ossimMpiSlaveOverviewSequencer.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: David Burken
6 //
7 // Description: Class definition for mpi slave sequencer for building
8 // overview files.
9 //
10 //----------------------------------------------------------------------------
11 // $Id: ossimMpiSlaveOverviewSequencer.cpp 17870 2010-08-12 13:12:32Z sbortman $
12
14 #include <ossim/ossimConfig.h> /* To pick up OSSIM_HAS_MPI. */
15 #include <ossim/base/ossimCommon.h> /* For get byte order. */
16 #include <ossim/base/ossimEndian.h>
17 #include <ossim/base/ossimRefPtr.h>
19
20
21
22 #if OSSIM_HAS_MPI
23 # include <mpi.h>
24 #endif
25
27  :
29  m_rank(0),
30  m_numberOfProcessors(1)
31 {
32 #if OSSIM_HAS_MPI
33  MPI_Comm_rank(MPI_COMM_WORLD, &m_rank);
34  MPI_Comm_size(MPI_COMM_WORLD, &m_numberOfProcessors);
35 #endif
36
37  if( m_rank != 0 )
38  {
39  //---
40  // Master process (rank 0) does not resample tiles so our process rank
41  // is 1 then we'll start at tile 0, rank 2 starts at 1, rank 3 starts
42  // at 2 and so on...
43  //---
45  }
46  else
47  {
49  }
50 }
51
53 {
54 }
55
57 {
58  return false;
59 }
60
62 {
64
66 }
67
69 {
70  if(m_rank != 0)
71  {
72  //---
73  // Subtract one since the masters job is just writing and not issue
74  // getTiles.
75  //---
77  }
78  else
79  {
80  // the master will start at 0
82  }
83 }
84
86 {
87 #if OSSIM_HAS_MPI
88
89  //---
90  // Bytes must be swapped to big endian (network byte order) if the scalar
91  // type is not 8 bit and the system byte order is little endian. We will
92  // use the endian pointer itself as a flag to swap.
93  //---
94  ossimEndian* endian = 0;
95  if (m_imageHandler.valid())
96  {
98  {
100  {
101  endian = new ossimEndian();
102  }
103  }
104  }
105
106  // Total number of tiles for all processes.
107  ossim_uint32 numberOfTiles = getNumberOfTiles();
108
109  int errorValue; // Needed for MPI_Isend and MPI_Wait.
110  MPI_Request request; // Needed for MPI_Isend and MPI_Wait.
111
112  while(m_currentTileNumber < numberOfTiles)
113  {
115
116  void* buf = data->getBuf();
117
118  // Data always sent in big endian byte order.
119  if (endian)
120  {
121  endian->swap(m_tile->getScalarType(), buf, m_tile->getSize());
122  }
123
124  // Send the buffer to the master process.
125  request = MPI_REQUEST_NULL;
126  errorValue = MPI_Isend(buf,
127  data->getSizeInBytes(),
128  MPI_UNSIGNED_CHAR,
129  0,
130  0,
131  MPI_COMM_WORLD,
132  &request);
133
134  //---
135  // Wait for send to complete before we overwrite the buffer with the
136  // next tile.
137  //---
138  errorValue = MPI_Wait(&request, MPI_STATUS_IGNORE);
139
140  //---
141  // If we have eight processes only seven are used for resampling tiles,
142  // so we would process every seventh tile.
143  //
144  // The call to getNextTile has already incremented m_currentTileNumber
145  // by one so adjust accordingly.
146  //---
147  if (m_numberOfProcessors>2)
148  {
150  }
151
152  } // End of while loop through number of tiles.
153
154  // cleanup...
155  if (endian)
156  {
157  delete endian;
158  endian = 0;
159  }
160
161 #endif /* End of #if OSSIM_HAS_MPI */
162
163 }
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimImageData > m_tile
ossimRefPtr< ossimImageHandler > m_imageHandler
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
ossim_uint32 getNumberOfTiles() const
virtual void initialize()
This must be called.
virtual ossim_uint32 getSizeInBytes() const
Returns the total number of bytes for all bands.
unsigned int ossim_uint32
virtual void slaveProcessTiles()
This is a trigger to start resampling tiles.
virtual ossimRefPtr< ossimImageData > getNextTile()
Will allow you to get the next tile in the sequence.
virtual ~ossimMpiSlaveOverviewSequencer()
virtual destructor
virtual ossim_uint32 getSize() const
Returns the total number of pixels in a tile for all bands.
8 bit unsigned integer
virtual void setToStartOfSequence()
Will set the internal pointers to the upperleft tile number.
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
