ossimWatermarkFilter.h
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 // Copyright (c) 2005, David Burken, all rights reserved.
3 //
4 // License: MIT
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: David Burken
9 //
10 // Description: Class declaration of ossimWatermarkFilter.
11 // Applies an image or watermark to image. Positioning is based on mode.
12 // Density is base on alpha weight.
13 //
14 //----------------------------------------------------------------------------
15 // $Id: ossimWatermarkFilter.h 16276 2010-01-06 01:54:47Z gpotts $
16 #ifndef ossimWatermarkFilter_HEADER
17 #define ossimWatermarkFilter_HEADER
18
20 #include <ossim/base/ossimString.h>
22 #include <ossim/base/ossimIrect.h>
24
32 {
33 public:
34
36  {
37  UPPER_LEFT = 0,
38  UPPER_CENTER = 1,
39  UPPER_RIGHT = 2,
40  CENTER = 3,
41  LOWER_LEFT = 4,
42  LOWER_CENTER = 5,
43  LOWER_RIGHT = 6,
44  UNIFORM_DENSE = 7,
45  UNIFORM_SPARSE = 8,
46  END = 9 //< Number of modes.
47  };
48
51
53  virtual ossimString getShortName() const;
54
56  virtual ossimString getLongName() const;
57
59  virtual ossimString getDescription() const;
60
74  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& tile_rect,
75  ossim_uint32 resLevel=0);
76
80  virtual void initialize();
81
94  virtual bool saveState(ossimKeywordlist& kwl,
95  const char* prefix=0)const;
96
116  virtual bool loadState(const ossimKeywordlist& kwl,
117  const char* prefix=0);
118
134  const ossimString& name)const;
135
142  virtual void setProperty(ossimRefPtr<ossimProperty> property);
143
152  virtual void getPropertyNames(std::vector<ossimString>& propertyNames)const;
153
159  void getModeList(vector<ossimString>& list) const;
160
162  ossimWatermarkFilter::WatermarkMode getMode() const;
163
165  ossimString getModeString() const;
166
172  void setFilename(const ossimFilename& file);
173
179  void setMode(const ossimString& mode);
180
187  void setWeight(ossim_float64 weight);
188
194  virtual std::ostream& print(std::ostream& out) const;
195
196 protected:
198  virtual ~ossimWatermarkFilter();
199
206  bool allocate();
207
215  bool openWatermarkFile();
216
217  // void verifyEnable();
218
223  template <class T> void fill(T dummy);
224
230  void getIntersectingRects(vector<ossimIrect>& rects);
231
238  void getUpperLeftRect(vector<ossimIrect>& rects);
239
246  void getUpperCenterRect(vector<ossimIrect>& rects);
247
254  void getUpperRightRect(vector<ossimIrect>& rects);
255
262  void getCenterRect(vector<ossimIrect>& rects);
263
270  void getLowerLeftRect(vector<ossimIrect>& rects);
271
278  void getLowerCenterRect(vector<ossimIrect>& rects);
279
286  void getLowerRightRect(vector<ossimIrect>& rects);
287
296  void getUniformDenseRects(vector<ossimIrect>& rects);
297
307  void getUniformSparceRects(vector<ossimIrect>& rects);
308
311
314
317
320
323
326
329
332
335
341
342
343 TYPE_DATA
344
345 }; // End of class ossimWatermarkFilter.
346
347 #endif /* #ifndef ossimWatermarkFilter_HEADER */
#define OSSIMDLLEXPORT
ossimScalarType theInputScalarType
The input scalar type.
Definition: ossimObject.cpp:48
WatermarkMode theMode
The filter mode.
double ossim_float64
ossim_uint32 theInputNumberOfBands
The number of input bands.
#define TYPE_DATA
Definition: ossimRtti.h:339
ossimRefPtr< ossimImageData > theWatermark
Tile storage for watermark image.
unsigned int ossim_uint32
Definition: ossimObject.cpp:53
ossim_uint32 theWatermarkNumberOfBands
The number of watermark bands.
The returned tile.
ossimScalarType
ossimIrect theInputBoundingRect
The bounding rectangle of the input connection.
class ossimWatermarkFilter Applies an image or watermark to image.
ossimFilename theFilename
File name of watermark image.
#define END
ossim_float64 theWatermarkWeight
Normalized between 0.0 and 1.0.
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
bool theDirtyFlag
Set in the initialize method this instructs the getTile that something has changes and it need to cal...
