ossimGeneralRasterTileSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: David Burken
8 //
9 // Description:
10 //
11 // Contains class definition for ossimGeneralRasterTileSource.
12 //*******************************************************************
13 // $Id: ossimGeneralRasterTileSource.cpp 22763 2014-05-06 14:07:51Z dburken $
14
17 #include <ossim/base/ossimDpt.h>
18 #include <ossim/base/ossimEndian.h>
22 #include <ossim/base/ossimIpt.h>
23 #include <ossim/base/ossimIrect.h>
28 #include <ossim/base/ossimTrace.h>
34
36  "ossimGeneralRasterTileSource",
38
39 static ossimTrace traceDebug("ossimGeneralRasterTileSource:debug");
40
41 // For interleave type enum to string conversions.
42 static const ossimInterleaveTypeLut ILUT;
43
44 //*******************************************************************
45 // Public Constructor:
46 //*******************************************************************
48  :
50  m_tile(0),
51  m_buffer(0),
52  m_lineBuffer(0),
54  m_fileStrList(0),
55  m_rasterInfo(),
56  m_bufferRect(0, 0, 0, 0),
57  m_swapBytesFlag(false),
58  m_bufferSizeInPixels(0),
59  m_outputBandList(0)
60 {}
61
63 {
64  close();
65 }
66
68  const ossimIrect& tile_rect, ossim_uint32 resLevel)
69 {
70  if ( m_tile.valid() == false )
71  {
72  allocateTile(); // First time through...
73  }
74
75  if (m_tile.valid())
76  {
77  // Image rectangle must be set prior to calling getTile.
78  m_tile->setImageRectangle(tile_rect);
79
80  if ( getTile( m_tile.get(), resLevel ) == false )
81  {
83  {
84  m_tile->makeBlank();
85  }
86  }
87  }
88
89  return m_tile;
90 }
91
93  ossim_uint32 resLevel)
94 {
95  bool status = false;
96
97  //---
98  // Not open, this tile source bypassed, or invalid res level,
99  // return a blank tile.
100  //---
101  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
102  result && (result->getNumberOfBands() == getNumberOfOutputBands()) )
103  {
104  //---
105  // Check for overview tile. Some overviews can contain r0 so always
106  // call even if resLevel is 0. Method returns true on success, false
107  // on error.
108  //---
109  status = getOverviewTile(resLevel, result);
110  if (status)
111  {
113  {
114  //---
115  // Temp fix:
116  // The overview handler could return a tile of OSSIM_UINT16 if
117  // the max sample value was not set to 2047.
118  //---
119  result->setScalarType(OSSIM_USHORT11);
120  }
121  else if(getOutputScalarType() == OSSIM_USHORT12)
122  {
123  result->setScalarType(OSSIM_USHORT12);
124  }
125  else if(getOutputScalarType() == OSSIM_USHORT13)
126  {
127  result->setScalarType(OSSIM_USHORT13);
128  }
129  else if(getOutputScalarType() == OSSIM_USHORT14)
130  {
131  result->setScalarType(OSSIM_USHORT14);
132  }
133  else if(getOutputScalarType() == OSSIM_USHORT15)
134  {
135  result->setScalarType(OSSIM_USHORT15);
136  }
137  }
138
139  if (!status) // Did not get an overview tile.
140  {
141  status = true;
142
143  //---
144  // Subtract any sub image offset to get the zero based image space
145  // rectangle.
146  //---
147  ossimIrect tile_rect = result->getImageRectangle();
148
149  // This should be the zero base image rectangle for this res level.
150  ossimIrect image_rect = getImageRectangle(resLevel);
151
152  //---
153  // See if any point of the requested tile is in the image.
154  //---
155  if ( tile_rect.intersects(image_rect) )
156  {
157  // Make the tile rectangle zero base.
158  result->setImageRectangle(tile_rect);
159
160  // Initialize the tile if needed as we're going to stuff it.
161  if (result->getDataObjectStatus() == OSSIM_NULL)
162  {
163  result->initialize();
164  }
165
166  ossimIrect clip_rect = tile_rect.clipToRect(image_rect);
167
168  if ( ! tile_rect.completely_within(m_bufferRect) )
169  {
170  // A new buffer must be loaded.
171  if ( !tile_rect.completely_within(clip_rect) )
172  {
173  //---
174  // Start with a blank tile since the whole tile buffer will
175  // not be
176  // filled.
177  //---
178  result->makeBlank();
179  }
180
181  // Reallocate the buffer if needed.
182  if ( m_bufferSizeInPixels != result->getSize() )
183  {
184  allocateBuffer( result );
185  }
186
187  ossimIpt size(static_cast<ossim_int32>(result->getWidth()),
188  static_cast<ossim_int32>(result->getHeight()));
189
190  if( !fillBuffer(clip_rect.ul(), size) )
191  {
193  << "Error from fill buffer..."
194  << std::endl;
195  //---
196  // Error in filling buffer.
197  //---
198  setErrorStatus();
199  status = false;
200  }
201  }
202
203  result->loadTile(m_buffer,
204  m_bufferRect,
205  clip_rect,
207  result->validate();
208
209  // Set the rectangle back.
210  result->setImageRectangle(tile_rect);
211
212  }
213  else // No intersection.
214  {
215  result->makeBlank();
216  }
217  }
218  }
219  return status;
220 }
221
223 {
224
225  static const char MODULE[] = "ossimGeneralRasterTileSource::fillBuffer";
226
227  // Note: InterleaveType enumerations in "constants.h" file.
