ossimQuickbirdMetaData.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Description:
8 //
9 // Class definition for ossimQuickbirdMetaData.
10 //
11 // This class parses a Space Imaging Quickbird meta data file.
12 //
13 //********************************************************************
14 // $Id: ossimQuickbirdMetaData.cpp 14431 2009-04-30 21:58:33Z dburken $
15
17 #include <ossim/base/ossimDpt.h>
19 #include <ossim/base/ossimNotify.h>
21 #include <ossim/base/ossimString.h>
22 #include <ossim/base/ossimTrace.h>
23 #include <cstdio>
24 #include <iostream>
25
26 RTTI_DEF1(ossimQuickbirdMetaData, "ossimQuickbirdMetaData", ossimObject);
27
28 // Define Trace flags for use within this file:
29 static ossimTrace traceExec ("ossimQuickbirdMetaData:exec");
30 static ossimTrace traceDebug ("ossimQuickbirdMetaData:debug");
31
33  :
34  theGenerationDate("Unknown"),
35  theBandId("Unknown"),
36  theBitsPerPixel(0),
37  theSatID("Unknown"),
38  theTLCDate("Unknown"),
39  theSunAzimuth(0.0),
40  theSunElevation(0.0),
41  theSatAzimuth(0.0),
42  theSatElevation(0.0),
43  theTDILevel(0),
44  theAbsCalFactors(),
45  theBandNameList("Unknown"),
46  theImageSize()
47 {
49  theAbsCalFactors.clear();
50 }
51
53 {
54 }
55
57 {
58  static const char MODULE[] = "ossimQuickbirdMetaData::open";
59
60  clearFields();
61
62  //retrieve information from the metadata file
63  //if the Quickbird tif is 02APR01105228-M1BS-000000128955_01_P001.TIF
64  //the metadata file will be 02APR01105228-M1BS-000000128955_01_P001.IMD
65
66  ossimFilename metadatafile = imageFile;
67  metadatafile.setExtension(ossimString("IMD"));
68
69  if( parseMetaData(metadatafile) == false )
70  {
71  if(traceDebug())
72  {
74  << MODULE << " errors parsing metadata" << std::endl;
75  }
76  return false;
77  }
78
79  return true;
80 }
81
83 {
84  theGenerationDate = "Unknown";
85  theBitsPerPixel = 0;
86  theBandId = "Unknown";
87  theSatID = "Unknown";
88  theTLCDate = "Unknown";
89  theSunAzimuth = 0.0;
90  theSunElevation = 0.0;
91  theSatAzimuth = 0.0;
92  theSatElevation = 0.0;
93  theTDILevel = 0;
94  theAbsCalFactors.clear();
95  theBandNameList = "Unknown";
97 }
98
100 {
101
102  out << "\n----------------- Info on Quickbird Image -------------------"
103  << "\n "
104  << "\n Generation date: " << theGenerationDate
105  << "\n Band Id: " << theBandId
106  << "\n Bits per pixel: " << theBitsPerPixel
107  << "\n Sat Id: " << theSatID
108  << "\n TLC date: " << theTLCDate
109  << "\n Sun Azimuth: " << theSunAzimuth
110  << "\n Sun Elevation: " << theSunElevation
111  << "\n Sat Azimuth: " << theSatAzimuth
112  << "\n Sat Elevation: " << theSatElevation
113  << "\n Band name list: " << theBandNameList
114  << "\n TDI Level: " << theTDILevel
115  << "\n abs Calibration Factors: "
116  << std::endl;
117  for(unsigned int i=0; i<theAbsCalFactors.size(); i++)
118  {
119  out<<theAbsCalFactors[i] << " ";
120  }
121  out << "\n Image Size: " << theImageSize
122  << "\n"
123  << "\n---------------------------------------------------------"
124  << "\n " << std::endl;
125  return out;
126 }
127
129  const char* prefix)const
130 {
131  kwl.add(prefix,
133  "ossimQuickbirdMetaData",
134  true);
135
136  kwl.add(prefix,
137  "generation_date",
139  true);
140
141  kwl.add(prefix,
142  "bits_per_pixel",
144  true);
145
146  kwl.add(prefix,
147  "band_id",
148  theBandId,
149  true);
150
151  kwl.add(prefix,
