384  ossimNotify(ossimNotifyLevel_WARN) << "ossimMaskFilter::executeMaskFilterBinary WARNING: Only uchar masks are supported" << endl;
385  return imageSourceData;
386  }
387
388  switch(imageSourceData->getScalarType())
389  {
390  case OSSIM_UCHAR:
391  {
393  (ossim_uint8)0,
394  imageSourceData,
395  maskSourceData);
396  break;
397  }
398  case OSSIM_USHORT11:
399  case OSSIM_USHORT12:
400  case OSSIM_USHORT13:
401  case OSSIM_USHORT14:
402  case OSSIM_USHORT15:
403  case OSSIM_USHORT16:
404  {
406  (ossim_uint8)0,
407  imageSourceData,
408  maskSourceData);
409  break;
410  }
411  case OSSIM_SSHORT16:
412  {
414  (ossim_uint8)0,
415  imageSourceData,
416  maskSourceData);
417  break;
418  }
419  case OSSIM_FLOAT:
421  {
423  (ossim_uint8)0,
424  imageSourceData,
425  maskSourceData);
426  break;
427  }
428  case OSSIM_DOUBLE:
430  {
432  (ossim_uint8)0,
433  imageSourceData,
434  maskSourceData);
435  break;
436  }
437  default:
438  {
439  ossimNotify(ossimNotifyLevel_WARN) << "ossimMaskFilter::executeMaskFilterBinary WARNING: Unknown scalar type" << endl;
440  break;
441  }
442  }
443
444  return theTile;
445 }
unsigned short ossim_uint16
signed short ossim_sint16
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
unsigned char ossim_uint8
8 bit unsigned iteger
ossimRefPtr< ossimImageData > executeMaskFilterBinarySelection(inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
◆ executeMaskFilterBinarySelection()
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilterBinarySelection ( inputT  dummyInput,
maskT  dummyMask,
protected
Definition at line 668 of file ossimMaskFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), OSSIM_MASK_TYPE_BINARY_INVERSE, theMaskType, theTile, and ossimImageData::validate().
Referenced by executeMaskFilterBinary().
673 {
674  ossim_uint32 maskBands = maskSourceData->getNumberOfBands();
675  ossim_uint32 inputBands = imageSourceData->getNumberOfBands();
676  if(maskBands&&inputBands)
677  {
678  ossim_uint32 maxOffset = theTile->getWidth()*theTile->getHeight();
679  for(ossim_uint32 band = 0; band < inputBands; ++band)
680  {
681  maskT* bufMask = (maskT*)maskSourceData->getBuf();
682  inputT* bufOut = (inputT*)theTile->getBuf(band);
683  const inputT NP = (inputT)theTile->getNullPix(band);
684  const inputT MP = (inputT)theTile->getMaxPix(band);
685  ossim_uint32 offset = 0;
686  for(offset = 0; offset < maxOffset; ++offset)
687  {
689  {
690  if(*bufMask) // if mask == 1
691  *bufOut = MP; // set to max pix
692  else // if mask == 0
693  *bufOut = NP; // set to null pix
694  }
695  else
696  {
697  if(*bufMask) // if mask == 1
698  *bufOut = NP; // set to null pix
699  else // if mask == 0
700  *bufOut = MP; // set to max pix
701  }
702  ++bufOut;
703  ++bufMask;
704  }
705  }
706  theTile->validate();
707  }
708
709  return theTile;
710 }
virtual const ossim_float64 * getMaxPix() const
virtual const ossim_float64 * getNullPix() const
◆ executeMaskFilterInvertSelect()
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilterInvertSelect ( ossimRefPtr< ossimImageData imageSourceData,
protected
everywhere the mask is 0 it copies the input data to the output else it outputs null.
Definition at line 243 of file ossimMaskFilter.cpp.
