ossimVpfTileSource.h
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 // Copyright (C) 2004 Garrett Potts, all rights reserved.
3 //
4 // License: MIT
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: Garrett Potts
9 //
10 // $Id: ossimVpfTileSource.h 17932 2010-08-19 20:34:35Z dburken $
11 //----------------------------------------------------------------------------
12 #ifndef ossimVpfTileSource_HEADER
13 #define ossimVpfTileSource_HEADER
14
17 #include <ossim/base/ossimRefPtr.h>
19
20
22  public ossimViewInterface
23 {
24 public:
25
27
28  virtual void close();
29
38  virtual bool open();
39
45  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& tileRect,
46  ossim_uint32 resLevel=0);
47
52  virtual ossim_uint32 getNumberOfInputBands() const;
53
59  virtual ossim_uint32 getNumberOfOutputBands() const;
60
65  virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level = 0) const;
66
71  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level = 0) const;
72
79
84  virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level = 0) const;
85
90  virtual bool saveState(ossimKeywordlist& kwl,
91  const char* prefix=0)const;
92
97  virtual bool loadState(const ossimKeywordlist& kwl,
98  const char* prefix);
99
102
106  virtual ossimScalarType getOutputScalarType() const;
107
111  virtual ossim_uint32 getTileWidth() const;
112
116  virtual ossim_uint32 getTileHeight() const;
117
124  virtual ossim_uint32 getImageTileWidth() const;
125
132  virtual ossim_uint32 getImageTileHeight() const;
133
134  virtual bool isOpen()const;
135
136  virtual double getNullPixelValue(ossim_uint32 band=0)const;
137
138  virtual double getMinPixelValue(ossim_uint32 band=0)const;
139
140  virtual double getMaxPixelValue(ossim_uint32 band=0)const;
141
142  virtual ossimObject* getView();
143
144  virtual const ossimObject* getView()const;
145
146  virtual bool setView(ossimObject* baseObject);
147
148  void getAllFeatures(std::vector<ossimVpfAnnotationFeatureInfo*>& featureList);
149
150  void setAllFeatures(std::vector<ossimVpfAnnotationFeatureInfo*>& featureList);
151
152  void transformObjects();
153
154  void computeBoundingRect();
155
156 protected:
157  virtual ~ossimVpfTileSource();
159
160
161 TYPE_DATA
162 };
163
164 #endif
virtual bool open()=0
Pure virtual open.
#define OSSIMDLLEXPORT
ossimRefPtr< ossimVpfAnnotationSource > m_AnnotationSource
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Returns the default processing tile height.
Returns the default processing tile width.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isOpen() const =0
Retuns the min pixel value.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
ossimScalarType
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual bool setView(ossimObject *baseObject)=0
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossimObject * getView()=0
virtual ossim_uint32 getNumberOfInputBands() const =0