228  bool status = false;
229  switch ( m_rasterInfo.interleaveType() )
230  {
231  case OSSIM_BIP:
232  {
233  status = fillBIP(origin, size);
234  break;
235  }
236  case OSSIM_BIL:
237  {
238  status = fillBIL(origin, size);
239  break;
240  }
241  case OSSIM_BSQ:
242  {
243  status = fillBSQ(origin, size);
244  break;
245  }
247  {
248  status = fillBsqMultiFile(origin, size);
249  break;
250  }
251  default:
252  {
254  << MODULE << " ERROR:\n"
255  << " Unsupported interleave type: "
257  << std::endl;
258  }
259  }
260
261  if (status && m_swapBytesFlag)
262  {
263  ossimEndian oe;
265  m_buffer,
267  }
268
269  return status;
270 }
271
272 bool ossimGeneralRasterTileSource::fillBIP(const ossimIpt& origin, const ossimIpt& size )
273 {
274  static const char MODULE[] = "ossimGeneralRasterTileSource::fillBIP ";
275
276  m_bufferRect.set_ul(origin);
277  m_bufferRect.set_lry(min( (origin.y + size.y -1),
278  m_rasterInfo.imageRect().lr().y));
279  m_bufferRect.set_lrx(min( (origin.x + size.x -1),
280  m_rasterInfo.imageRect().lr().x));
281
282  const ossim_int32 WIDTH = static_cast<ossim_int32>( m_bufferRect.width() );
283  const ossim_int32 HEIGHT = static_cast<ossim_int32>( m_bufferRect.height() );
284  const ossim_int32 INPUT_BANDS = m_rasterInfo.numberOfBands();
285  const ossim_int32 OUTPUT_BANDS = static_cast<ossim_int32>( m_outputBandList.size() );
286  const ossim_int32 BYTES_PER_PIXEL = m_rasterInfo.bytesPerPixel();
287  const ossim_int32 INPUT_BYTES_PER_SAMPLE = BYTES_PER_PIXEL * INPUT_BANDS;
288  const ossim_int32 OUTPUT_BYTES_PER_SAMPLE = BYTES_PER_PIXEL * OUTPUT_BANDS;
289
290  // Seek position.
291  std::streamoff rasterOffset = m_rasterInfo.offsetToFirstValidSample() +
292  origin.y * m_rasterInfo.bytesPerRawLine() +
293  origin.x * INPUT_BYTES_PER_SAMPLE;
294
295  // Input line buffer, all bands.
296  std::streamsize inputLineBufferWidth = WIDTH * INPUT_BYTES_PER_SAMPLE;
297
298  // Output buffer width:
299  std::streamsize outputLineBufferWidth = WIDTH * OUTPUT_BYTES_PER_SAMPLE;
300
301 #if 0 /* Please keep for debug. (drb) */
303  << "\nDEBUG:"
304  << "\norigin: " << origin
305  << "\nSeek position: " << rasterOffset
306  << "\ninputLineBufferWidth: " << inputLineBufferWidth
307  << "\noutputLineBufferWidth: " << outputLineBufferWidth
308  << "\nINPUT_BANDS: " << INPUT_BANDS
309  << "\nOUTPUT_BANDS: " << OUTPUT_BANDS
310  << std::endl;
311 #endif
312
313  ossim_int32 bufferOffset = 0;
314
315  // Line loop:
316  ossim_int32 currentLine = 0;
317  while ( currentLine < HEIGHT )
318  {
319  // Seek to line.
320  m_fileStrList[0]->seekg(rasterOffset, ios::beg);
321  if (!(*m_fileStrList[0]))
322  {
325  << MODULE << " ERROR:\n"
326  << " Seek error! Returning with error..." << std::endl;
327  return false;
328  }
329
330  // Read image data from line for all bands into line buffer.
331  m_fileStrList[0]->read( (char*)m_lineBuffer, inputLineBufferWidth );
332  if ( m_fileStrList[0]->gcount() != inputLineBufferWidth )
333  {
336  << MODULE << "\nERROR: Reading image line." << std::endl;
337  return false;
338  }
339
340  // Sample loop:
341  for ( ossim_int32 sample = 0; sample < WIDTH; ++sample )
342  {
343  // Band loop:
344  for ( ossim_int32 band = 0; band < OUTPUT_BANDS; ++band )
345  {
346  ossim_int32 selectedBand = static_cast<ossim_int32>(m_outputBandList[band]);
347  memcpy( (void*)(m_buffer + bufferOffset +
348  sample * OUTPUT_BYTES_PER_SAMPLE +
349  band * BYTES_PER_PIXEL),
350  (void*)(m_lineBuffer +
351  sample * INPUT_BYTES_PER_SAMPLE +
352  selectedBand * BYTES_PER_PIXEL),
353  BYTES_PER_PIXEL );
354  }
355  }
356
357  ++currentLine;
358  bufferOffset += outputLineBufferWidth;
359  rasterOffset += m_rasterInfo.bytesPerRawLine();
360  }
361
362  return true;
363
364 } // End: bool ossimGeneralRasterTileSource::fillBipBandSelect(...
365
367  const ossimIpt& size)
368 {
369  static const char MODULE[] = "ossimGeneralRasterTileSource::fillBIL";
370
371  //***
372  // This will fill a buffer the full width of valid samples * tileHeight().
373  //***
374  m_bufferRect.set_ul(origin);
375  m_bufferRect.set_lry(min((origin.y + size.y - 1),
376  m_rasterInfo.imageRect().lr().y));
377  m_bufferRect.set_lrx(min((origin.x + size.x - 1),
378  m_rasterInfo.imageRect().lr().x));
379
380  ossim_sint64 currentLine = origin.y;
381
382  // Bytes in one line all bands.
383  const std::streamoff LINE_OFFSET =
385
386  // Start seek position.
387  std::streamoff offset = ( m_rasterInfo.offsetToFirstValidSample() +
388  currentLine * LINE_OFFSET +
389  origin.x * m_rasterInfo.bytesPerPixel() );
390
391  //---
392  // Loop through and process lines.
393  //---
394  ossim_int32 linesProcessed = 0;
395  std::streamsize buffer_width = m_bufferRect.width() * m_rasterInfo.bytesPerPixel();
396  ossim_uint8* buf = m_buffer;
397
398 #if 0 /* Please leave for debug. (drb) */
400  << "\nDEBUG:"
401  << "\norigin: " << origin
402  << "\nSeek position: " << offset
403  << "\nStarting line number: " << currentLine
404  << "\nbuffer_width: " << buffer_width << std::endl;
405 #endif
406
407  // Line loop:
408  while ((currentLine <= static_cast<ossim_sint64>(m_rasterInfo.imageRect().lr().y)) &&
409  linesProcessed < size.y)
410  {
411  // Band loop:
412  std::vector<ossim_uint32>::const_iterator i = m_outputBandList.begin();
413  while ( i != m_outputBandList.end() )
414  {
415  ossim_int64 band = static_cast<ossim_sint64>( (*i) );
416  const std::streamoff bandOffset = band * m_rasterInfo.bytesPerRawLine();
417
418  // Seek to line.
419  m_fileStrList[0]->seekg(offset + bandOffset, ios::beg);
420  if (!m_fileStrList[0])
421  {
424  << MODULE << " ERROR:\n"
425  << " Seek error! Returning with error..." << std::endl;
426  return false;
427  }
428
429  // Read the line of image data.