References executeMaskFilterInvertSelection(), ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
245 {
246  if(maskSourceData->getScalarType() != OSSIM_UCHAR)
247  {
248  ossimNotify(ossimNotifyLevel_WARN) << "ossimMaskFilter::executeMaskFilterSelect WARNING: Only uchar masks are supported" << endl;
249  return imageSourceData;
250  }
251
252  switch(imageSourceData->getScalarType())
253  {
254  case OSSIM_UCHAR:
255  {
257  (ossim_uint8)0,
258  imageSourceData,
259  maskSourceData);
260  break;
261  }
262  case OSSIM_USHORT11:
263  case OSSIM_USHORT12:
264  case OSSIM_USHORT13:
265  case OSSIM_USHORT14:
266  case OSSIM_USHORT15:
267  case OSSIM_USHORT16:
268  {
270  (ossim_uint8)0,
271  imageSourceData,
272  maskSourceData);
273  break;
274  }
275  case OSSIM_SSHORT16:
276  {
278  (ossim_uint8)0,
279  imageSourceData,
280  maskSourceData);
281  break;
282  }
283  case OSSIM_FLOAT:
285  {
287  (ossim_uint8)0,
288  imageSourceData,
289  maskSourceData);
290  break;
291  }
292  case OSSIM_DOUBLE:
294  {
296  (ossim_uint8)0,
297  imageSourceData,
298  maskSourceData);
299  break;
300  }
301  default:
302  {
303  ossimNotify(ossimNotifyLevel_WARN) << "ossimMaskFilter::executeMaskFilterSelect WARNING: Unknown scalar type" << endl;
304  break;
305  }
306  }
307
308  return theTile;
309 }
ossimRefPtr< ossimImageData > executeMaskFilterInvertSelection(inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
◆ executeMaskFilterInvertSelection()
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilterInvertSelection ( inputT  dummyInput,
maskT  dummyMask,
protected
Definition at line 524 of file ossimMaskFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, theTile, and ossimImageData::validate().
Referenced by executeMaskFilterInvertSelect().
529 {
530  ossimDataObjectStatus maskDataStatus = maskSourceData->getDataObjectStatus();
531  ossimDataObjectStatus inputDataStatus = imageSourceData->getDataObjectStatus();
532
533  // First just check if mask is empty, which means pass the image source along untouched:
534  if( (maskDataStatus == OSSIM_NULL) || (maskDataStatus == OSSIM_EMPTY))
535  {
536  theTile = imageSourceData;
537  return theTile;
538  }
539
540  // Then check for a total mask (all mask values are 1) and return empty tile if so:
541  if (maskDataStatus == OSSIM_FULL)
542  {
543  theTile->makeBlank();
544  return theTile;
545  }
546
547  // Finally check for blank source tile and return it if so:
548  if( (inputDataStatus == OSSIM_NULL) || (inputDataStatus == OSSIM_EMPTY))
549  {
550  theTile->makeBlank();
551  return theTile;
552  }
553
554  ossim_uint32 maskBands = maskSourceData->getNumberOfBands();
555  ossim_uint32 inputBands = imageSourceData->getNumberOfBands();
556  if(maskBands&&inputBands)
557  {
558  ossim_uint32 maxOffset = theTile->getWidth()*theTile->getHeight();
559  for(ossim_uint32 band = 0; band < inputBands; ++band)
560  {
561  maskT* bufMask = (maskT*)maskSourceData->getBuf();
562  inputT* bufIn = (inputT*)imageSourceData->getBuf(band);
563  inputT* bufOut = (inputT*)theTile->getBuf(band);
564  inputT np = (inputT)theTile->getNullPix(band);
565  ossim_uint32 offset = 0;
566  for(offset = 0; offset < maxOffset; ++offset)
567  {
568  if(!*bufMask)
569  {
570  *bufOut = *bufIn;
571  }
572  else
573  {
574  *bufOut = np;
575  }
576  ++bufOut;
577  ++bufIn;
578  ++bufMask;
579  }
580  }
581  theTile->validate();
582  }
583
584  return theTile;
585 }
virtual void makeBlank()
Definitions for data object status.