152  "sat_id",
153  theSatID,
154  true);
155
156  kwl.add(prefix,
157  "tlc_date",
158  theTLCDate,
159  true);
160
161  kwl.add(prefix,
164  true);
165
166  kwl.add(prefix,
169  true);
170
171  kwl.add(prefix,
172  "sat_azimuth_angle",
174  true);
175
176  kwl.add(prefix,
177  "sat_elevation_angle",
179  true);
180
181  kwl.add(prefix,
182  "TDI_level",
183  theTDILevel,
184  true);
185  kwl.add(prefix,
186  "band_name_list",
188  true);
189
190  if( theBandId=="Multi" )
191  {
192  std::vector<ossimString> bandNameList = theBandNameList.split(" ");
193  for(unsigned int i = 0 ; i < bandNameList.size(); ++i)
194  {
195  kwl.add(prefix,
196  bandNameList[i] + "_band_absCalFactor",
197  theAbsCalFactors[i],
198  true);
199
200  }
201  }
202  else if(!theAbsCalFactors.empty())
203  {
204  kwl.add(prefix,
205  "absCalFactor",
206  theAbsCalFactors[0],
207  true);
208  }
209
210  return true;
211 }
212
214  const char* prefix)
215 {
216  clearFields();
217
218  const char* lookup = 0;
219  ossimString s;
220
221  lookup = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
222  if (lookup)
223  {
224  s = lookup;
225  if(s != "ossimQuickbirdMetaData")
226  {
227  return false;
228  }
229  }
230
231  lookup = kwl.find(prefix, "generation_date");
232  if (lookup)
233  {
234  theGenerationDate = lookup;
235  }
236
237  lookup = kwl.find(prefix, "band_id");
238  if (lookup)
239  {
240  theBandId = lookup;
241  }
242
243  lookup = kwl.find(prefix, "bits_per_pixel");
244  if (lookup)
245  {
246  s = lookup;
247  theBitsPerPixel = s.toInt();;
248  }
249
250  lookup = kwl.find(prefix, "sat_id");
251  if (lookup)
252  {
253  theSatID = lookup;
254  }
255
256  lookup = kwl.find(prefix, "tlc_date");
257  if (lookup)
258  {
259  theTLCDate= lookup;
260  }
261
262  lookup = kwl.find(prefix, "TDI_level");
263  if (lookup)
264  {
265  s = lookup;
266  theTDILevel = s.toInt();
267  }
268
269  lookup = kwl.find(prefix, ossimKeywordNames::AZIMUTH_ANGLE_KW);
270  if (lookup)
271  {
272  s = lookup;
273  theSunAzimuth = s.toFloat64();
274  }
275
276  lookup = kwl.find(prefix, ossimKeywordNames::ELEVATION_ANGLE_KW);
277  if (lookup)
278  {
279  s = lookup;
281  }
282
283  lookup = kwl.find(prefix, "sat_azimuth_angle");
284  if (lookup)
285  {
286  s = lookup;
287  theSatAzimuth = s.toFloat64();
288  }
289
290  lookup = kwl.find(prefix, "sat_elevation_angle");
291  if (lookup)
292  {
293  s = lookup;
295  }
296
297  lookup = kwl.find(prefix, "band_name_list");
298  if (lookup)
299  {
300  theBandNameList= lookup;
301  }
302
303  if(theBandId=="Multi")
304  {
305  std::vector<ossimString> bandNameList = theBandNameList.split(" ");
306  theAbsCalFactors = std::vector<double>(bandNameList.size(), 1.);
307  for(unsigned int i = 0 ; i < bandNameList.size() ; ++i)
308  {
309  lookup = kwl.find(prefix, bandNameList[i] + "_band_absCalFactor");
310  if (lookup)
311  {
312  s = lookup;
313  theAbsCalFactors[i] = s.toDouble();
314  }
315  }
316  }
317  else if (theBandId=="P")
318  {
319  theAbsCalFactors = std::vector<double>(1, 1.);
320  lookup = kwl.find(prefix, "absCalFactor");
321  if (lookup)
322  {
323  s = lookup;
324  theAbsCalFactors[0] = s.toDouble();
325  }
326  }
327  return true;
328 }
329
330 //*****************************************************************************
331 // PROTECTED METHOD: ossimQuickbirdMetaData::parseMetaData()
332 //
333 // Parses the Quickbird IMD file.