430  m_fileStrList[0]->read( (char*)buf, buffer_width );
431
432  if ( m_fileStrList[0]->gcount() != buffer_width )
433  {
436  << MODULE << "\nERROR: Reading image line."
437  << "\ncurrentLine: " << currentLine << std::endl;
438  return false;
439  }
440
441  buf += buffer_width;
442  ++i;
443
444  } // End of band loop.
445
446  ++linesProcessed;
447  ++currentLine;
448  offset += LINE_OFFSET;
449
450  } // End: line loop
451
452  return true;
453 }
454
455 //*******************************************************************
456 // Private Method:
457 //*******************************************************************
459  const ossimIpt& size)
460 {
461  static const char MODULE[] = "ossimGeneralRasterTileSource::fillBSQ";
462
463  // This will fill a buffer the full width of valid samples * tileHeight().
464
465  m_bufferRect.set_ul(origin);
466
467  m_bufferRect.set_lry(min((origin.y + size.y -1),
468  m_rasterInfo.imageRect().lr().y));
469  m_bufferRect.set_lrx(min((origin.x + size.x - 1),
470  m_rasterInfo.imageRect().lr().x));
471
472  // Start seek position.
473  std::streamoff startSeekPosition
475  origin.y * m_rasterInfo.bytesPerRawLine() +
476  origin.x * m_rasterInfo.bytesPerPixel();
477
478  std::streamsize buffer_width = m_bufferRect.width() * m_rasterInfo.bytesPerPixel();
479
481
482  std::streamoff bandOffset
484
485 #if 0 /* Please leave for debug. (drb) */
487  << "\nDEBUG:"
488  << "\norigin: " << origin
489  << "\nSeek position: " << startSeekPosition
490  << "\nStarting line number: " << origin.y
491  << "\nbuffer_width: " << buffer_width
492  << "\nbytesPerRawLine(): "
494  << "\nm_rasterInfo.offsetToFirstValidSample(): "
496  << "\nbandOffset: " << bandOffset << std::endl;
497 #endif
498
499  ossim_int32 num_bands = m_rasterInfo.numberOfBands();
500  ossim_int32 height = size.y;
501
502  // Band loop:
503  for (ossim_int32 band = 0; band < num_bands; ++band)
504  {
505  ossim_sint64 currentLine = origin.y;
506  ossim_sint64 linesProcessed = 0;
507
508  std::streamoff offset = startSeekPosition + (band * bandOffset);
509
510  // Line loop:
511  while (currentLine <= m_rasterInfo.imageRect().lr().y &&
512  linesProcessed < height)
513  {
514  // Seek to line.
515  m_fileStrList[0]->seekg(offset, ios::beg);
516  if (!m_fileStrList[0])
517  {
520  << MODULE << " ERROR:\n"
521  << " Seek error! Returning with error..." << std::endl;
522  return false;
523  }
524
525  // Read the line of image data.
526  m_fileStrList[0]->read( (char*)buf, buffer_width );
527  if ( m_fileStrList[0]->gcount() != buffer_width )
528  {
531  << MODULE << "\nERROR: Reading image line."
532  << "\ncurrentLine: " << currentLine << std::endl;
533  return false;
534  }
535
536  // Increment everybody accordingly.
537  buf += buffer_width;
538  offset += m_rasterInfo.bytesPerRawLine();
539  ++linesProcessed;
540  ++currentLine;
541
542  } // End of line loop.
543
544  } // End of band loop.
545
546  return true;
547 }
548
549 //*******************************************************************
550 // Private Method:
551 //*******************************************************************
553 {
554  static const char MODULE[] = "ossimGeneralRasterTileSource::fillBsqMultiFile";
555
556  if (traceDebug()) CLOG << " Entered..." << std::endl;
557
558
559  // This will fill a buffer the full width of valid samples * tileHeight().
560  m_bufferRect.set_ul(origin);
561
562  m_bufferRect.set_lry(min((origin.y + size.y -1),
563  m_rasterInfo.imageRect().lr().y));
564  m_bufferRect.set_lrx(min((origin.x + size.x - 1),
565  m_rasterInfo.imageRect().lr().x));
566
567  //---
568  // Start seek position.
569  //---
570  std::streamoff startSeekPosition = m_rasterInfo.offsetToFirstValidSample() +
571  origin.y * m_rasterInfo.bytesPerRawLine() +
572  origin.x * m_rasterInfo.bytesPerPixel();
573
574  //---
575  // Loop through and process lines.
576  //---
577  std::streamsize buffer_width = m_bufferRect.width() * m_rasterInfo.bytesPerPixel();
578
580
581 #if 0
582  if (traceDebug())
583  {
585  << "\nDEBUG:"
586  << "\norigin: " << origin
587  << "\nSeek position: " << startSeekPosition
588  << "\nStarting line number: " << origin.y
589  << "\nbuffer_width: " << buffer_width
590  << "\nbuffer_rect: " << m_bufferRect
591  << "\nbytesPerRawLine(): "
593  << "\nm_rasterInfo.offsetToFirstValidSample(): "
594  << m_rasterInfo.offsetToFirstValidSample() << std::endl;
595  }
596 #endif
597
598  // ossim_int32 num_bands = m_rasterInfo.numberOfBands();
599  std::vector<ossim_uint32>::const_iterator bandIter = m_outputBandList.begin();
600  while ( bandIter != m_outputBandList.end() )
601  {
602  ossim_int32 currentLine = origin.y;
603  ossim_int32 linesProcessed = 0;
604  ossim_int64 offset = startSeekPosition;
605
606  while (currentLine <= m_rasterInfo.imageRect().lr().y && linesProcessed < size.y)
607  {
608  //---
609  // Seek to line.
610  //---
611  m_fileStrList[ *bandIter ]->seekg(offset, ios::beg);
612
613  if ( !m_fileStrList[ *bandIter ] )
614  {
617  << MODULE << " ERROR:\n"
618  << " Seek error! Returning with error..." << std::endl;
619  return false;
620  }
621
622  //---
623  // Read the line of image data.
624  //---
625  m_fileStrList[ *bandIter ]->read((char*)buf, buffer_width);
626
627  if ( m_fileStrList[ *bandIter ]->gcount() != buffer_width)
628  {
631  << MODULE << "\nERROR: Reading image line."
632  << "\ncurrentLine: " << currentLine << std::endl;
633  return false;
634  }
635
636  // Increment everybody accordingly.
637  buf += buffer_width;
638  offset += m_rasterInfo.bytesPerRawLine();
639  ++linesProcessed;
640  ++currentLine;
641
642  } // End of line loop.
