14 static std::string IID_KW =
"iid";
15 static std::string EDITION_KW =
"edition";
17 static std::string RSN_KW =
"rsn";
18 static std::string CSN_KW =
"csn";
20 static std::string RFEP_KW =
"rfep";
21 static std::string CFEP_KW =
"cfep";
23 static std::string RNRMO_KW =
"rnrmo";
24 static std::string CNRMO_KW =
"cnrmo";
25 static std::string XNRMO_KW =
"xnrmo";
26 static std::string YNRMO_KW =
"ynrmo";
27 static std::string ZNRMO_KW =
"znrmo";
29 static std::string RNRMSF_KW =
"rnrmsf";
30 static std::string CNRMSF_KW =
"cnrmsf";
31 static std::string XNRMSF_KW =
"xnrmsf";
32 static std::string YNRMSF_KW =
"ynrmsf";
33 static std::string ZNRMSF_KW =
"znrmsf";
35 static std::string RNPWRX_KW =
"rnpwrx";
36 static std::string RNPWRY_KW =
"rnpwry";
37 static std::string RNPWRZ_KW =
"rnpwrz";
38 static std::string RNTRMS_KW =
"rntrms";
40 static std::string RNPCF_KW =
"rnpcf";
42 static std::string RDPWRX_KW =
"rdpwrx";
43 static std::string RDPWRY_KW =
"rdpwry";
44 static std::string RDPWRZ_KW =
"rdpwrz";
45 static std::string RDTRMS_KW =
"rdtrms";
47 static std::string RDPCF_KW =
"rdpcf";
49 static std::string CNPWRX_KW =
"cnpwrx";
50 static std::string CNPWRY_KW =
"cnpwry";
51 static std::string CNPWRZ_KW =
"cnpwrz";
52 static std::string CNTRMS_KW =
"cntrms";
54 static std::string CNPCF_KW =
"cnpcf";
56 static std::string CDPWRX_KW =
"cdpwrx";
57 static std::string CDPWRY_KW =
"cdpwry";
58 static std::string CDPWRZ_KW =
"cdpwrz";
59 static std::string CDTRMS_KW =
"cdtrms";
61 static std::string CDPCF_KW =
"cdpcf";
119 m_edition( obj.m_edition ),
124 m_rfep( obj.m_rfep ),
125 m_cfep( obj.m_cfep ),
127 m_rnrmo( obj.m_rnrmo ),
128 m_cnrmo( obj.m_cnrmo ),
129 m_xnrmo( obj.m_xnrmo ),
130 m_ynrmo( obj.m_ynrmo ),
131 m_znrmo( obj.m_znrmo ),
133 m_rnrmsf( obj.m_rnrmsf ),
134 m_cnrmsf( obj.m_cnrmsf ),
135 m_xnrmsf( obj.m_xnrmsf ),
136 m_ynrmsf( obj.m_ynrmsf ),
137 m_znrmsf( obj.m_znrmsf ),
139 m_rnpwrx( obj.m_rnpwrx ),
140 m_rnpwry( obj.m_rnpwry ),
141 m_rnpwrz( obj.m_rnpwrz ),
142 m_rntrms( obj.m_rntrms ),
144 m_rnpcf( obj.m_rnpcf ),
146 m_rdpwrx( obj.m_rdpwrx ),
147 m_rdpwry( obj.m_rdpwry ),
148 m_rdpwrz( obj.m_rdpwrz ),
149 m_rdtrms( obj.m_rdtrms ),
151 m_rdpcf( obj.m_rdpcf ),
153 m_cnpwrx( obj.m_cnpwrx ),
154 m_cnpwry( obj.m_cnpwry ),
155 m_cnpwrz( obj.m_cnpwrz ),
156 m_cntrms( obj.m_cntrms ),
158 m_cnpcf( obj.m_cnpcf ),
160 m_cdpwrx( obj.m_cdpwrx ),
161 m_cdpwry( obj.m_cdpwry ),
162 m_cdpwrz( obj.m_cdpwrz ),
163 m_cdtrms( obj.m_cdtrms ),
165 m_cdpcf( obj.m_cdpcf )
228 std::string pfx = prefix + std::string(
"rsmpca");
230 pfx += std::string(
232 kwl.