334 //
335 //*****************************************************************************
337 {
338  if (traceExec()) ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG ossimQuickbirdMetaData::parseMetaData(data_file): entering..." << std::endl;
339
340  if( !data_file.exists() )
341  {
342  if (traceExec()) ossimNotify(ossimNotifyLevel_WARN) << "ossimQuickbirdMetaData::parseMetaData(data_file) WARN:" << "\nmetadate data file <" << data_file << ">. " << "doesn't exist..." << std::endl;
343  return false;
344  }
345
346
347  FILE* fptr = fopen (data_file, "r");
348  if (!fptr)
349  {
350  if (traceDebug())
351  {
353  << "ossimQuickbirdRpcModel::parseMetaData(data_file) DEBUG:"
354  << "\nCould not open Meta data file: " << data_file
355  << "\nreturning with error..." << std::endl;
356  }
357  return false;
358  }
359
360  char* strptr(NULL);
361
362  //---
363  // Read the file into a buffer:
364  //---
365  ossim_int32 fileSize = static_cast<ossim_int32>(data_file.fileSize());
366  char* filebuf = new char[fileSize];
367  fread(filebuf, 1, fileSize, fptr);
368  strptr = filebuf;
369  fclose(fptr);
370  ossimString temp;
371
372  //---
373  // Generation time:
374  //---
375
376  if(getEndOfLine( strptr, ossimString("\ngenerationTime ="), "%17c %s", temp))
377  theGenerationDate = ossimString(temp).before(";");
378  else
379  {
380  if(traceDebug())
381  {
383  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
384  << "\n\tAborting construction. Error encountered parsing "
385  << "presumed meta-data file." << std::endl;
386
387  delete [] filebuf;
388  return false;
389  }
390  }
391
392  // Number of rows and columns in full image:
393  if(getEndOfLine( strptr, ossimString("\nnumRows ="), "%10c %s", temp))
394  theImageSize.line = ossimString(temp).before("\";").toInt();
395
396  if(getEndOfLine( strptr, ossimString("\nnumColumns ="), "%13c %s", temp))
397  theImageSize.samp = ossimString(temp).before("\";").toInt();
398
399  //---
400  // BandId:
401  //---
402  if(getEndOfLine( strptr, ossimString("\nbandId ="), "%9c %s", temp))
403  theBandId = ossimString(temp).after("\"").before("\";");
404  else
405  {
406  if(traceDebug())
407  {
409  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
410  << "\n\tAborting construction. Error encountered parsing "
411  << "presumed meta-data file." << std::endl;
412
413  delete [] filebuf;
414  return false;
415  }
416  }
417
418
419  //---
420  // BitsPerPixel:
421  //---
422  if(getEndOfLine( strptr, ossimString("\nbitsPerPixel = "), "%16c %s", temp))
423  theBitsPerPixel = ossimString(temp).before(";").toInt();
424  else
425  {
426  if(traceDebug())
427  {
429  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
430  << "\n\tAborting construction. Error encountered parsing "
431  << "presumed meta-data file." << std::endl;
432
433  delete [] filebuf;
434  return false;
435  }
436  }
437
438  //---
439  // absCalFactors:
440  //---
441
442  char *iter = (char *)filebuf;
443  unsigned int nbBand = 0;
444  theBandNameList = "";
445  for(iter = strstr(iter, "BEGIN_GROUP = BAND_"); iter ; iter = strstr(iter, "BEGIN_GROUP = BAND_"))
446  {
447  ++nbBand;
448  char dummy[80], nameChar[80];
449  sscanf(iter, "%19c %s", dummy, nameChar);
450  ossimString bandCur = ossimString(nameChar).before("\n");
451  theBandNameList = theBandNameList + bandCur + " ";
452  ++iter;
453  }
455
456  //--- Multispectral
457  if(theBandId=="Multi")
458  {