643
644  ++bandIter; // Next band...
645
646  } // End: while ( bandIter ! = m_outputBandList.end() )
647
648  return true;
649 }
650
651 //*******************************************************************
652 // Public method:
653 //*******************************************************************
655  const char* prefix) const
656 {
657  // Our stuff:
658  m_rasterInfo.saveState(kwl, prefix);
659
660  // Base class:
661  bool result = ossimImageHandler::saveState(kwl, prefix);
662
663  if ( result && isBandSelector() && m_outputBandList.size() )
664  {
665  if ( isIdentityBandList( m_outputBandList ) == false )
666  {
667  // If we're not identity output the bands.
668  ossimString bandsString;
670  kwl.add(prefix,
672  bandsString,
673  true);
674  }
675  }
676
677  return result;
678 }
679
680 //*******************************************************************
681 // Public method:
682 //*******************************************************************
684  const char* prefix)
685 {
686  bool result = false;
687  m_outputBandList.clear();
688
689  if ( ossimImageHandler::loadState(kwl, prefix) )
690  {
691  // Set the band list if key is present.
692  std::string pfx = ( prefix ? prefix : "" );
693  std::string key = ossimKeywordNames::BANDS_KW;
694  ossimString value;
695  value.string() = kwl.findKey( pfx, key );
696  if ( value.size() )
697  {
699  }
700  result = open();
701  }
702  return result;
703 }
704
705 //*******************************************************************
706 // Public method:
707 //*******************************************************************
709 {
711 }
712
713 //*******************************************************************
714 // Public method:
715 //*******************************************************************
717 {
718  ossim_uint32 result = 0;
719  if ( m_tile.valid() )
720  {
721  m_tile->getWidth();
722  }
723  else
724  {
725  ossimIpt tileSize;
726  ossim::defaultTileSize(tileSize);
727  result = tileSize.x;
728  }
729  return result;
730 }
731
732 //*******************************************************************
733 // Public method:
734 //*******************************************************************
736 {
737  ossim_uint32 result = 0;
738  if ( m_tile.valid() )
739  {
740  m_tile->getHeight();
741  }
742  else
743  {
744  ossimIpt tileSize;
745  ossim::defaultTileSize(tileSize);
746  result = tileSize.y;
747  }
748  return result;
749 }
750
751 //*******************************************************************
752 // Public method:
753 //*******************************************************************
754 bool
756 {
757  static const char MODULE[] = "ossimGeneralRasterTileSource::isValidRLevel";
758
759  if (reduced_res_level == 0)
760  {
761  return true;
762  }
763  else if (theOverview.valid())
764  {
765  return theOverview->isValidRLevel(reduced_res_level);
766  }
767  else
768  {
770  << MODULE
771  << " Invalid reduced_res_level: " << reduced_res_level
772  << "\nHighest available: " << (getNumberOfDecimationLevels() - 1)
773  << std::endl;
774  return false;
775  }
776 }
777
778
779
780 //*******************************************************************
781 // Public method:
782 //*******************************************************************
785 {
786  if (reduced_res_level == 0)
787  {
788  return m_rasterInfo.validLines();
789  }
790  else if (theOverview.valid())
791  {
792  return theOverview->getNumberOfLines(reduced_res_level);
793  }
794
795  return 0;
796 }
797
798 //*******************************************************************
799 // Public method:
800 //*******************************************************************
802  ossim_uint32 reduced_res_level) const
803 {
804  if (reduced_res_level == 0)
805  {
806  return m_rasterInfo.validSamples();
807  }
808  else if (theOverview.valid())
809  {
810  return theOverview->getNumberOfSamples(reduced_res_level);
811  }
812
813  return 0;
814 }
815
817 {
819 }
820
822 {
823  return m_rasterInfo.getImageMetaData().getMinPix(band);
824 }
825
827 {
828  return m_rasterInfo.getImageMetaData().getMaxPix(band);
829 }
830
832 {
833  static const char MODULE[] = "ossimGeneralRasterTileSource::open";
834
835  if (traceDebug()) CLOG << " Entered..." << std::endl;
836
837  bool result = false;
838
839  if(isOpen())
840  {
841  close();
842  }
843
844  //---
845  // Find the header file:
846  //
847  // We need lines, samples, bands, scalar and interleave at a minimum:
848  //
849  // A general raster image requires a keyword list to get essential image
850  // information or meta data as its sometimes called. The meta data file
851  // can have four types of extensions: ".omd", ".hdr", ".kwl" and xml.
852  // Look for them in that order.
853  // Note that the ".omd" extension is for "Ossim Meta Data" and was made
854  // up to avoid conflicting with other software packages ".hdr" files.
855  //---
856  if ( m_rasterInfo.open( theImageFile ) )
857  {
859
860  result = initializeHandler();
861  if ( result )
862  {
863  completeOpen();
864
865  if ( isBandSelector() && m_outputBandList.size() &&
866  ( isIdentityBandList( m_outputBandList ) == false ) )
867  {
868  // This does range checking and will pass to overview if open.
870  }
871  }
872  }
873
874  if ( traceDebug() )
875  {
877  << MODULE << " Exit status: " << (result?"true":"false") << std::endl;
878  }
879  return result;
880 }
881
883 {
884  if( isOpen() )
885  {
886  close();
887  }
888
889  m_rasterInfo = info;
890
891  bool result = initializeHandler();
892
893  if ( result )
894  {
895  completeOpen();
896
897  if ( isBandSelector() && m_outputBandList.size() &&
898  ( isIdentityBandList( m_outputBandList ) == false ) )
899  {
900  // This does range checking and will pass to overview if open.
902  }
903  }
904
905  return result;
906 }
907
909 {
910  //---
911  // This private method assumes that "m_rasterInfo" object has been
912  // initialized. Note that "close() should have already been called if
913  // there was an open file prior to this.
914  //---
915  std::vector<ossimFilename> aList = m_rasterInfo.getImageFileList();
916
917  for (ossim_uint32 i=0; i<aList.size(); ++i)
918  {
919  ossimFilename f = aList[i];
920
921  // open it...
922  std::shared_ptr<ossim::istream> is = ossim::StreamFactoryRegistry::instance()->
923  createIstream(f);
924
925  // check the stream...
926  if( is )
927  {
928  // Check the file stream.
929  if ( is->fail() )
930  {
933  << "ossimGeneralRasterTileSource::open" << " ERROR:\n"
934  << "Cannot open: " << f.c_str() << std::endl;
935  is = 0;
936  return false;
937  }
938  }
939
940  // Check the file size (removed).