◆ executeMaskFilterSelect()
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilterSelect ( ossimRefPtr< ossimImageData imageSourceData,
protected
everywhere the mask is not 0 it copies the input data to the output and everywhere the input is null it writes a null pixel to the output.
Definition at line 174 of file ossimMaskFilter.cpp.
References executeMaskFilterSelection(), ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
177 {
178  if(maskSourceData->getScalarType() != OSSIM_UCHAR)
179  {
180  ossimNotify(ossimNotifyLevel_WARN) << "ossimMaskFilter::executeMaskFilterSelect WARNING: Only uchar masks are supported" << endl;
181  return imageSourceData;
182  }
183
184  switch(imageSourceData->getScalarType())
185  {
186  case OSSIM_UCHAR:
187  {
189  (ossim_uint8)0,
190  imageSourceData,
191  maskSourceData);
192  break;
193  }
194  case OSSIM_USHORT11:
195  case OSSIM_USHORT12:
196  case OSSIM_USHORT13:
197  case OSSIM_USHORT14:
198  case OSSIM_USHORT15:
199  case OSSIM_USHORT16:
200  {
202  (ossim_uint8)0,
203  imageSourceData,
204  maskSourceData);
205  break;
206  }
207  case OSSIM_SSHORT16:
208  {
210  (ossim_uint8)0,
211  imageSourceData,
212  maskSourceData);
213  break;
214  }
215  case OSSIM_FLOAT:
217  {
219  (ossim_uint8)0,
220  imageSourceData,
221  maskSourceData);
222  break;
223  }
224  case OSSIM_DOUBLE:
226  {
227  executeMaskFilterSelection((double)0,
228  (ossim_uint8)0,
229  imageSourceData,
230  maskSourceData);
231  break;
232  }
233  default:
234  {
235  ossimNotify(ossimNotifyLevel_WARN) << "ossimMaskFilter::executeMaskFilterSelect WARNING: Unknown scalar type" << endl;
236  break;
237  }
238  }
239
240  return theTile;
241 }
ossimRefPtr< ossimImageData > executeMaskFilterSelection(inputT dummyInput, maskT dummyMask, ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
◆ executeMaskFilterSelection()
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilterSelection ( inputT  dummyInput,
maskT  dummyMask,
protected
Definition at line 448 of file ossimMaskFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_MASK_TYPE_SELECT, OSSIM_NULL, theMaskType, theTile, and ossimImageData::validate().
Referenced by executeMaskFilterSelect().
453 {
454  ossimDataObjectStatus maskDataStatus = maskSourceData->getDataObjectStatus();
455  ossimDataObjectStatus inputDataStatus = imageSourceData->getDataObjectStatus();
456
457  // First just check if mask is full, which means pass the image source along untouched:
458  if (maskDataStatus == OSSIM_FULL)
459  {
460  theTile = imageSourceData;
461  return theTile;
462  }
463
464  // Then check for a total mask (all mask values are 0) and return empty tile if so:
465  if( (maskDataStatus == OSSIM_NULL) || (maskDataStatus == OSSIM_EMPTY))
466  {
467  theTile->makeBlank();
468  return theTile;
469  }
470
471  // Finally check for blank source tile and return it if so:
472  if( (inputDataStatus == OSSIM_NULL) || (inputDataStatus == OSSIM_EMPTY))
473  {
474  theTile->makeBlank();
475  return theTile;
476  }
477
478  ossim_uint32 maskBands = maskSourceData->getNumberOfBands();
479  ossim_uint32 inputBands = imageSourceData->getNumberOfBands();
480  if(maskBands&&inputBands)
481  {
482  ossim_uint32 maxOffset = theTile->getWidth()*theTile->getHeight();
483  for(ossim_uint32 band = 0; band < inputBands; ++band)
484  {
485  maskT* bufMask = static_cast<maskT*> ( maskSourceData->getBuf() );
486  inputT* bufIn = static_cast<inputT*>( imageSourceData->getBuf(band) );
487  inputT* bufOut = static_cast<inputT*>( theTile->getBuf(band) );
488  inputT nullPix = static_cast<inputT> ( theTile->getNullPix(band) );
489  inputT minPix = static_cast<inputT> ( theTile->getMinPix(band) );
490  ossim_uint32 offset = 0;
491  for(offset = 0; offset < maxOffset; ++offset)
492  {
493  if(*bufMask)
494  {
496  {
497  *bufOut = *bufIn;
498  }
499  else
500  {
501  //---
502  // OSSIM_MASK_TYPE_SELECT_CLAMP_MIN
503  // Use input pixel clamping any nulls to min.