459  std::vector<ossimString> bandList;
460  bandList = theBandNameList.split(" ");
461  theAbsCalFactors = std::vector<double>(bandList.size(), 1.);
462  for(unsigned int j=0; j<bandList.size(); j++)
463  {
464  ossimString begin_group = "BEGIN_GROUP = BAND_" + bandList[j];
465  strptr = strstr(filebuf, begin_group.c_str());
466  if(!strptr && traceDebug())
467  {
469  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
470  << "\n\tAborting construction. Error encountered parsing "
471  << "presumed meta-data file." << std::endl;
472  delete [] filebuf;
473  return false;
474  }
475  else
476  {
477  char dummy[80], nameChar[80];
478  sscanf(strptr, "%19c %s", dummy, nameChar);
479  ossimString bandCur = ossimString(nameChar).before("\n");
480  if(!strptr && traceDebug())
481  {
483  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
484  << "\n\tAborting construction. Error encountered parsing "
485  << "presumed meta-data file." << std::endl;
486  delete [] filebuf;
487  return false;
488  }
489  else
490  {
491  if(bandList[j] == bandCur)
492  {
493  strptr = strstr(strptr, "\tabsCalFactor = ");
494  sscanf(strptr, "%16c %s", dummy, nameChar);
495  theAbsCalFactors[j] = ossimString(nameChar).before(";").toDouble();
496  }
497  }
498  }
499  }
500  }
501  //--- Panchromatic
502  else
503  {
504  theAbsCalFactors = std::vector<double>(1, 1.);
505  if(getEndOfLine( strptr, ossimString("\tabsCalFactor = "), "%16c %s", temp))
506  theAbsCalFactors[0] = ossimString(temp).before(";").toDouble();
507  else
508  {
509  if(traceDebug())
510  {
512  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
513  << "\n\tAborting construction. Error encountered parsing "
514  << "presumed meta-data file." << std::endl;
515
516  delete [] filebuf;
517  return false;
518  }
519  }
520  }
521
522  //---
523  // SatID:
524  //---
525  if(getEndOfLine( strptr, ossimString("\n\tsatId ="), "%9c %s", temp))
526  theSatID = ossimString(temp).after("\"").before("\";");
527  else
528  {
529  if(traceDebug())
530  {
532  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
533  << "\n\tAborting construction. Error encountered parsing "
534  << "presumed meta-data file." << std::endl;
535
536  delete [] filebuf;
537  return false;
538  }
539  }
540
541  //---
542  // TLCTime:
543  //---
544  if(getEndOfLine( strptr, ossimString("\n\tTLCTime ="), "%11c %s", temp))
545  theTLCDate = ossimString(temp).before("\";");
546  else
547  {
548  if(getEndOfLine( strptr, ossimString("\n\tfirstLineTime ="), "%17c %s", temp))
549  theTLCDate = ossimString(temp).before("\";");
550  else
551  {
552  if(traceDebug())
553  {
555  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
556  << "\n\tAborting construction. Error encountered parsing "
557  << "presumed meta-data file." << std::endl;
558  delete [] filebuf;
559  return false;
560  }
561  }
562  }
563
564  //---
565  // Sun Azimuth:
566  //---
567  if(getEndOfLine( strptr, ossimString("\n\tsunAz ="), "%9c %s", temp))
568  theSunAzimuth = ossimString(temp).before(";").toFloat64();
569  else
570  {
571  if(getEndOfLine( strptr, ossimString("\n\tmeanSunAz ="), "%13c %s", temp))
572  theSunAzimuth = ossimString(temp).before(";").toFloat64();
573  else
574  {
575  if(traceDebug())
576  {
578  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
579  << "\n\tAborting construction. Error encountered parsing "
580  << "presumed meta-data file." << std::endl;
581
582  delete [] filebuf;