941
942  m_fileStrList.push_back(is); // Add it to the list...
943  }
944
945  if ((aList.size()==1) && theImageFile.empty())
946  {
947  theImageFile = aList[0];
948  }
949
950  // Set the buffer interleave type.
953  {
955  }
956
957  if ( m_outputBandList.empty() )
958  {
959  // Set starting output band list to identity.
961  }
962
963  //---
964  // Get the byte order of the image data and host machine. If different,
965  // set the swap bytes flag...
966  //---
968  {
969  m_swapBytesFlag = true;
970  }
971
972  if (traceDebug())
973  {
975  << "ossimGeneralRasterTileSource::initializeHandler()" << " DEBUG:"
976  << "\nScalar type: "
978  getEntryString(m_rasterInfo.getImageMetaData().getScalarType())
979  << "\nByte swapping is "
980  << (m_swapBytesFlag?"enabled.":"not enabled.")
981  // << "\nm_bufferSizeInPixels: " << m_bufferSizeInPixels
982  // << "\nbuffer size: " << buffer_size
983  << "\nRasterInfo:\n";
985  }
986
987  return true;
988 }
989
991 {
992  bool result = false;
993  if (m_fileStrList.size() > 0)
994  {
995  if( m_fileStrList[0] )
996  {
997  result = !(m_fileStrList[0]->fail());
998  }
999  }
1000  return result;
1001 }
1002
1004 {
1005  ossimImageHandler::close(); // base class
1006
1007  m_tile = 0; // Not a leak, ref ptr.
1008
1009  if ( m_buffer )
1010  {
1011  delete [] m_buffer;
1012  m_buffer = 0;
1013  m_bufferSizeInPixels = 0; // Must zero out for check in getTile method.
1014  }
1015
1016  if ( m_lineBuffer )
1017  {
1018  delete [] m_lineBuffer;
1019  m_lineBuffer = 0;
1020  }
1021
1022  std::vector< shared_ptr<ossim::istream> >::iterator is = m_fileStrList.begin();
1023  while (is != m_fileStrList.end())
1024  {
1025  (*is) = 0;
1026
1027  ++is;
1028  }
1029  m_fileStrList.clear();
1030 }
1031
1033 {
1034  return 0;
1035 }
1036
1038 {
1039  return 0;
1040 }
1041
1043 {
1044  return ossimString("ossim_raster");
1045 }
1046
1048 {
1049  return ossimString("general raster reader");
1050 }
1051
1053 {
1055 }
1056
1058 {
1059  ossim_uint32 result = 0;
1060  if ( isBandSelector() && m_outputBandList.size() )
1061  {
1062  result = (ossim_uint32)m_outputBandList.size();
1063  }
1064  else
1065  {
1067  }
1068  return result;
1069 }
1070
1072 {
1073  ossimKeywordlist kwl;
1074  char delimeter = ' ';
1075  kwl.change_delimiter(delimeter);
1076  kwl.addFile(hdrFile);
1077  kwl.downcaseKeywords();
1078
1079  ossimKeywordlist geoKwl;
1080  ossim_uint32 lines = 0;
1081  ossim_uint32 samples = 0;
1082  ossim_float32 noData = -9999;
1083  ossimString scalarType = "ossim_uint8";
1084  ossim_int32 numBands = 1;
1085  // ossim_int32 skipBytes = 0;
1086  ossim_int32 numBits = -1;
1087  ossimString chPixelType = "N"; // not defined
1088  ossimString interleaveType = "BIL";
1090  bool noDataFound = false;
1091
1092  const char* lookup = kwl.find("ncols");
1093  if (lookup)
1094  {
1095  samples = ossimString(lookup).toUInt32();
1096  geoKwl.add(ossimKeywordNames::NUMBER_SAMPLES_KW, samples);
1097  }
1098
1099  lookup = kwl.find("nrows");
1100  if (lookup)
1101  {
1102  lines = ossimString(lookup).toUInt32();
1103  geoKwl.add(ossimKeywordNames::NUMBER_LINES_KW, lines);
1104  }
1105
1106  // lookup = kwl.find("skipbytes");
1107  // if (lookup)
1108  // {
1109  // skipBytes = ossimString(lookup).toInt();
1110  // }
1111
1112  lookup = kwl.find("nbands");
1113  if (lookup)
1114  {
1115  numBands = ossimString(lookup).toInt();
1116  }
1117
1118  lookup = kwl.find("nodata");
1119  if (lookup)
1120  {
1121  noData = ossimString(lookup).toFloat32();
1122  noDataFound = true;
1123  }
1124  lookup = kwl.find("nodata_value");
1125  if (lookup)
1126  {
1127  noData = ossimString(lookup).toFloat32();
1128  noDataFound = true;
1129  }
1130
1131  lookup = kwl.find("nbits");
1132  if (lookup)
1133  {
1134  numBits = ossimString(lookup).toInt();
1135  }
1136
1137  lookup = kwl.find("pixeltype");
1138  if (lookup)
1139  {
1140  chPixelType = ossimString(lookup);
1141  }
1142
1143  lookup = kwl.find("layout");
1144  if (lookup)
1145  {
1146  interleaveType = ossimString(lookup);
1147  }
1148
1149  lookup = kwl.find("byteorder");
1150  if (lookup)
1151  {
1152  byteOrder = ossimString(lookup);
1153  }
1154
1155  if (numBits == -1)
1156  {
1157  FILE* fp;
1158  ossim_int64 size = 0;
1159  fp = fopen(theImageFile.c_str(), "r");
1160  if (fp != 0)
1161  {
1162  fseek(fp, 0, SEEK_END);
1163  size = ftell(fp);
1164  }
1165  fclose(fp);
1166
1167  if (lines > 0 && samples > 0)
1168  {
1169  ossim_int32 numBytes = size/samples/lines/numBands;
1170  if( numBytes > 0 && numBytes != 3 )
1171  {
1172  numBits = numBytes*8;
1173
1174  if( numBytes == 4 )
1175  {
1176  chPixelType = "F";
1177  }
1178  }
1179  }
1180  }
1181
1182  if( numBits == 16 )
1183  {
1184  if (chPixelType == "S")
1185  {
1186  scalarType = "ossim_sint16";
1187  }
1188  else
1189  {
1190  scalarType = "ossim_uint16"; // default
1191  }
1192  }
1193  else if( numBits == 32 )
1194  {
1195  if( chPixelType == "S")
1196  {
1197  scalarType = "ossim_sint32";
1198  }
1199  else if( chPixelType == "F")
1200  {
1201  scalarType = "ossim_float32";
1202  }
1203  else
1204  {
1205  scalarType = "ossim_uint32"; // default
1206  }
1207  }
1208  else if( numBits == 8 )
1209  {
1210  scalarType = "ossim_uint8";
1211  numBits = 8;
1212  }
1213  else if( numBits < 8 && numBits >= 1 )
1214  {
