ossimRgbToGreyFilter.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2000 ImageLinks Inc.
3 //
4 // License: LGPL
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: Garrett Potts
9 //
10 //*************************************************************************
11 // $Id: ossimRgbToGreyFilter.cpp 19223 2011-03-24 13:38:21Z dburken $
12
16 #include <ossim/base/ossimCommon.h>
18
20
22  :ossimImageSourceFilter(owner),
23  theBlankTile(NULL),
24  theTile(NULL),
25  theC1(1.0/3.0),
26  theC2(1.0/3.0),
27  theC3(1.0/3.0)
28 {
29 }
30
32  double c1,
33  double c2,
34  double c3)
35  : ossimImageSourceFilter(NULL, inputSource),
36  theBlankTile(NULL),
37  theTile(NULL),
38  theC1(c1),
39  theC2(c2),
40  theC3(c3)
41 {
42 }
43
45  ossimImageSource* inputSource,
46  double c1,
47  double c2,
48  double c3)
49  : ossimImageSourceFilter(owner, inputSource),
50  theBlankTile(NULL),
51  theTile(NULL),
52  theC1(c1),
53  theC2(c2),
54  theC3(c3)
55 {
56 }
58 {
59 }
60
62  ossim_uint32 resLevel)
63 {
65  {
66  return NULL; // This filter requires an input.
67  }
68
70  resLevel);
71  if(!isSourceEnabled() || !inputTile.valid())
72  {
73  return inputTile;
74  }
75
76  if(!theTile)
77  {
78  allocate(); // First time through...
79  }
80
81  // if (!theTile) // throw exeption...
82
83  if( inputTile->getDataObjectStatus() == OSSIM_NULL ||
84  inputTile->getDataObjectStatus() == OSSIM_EMPTY )
85  {
87  return theBlankTile;
88  }
89
90  // Set the origin, resize if needed of the output tile.
91  theTile->setImageRectangle(tileRect);
92
93  // Filter the tile.
94  runUcharTransformation(inputTile);
95
96  // Always validate to set the status.
97  theTile->validate();
98
99  return theTile;
100 }
101
102
104 {
105  // Base class will recapture "theInputConnection".
107 }
108
110 {
112  {
113  theTile = NULL;
114  theBlankTile = NULL;
115
116  if(isSourceEnabled())
117  {
118  theBlankTile = new ossimU8ImageData(this,
119  1,
122
123
125  theTile->initialize();
126  }
127  }
128 }
129
131 {
132  if(isSourceEnabled())
133  {
134  return 1;
135  }
136
138 }
139
141  const char* prefix)const
142 {
144
145  kwl.add(prefix,
146  "c1",
147  theC1,
148  true);
149  kwl.add(prefix,
150  "c2",
151  theC2,
152  true);
153  kwl.add(prefix,
154  "c3",
155  theC2,
156  true);
157
158  return true;
159 }
160
162  const char* prefix)
163 {
165
166  const char* lookup = kwl.find(prefix, "c1");
167  if(lookup)
168  {
169  theC1 = ossimString(lookup).toDouble();
170  }
171  lookup = kwl.find(prefix, "c2");
172  if(lookup)
173  {
174  theC2 = ossimString(lookup).toDouble();
175  }
176  lookup = kwl.find(prefix, "c3");
177  if(lookup)
178  {
179  theC3 = ossimString(lookup).toDouble();
180  }
181  return true;
182 }
183
185 {
186  unsigned char** bandSrc = new unsigned char*[tile->getNumberOfBands()];
187  unsigned char* bandDest;
188
189  if(tile->getNumberOfBands() == 1)
190  {
191  bandSrc[0] = static_cast<unsigned char*>(tile->getBuf(0));
192  bandSrc[1] = static_cast<unsigned char*>(tile->getBuf(0));
193  bandSrc[2] = static_cast<unsigned char*>(tile->getBuf(0));
194  }
195  else if(tile->getNumberOfBands() == 2)
196  {
197  bandSrc[0] = static_cast<unsigned char*>(tile->getBuf(0));
198  bandSrc[1] = static_cast<unsigned char*>(tile->getBuf(1));
199  bandSrc[2] = static_cast<unsigned char*>(tile->getBuf(1));
200  }
201  else if(tile->getNumberOfBands() >= 3)
202  {
203  bandSrc[0] = static_cast<unsigned char*>(tile->getBuf(0));
204  bandSrc[1] = static_cast<unsigned char*>(tile->getBuf(1));
205  bandSrc[2] = static_cast<unsigned char*>(tile->getBuf(2));
206  }
207  bandDest = static_cast<unsigned char*>(theTile->getBuf());
208
209  ossim_int32 offset;
210
211  ossim_int32 upperBound = tile->getWidth()*tile->getHeight();
212  for(offset = 0; offset < upperBound; ++offset)
213  {
214  ossim_int32 value;
215
216  value = ossim::round<int>(theC1*(bandSrc[0][offset]) +
217  theC2*(bandSrc[1][offset]) +
218  theC3*(bandSrc[2][offset]));
219
220  value = value<255?value:255;
221  value = value>0?value:0;
222
223  bandDest[offset] = value;
224  }
225
226  delete [] bandSrc;
227 }
228
230 {
231  return ossimString("grey");
232 }
233
235 {
236  return ossimString("rgb to grey scale filter");
237 }
238
240 {
241  if(isSourceEnabled())
242  {
243  return OSSIM_UCHAR;
244  }
245
247 }
ossimRgbToGreyFilter(ossimObject *owner=NULL)
ossimRefPtr< ossimImageData > theBlankTile
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
void runUcharTransformation(ossimRefPtr< ossimImageData > &tile)
virtual void initialize()
Initialize the data buffer.
ossim_uint32 getNumberOfOutputBands() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual ossimObject * dup() const
unsigned int ossim_uint32
double toDouble() const
void allocate()
Called on first getTile, will initialize all data needed.
ossimScalarType
virtual ossimString getLongName() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
virtual ossimString getShortName() const
8 bit unsigned iteger
int ossim_int32