504  //---
505  *bufOut = *bufIn != nullPix ? *bufIn : minPix;
506  }
507  }
508  else
509  {
510  *bufOut = nullPix;
511  }
512  ++bufOut;
513  ++bufIn;
514  ++bufMask;
515  }
516  }
517  theTile->validate();
518  }
519
520  return theTile;
521 }
virtual const ossim_float64 * getMinPix() const
◆ executeMaskFilterWeighted() [1/2]
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilterWeighted ( ossimRefPtr< ossimImageData imageSourceData,
protected
It normalizes the mask value to be between 0 and 1 and multiplies the input data by that value and outputs it.
Definition at line 311 of file ossimMaskFilter.cpp.
References ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, and theTile.
313 {
314  if(maskSourceData->getScalarType() != OSSIM_UCHAR)
315  {
316  ossimNotify(ossimNotifyLevel_WARN) << "ossimMaskFilter::executeMaskFilterSelect WARNING: Only uchar masks are supported" << endl;
317  return imageSourceData;
318  }
319
320  switch(imageSourceData->getScalarType())
321  {
322  case OSSIM_UCHAR:
323  {
325  (ossim_uint8)0,
326  imageSourceData,
327  maskSourceData);
328  break;
329  }
330  case OSSIM_USHORT11:
331  case OSSIM_USHORT12:
332  case OSSIM_USHORT13:
333  case OSSIM_USHORT14:
334  case OSSIM_USHORT15:
335  case OSSIM_USHORT16:
336  {
338  (ossim_uint8)0,
339  imageSourceData,
340  maskSourceData);
341  break;
342  }
343  case OSSIM_SSHORT16:
344  {
346  (ossim_uint8)0,
347  imageSourceData,
348  maskSourceData);
349  break;
350  }
351  case OSSIM_FLOAT:
353  {
354  executeMaskFilterWeighted((float)0,
355  (ossim_uint8)0,
356  imageSourceData,
357  maskSourceData);
358  break;
359  }
360  case OSSIM_DOUBLE:
362  {
363  executeMaskFilterWeighted((double)0,
364  (ossim_uint8)0,
365  imageSourceData,
366  maskSourceData);
367  break;
368  }
369  default:
370  {
371  ossimNotify(ossimNotifyLevel_WARN) << "ossimMaskFilter::executeMaskFilterSelect WARNING: Unknown scalar type" << endl;
372  break;
373  }
374  }
375
376  return theTile;
377 }
◆ executeMaskFilterWeighted() [2/2]
ossimRefPtr< ossimImageData > ossimMaskFilter::executeMaskFilterWeighted ( inputT  dummyInput,
maskT  dummyMask,
protected
Definition at line 588 of file ossimMaskFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, OSSIM_PARTIAL, theTile, and ossimImageData::validate().