1215  scalarType = "ossim_uint8";
1216  }
1217  else if(numBits == -1)
1218  {
1219  if( chPixelType == "F")
1220  {
1221  scalarType = "ossim_float32";
1222  numBits = 32;
1223  }
1224  else
1225  {
1226  scalarType = "ossim_uint8";
1227  numBits = 8;
1228  }
1229  }
1230
1231  if (noDataFound)
1232  {
1233  for (ossim_int32 i = 0; i < numBands; i++)
1234  {
1235  ossimString prefix = "band" + ossimString::toString(i+1) + ": ";
1236  geoKwl.add(prefix, ossimKeywordNames::NULL_VALUE_KW, noData);
1237  }
1238  }
1239
1240  geoKwl.add(ossimKeywordNames::NUMBER_BANDS_KW, numBands);
1241  geoKwl.add(ossimKeywordNames::SCALAR_TYPE_KW, scalarType);
1242  geoKwl.add(ossimKeywordNames::INTERLEAVE_TYPE_KW, interleaveType);
1243
1244  return geoKwl;
1245 }
1246
1248 {
1249  ossimKeywordlist kwl;
1250  ossimFgdcXmlDoc file;
1251  if (file.open(xmlFile))
1252  {
1253
1254  ossimString scalarType = "ossim_uint8";
1255  ossim_int32 numBits = -1;
1256  ossimString interleaveType = "BIL";
1257
1258  ossimIpt size;
1259  ossim_int32 samples = 0;
1260  ossim_int32 lines = 0;
1261  if (file.getImageSize(size))
1262  {
1263  samples = size.x;
1264  lines = size.y;
1265  }
1266  if (samples > 0)
1267  {
1269  }
1270  if (lines > 0)
1271  {
1273  }
1274
1275  ossim_int32 bands = file.getNumberOfBands();
1276  if (bands > 0)
1277  {
1279  }
1280  else
1281  {
1282  if (samples > 0 && lines > 0)//if there is no bands info but samples and lines info, default number of bands to 1
1283  {
1284  bands = 1;
1286  }
1287  }
1288
1289  ossimString eainfo;
1290  file.getPath("/metadata/eainfo/detailed/enttyp/enttypd", eainfo);
1291
1292  if (numBits == -1)
1293  {
1294  if ( (lines > 0) && (samples > 0) && (bands > 0) )
1295  {
1297  ossim_int32 numBytes = size/samples/lines/bands;
1298  if( numBytes > 0 && numBytes != 3 )
1299  {
1300  numBits = numBytes*8;
1301  }
1302  }
1303  }
1304
1305  if( numBits == 16 )
1306  {
1307  scalarType = "ossim_uint16"; // default
1308  }
1309  else if( numBits == 32 )
1310  {
1311  if(eainfo.contains("float"))
1312  {
1313  scalarType = "ossim_float32";
1314  }
1315  else
1316  {
1317  scalarType = "ossim_uint32"; // default
1318  }
1319  }
1320  else if( numBits == 8 )
1321  {
1322  scalarType = "ossim_uint8";
1323  numBits = 8;
1324  }
1325  else if( numBits < 8 && numBits >= 1 )
1326  {
1327  scalarType = "ossim_uint8";
1328  }
1329
1330  kwl.add(ossimKeywordNames::SCALAR_TYPE_KW, scalarType);
1331  kwl.add(ossimKeywordNames::INTERLEAVE_TYPE_KW, interleaveType);
1332  }
1333  return kwl;
1334 }
1335
1337 {
1338  if ( !theGeometry.valid() )
1339  {
1340  // Check for external geom:
1342
1343  if ( !theGeometry.valid() )
1344  {
1346
1347  ossimString ext = theImageFile.ext();
1348  ossimFilename hdrFile = theImageFile;
1349  ossimFilename xmlFile = theImageFile;
1350  hdrFile = hdrFile.setExtension("hdr");
1351  xmlFile = xmlFile.setExtension("xml");
1352  if (hdrFile.exists())
1353  {
1354  ossimKeywordlist geoKwl;
1355  ossimKeywordlist kwl(hdrFile, ' ');
1356  kwl.downcaseKeywords();
1357
1358  ossim_uint32 lines = 0;
1359  ossim_uint32 samples = 0;
1360  ossim_float32 ll_lon = 0.0;
1361  ossim_float32 ll_lat = 0.0;
1362  ossim_float32 xCellSize = 1.0;
1363  ossim_float32 yCellSize = 1.0;
1364
1365  const char* lookup = kwl.find("ncols");
1366  if (lookup)
1367  {
1368  samples = ossimString(lookup).toUInt32();
1369  geoKwl.add(ossimKeywordNames::NUMBER_SAMPLES_KW, samples);
1370  }
1371
1372  lookup = kwl.find("nrows");
1373  if (lookup)
1374  {
1375  lines = ossimString(lookup).toUInt32();
1376  geoKwl.add(ossimKeywordNames::NUMBER_LINES_KW, lines);
1377  }
1378
1379  lookup = kwl.find("cellsize");
1380  if (lookup)
1381  {
1382  xCellSize = ossimString(lookup).toFloat32();
1383  yCellSize = xCellSize;
1386  }
1387
1388  lookup = kwl.find("xdim");
1389  if (lookup)
1390  {
1391  xCellSize = ossimString(lookup).toFloat32();
1393  }
1394
1395  lookup = kwl.find("ydim");
1396  if (lookup)
1397  {
1398  yCellSize = ossimString(lookup).toFloat32();
1400  }
1401
1402  lookup = kwl.find("xllcenter");
1403  if (lookup)
1404  {
1405  ossim_float32 centerX = ossimString(lookup).toFloat32();
1406  ll_lon = centerX + xCellSize * 0.5;
1407  geoKwl.add(ossimKeywordNames::TIE_POINT_LON_KW, ll_lon);
1408  }
1409
1410  lookup = kwl.find("yllcenter");
1411  if (lookup)
1412  {
1413  ossim_float32 centerY = ossimString(lookup).toFloat32();
1414  ll_lat = (centerY + (lines - 1) * yCellSize) + yCellSize * 0.5;
1415  geoKwl.add(ossimKeywordNames::TIE_POINT_LAT_KW, ll_lat);
1416  }
1417
1418  lookup = kwl.find("xllcorner");
1419  if (lookup)
1420  {
1421  ll_lon = ossimString(lookup).toFloat32();
1422  geoKwl.add(ossimKeywordNames::TIE_POINT_LON_KW, ll_lon);
1423  }
1424
1425  lookup = kwl.find("yllcorner");
1426  if (lookup)
1427  {
1428  ossim_uint32 centerY = ossimString(lookup).toFloat32();
1429  ll_lat = centerY + lines * yCellSize;
1430  geoKwl.add(ossimKeywordNames::TIE_POINT_LAT_KW, ll_lat);
1431  }
1432
1433  lookup = kwl.find("ulxmap");
1434  if (lookup)
1435  {
1436  ll_lon = ossimString(lookup).toFloat32();
1437  geoKwl.add(ossimKeywordNames::TIE_POINT_LON_KW, ll_lon);
1438  }
1439
1440  lookup = kwl.find("ulymap");
1441  if (lookup)
1442  {
1443  ossim_uint32 centerY = ossimString(lookup).toFloat32();
1444  ll_lat = centerY + lines * yCellSize;