583  return false;
584  }
585  }
586  }
587
588  //---
589  // Sun Elevation:
590  //---
591  if(getEndOfLine( filebuf, ossimString("\n\tsunEl ="), "%9c %s", temp))
593  else
594  {
595  if(getEndOfLine( filebuf, ossimString("\n\tmeanSunEl ="), "%13c %s", temp))
597  else
598  {
599  if(traceDebug())
600  {
602  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
603  << "\n\tAborting construction. Error encountered parsing "
604  << "presumed meta-data file." << std::endl;
605
606  delete [] filebuf;
607  return false;
608  }
609  }
610  }
611
612  //---
613  // Sun Azimuth:
614  //---
615  if(getEndOfLine( strptr, ossimString("\n\tsunAz ="), "%9c %s", temp))
616  theSunAzimuth = ossimString(temp).before(";").toFloat64();
617  else
618  {
619  if(getEndOfLine( strptr, ossimString("\n\tmeanSunAz ="), "%13c %s", temp))
620  theSunAzimuth = ossimString(temp).before(";").toFloat64();
621  else
622  {
623  if(traceDebug())
624  {
626  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
627  << "\n\tAborting construction. Error encountered parsing "
628  << "presumed meta-data file." << std::endl;
629
630  delete [] filebuf;
631  return false;
632  }
633  }
634  }
635
636  //---
637  // Sun Elevation:
638  //---
639  if(getEndOfLine( filebuf, ossimString("\n\tsunEl ="), "%9c %s", temp))
641  else
642  {
643  if(getEndOfLine( filebuf, ossimString("\n\tmeanSunEl ="), "%13c %s", temp))
645  else
646  {
647  if(traceDebug())
648  {
650  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
651  << "\n\tAborting construction. Error encountered parsing "
652  << "presumed meta-data file." << std::endl;
653
654  delete [] filebuf;
655  return false;
656  }
657  }
658  }
659
660
661  //---
662  // Sat Azimuth:
663  //---
664  if(getEndOfLine( strptr, ossimString("\n\tsatAz ="), "%9c %s", temp))
665  theSatAzimuth = ossimString(temp).before(";").toFloat64();
666  else
667  {
668  if(getEndOfLine( strptr, ossimString("\n\tmeanSatAz ="), "%13c %s", temp))
669  theSatAzimuth = ossimString(temp).before(";").toFloat64();
670  else
671  {
672  if(traceDebug())
673  {
675  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
676  << "\n\tAborting construction. Error encountered parsing "
677  << "presumed meta-data file." << std::endl;
678
679  delete [] filebuf;
680  return false;
681  }
682  }
683  }
684
685  //---
686  // Sat Elevation:
687  //---
688  if(getEndOfLine( filebuf, ossimString("\n\tsatEl ="), "%9c %s", temp))
690  else
691  {
692  if(getEndOfLine( filebuf, ossimString("\n\tmeanSatEl ="), "%13c %s", temp))
694  else
695  {
696  if(traceDebug())
697  {
699  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
700  << "\n\tAborting construction. Error encountered parsing "
701  << "presumed meta-data file." << std::endl;
702
703  delete [] filebuf;
704  return false;
705  }
706  }
707  }
708
709
710  //---
711  // TDILevel:
712  //---
713  if(getEndOfLine( strptr, ossimString("\n\tTDILevel = "), "%13c %s", temp))
714  theTDILevel = ossimString(temp).before(";").toInt();
715  else
716  {
717  if(traceDebug())
718  {
720  << "FATAL ossimQuickbirdRpcModel::parseMetaData(data_file): "
721  << "\n\tAborting construction. Error encountered parsing "
722  << "presumed meta-data file." << std::endl;
723
724  delete [] filebuf;
725  return false;
726  }
727  }
728
729
730  delete [] filebuf;
731  filebuf = 0;
732
733  if (traceExec())
734  {
736  << "DEBUG ossimQuickbirdRpcModel::parseMetaData(data_file): returning..."