593 {
594  ossimDataObjectStatus maskDataStatus = maskSourceData->getDataObjectStatus();
595  ossimDataObjectStatus inputDataStatus = imageSourceData->getDataObjectStatus();
596
597  if( (maskDataStatus == OSSIM_NULL)||
598  (maskDataStatus == OSSIM_EMPTY))
599  {
600  theTile->makeBlank();
601  return theTile;
602  }
603  if( (inputDataStatus == OSSIM_NULL)||
604  (inputDataStatus == OSSIM_EMPTY))
605  {
606  return theTile;
607  }
608
609  ossim_uint32 maskBands = maskSourceData->getNumberOfBands();
610  ossim_uint32 inputBands = imageSourceData->getNumberOfBands();
611  if(maskBands&&inputBands)
612  {
613  ossim_uint32 maxOffset = theTile->getWidth()*theTile->getHeight();
614  for(ossim_uint32 band = 0; band < inputBands; ++band)
615  {
616  maskT* bufMask = (maskT*)maskSourceData->getBuf();
617  inputT* bufIn = (inputT*)imageSourceData->getBuf(band);
618  inputT* bufOut = (inputT*)theTile->getBuf(band);
619  inputT np = (inputT)theTile->getNullPix(band);
620  inputT minp = (inputT)theTile->getMinPix(band);
621  ossim_uint32 offset = 0;
622
623  if(inputDataStatus == OSSIM_PARTIAL)
624  {
625  for(offset = 0; offset < maxOffset; ++offset)
626  {
627  if(*bufIn != np)
628  {
629  *bufOut = (inputT)((*bufIn)*((double)(*bufMask)/255.0));
630  if((*bufOut != np)&&
631  (*bufOut < minp))
632  {
633  *bufOut = minp;
634  }
635  }
636  else
637  {
638  *bufOut = np;
639  }
640  ++bufOut;
641  ++bufIn;
642  ++bufMask;
643  }
644  }
645  else
646  {
647  for(offset = 0; offset < maxOffset; ++offset)
648  {
649  *bufOut = (inputT)((*bufIn)*((double)(*bufMask)/255.0));
650  if((*bufOut != np)&&
651  (*bufOut < minp))
652  {
653  *bufOut = minp;
654  }
655  ++bufOut;
656  ++bufIn;
657  ++bufMask;
658  }
659  }
660  }
661  theTile->validate();
662  }
663
664  return theTile;
665 }
◆ getMaskType()
ossimMaskFilter::ossimFileSelectionMaskType ossimMaskFilter::getMaskType ( ) const
virtual
Returns
the current ossimFileSelectionMaskType used.
Definition at line 751 of file ossimMaskFilter.cpp.
References theMaskType.
752 {
753  return theMaskType;
754 }
◆ getMaskTypeString()
ossimString ossimMaskFilter::getMaskTypeString ( ) const
virtual
Returns
Definition at line 756 of file ossimMaskFilter.cpp.
References OSSIM_MASK_TYPE_BINARY, OSSIM_MASK_TYPE_BINARY_INVERSE, OSSIM_MASK_TYPE_INVERT, OSSIM_MASK_TYPE_SELECT, OSSIM_MASK_TYPE_SELECT_CLAMP_MIN, OSSIM_MASK_TYPE_WEIGHTED, and theMaskType.
757 {
758  ossimString maskType;
759
760  switch(theMaskType)
761  {
763  {
764  maskType = "select";
765  break;
766  }
768  {
769  maskType = "invert";
770  break;
771  }
773  {
774  maskType = "weighted";
775  break;
776  }
778  {
779  maskType = "binary";
780  break;
781  }
783  {
784  maskType = "binary_inverse";
785  break;
786  }
788  {
789  maskType = "select_clamp_min";
790  break;
791  }
792  }
793
794  return maskType;
795 }
◆ getNumberOfInputBands()
ossim_uint32 ossimMaskFilter::getNumberOfInputBands ( ) const
virtual
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 871 of file ossimMaskFilter.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getNumberOfInputBands(), and PTR_CAST.
872 {
874  if (img_source)
875  return img_source->getNumberOfInputBands();
876  return 0;
877 }
virtual ossim_uint32 getNumberOfInputBands() const =0
◆ getProperty()
ossimRefPtr< ossimProperty > ossimMaskFilter::getProperty ( const ossimString name) const
virtual
Returns
"mask_type" property.