1445  geoKwl.add(ossimKeywordNames::TIE_POINT_LAT_KW, ll_lat);
1446  }
1447
1449
1450  geoKwl.add(ossimKeywordNames::TYPE_KW, "ossimEquDistCylProjection");
1451
1453  code());
1454
1456  createProjection(geoKwl);
1457
1458  if ( proj.valid() )
1459  {
1460  theGeometry->setProjection(proj.get());
1461  }
1462  }
1463  else if (xmlFile.exists())
1464  {
1465  ossimFgdcXmlDoc file;
1466  if ( file.open(xmlFile) )
1467  {
1469  if ( !proj.valid() )
1470  {
1471  proj = file.getGridCoordSysProjection();
1472  }
1473  if ( proj.valid() )
1474  {
1475  theGeometry->setProjection(proj.get());
1476  }
1477  }
1478
1479  } // xml file exist...
1480
1481  } // Matches second if ( !theGeometry.valid() )
1482
1483  //---
1484  // WARNING:
1485  // Must have theGeometry at this point or the next call to
1486  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
1487  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
1488  //---
1489
1490  // Check for set projection.
1491  if ( !theGeometry->getProjection() )
1492  {
1493  // Try factories for projection.
1495  }
1496
1497  // Set image things the geometry object should know about.
1499
1500  } // Matches first if ( !theGeometry.valid() )
1501
1502  return theGeometry;
1503 }
1504
1506 {
1507  bool result = false;
1511  {
1512  result = true;
1513  }
1514
1515  if ( result && theOverview.valid() )
1516  {
1517  result = theOverview->isBandSelector();
1518  }
1519  return result;
1520 }
1521
1522 bool ossimGeneralRasterTileSource::setOutputBandList(const std::vector<ossim_uint32>& band_list)
1523 {
1524  bool result = false;
1525  if ( isBandSelector() )
1526  {
1527  // Making a copy as passed in list could be our m_outputBandList.
1528  std::vector<ossim_uint32> inputList = band_list;
1530  if ( result && m_tile.valid() )
1531  {
1532  if ( m_tile->getNumberOfBands() != m_outputBandList.size() )
1533  {
1534  m_tile = 0; // Force a reinitialize on next getTile.
1535  }
1536  }
1537  }
1538  return result;
1539 }
1540
1541 void ossimGeneralRasterTileSource::getOutputBandList(std::vector<ossim_uint32>& bandList) const
1542 {
1543  bandList = m_outputBandList;
1544 }
1545
1547 {
1548  m_tile = 0;
1549  ossim_uint32 bands = 0;
1550  if ( m_outputBandList.empty() )
1551  {
1552  bands = m_rasterInfo.numberOfBands();
1553  }
1554  else
1555  {
1556  bands = (ossim_uint32)m_outputBandList.size();
1557  }
1558
1559  if ( bands )
1560  {
1562  this, m_rasterInfo.getImageMetaData().getScalarType(), bands );
1563
1564  if ( m_tile.valid() )
1565  {
1566  // These values can be overridden by loadState...
1567  for(ossim_uint32 band = 0; band < bands; ++ band)
1568  {
1572  }
1573  m_tile->initialize(); // This does a makeBlank().
1574  }
1575  }
1576 }
1577
1579 {
1580  if( m_buffer )
1581  {
1582  delete [] m_buffer;
1583  m_buffer = 0;
1584  m_bufferSizeInPixels = 0; // Must zero out for check in getTile method.
1585  }
1586  if ( m_lineBuffer )
1587  {
1588  delete [] m_lineBuffer;
1589  m_lineBuffer = 0;
1590  }
1591
1592  if ( tile )
1593  {
1594  // Store the size of the buffer in pixels for swapping bytes.
1595  m_bufferSizeInPixels = tile->getSize();
1596  if ( m_bufferSizeInPixels )
1597  {
1598  // Initialize buffer. This is bytes, not pixels.
1599  m_buffer = new ossim_uint8[ tile->getSizeInBytes() ];
1600
1601  // Zero out the buffer rect.
1602  m_bufferRect = ossimIrect(0, 0, 0, 0);
1603  }
1604
1606  {
1607  // Big enough to hold a whole line all bands.
1608  ossim_uint32 widthInBytes =
1611
1612  m_lineBuffer = new ossim_uint8[ widthInBytes ];
1613  }
1614  }
1615 }
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
ossim_int32 validSamples() const
Returns the number of samples within "theValidImageRect".
virtual bool open()
Pure virtual open.
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
ossim_int32 bytesPerPixel() const
Bytes per pixel.
static const char * DATUM_KW
#define CLOG
Definition: ossimTrace.h:23
ossimFilename theImageFile
ossim_uint32 getBytesPerPixel() const
double getMinPix(ossim_uint32 band) const
bool addFile(const char *file)
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossim_uint32 getImageTileHeight() const
ossimInterleaveType interleaveType() const
Enumerated in InterleaveTypeLUT.
virtual bool fillBIL(const ossimIpt &origin, const ossimIpt &size)
ossim_int64 fileSize() const
float ossim_float32
virtual ossimString getEntryString(ossim_int32 entry_number) const
ossimScalarType getScalarType() const
std::vector< ossim_uint32 > m_outputBandList
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
Returns the number of samples in the image.
ossim_uint32 getNumberOfBands()
Get Bands.
std::streamoff offsetToFirstValidSample() const
Returns the offset in bytes to the first valid sample in the image.
ossimKeywordlist & downcaseKeywords()
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Override base getXXXXPixValue methods since the null/min/max can be set to something different...
static ossimMapProjectionFactory * instance()
ossim_uint32 height() const
Definition: ossimIrect.h:487
bool contains(char aChar) const
Definition: ossimString.h:58
static const char * NULL_VALUE_KW
virtual bool fillBIP(const ossimIpt &origin, const ossimIpt &size)
ossimRefPtr< ossimProjection > getGridCoordSysProjection()
Gets projection from Grid Coordinate system node.