737  << std::endl;
738  }
739
740  return true;
741 }
742
743 //*****************************************************************************
744 // PROTECTED METHOD: ossimQuickbirdMetaData::parseGEOData()
745 //
746 // Parses the Quickbird GEO file.
747 //
748 //*****************************************************************************
750 {
751  return true;
752 }
753
754 //*****************************************************************************
755 // PROTECTED METHOD: ossimQuickbirdMetaData::parseRpcData()
756 //
757 // Parses the Quickbird EPH file.
758 //
759 //*****************************************************************************
761 {
762  return true;
763 }
764
765 //*****************************************************************************
766 // PROTECTED METHOD: ossimQuickbirdMetaData::parseRpcData()
767 //
768 // Parses the Quickbird ATT file.
769 //
770 //*****************************************************************************
772 {
773  return true;
774 }
775
777 {
778  return theSatID;
779 }
780
782  ossimKeywordlist& kwl )
783 {
784  static const char MODULE[] = "ossimQuickbirdMetaData::getMapProjectionKwl";
785  if(traceDebug())
786  {
787  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
788  }
789
790  bool result = false;
791
792  if( imd_file.exists() )
793  {
794  FILE* fptr = fopen (imd_file.c_str(), "r");
795  if (fptr)
796  {
797
798  char* strptr(NULL);
799
800  //---
801  // Read the file into a buffer:
802  //---
803  ossim_int32 fileSize = static_cast<ossim_int32>(imd_file.fileSize());
804  char* filebuf = new char[fileSize];
805  fread(filebuf, 1, fileSize, fptr);
806  strptr = filebuf;
807  fclose(fptr);
808  ossimString imd_key;
809  ossimString tempStr;
810  std::string key;
811  std::string value;
812
813
814  // Loop until we find all our keys or bust out with error.
815  while ( 1 )
816  {
817  // Verify map projected.
818  imd_key = "BEGIN_GROUP = MAP_PROJECTED_PRODUCT";
819  if ( strstr( filebuf, imd_key.c_str() ) == NULL )
820  {
821  break; // Not a map projected product.