Definition at line 841 of file ossimMaskFilter.cpp.
843 {
844  ossimRefPtr<ossimProperty> result = 0;
845
846  if(name == MASK_FILTER_MASK_TYPE_KW)
847  {
848  std::vector<ossimString> constraintList;
849  constraintList.push_back(ossimString("select"));
850  constraintList.push_back(ossimString("invert"));
851  constraintList.push_back(ossimString("weighted"));
852
853  result = new ossimStringProperty(MASK_FILTER_MASK_TYPE_KW,
855  false,
856  constraintList);
857  }
858  else
859  {
860  result = ossimImageSource::getProperty(name);
861  }
862  return result;
863 }
virtual ossimString getMaskTypeString() const
◆ getPropertyNames()
void ossimMaskFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 865 of file ossimMaskFilter.cpp.
References ossimImageSource::getPropertyNames().
866 {
867  ossimImageSource::getPropertyNames(propertyNames);
868  propertyNames.push_back(MASK_FILTER_MASK_TYPE_KW);
869 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimMaskFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Parameters
rect
Definition at line 46 of file ossimMaskFilter.cpp.
References allocate(), executeMaskFilter(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimImageSource::getTile(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), OSSIM_NULL, PTR_CAST, ossimImageData::setImageRectangle(), ossimImageData::setOrigin(), theMaskSource, theTile, ossimIrect::ul(), and ossimRefPtr< T >::valid().
Referenced by ossimOverviewSequencer::getNextTile().
48 {
50  if (!imageSource || !theMaskSource.valid())
51  {
53  return theTile;
54  }
55
56  ossimRefPtr<ossimImageData> imageSourceData;
57  ossimRefPtr<ossimImageData> maskSourceData;
58
59  imageSourceData = imageSource->getTile(rect, resLevel);
60  if(!isSourceEnabled())
61  return imageSourceData;
62
63  if (!theTile.valid())
64  allocate();
65
66  maskSourceData = theMaskSource->getTile(rect, resLevel);
67  if(!imageSourceData.valid() || !theTile.valid())
68  {
70  }
71
72  theTile->setOrigin(rect.ul());
73  if(theTile->getImageRectangle() != rect)
74  {
77  }
78  if(!imageSourceData.valid())
79  {
80  return theTile;
81  }
82  if(!maskSourceData.valid())
83  {
84  return imageSourceData;
85  }
86
87  if(imageSourceData->getDataObjectStatus() != OSSIM_NULL)
88  {
89  return executeMaskFilter(imageSourceData, maskSourceData);
90  }
91
92  return theTile;
93 }
bool valid() const
Definition: ossimRefPtr.h:75
const ossimIpt & ul() const
Definition: ossimIrect.h:274
ossimRefPtr< ossimImageSource > theMaskSource
virtual ossimIrect getImageRectangle() const
virtual ossimRefPtr< ossimImageData > executeMaskFilter(ossimRefPtr< ossimImageData > imageSourceData, ossimRefPtr< ossimImageData > maskSourceData)
◆ initialize()
void ossimMaskFilter::initialize ( )
virtual
Definition at line 101 of file ossimMaskFilter.cpp.
References ossimConnectableObject::getInput(), and theTile.
102 {
103  if(getInput(0))
104  {
105  // Force an allocate on the next getTile.
106  theTile = 0;
107  }
108 }
◆ loadState()
bool ossimMaskFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 797 of file ossimMaskFilter.cpp.
References ossimKeywordlist::find(), ossimImageSource::loadState(), ossimConnectableObject::setNumberOfInputs(), ossimConnectableObject::theInputListIsFixedFlag, and ossimConnectableObject::theOutputListIsFixedFlag.