Numeric to string methods.
bool getPath(const ossimString &path, ossimString &s) const
Gets path from doc and initializes string.
static const char * NUMBER_LINES_KW
static const char * TIE_POINT_LON_KW
Retuns the min pixel value.
OSSIM_DLL void defaultTileSize(ossimIpt &tileSize)
double getMaxPix(ossim_uint32 band) const
virtual bool isOpen() const
virtual bool isBandSelector() const
Indicates whether or not the image handler can control output band selection via the setOutputBandLis...
void toSimpleStringList(ossimString &result, const std::vector< T > &valuesList)
This will output a vector of values inst a string.
Definition: ossimCommon.h:484
const ossimIpt & ul() const
Definition: ossimIrect.h:274
ossim_int32 bytesPerRawLine() const
Returns the number of bytes in a raw line.
void change_delimiter(char del)
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const ossimErrorCode OSSIM_ERROR
ossim_uint32 toUInt32() const
static StreamFactoryRegistry * instance()
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
ossim_int32 validLines() const
Returns the number of lines within "theValidImageRect".
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
virtual bool fillBsqMultiFile(const ossimIpt &origin, const ossimIpt &size)
virtual ossim_uint32 getTileHeight() const
Returns the height of the output tile.
double getNullPix(ossim_uint32 band) const
static const char * TYPE_KW
virtual bool extendGeometry(ossimImageHandler *handler) const
virtual void initialize()
Initialize the data buffer.
ossim_uint32 getNumberOfBands() const
ossimByteOrder getImageDataByteOrder() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
Generic print method.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
bool toSimpleVector(std::vector< T > &result, const ossimString &stringOfPoints)
Definition: ossimCommon.h:537
void set_ul(const ossimIpt &pt)
Definition: ossimIrect.h:589
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
virtual bool fillBSQ(const ossimIpt &origin, const ossimIpt &size)
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
#define RTTI_DEF1_INST(cls, name, b1)
Definition: ossimRtti.h:481
const std::vector< ossimFilename > & getImageFileList() const
std::vector< std::shared_ptr< ossim::istream > > m_fileStrList
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
virtual void setNullPix(ossim_float64 null_pix)
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
virtual void getOutputBandList(std::vector< ossim_uint32 > &bandList) const
Initializes bandList.
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
virtual bool fillBuffer(const ossimIpt &origin, const ossimIpt &size)
Methods return true on succes false on error.
bool open(const ossimFilename &imageFile)
Takes image file and attempts to derive/find header file to parse for general raster data...
virtual ossim_uint32 getSizeInBytes() const
Returns the total number of bytes for all bands.
virtual ossim_uint32 getTileWidth() const
Returns the width of the output tile.
yy_size_t size
bool exists() const
std::string::size_type size() const
Definition: ossimString.h:405
virtual bool isIdentityBandList(const std::vector< ossim_uint32 > &bandList) const
Convenience method to see if band list is identity.
bool isValidRLevel(ossim_uint32 reduced_res_level) const
unsigned int ossim_uint32
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
Returns the number of lines in the image.
ossim_int32 rawLines() const
Returns the number of lines within "theRawImageRect".
Class for FGDC XML doc parsing.
static ossimDatumFactory * instance()
virtual ossimIrect getImageRectangle() const
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
bool getImageSize(ossimIpt &size) const
virtual ossimKeywordlist getHdrInfo(ossimFilename hdrFile)
ossim_float32 toFloat32() const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual void close()
static const char * NUMBER_BANDS_KW
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
ossim_uint32 width() const
Definition: ossimIrect.h:500
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
static const char * BANDS_KW
virtual ossimKeywordlist getXmlInfo(ossimFilename xmlFile)
ossimScalarType
virtual ossim_uint32 getImageTileWidth() const
ossimRefPtr< ossimImageData > m_tile
static const char * ORIGIN_LATITUDE_KW
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
void set_lrx(ossim_int32 x)
Definition: ossimIrect.h:693
return status
ossimRefPtr< ossimProjection > getProjection()
Gets projection from document.
virtual void makeBlank()
virtual void completeOpen()
Will complete the opening process.
static const char * INTERLEAVE_TYPE_KW
ossimImageMetaData theMetaData
ossimRefPtr< ossimImageHandler > theOverview
Initializes bandList to the zero based order of output bands.
virtual void setMaxPix(ossim_float64 max_pix)
This class defines an abstract Handler which all image handlers(loaders) should derive from...
void set_lry(ossim_int32 y)
Definition: ossimIrect.h:702
virtual ossim_uint32 getSize() const
Returns the total number of pixels in a tile for all bands.
ossim_int32 y
Definition: ossimIpt.h:142
long long ossim_int64
const char * c_str() const
Definition: ossimString.h:396
static const char * SCALAR_TYPE_KW
bool empty() const
Definition: ossimString.h:411
const ossimImageMetaData & getImageMetaData() const
const ossimIrect & imageRect() const
Zero based rectangle of the valid image.
ossimString ext() const
bool open(const ossimFilename &xmlFileName)
Open method.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
ossim_int32 x
Definition: ossimIpt.h:141
static const char * TIE_POINT_LAT_KW
virtual void setScalarType(ossimScalarType type)
See ossimScalarType in ossimConstants for a full list.
void allocateBuffer(const ossimImageData *tile)
Allocates m_buffer.
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual void setMinPix(ossim_float64 min_pix)
ossim_int32 numberOfBands() const
Number of bands.
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
static const char * NUMBER_SAMPLES_KW
unsigned char ossim_uint8
int toInt() const
signed long long ossim_sint64
#define min(a, b)
Definition: auxiliary.h:75
int ossim_int32
const std::string & string() const
Definition: ossimString.h:414
virtual ossim_uint32 getNumberOfInputBands() const
Returns the number of bands in the image.