822  }
823
824  // Get datum:
825  if( getEndOfLine( strptr, ossimString("\n\tdatumName = "), "%13c %s", tempStr) )
826  {
827  if ( tempStr.contains("WE") )
828  {
829  key = "dataum";
830  value = "WGE";
831  kwl.addPair(key, value);
832  }
833  else
834  {
835  if(traceDebug())
836  {
838  << "Unhandled datum: " << tempStr << "\n";
839  }
840  }
841  }
842
843  // Get projection:
844  if( getEndOfLine( strptr, ossimString("\n\tmapProjName = "), "%15c %s", tempStr) )
845  {
846  if ( tempStr.contains("UTM") )
847  {
848  key = "type";
849  value = "ossimUtmProjection";
850  kwl.addPair(key, value);
851  }
852  else
853  {
854  if(traceDebug())
855  {
857  << "Unhandled projection name: " << tempStr << "\n";
858  }
859  }
860  }
861
862  // Get projection:
863  if( getEndOfLine( strptr, ossimString("\n\tmapProjName = "), "%15c %s", tempStr) )
864  {
865  if ( tempStr.contains("UTM") )
866  {
867  key = "type";
868  value = "ossimUtmProjection";
869  kwl.addPair(key, value);
870
871  // Get UTM zone:
872  if( getEndOfLine( strptr, ossimString("\n\tmapZone = "), "%11c %s", tempStr) )
873  {
874  key = "zone";
875  value = tempStr.trim(";").string();
876  kwl.addPair(key, value);
877  }
878  else
879  {
880  break;
881  }
882
883  // Get UTM hemisphere:
884  if( getEndOfLine( strptr, ossimString("\n\tmapHemi = "), "%11c %s", tempStr) )
885  {
886  key = "hemisphere";
887  tempStr = tempStr.trim(";");
888  tempStr = tempStr.trim("\"");
889  value = tempStr.string();
890  kwl.addPair(key, value);
891  }
892  else
893  {
894  break;
895  }
896
897  } // End UTM:
898  }
899
900  // Get projection units:
901  std::string units;
902  if( getEndOfLine( strptr, ossimString("\n\tproductUnits = "), "%16c %s", tempStr) )
903  {
904  if ( tempStr == "\"M\";" )
905  {
906  key = "units";
907  units = "meters";
908  kwl.addPair(key, units);
909  }
910  else
911  {
912  if(traceDebug())
913  {
915  << "Unhandled units: " << tempStr << "\n";
916  }
917  }
918  }
919
920  // Get projection tie point:
921  ossimDpt dpt;
922  dpt.makeNan();
923  if( getEndOfLine( strptr, ossimString("\n\toriginX = "), "%11c %s", tempStr) )
924  {
925  tempStr = tempStr.trim(";");
926  dpt.x = tempStr.toFloat64();
927  }
928  else
929  {
930  break;
931  }
932  if( getEndOfLine( strptr, ossimString("\n\toriginY = "), "%11c %s", tempStr) )
933  {
934  tempStr = tempStr.trim(";");
935  dpt.y = tempStr.toFloat64();
936  }
937  else
938  {
939  break;
940  }
941  if ( dpt.hasNans() == false )
942  {
943  key = "tie_point_units";
944  kwl.addPair(key, units);
945
946  key = "tie_point_xy";
947  value = dpt.toString().string();
948  kwl.addPair( key, value );
949  }
950  else
951  {
952  if(traceDebug())
953  {
955  << "tie point has nans!";
956  }
957  break;
958  }
959
960  // Get projection scale:
961  dpt.makeNan();
962  if( getEndOfLine( strptr, ossimString("\n\tcolSpacing = "), "%14c %s", tempStr) )
963  {
964  tempStr = tempStr.trim(";");
965  dpt.x = tempStr.toFloat64();
966  }
967  else
968  {
969  break;
970  }
971  if( getEndOfLine( strptr, ossimString("\n\trowSpacing = "), "%14c %s", tempStr) )
972  {
973  tempStr = tempStr.trim(";");
974  dpt.y = tempStr.toFloat64();
975  }
976  else
977  {
978  break;
979  }
980
981  if ( dpt.hasNans() == false )
982  {
983  key = "pixel_scale_units";
984  kwl.addPair(key, units);
985
986  key = "pixel_scale_xy";
987  value = dpt.toString().string();
988  kwl.addPair( key, value );
989  }
990  else
991  {
992  if(traceDebug())
993  {
995  << "scale has nans!";
996  }
997  break;
998  }
999
1000  //---
1001  // End of key look up. If we get here set the status to true and
1002  // bust out of loop.
