10 #ifndef ossimWktProjectionFactory_HEADER 11 #define ossimWktProjectionFactory_HEADER 48 const char* prefix = 0)
const;
69 void loadRecords()
const;
71 template<
class T>
void doMapCommon(
const ossimKeywordlist& kwl, T proj)
const;
Projection Factory for coded projections defined in database.
std::map< std::string, ossim_uint32 > m_wktProjRecords
virtual void getTypeNameList(std::vector< ossimString > &typeList) const =0
static ossimWktProjectionFactory * m_instance
Singleton implementation.
virtual ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const =0
takes a filename.
unsigned int ossim_uint32
virtual ossimObject * createObject(const ossimString &typeName) const =0
ossimWktProjectionFactory()
Constructor loads the WKT CSV file specified in the ossim prefs with "wkt_database_file" keyword...