799 {
800  bool result = ossimImageSource::loadState(kwl, prefix);
801
803  theOutputListIsFixedFlag = false;
805
806  const char* lookup = kwl.find(prefix, MASK_FILTER_MASK_TYPE_KW);
807  if (lookup)
808  {
809  setMaskType(ossimString(lookup));
810  }
811
812  return result;
813 }
virtual void setNumberOfInputs(ossim_int32 numberOfInputs)
Will set the number of inputs.
virtual void setMaskType(ossimFileSelectionMaskType type)
Sets the mask type.
Indicates whether the theInputObjectList is fixed.
Indicates whether the theOutputObjectList is fixed.
◆ saveState()
bool ossimMaskFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 815 of file ossimMaskFilter.cpp.
References ossimKeywordlist::add().
817 {
818  kwl.add(prefix,
819  MASK_FILTER_MASK_TYPE_KW,
820  getMaskTypeString().c_str(),
821  true);
822
823  return ossimImageSource::saveState(kwl, prefix);
824 }
◆ setMaskSource()
void ossimMaskFilter::setMaskSource ( ossimImageSource maskSource)
If the intent is to insert this object in place of the image handler in a chain, First remove the handler from the chain, then add a default-constructed mask filter object, then call this method to assign the inputs.
Definition at line 41 of file ossimMaskFilter.cpp.
References theMaskSource.
42 {
43  theMaskSource = maskSource;
44 }
◆ setMaskType() [1/2]
void ossimMaskFilter::setMaskType ( ossimFileSelectionMaskType  type)
virtual
Sets the mask type.
Parameters
typeThe mask algorithm type to be used. see ossimFileSelectionMaskType
Definition at line 712 of file ossimMaskFilter.cpp.
713 {
714  theMaskType = type;
715 }
◆ setMaskType() [2/2]
void ossimMaskFilter::setMaskType ( const ossimString type)
virtual
Valid strings are: "select", "invert" and "weighted".
Parameters
Definition at line 717 of file ossimMaskFilter.cpp.
References ossimString::downcase(), OSSIM_MASK_TYPE_BINARY, OSSIM_MASK_TYPE_BINARY_INVERSE, OSSIM_MASK_TYPE_INVERT, OSSIM_MASK_TYPE_SELECT, OSSIM_MASK_TYPE_SELECT_CLAMP_MIN, OSSIM_MASK_TYPE_WEIGHTED, and theMaskType.
718 {
719  if(type != "")
720  {
721  ossimString maskType = type;
722  maskType.downcase();
723
724  if(maskType == "select")
725  {
727  }
728  else if(maskType == "invert")
729  {
731  }
732  else if(maskType == "weighted")
733  {
735  }
736  else if(maskType == "binary")
737  {
739  }
740  else if(maskType == "binary_inverse")
741  {
743  }
744  else if(maskType == "select_clamp_min")
745  {
747  }
748  }
749 }
◆ setProperty()
void ossimMaskFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 826 of file ossimMaskFilter.cpp.
References ossimProperty::getName(), and ossimRefPtr< T >::valid().
827 {
828  if( property.valid() )
829  {
830  if(property->getName() == MASK_FILTER_MASK_TYPE_KW)
831  {
832  setMaskType(property->valueToString());
833  }
834  else
835  {
837  }
838  }
839 }
virtual void valueToString(ossimString &valueResult) const =0
bool valid() const
Sets the mask type.
const ossimString & getName() const
Member Data Documentation
◆ theMaskSource
ossimRefPtr<ossimImageSource> ossimMaskFilter::theMaskSource
protected
Definition at line 261 of file ossimMaskFilter.h.
Referenced by getTile(), and setMaskSource().
◆ theMaskType
ossimFileSelectionMaskType ossimMaskFilter::theMaskType
protected
Definition at line 254 of file ossimMaskFilter.h.
Referenced by executeMaskFilter(), executeMaskFilterBinarySelection(), executeMaskFilterSelection(), getMaskType(), getMaskTypeString(), and setMaskType().
◆ theTile
ossimRefPtr<ossimImageData> ossimMaskFilter::theTile
protected