1003  //---
1004  result = true;
1005  break;
1006  }
1007
1008  if ( result == false )
1009  {
1010  if(traceDebug())
1011  {
1013  << "ERROR: Missing or unhandled key in metadat: " << imd_key << "\n";
1014  }
1015  }
1016
1017  delete [] filebuf;
1018  filebuf = 0;
1019  }
1020  else
1021  {
1022  if (traceDebug())
1023  {
1025  << "ossimQuickbirdRpcModel::parseMetaData(imd_file) DEBUG:"
1026  << "\nCould not open Meta data file: " << imd_file
1027  << "\nreturning with error...\n";
1028  }
1029  }
1030  }
1031
1032  if(traceDebug())
1033  {
1035  << MODULE << " exit status = " << (result?"true":"false") << "\n";
1036  }
1037
1038  return result;
1039 }
1040
1041 //*****************************************************************************
1042 // PROTECTED METHOD: ossimQuickbirdMetaData::getEndOfLine
1043 //
1044 // // Parse a char * to find another char *. Change the pointer only if the second char * is found.
1045 //
1046 //*****************************************************************************
1048  ossimString lineBeginning,
1049  const char * format,
1050  ossimString & name)
1051 {
1052  //char * res = strstr(fileBuf, lineBeginning.c_str());
1053  //if (!res)
1054  //{
1055  // return false;
1056  // }
1058  //fileBuf = res;
1059
1060  //char dummy[80], nameChar[80];
1061  //sscanf(res, format, dummy, nameChar);
1062  //name = ossimString(nameChar);
1063
1064  char * res = strstr(fileBuf, lineBeginning.c_str());
1065  if(!res)
1066  {
1067  return false;
1068  }
1069  fileBuf = strstr(fileBuf, lineBeginning.c_str());
1070  char dummy[80], nameChar[80];
1071  sscanf(fileBuf, format, dummy, nameChar);
1072  name = ossimString(nameChar);
1073
1074  return true;
1075 }
1076
1078 {
1079  return theImageSize;
1080 }
ossimString before(const ossimString &str, std::string::size_type pos=0) const
METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If strin...
void makeNan()
Definition: ossimIpt.h:56
std::basic_filebuf< char > filebuf
Class for char file buffers.
Definition: ossimIosFwd.h:41
Method to the load (recreate) the state of the object from a keyword list.
ossim_int64 fileSize() const
bool parseATTData(const ossimFilename &data_file)
bool parseGEOData(const ossimFilename &data_file)
Method to parse Quickbird rpc file.
double y
Definition: ossimDpt.h:165
bool contains(char aChar) const
Definition: ossimString.h:58
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
std::vector< double > theAbsCalFactors
bool getMapProjectionKwl(const ossimFilename &imd_file, ossimKeywordlist &kwl)
static const char * TYPE_KW
virtual ~ossimQuickbirdMetaData()
virtual destructor
bool exists() const
Method to save the state of the object to a keyword list.
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
double toDouble() const
ossim_float64 toFloat64() const
static const char * AZIMUTH_ANGLE_KW
bool hasNans() const
Definition: ossimDpt.h:67
bool parseMetaData(const ossimFilename &metadata)
Method to parse Quickbird metadata file.
default constructor
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimDpt.cpp:160
ossim_int32 samp
Definition: ossimIpt.h:141
bool parseEPHData(const ossimFilename &data_file)
double x
Definition: ossimDpt.h:164
bool open(const ossimFilename &imageFile)
Open method that takes the image file, derives the metadata, header and rpc files, then calls parse methods parseMetaData, parseHdrData, and parseRpcData.
const char * c_str() const
Definition: ossimString.h:396
const ossimIpt & getImageSize() const
ossim_int32 line
Definition: ossimIpt.h:142
static const char * ELEVATION_ANGLE_KW
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
bool getEndOfLine(char *fileBuf, ossimString lineBeginning, const char *format, ossimString &name)
int toInt() const
void makeNan()
Definition: ossimDpt.h:65
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
int ossim_int32
const std::string & string() const
Definition: ossimString.h:414
Generic print method.
