include
ossim
matrix
solution.h
Go to the documentation of this file.
1
//$$ solution.h // solve routines
2
3
// #include <ossim/matrix/boolean.h>
4
#include <
ossim/matrix/myexcept.h
5
6
#ifdef use_namespace
7
namespace
RBD_COMMON
8
#endif
9
10
11
// Solve the equation f(x)=y for x where f is a monotone continuous
12
// function of x
13
// Essentially Brent s method
14
15
// You need to derive a class from R1_R1 and override "operator()"
16
// with the function you want to solve.
17
// Use an object from this class in OneDimSolve
18
19
class
R1_R1
20
21
// the prototype for a Real function of a Real variable
22
// you need to derive your function from this one and put in your
23
// function for operator() at least. You probably also want to set up a
24
// constructor to put in additional parameter values (e.g. that will not
25
// vary during a solve)
26
27
protected
28
Real
x
// Current x value
29
bool
xSet
// true if a value assigned to x
30
31
public
32
virtual
R1_R1
33
34
Real
minX
, maxX;
// range of value x
35
bool
minXinf
, maxXinf;
// true if these are infinite
36
R1_R1
() : xSet(false), minXinf(
true
), maxXinf(
true
37
virtual
Real
operator()() = 0;
// function value at current x
38
// set current x
39
virtual
void
Set(
Real
X);
// set x, check OK
40
Real
operator()
Real
X) { Set(X);
return
operator()
41
// set x, return value
42
virtual
bool
IsValid(
Real
X);
43
operator
Real
// implicit conversion
44
45
46
class
SolutionException
public
Exception
47
48
public
49
static
unsigned
long
Select
50
SolutionException
const
char
* a_what = 0);
51
52
53
class
OneDimSolve
54
55
R1_R1
function
// reference to the function
56
Real
accX
// accuracy in X direction
57
Real
accY
// accuracy in Y direction
58
int
lim
// maximum number of iterations
59
60
public
61
OneDimSolve
R1_R1
& f,
Real
AccY = 0.0001,
Real
AccX = 0.0)
62
: function(f), accX(AccX), accY(AccY) {}
63
// f is an R1_R1 function
64
Real
Solve(
Real
Y,
Real
X,
Real
Dev,
int
Lim=100);
65
// Solve for x in Y=f(x)
66
// X is the initial trial value of x
67
// X+Dev is the second trial value
68
// program returns a value of x such that
69
// |Y-f(x)| <= accY or |f.inv(Y)-x| <= accX
70
71
private
72
Real
x
[3],
y
[3];
// Trial values of X and Y
73
int
L,C,U,Last;
// Locations of trial values
74
int
vpol
, hpol;
// polarities
75
Real
YY
// target value
76
int
i
77
void
LookAt(
int
// get new value of function
78
bool
Finish
// true if LookAt finds conv.
79
bool
Captured
// true when target surrounded
80
void
VFlip();
81
void
HFlip();
82
void
Flip();
83
void
State(
int
I,
int
J,
int
K);
84
void
Linear(
int
int
int
85
void
Quadratic(
int
int
int
86
87
88
89
90
91
#endif
92
93
// body file: solution.cpp
94
95
96
x
ossim_uint32 x
Definition:
ossimPdfWriter.cpp:519
R1_R1::R1_R1
R1_R1()
Definition:
solution.h:36
RBD_COMMON::Real
double Real
Definition:
include.h:57
OneDimSolve::accX
Real accX
Definition:
solution.h:56
R1_R1::minXinf
bool minXinf
Definition:
solution.h:35
OneDimSolve::OneDimSolve
OneDimSolve(R1_R1 &f, Real AccY=0.0001, Real AccX=0.0)
Definition:
solution.h:61
R1_R1::xSet
bool xSet
Definition:
solution.h:29
y
ossim_uint32 y
Definition:
ossimPdfWriter.cpp:520
OneDimSolve::Finish
bool Finish
Definition:
solution.h:78
true
return true
Definition:
ossimGeneralRasterTileSource.cpp:987
R1_R1::minX
Real minX
Definition:
solution.h:34
OneDimSolve::vpol
int vpol
Definition:
solution.h:74
R1_R1::operator()
Real operator()(Real X)
Definition:
solution.h:40
R1_R1
Definition:
solution.h:19
R1_R1::x
Real x
Definition:
solution.h:28
OneDimSolve::YY
Real YY
Definition:
solution.h:75
OneDimSolve::i
int i
Definition:
solution.h:76
SolutionException::Select
static unsigned long Select
Definition:
solution.h:49
OneDimSolve
Definition:
solution.h:53
OneDimSolve::Captured
bool Captured
Definition:
solution.h:79
SolutionException
Definition:
solution.h:46
RBD_COMMON
Definition:
include.h:47
OneDimSolve::lim
int lim
Definition:
solution.h:58
myexcept.h
OneDimSolve::accY
Real accY
Definition:
solution.h:57
Generated on Fri Aug 3 2018 08:46:55 for OSSIM - Open Source Software Image Map by