add( pfx.c_str(), IID_KW.c_str(),
m_iid.c_str() );
233 kwl.
add(pfx.c_str(), EDITION_KW.c_str(),
m_edition.c_str());
235 kwl.
add(pfx.c_str(), RSN_KW.c_str(),
m_rsn);
236 kwl.
add(pfx.c_str(), CSN_KW.c_str(),
m_csn);
238 kwl.
add(pfx.c_str(), RFEP_KW.c_str(),
m_rfep);
239 kwl.
add(pfx.c_str(), CFEP_KW.c_str(),
m_cfep);
241 kwl.
add(pfx.c_str(), RNRMO_KW.c_str(),
m_rnrmo);
242 kwl.
add(pfx.c_str(), CNRMO_KW.c_str(),
m_cnrmo);
243 kwl.
add(pfx.c_str(), XNRMO_KW.c_str(),
m_xnrmo);
244 kwl.
add(pfx.c_str(), YNRMO_KW.c_str(),
m_ynrmo);
245 kwl.
add(pfx.c_str(), ZNRMO_KW.c_str(),
m_znrmo);
261 key = RNPCF_KW.c_str();
275 key = RDPCF_KW.c_str();
288 key = CNPCF_KW.c_str();
301 key = CDPCF_KW.c_str();
311 const std::string& prefix,
314 std::string pfx = prefix + std::string(
"rsmpca");
316 pfx += std::string(
326 value = kwl.
findKey( pfx, key );
337 value = kwl.
540 bool keysParsed =
true;
553 if ( keysParsed ==
false )
598 bool keysParsed =
true;
611 if ( keysParsed ==
false )
656 bool keysParsed =
true;
669 if ( keysParsed ==
false )
718 bool keysParsed =
true;
731 if ( keysParsed ==
false )
749 if ( result ==
false )
753 <<
"ossimRsmpca::loadState WARNING:\n" 754 <<
"Error encountered parsing the following required keyword: " 755 <<
"<" << key <<
">. Check the keywordlist for proper syntax." const ossimRsmpca & operator=(const ossimRsmpca &rhs)
assignment operator
ossimString getRnrmo() const
ossimString getCnpwrz() const
ossimString getCnrmo() const
ossimString getZnrmsf() const
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
ossimString getRnpwrx() const
ossimString getCfep() const
ossimString getRsn() const
ossimString getXnrmsf() const
Numeric to string methods.
ossimString getCdpwry() const
ossimString getRnpwry() const
ossimString getCdtrms() const
bool loadState(const ossimKeywordlist &kwl, const std::string &prefix, ossim_uint32 index)
loadState Loads state from keyword list.
ossim_uint32 toUInt32() const
ossimString getCnpcf(ossim_uint32 index) const
ossimString getYnrmo() const
std::vector< ossim_float64 > m_rnpcf
ossimString getRdpwrx() const
ossimString getZnrmo() const
ossimString getCsn() const
ossimString getRdpcf(ossim_uint32 index) const
std::vector< ossim_float64 > m_cnpcf
ossimString getCntrms() const
ossimString getEdition() const
bool initialize(const ossimNitfRsmpcaTag *rsmpcaTag)
initialize Initializes from nitf rsmpia tag.
std::vector< ossim_float64 > m_rdpcf
ossimString getRfep() const
ossimString getRnpcf(ossim_uint32 index) const
unsigned int ossim_uint32
ossimString getIid() const
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
ossim_float64 toFloat64() const
ossimString getCdpcf(ossim_uint32 index) const
ossimString getYnrmsf() const
ossimString getRnrmsf() const
ossimString getRdpwrz() const
ossimString getCnpwry() const
ossimString getRntrms() const
ossimString getXnrmo() const
ossimString getCdpwrx() const
ossimString getRdtrms() const
RSM Polynomial Coefficients: Polynomials coefficients for a section.
ossimString getCdpwrz() const
ossimString getCnrmsf() const
void saveState(ossimKeywordlist &kwl, const std::string &prefix, ossim_uint32 index) const
saveState Saves state to keyword list.
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
ossimString getRnpwrz() const
ossimString getRdpwry() const
std::vector< ossim_float64 > m_cdpcf
ossimRsmpca()
default constructor
ossimString getCnpwrx() const
const std::string & string() const
